[GRASS-SVN] r68113 - grass-addons/grass7/raster/r.vif
svn_grass at osgeo.org
Wed Mar 23 02:01:40 PDT 2016
Author: pvanbosgeo
Date: 2016-03-23 02:01:39 -0700 (Wed, 23 Mar 2016)
New Revision: 68113
grass-addons/grass7/raster/r.vif/r.vif.py
r.vif addon: bugfix option to retain variables during stepwise selection + some other small improvements
Modified: grass-addons/grass7/raster/r.vif/r.vif.py
--- grass-addons/grass7/raster/r.vif/r.vif.py 2016-03-23 03:55:14 UTC (rev 68112)
+++ grass-addons/grass7/raster/r.vif/r.vif.py 2016-03-23 09:01:39 UTC (rev 68113)
@@ -66,9 +66,6 @@
#% guisection: Input
#%end
-# Testing
-#options = {"maps":"bio_1_Africa,bio_2_Africa,bio_3_Africa,bio_4_Africa,bio_5_Africa", "output":"bb.txt", retain":"bio_1_Africa", "maxvif":"20", "file":"aa.txt"}
## General
@@ -76,7 +73,6 @@
# import libraries
import os
import sys
-import atexit
import math
import tempfile
import numpy as np
@@ -94,14 +90,6 @@
if ffile['fullname'] == '':
grass.fatal("The layer " + envlay[chl] + " does not exist.")
-# create set to store names of temporary maps to be deleted upon exit
-clean_rast = set()
-def cleanup():
- for rast in clean_rast:
- grass.run_command("g.remove",
- type="rast", name=rast, quiet=True)
# main function
def main():
@@ -109,29 +97,24 @@
IPF = options['maps']
IPF = IPF.split(',')
CheckLayer(IPF)
- IPFn = [i.split('@')[0] for i in IPF]
- MXVIF = options['maxvif']
- if MXVIF != '':
- MXVIF = float(MXVIF)
IPR = options['retain']
if IPR != '':
IPR = IPR.split(',')
CheckLayer(IPR)
+ for k in xrange(len(IPR)):
+ if IPR[k] not in IPF:
+ IPF.extend([IPR[k]])
+ IPFn = [i.split('@')[0] for i in IPF]
IPRn = [i.split('@')[0] for i in IPR]
+ MXVIF = options['maxvif']
+ if MXVIF != '':
+ MXVIF = float(MXVIF)
OPF = options['file']
if OPF == '':
- OPF = tempfile.mkstemp()[1]
+ idf, OPF = tempfile.mkstemp()
- # Test if text file exists. If so, append _v1 to file name
- k = 0
- while os.path.isfile(OPF):
- k = k + 1
- opft = OPF.split('.')
- if len(opft) == 1:
- OPF = opft[0] + "_v" + str(k)
- else:
- OPF = opft[0] + "_v" + str(k) + "." + opft[1]
## Calculate VIF and write to standard output (& optionally to file)
@@ -162,7 +145,12 @@
else:
text_file = open(OPF, "w")
rvifmx = MXVIF + 1
+ m = 0
while MXVIF < rvifmx:
+ m += 1
+ grass.info("\n")
+ grass.info("VIF round " + str(m))
+ grass.info("----------------------------------------")
rvif = np.zeros(len(IPF))
text_file.write("variable\tvif\tsqrtvif\n")
for k in xrange(len(IPF)):
@@ -206,6 +194,7 @@
# Write to std output
grass.info("")
grass.info("selected variables are: ")
grass.info(', '.join(IPFn))
grass.info("with as maximum VIF: " + str(rvifmx))
grass.info("")
@@ -214,7 +203,6 @@
if __name__ == "__main__":
options, flags = grass.parser()
- atexit.register(cleanup)
sys.exit(main())
