[GRASS-SVN] r68106 - in grass/branches/releasebranch_7_0: imagery/i.target locale/po
svn_grass at osgeo.org
Tue Mar 22 03:40:10 PDT 2016
Author: neteler
Date: 2016-03-22 03:40:10 -0700 (Tue, 22 Mar 2016)
New Revision: 68106
grass/branches/releasebranch_7_0/imagery/i.target/main.c
grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po
grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
i.target: Fix a message (r68090 + r68105)
Modified: grass/branches/releasebranch_7_0/imagery/i.target/main.c
--- grass/branches/releasebranch_7_0/imagery/i.target/main.c 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/imagery/i.target/main.c 2016-03-22 10:40:10 UTC (rev 68106)
@@ -65,7 +65,7 @@
c = G_define_flag();
c->key = 'c';
c->description =
- _("Set current location and mapset as target for of imagery group");
+ _("Set current location and mapset as target for imagery group");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14984,7 +14984,7 @@
msgstr "اسم الخريطة الناتجة"
#: ../imagery/i.target/main.c:68
-msgid "Set current location and mapset as target for of imagery group"
+msgid "Set current location and mapset as target for imagery group"
msgstr ""
#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15092,7 +15092,7 @@
msgstr "Název cílového mapsetu"
msgstr "Nastaví aktuální lokaci a mapset jako cíl pro obrazovou skupinu"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15052,7 +15052,7 @@
msgstr "Name des Zielmapsets."
msgstr "Setzt aktuelle Location und Mapset als Ziel für die Bildgruppe."
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14446,7 +14446,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15068,7 +15068,7 @@
msgstr "Nombre de destino del conjunto de mapas"
msgstr ""
"Asignar la localización y el conjunto de mapas activo como destino del grupo "
"de imágenes"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -13812,7 +13812,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15751,7 +15751,7 @@
msgstr "Nom du jeu de données en sortie"
msgstr ""
"Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14838,7 +14838,7 @@
msgstr "Nome del mapset di destinazione"
msgstr ""
"Imposta location e mapset correnti come destinazione del gruppo di immagini"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14925,7 +14925,7 @@
msgstr "ターゲットマップセット名"
msgstr ""
"画像グループのターゲットとして現在のロケーションとマップセットを設定する。"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14519,7 +14519,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14923,7 +14923,7 @@
msgstr "Rastra kartes nosaukums"
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14999,7 +14999,7 @@
msgstr "Nazwa docelowego mapsetu"
msgstr "Ustaw bieżącą lokację i mapset jako docelowe dla grupy obrazów"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15365,7 +15365,7 @@
msgstr "Nome do mapset de destino"
msgstr "Definir locação e mapset atuais como destino para um grupo de imagens"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2016-03-22 10:40:10 UTC (rev 68106)
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -13989,7 +13989,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15096,7 +15096,7 @@
msgstr "Имя целевого набора"
msgstr "Установить текущую область и набор как целевые для группы изображений"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2016-03-22 10:40:10 UTC (rev 68106)
msgstr "Ime izhodnega rastrskega sloja"
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15047,7 +15047,7 @@
msgstr "ชื่อของ ชุดแผนที่เป้าหมาย"
msgstr "กำหนด ตำแหน่งและชุดแผนที่ ปัจจุบัน เป็นเป้าหมายสำหรับ กลุ่มภาพ"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14865,7 +14865,7 @@
msgstr "Hedef harita takımının adı"
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -15126,7 +15126,7 @@
msgstr "Tên của bộ bản đồ đích"
msgstr "Thiết lập vị trí và bộ bản đồ hiện tại làm đích cho nhóm ảnh"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2016-03-22 10:35:40 UTC (rev 68105)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2016-03-22 10:40:10 UTC (rev 68106)
@@ -14995,7 +14995,7 @@
msgstr ""
msgstr ""
