[GRASS-SVN] r68093 - grass-addons/grass7/raster/r.forestfrag
svn_grass at osgeo.org
Mon Mar 21 06:21:00 PDT 2016
Author: pvanbosgeo
Date: 2016-03-21 06:20:59 -0700 (Mon, 21 Mar 2016)
New Revision: 68093
grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag addon: bugfix, closing files (os.close) before removing (os.remove)
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-03-21 10:14:09 UTC (rev 68092)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-03-21 13:20:59 UTC (rev 68093)
@@ -101,10 +101,11 @@
sys.exit(1)
# create set to store names of temporary maps to be deleted upon exit
-clean_rast = set()
+clean_rast = []
def cleanup():
- for rast in clean_rast:
+ cleanrast = list(reversed(clean_rast))
+ for rast in cleanrast:
grass.run_command("g.remove", flags="f", type="rast", name=rast, quiet=True)
@@ -119,7 +120,7 @@
def tmpname(prefix):
tmpf = prefix + str(uuid.uuid4())
tmpf = string.replace(tmpf, '-', '_')
- clean_rast.add(tmpf)
+ clean_rast.append(tmpf)
return tmpf
@@ -182,11 +183,6 @@
grass.mapcalc("$pf = float($tmpA2) / float($tmpC3)", pf=pf,
tmpA2=tmpA2, tmpC3=tmpC3,quiet=True)
- # Clean up
- grass.run_command("g.remove", quiet=True,
- flags="f", type="raster",
- name=[tmpA2, tmpC3])
# computing pff values
@@ -205,7 +201,7 @@
SWn= int((wz - 1) / 2)
# Write mapcalc expression to tmpf - rows
- tmpfile2 = tempfile.mkstemp()[1]
+ fd2, tmpfile2 = tempfile.mkstemp()
tmpl4 = tmpname('pff1_')
text_file = open(tmpfile2, "w")
text_file.write(tmpl4 + " = ")
@@ -227,12 +223,13 @@
text_file.close()
grass.run_command("r.mapcalc", file=tmpfile2, quiet=True)
+ os.close(fd2)
os.remove(tmpfile2)
# number of 'forest patches
- tmpfile3 = tempfile.mkstemp()[1]
+ fd3, tmpfile3 = tempfile.mkstemp()
tmpl5 = tmpname('pff2_')
text_file = open(tmpfile3, "w")
text_file.write(tmpl5 + " = ")
@@ -255,6 +252,7 @@
text_file.close()
grass.run_command("r.mapcalc", file=tmpfile3, quiet=True)
+ os.close(fd3)
os.remove(tmpfile3)
# create pff map
@@ -298,8 +296,8 @@
#create categories
indexfin3 = tmpname('indexfin3_')
- tmprul = tempfile.mkstemp()
- text_file = open(tmprul[1], "w")
+ fd4, tmprul = tempfile.mkstemp()
+ text_file = open(tmprul, "w")
text_file.write("0 = 0 nonforest\n")
text_file.write("1 = 1 patch\n")
text_file.write("2 = 2 transitional\n")
@@ -309,8 +307,9 @@
text_file.write("6 = 6 undetermined\n")
text_file.close()
grass.run_command("r.reclass", quiet=True, input=indexfin2, output=indexfin3,
- title="fragmentation index", rules=tmprul[1])
- os.remove(tmprul[1])
+ title="fragmentation index", rules=tmprul)
+ os.close(fd4)
+ os.remove(tmprul)
# Shrink the region
if flag_a:
@@ -327,12 +326,10 @@
quiet=True)
grass.mapcalc("$opl = $if3", opl=opl, if3=indexfin3, quiet=True)
grass.run_command("r.null", map=opl, null=0, quiet=True)
- grass.run_command("g.remove", flags="f", quiet=True, type="rast", name=[indexfin3])
- grass.run_command("g.remove", flags="f", quiet=True, type="rast", name=[indexfin2])
#create color codes
- tmpcol = tempfile.mkstemp()
- text_file = open(tmpcol[1], "w")
+ fd5, tmpcol = tempfile.mkstemp()
+ text_file = open(tmpcol, "w")
text_file.write("0 255:255:0\n")
text_file.write("1 215:48:39\n")
text_file.write("2 252:141:89\n")
@@ -341,8 +338,9 @@
text_file.write("5 26:152:80\n")
text_file.write("6 145:207:96\n")
text_file.close()
- grass.run_command("r.colors", quiet=True, map=opl, rules=tmpcol[1])
- os.remove(tmpcol[1])
+ grass.run_command("r.colors", quiet=True, map=opl, rules=tmpcol)
+ os.close(fd5)
+ os.remove(tmpcol)
# Function call
@@ -358,8 +356,8 @@
"\n\twindow=" + str(wz) + rflag + tflag + sflag + aflag
# Write metadata for main layer
- tmphist = tempfile.mkstemp()
- text_file = open(tmphist[1], "w")
+ fd6, tmphist = tempfile.mkstemp()
+ text_file = open(tmphist, "w")
text_file.write("Forest fragmentation index (6 classes) following Riiters et al. (2000)\n\
\t(1) patch\n\t(2) transitional\n\t(3) edge\n\t(4) perforated\n\t(5) interior\n\t(6) undetermined\n")
text_file.write("\ncreated using:\n")
@@ -370,12 +368,14 @@
source1="based on " + ipl,
source2="",
description="Forst fragmentation index (6 classes)",
- loadhistory=tmphist[1])
+ loadhistory=tmphist)
+ os.close(fd6)
+ os.remove(tmphist)
# Write metadata for intermediate layers
if flag_t:
# pf layer
+ fd7, tmphist = tempfile.mkstemp()
text_file.write("created using:\n")
text_file.write(desctxt + "\n")
@@ -386,11 +386,13 @@
source2="",
description="Proportion of pixels in the moving window that is forested",
+ os.close(fd7)
# pff layer
+ fd8, tmphist = tempfile.mkstemp()
text_file.write(desctxt + "\n\n")
text_file.write("Proportion of all adjacent (cardinal directions only) pixel pairs that\n")
@@ -405,8 +407,9 @@
source2="",
description="Probability neighbor of forest cell is forest",
+ os.close(fd8)
# Report fragmentation index and names of layers created
@@ -422,21 +425,16 @@
grass.run_command("g.rename", quiet=True, raster=[pff,opl + "_pff"])
grass.info("The proportion forested (pf): " + opl + "_pf\n")
grass.info("The proportion forested pixel pairs: " + opl + "_pff\n")
- else:
- grass.run_command("g.remove", flags="f", quiet=True, type="rast", name=[pf,pff])
+ clean_rast.remove(pf)
+ clean_rast.remove(pff)
# Clean up
if flag_a:
grass.run_command("g.region", region=regionoriginal, quiet=True, overwrite=True)
- grass.run_command("g.remove", flags="f", type="region", quiet=True, name=regionoriginal)
os.removedirs(tmpdir)
- os.remove(tmphist[1])
- grass.run_command("g.remove", flags="f", quiet=True, type="rast", name=[f1,f2,f3,f4,f5,f6, pf2])
- grass.run_command("g.remove", flags="f", quiet=True, type="rast", name=[tmpl4,tmpl5,Index])
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
