[GRASS-SVN] r68080 - grass/trunk/raster/r.neighbors
svn_grass at osgeo.org
Sat Mar 19 00:51:11 PDT 2016
Author: marisn
Date: 2016-03-19 00:51:10 -0700 (Sat, 19 Mar 2016)
New Revision: 68080
grass/trunk/raster/r.neighbors/r.neighbors.html
r.neighbors: list all methods in documentation (fixes #2965); Provide an example of use (related to #2620)
Modified: grass/trunk/raster/r.neighbors/r.neighbors.html
--- grass/trunk/raster/r.neighbors/r.neighbors.html 2016-03-18 16:46:45 UTC (rev 68079)
+++ grass/trunk/raster/r.neighbors/r.neighbors.html 2016-03-19 07:51:10 UTC (rev 68080)
@@ -129,6 +129,9 @@
<dd>The sum of values within the neighborhood.
+<dt><b>count</b>
+<dd>The count of filled (not NULL) cells.
<dt><b>variance</b>
<dd>The statistical variance of values
@@ -153,6 +156,18 @@
The result is rounded to the nearest integer (in this case 64).
+<dt><b>quart1, quart3</b>
+<dd>The result will be the first or the third quartile (equal of 25th and 75th percentiles).
+<dt><b>perc90</b>
+<dd>The result will be the 90th percentile of neighborhood.
+<dt><b>quantile</b>
+<dd>Any quantile as specified by "quantile" input parameter.
</dl>
<p><br>
@@ -363,15 +378,33 @@
otherwise float: sum.</li>
</ol>
-<!-- TODO
<h2>EXAMPLES</h2>
+<h3>Measure occupancy of neighborhood</h3>
+Set up 10x10 computational region to aid visual inspection of results
<div class="code"><pre>
-r.neighbors
+g.region rows=10 cols=10
</pre></div>
+Fill 50% of computational region with randomly located cells.
+"distance=0" will allow to fill adjacent cells.
+<div class="code"><pre>
+r.random.cells output=random_cells distance=0 ncells=50
+</pre></div>
+Count non-empty (not NULL) cells in 3x3 neighborhood
+r.neighbors input=random_cells output=counts method=count
+</pre></div>
+Optionally - exclude centre cell from the count (= only look around)
+r.mapcalc "cound_around = if( isnull(random_cells), counts, counts - 1)"
+</pre></div>
<h2>SEE ALSO</h2>
<em><a href="g.region.html">g.region</a></em><br>
