[GRASS-SVN] r68131 - grass/trunk/lib/proj
svn_grass at osgeo.org
Thu Mar 24 07:12:08 PDT 2016
Author: mmetz
Date: 2016-03-24 07:12:07 -0700 (Thu, 24 Mar 2016)
New Revision: 68131
grass/trunk/lib/proj/convert.c
libproj: fix mixing of projection name and coordinate system name
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c 2016-03-24 13:34:29 UTC (rev 68130)
+++ grass/trunk/lib/proj/convert.c 2016-03-24 14:12:07 UTC (rev 68131)
@@ -141,6 +141,9 @@
return NULL;
G_free(proj4mod);
+ sysname = G_find_key_value("name", proj_info);
+ if (sysname)
+ OSRSetProjCS(hSRS, sysname);
if ((errcode = OSRExportToWkt(hSRS, &wkt)) != OGRERR_NONE) {
G_warning(_("OGR can't get WKT-style parameter string "
@@ -152,7 +155,7 @@
GPJ__get_ellipsoid_params(proj_info, &a, &es, &rf);
haveparams = GPJ__get_datum_params(proj_info, &datum, ¶ms);
- if(ellpskv != NULL)
+ if (ellpskv != NULL)
ellps = G_store(ellpskv);
else
ellps = NULL;
@@ -278,6 +281,7 @@
struct Key_Value *temp_projinfo;
char *pszProj4 = NULL, *pszRemaining;
char *pszProj = NULL;
+ const char *pszProjCS = NULL;
char *datum = NULL;
struct gpj_datum dstruct;
@@ -357,14 +361,13 @@
else
pszValue = "defined";
+ /* projection name */
if (G_strcasecmp(pszToken, "proj") == 0) {
/* The ll projection is known as longlat in PROJ.4 */
if (G_strcasecmp(pszValue, "longlat") == 0)
pszValue = "ll";
pszProj = pszValue;
- continue;
/* Ellipsoid and datum handled separately below */
@@ -383,15 +386,26 @@
G_set_key_value(pszToken, pszValue, temp_projinfo);
+ if (!pszProj)
+ G_warning(_("No projection name! Projection parameters likely to be meaningless."));
*projinfo = G_create_key_value();
- /* Derive the user name for the projection. */
+ /* Derive the user name for the coordinate system. */
- if (pszProj) {
+ pszProjCS = OSRGetAttrValue(hSRS, "PROJCS", 0);
+ if (!pszProjCS)
+ pszProjCS = OSRGetAttrValue(hSRS, "GEOGCS", 0);
+ if (pszProjCS) {
+ G_set_key_value("name", pszProjCS, *projinfo);
+ else if (pszProj) {
char path[4095];
char name[80];
+ /* use name of the projection as name for the coordinate system */
sprintf(path, "%s/etc/proj/projections", G_gisbase());
if (G_lookup_key_value_from_file(path, pszProj, name, sizeof(name)) >
@@ -399,11 +413,7 @@
G_set_key_value("name", name, *projinfo);
else
G_set_key_value("name", pszProj, *projinfo);
- G_set_key_value("proj", pszProj, *projinfo);
- else
- G_warning(_("No projection name! Projection parameters likely to be meaningless."));
