[GRASS-SVN] r68099 - grass-addons/grass7/raster/r.mess
svn_grass at osgeo.org
Mon Mar 21 12:44:09 PDT 2016
Author: pvanbosgeo
Date: 2016-03-21 12:44:09 -0700 (Mon, 21 Mar 2016)
New Revision: 68099
grass-addons/grass7/raster/r.mess/r.mess.py
r.mess addon: bugfixes
Modified: grass-addons/grass7/raster/r.mess/r.mess.py
--- grass-addons/grass7/raster/r.mess/r.mess.py 2016-03-21 19:44:04 UTC (rev 68098)
+++ grass-addons/grass7/raster/r.mess/r.mess.py 2016-03-21 19:44:09 UTC (rev 68099)
@@ -162,8 +162,8 @@
clean_rast = set()
def cleanup():
for rast in clean_rast:
- grass.run_command("g.remove",
- type="rast", name = rast, quiet = True)
+ grass.run_command("g.remove", type=["rast", "region"], name = rast,
+ quiet = True, flags="f")
def CheckLayer(envlay):
for chl in xrange(len(envlay)):
@@ -217,7 +217,8 @@
ipl2 = ipl2.split(',')
CheckLayer(ipl2)
if len(ipl2) != len(ipl) and len(ipl2) != 0:
- grass.fatal('number of old and new environmental variables is not the same')
+ msg = 'number of old and new environmental variables is not the same'
+ grass.fatal(msg)
# output layers
opl = options['output']
@@ -238,8 +239,8 @@
digits2 = pow(10, digits)
# Color table
- tmpcol = tempfile.mkstemp()
- text_file = open(tmpcol[1], "w")
+ fd1, tmpcol = tempfile.mkstemp()
+ text_file = open(tmpcol, "w")
text_file.write("0% 244:109:67\n")
text_file.write("0 255:255:210\n")
text_file.write("100% 50:136:189\n")
@@ -330,8 +331,8 @@
a2 = np.hstack([np.array(sstval.T[0])[0,:] -1, (e2)])
b1 = np.hstack([(0), c])
- tmprule = tempfile.mkstemp(suffix=ipn[i])
- text_file = open(tmprule[1], "w")
+ fd2, tmprule = tempfile.mkstemp(suffix=ipn[i])
+ text_file = open(tmprule, "w")
for k in np.arange(0,len(b1.T)):
rtmp = str(int(a1[k])) + ":" + str(int(a2[k])) + ":" + str(b1[k])
text_file.write(rtmp + "\n")
@@ -339,24 +340,22 @@
# Create the recode layer and calculate the IES
tmpf3 = tmpname('rmess_tmp3')
- grass.run_command("r.recode", input=tmpf2, output=tmpf3, rules=tmprule[1])
+ grass.run_command("r.recode", input=tmpf2, output=tmpf3, rules=tmprule)
z1 = ipi[i] + " = if(" + tmpf3 + "==0, (float(" + tmpf2 + ")-" + str(float(envmin)) + ")/(" + str(float(envmax)) + "-" + str(float(envmin)) + ") * 100"
z2 = ", if(" + tmpf3 + "<=50, 2*float(" + tmpf3 + ")"
z3 = ", if(" + tmpf3 + "<100, 2*(100-float(" + tmpf3 + "))"
z4 = ", (" + str(float(envmax)) + "- float(" + tmpf2 + "))/(" + str(float(envmax)) + "-" + str(float(envmin)) + ") * 100.0)))"
calcc = z1 + z2 + z3 + z4
grass.mapcalc(calcc, quiet=True)
- grass.run_command("r.colors", quiet=True, map=ipi[i], rules=tmpcol[1])
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", pattern=[tmpf1,tmpf2,tmpf3])
- os.remove(tmprule[1])
+ grass.run_command("r.colors", quiet=True, map=ipi[i], rules=tmpcol)
+ os.close(fd2)
+ os.remove(tmprule)
grass.run_command("g.region", quiet=True, region=regionbackup)
if citiam['fullname'] != '':
grass.mapcalc("MASK1 = 1 * MASK", overwrite=True)
grass.run_command("r.mask", quiet=True, flags="r")
