[GRASS-SVN] r68110 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Tue Mar 22 13:20:16 PDT 2016
Author: mmetz
Date: 2016-03-22 13:20:16 -0700 (Tue, 22 Mar 2016)
New Revision: 68110
grass/trunk/vector/v.select/main.c
grass/trunk/vector/v.select/overlap.c
grass/trunk/vector/v.select/proto.h
grass/trunk/vector/v.select/select.c
grass/trunk/vector/v.select/write.c
v.select: fix reverse selection of areas
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2016-03-22 18:33:32 UTC (rev 68109)
+++ grass/trunk/vector/v.select/main.c 2016-03-22 20:20:16 UTC (rev 68110)
@@ -33,6 +33,7 @@
int itype[2], ifield[2];
int *ALines; /* List of lines: 0 do not output, 1 - write to output */
+ int *AAreas; /* List of areas: 0 do not output, 1 - write area boundaries to output */
int **cats, *ncats, *fields, nfields;
struct GModule *module;
@@ -112,6 +113,9 @@
/* Alloc space for input lines array */
ALines = (int *)G_calloc(Vect_get_num_lines(&(In[0])) + 1, sizeof(int));
+ AAreas = NULL;
+ if (flag.reverse->answer)
+ AAreas = (int *)G_calloc(Vect_get_num_areas(&(In[0])) + 1, sizeof(int));
/* Read field info */
IFi = Vect_get_field(&(In[0]), ifield[0]);
@@ -133,13 +137,13 @@
&(In[1]), itype[1], ifield[1],
flag.cat->answer ? 1 : 0, operator,
parm.relate->answer,
- ALines, nskipped);
+ ALines, AAreas, nskipped);
#else
select_lines(&(In[0]), itype[0], ifield[0],
NULL,
#endif
#ifdef HAVE_GEOS
@@ -159,7 +163,7 @@
Vect_copy_map_dblinks(&(In[0]), &Out, TRUE);
- write_lines(&(In[0]), IFi, ALines,
+ write_lines(&(In[0]), IFi, ALines, AAreas,
&Out, flag.table->answer ? 1 : 0, flag.reverse->answer ? 1 : 0,
nfields, fields, ncats, cats);
Modified: grass/trunk/vector/v.select/overlap.c
--- grass/trunk/vector/v.select/overlap.c 2016-03-22 18:33:32 UTC (rev 68109)
+++ grass/trunk/vector/v.select/overlap.c 2016-03-22 20:20:16 UTC (rev 68110)
@@ -6,7 +6,7 @@
#include "proto.h"
/* Add all elements of area A to the list */
-void add_aarea(struct Map_info *In, int aarea, int *ALines)
+void add_aarea(struct Map_info *In, int aarea, int *ALines, int *AAreas)
int i, j, aline, naisles, aisle, acentroid;
static struct ilist *BoundList = NULL;
@@ -34,6 +34,8 @@
ALines[aline] = 1;
+ if (AAreas)
+ AAreas[aarea] = 1;
/* Returns 1 if line1 from Map1 overlaps area2 from Map2,
Modified: grass/trunk/vector/v.select/proto.h
--- grass/trunk/vector/v.select/proto.h 2016-03-22 18:33:32 UTC (rev 68109)
+++ grass/trunk/vector/v.select/proto.h 2016-03-22 20:20:16 UTC (rev 68110)
@@ -38,14 +38,14 @@
/* select.c */
void select_lines(struct Map_info *, int, int,
- int, int, const char *, int *, int*);
+ int, int, const char *, int *, int*, int*);
/* overlap.c */
-void add_aarea(struct Map_info *, int, int *);
+void add_aarea(struct Map_info *, int, int *, int *);
int line_overlap_area(struct line_pnts *, struct Map_info *, int);
/* write.c */
-void write_lines(struct Map_info *, struct field_info *, int *,
+void write_lines(struct Map_info *, struct field_info *, int *, int *,
int, int *, int *, int **);
#endif /* PROTO_H */
Modified: grass/trunk/vector/v.select/select.c
--- grass/trunk/vector/v.select/select.c 2016-03-22 18:33:32 UTC (rev 68109)
+++ grass/trunk/vector/v.select/select.c 2016-03-22 20:20:16 UTC (rev 68110)
@@ -9,7 +9,7 @@
void select_lines(struct Map_info *aIn, int atype, int afield,
struct Map_info *bIn, int btype, int bfield,
int cat_flag, int operator, const char *relate,
- int *ALines, int* nskipped)
+ int *ALines, int *AAreas, int* nskipped)
int i;
int nalines, aline, ltype;
@@ -211,7 +211,7 @@
#ifdef HAVE_GEOS
if(line_relate_geos(bIn, AGeom,
bline, operator, relate)) {
- add_aarea(aIn, aarea, ALines);
+ add_aarea(aIn, aarea, ALines, AAreas);
break;
#endif
@@ -220,7 +220,7 @@
Vect_read_line(bIn, BPoints, NULL, bline);
if (line_overlap_area(BPoints, aIn, aarea)) {
continue;
@@ -310,7 +310,7 @@
if (found) {
break;
Modified: grass/trunk/vector/v.select/write.c
--- grass/trunk/vector/v.select/write.c 2016-03-22 18:33:32 UTC (rev 68109)
+++ grass/trunk/vector/v.select/write.c 2016-03-22 20:20:16 UTC (rev 68110)
@@ -2,6 +2,7 @@
#include <grass/glocale.h>
void write_lines(struct Map_info *In, struct field_info *IFi, int *ALines,
+ int *AAreas,
struct Map_info *Out, int table_flag, int reverse_flag,
int nfields, int *fields, int *ncats, int **cats)
@@ -27,11 +28,33 @@
for (aline = 1; aline <= nalines; aline++) {
G_debug(3, "aline = %d ALines[aline] = %d", aline, ALines[aline]);
G_percent(aline, nalines, 2);
- if ((!reverse_flag && !(ALines[aline])) ||
- (reverse_flag && ALines[aline]))
+ if ((!reverse_flag && !(ALines[aline])))
continue;
atype = Vect_read_line(&(In[0]), APoints, ACats, aline);
+ if ((reverse_flag && ALines[aline])) {
+ if (atype == GV_BOUNDARY && AAreas) {
+ int left, right, skipme;
+ skipme = 1;
+ Vect_get_line_areas(&(In[0]), aline, &left, &right);
+ if (left < 0)
+ left = Vect_get_isle_area(&(In[0]), abs(left));
+ if (left > 0 && !AAreas[left])
+ skipme = 0;
+ if (right < 0)
+ right = Vect_get_isle_area(&(In[0]), abs(right));
+ if (right > 0 && !AAreas[right])
+ skipme = 0;
+ if (skipme)
+ continue;
+ else
+ continue;
Vect_write_line(Out, atype, APoints, ACats);
if (!table_flag && (IFi != NULL)) {
