[GRASS-SVN] r68119 - grass-addons/grass7/raster/r.recode.attr
svn_grass at osgeo.org
Wed Mar 23 02:12:28 PDT 2016
Author: pvanbosgeo
Date: 2016-03-23 02:12:28 -0700 (Wed, 23 Mar 2016)
New Revision: 68119
grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py
r.recode.attr addon: fix how temp txt files are removed + cleaning up code
Modified: grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py
--- grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py 2016-03-23 09:09:27 UTC (rev 68118)
+++ grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py 2016-03-23 09:12:28 UTC (rev 68119)
@@ -44,7 +44,7 @@
#% multiple: no
#%end
-#%option G_OPT_F_OUTPUT
+#%option G_OPT_F_INPUT
#% key: rules
#% label: Full path to rules file
#% required: yes
@@ -59,36 +59,16 @@
import os
import sys
import numpy as np
-from tempfile import gettempdir, gettempprefix
-from os.path import join
-from string import ascii_lowercase, digits
-from random import choice
+import tempfile
import grass.script as grass
-def cleanup():
- grass.run_command('g.remove',
- type = 'raster',
- pattern = 'tmp_map',
- flags='f',
- quiet = True)
-def CreateFileName():
- (suffix1, suffix2) = ("", "")
- for _ in xrange( 8 ):
- suffix1 += choice( ascii_lowercase )
- suffix2 += choice( digits )
- flname = join(gettempdir(), '-'.join([gettempprefix(), suffix1, suffix2 ]))
- while os.path.isfile(flname):
- flname = flname + "1"
- return flname
# main function
def main():
# check if GISBASE is set
if "GISBASE" not in os.environ:
# return an error advice
- grass.fatal(_("You must be in GRASS GIS to run this program"))
+ grass.fatal("You must be in GRASS GIS to run this program")
# input raster map and parameters
inputmap = options['input']
@@ -109,7 +89,8 @@
for x in numVar:
y = x + 1
myRecode = np.column_stack((myData[:,0], myData[:,0], myData[:,y]))
- tmpname = CreateFileName()
+ fd1, tmpname = tempfile.mkstemp()
np.savetxt(tmpname, myRecode, delimiter=":")
if len(numVar) == lengthNames:
@@ -117,6 +98,11 @@
else:
nmOutput = outNames[0] + '_' + nmsData[y]
+ cf = grass.find_file(name=nmOutput, element = 'cell',
+ mapset=grass.gisenv()['MAPSET'])
+ if cf['fullname'] != '':
+ grass.fatal("The layer " + nmOutput + " already exist in this mapset")
if flag_a:
grass.run_command('r.recode',
input = inputmap,
@@ -128,6 +114,7 @@
input = inputmap,
output = nmOutput,
rules = tmpname)
+ os.close(fd1)
os.remove(tmpname)