- grass.run_command("g.remove", quiet=True, flags="fb", type="raster", pattern=rname)
grass.run_command("g.rename", raster=("MASK1","MASK"))
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", pattern=tmpf0)
# Create the recode table - Reference distribution is vector
@@ -424,8 +423,8 @@
a2 = np.hstack([a0 -1, (e2) ])
- tmprule = tempfile.mkstemp(suffix=ipn[m])
+ fd3, tmprule = tempfile.mkstemp(suffix=ipn[m])
for k in np.arange(0,len(b1)):
@@ -433,7 +432,7 @@
- grass.run_command("r.recode", quiet=True, input=tmpf2, output=tmpf3, rules=tmprule[1])
+ grass.run_command("r.recode", quiet=True, input=tmpf2, output=tmpf3, rules=tmprule)
z1 = ipi[m] + " = if(" + tmpf3 + "==0, (float(" + tmpf2 + ")-" + str(float(envmin)) + ")/(" + str(float(envmax)) + "-" + str(float(envmin)) + ") * 100"
@@ -441,24 +440,24 @@
- grass.run_command("r.colors", quiet=True, map=ipi[m], rules=tmpcol[1])
+ grass.run_command("r.colors", quiet=True, map=ipi[m], rules=tmpcol)
# Clean up
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=[tmpf2,tmpf3])
+ os.close(fd3)
- # Clean up
- grass.run_command("g.remove", quiet=True, flags="f", type="vector", name=tmpf0)
# Calculate MESS statistics
# MESS
grass.run_command("r.series", quiet=True, output=opc, input=ipi, method="minimum")
- grass.run_command("r.colors", quiet=True, map=opc, rules=tmpcol[1])
+ grass.run_command("r.colors", quiet=True, map=opc, rules=tmpcol)
+ grass.message("\n")
+ grass.message("The following layers were created:")
+ grass.message("MES layer: " + opc)
# Area with negative MESS
if fln:
@@ -468,13 +467,15 @@
if flm:
mod = opc + "_MoD"
grass.run_command("r.series", quiet=True, output=mod, input=ipi, method="min_raster")
- tmpcat = tempfile.mkstemp()
- text_file = open(tmpcat[1], "w")
+ fd4, tmpcat = tempfile.mkstemp()
+ text_file = open(tmpcat, "w")
for cats in xrange(len(ipi)):
text_file.write(str(cats) + ":" + ipi[cats] + "\n")
text_file.close()
- grass.run_command("r.category", quiet=True, map=mod, rules=tmpcat[1], separator=":")
- os.remove(tmpcat[1])
+ grass.run_command("r.category", quiet=True, map=mod, rules=tmpcat, separator=":")
+ os.close(fd4)
+ os.remove(tmpcat)
+ grass.message("MoD layer: " + mod)
# sum(IES), where IES < 0
if flk:
@@ -482,6 +483,7 @@
c0 = -0.01/digits2
grass.run_command("r.series", quiet=True, input=ipi, output=mod, method="sum", range=('-inf',c0))
grass.run_command("r.colors", quiet=True, map=mod, col="ryg")
+ grass.message("Sum(IES): " + mod)
# Number of layers with negative values
if fll:
@@ -492,21 +494,14 @@
c0 = -0.0001/digits2
grass.run_command("r.series", quiet=True, input=ipi, output=mod, method="count", range=(MinMes,c0))
+ grass.message("Count(layers<0): " + mod)
# Remove IES layers
if fli:
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=ipi)
- ## Clean up
- grass.run_command("g.remove", type="region", flags="f", quiet=True, name=regionbackup)
- os.remove(tmpcol[1])
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
sys.exit(main())
