[GRASS-SVN] r68141 - in grass/trunk: . lib/init
svn_grass at osgeo.org
Fri Mar 25 01:32:44 PDT 2016
Author: martinl
Date: 2016-03-25 01:32:44 -0700 (Fri, 25 Mar 2016)
New Revision: 68141
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/lib/init/Makefile
svn revision 00000 to exported (no need for backport)
Modified: grass/trunk/configure
--- grass/trunk/configure 2016-03-25 05:50:23 UTC (rev 68140)
+++ grass/trunk/configure 2016-03-25 08:32:44 UTC (rev 68141)
@@ -1290,7 +1290,7 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
-GRASS_VERSION_SVN=00000
+GRASS_VERSION_SVN="exported"
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
@@ -1327,7 +1327,9 @@
if test "$SVN_VERSION" != "no" ; then
GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
if test "$GRASS_VERSION_SVN" = "exported" -o "$GRASS_VERSION_SVN" = "Unversioned directory" ; then
- GRASS_VERSION_SVN=00000
+ GRASS_VERSION_SVN="exported"
+ else
+ GRASS_VERSION_SVN="r$GRASS_VERSION_SVN"
fi
fi
@@ -1353,7 +1355,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1357: checking for MacOSX App" >&5
+echo "configure:1359: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1365,7 +1367,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1369: checking for MacOSX architectures" >&5
+echo "configure:1371: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1394,7 +1396,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1398: checking for MacOSX SDK" >&5
+echo "configure:1400: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1404,7 +1406,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1408: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1410: checking for $with_macosx_sdk/SDKSettings.plist" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1448,7 +1450,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1452: checking how to build libraries" >&5
+echo "configure:1454: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -2354,7 +2356,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2358: checking for additional include dirs" >&5
+echo "configure:2360: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2377,7 +2379,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2381: checking for additional library dirs" >&5
+echo "configure:2383: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2411,7 +2413,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2415: checking for a BSD compatible install" >&5
+echo "configure:2417: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2464,7 +2466,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2468: checking for $ac_word" >&5
+echo "configure:2470: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2495,13 +2497,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2499: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2501: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2505 "configure"
+#line 2507 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2512,7 +2514,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2537,7 +2539,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2541: checking for $ac_word" >&5
+echo "configure:2543: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2577,7 +2579,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2581: checking for $ac_word" >&5
+echo "configure:2583: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2608,7 +2610,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2612: checking for $ac_word" >&5
+echo "configure:2614: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2646,7 +2648,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2650: checking for $ac_word" >&5
+echo "configure:2652: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2675,7 +2677,7 @@
-echo "configure:2679: checking for $ac_word" >&5
+echo "configure:2681: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2706,7 +2708,7 @@
-echo "configure:2710: checking for $ac_word" >&5
+echo "configure:2712: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2735,7 +2737,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2739: checking for $ac_word" >&5
+echo "configure:2741: checking for $ac_word" >&5
case "$PERL" in
@@ -2766,7 +2768,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2770: checking how to run the C preprocessor" >&5
+echo "configure:2772: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2779,13 +2781,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2783 "configure"
+#line 2785 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2791: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2796,13 +2798,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2800 "configure"
+#line 2802 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2813,13 +2815,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2817 "configure"
+#line 2819 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2823: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2843,10 +2845,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2847: checking for ANSI C header files" >&5
+echo "configure:2849: checking for ANSI C header files" >&5
-#line 2850 "configure"
+#line 2852 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2854,7 +2856,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2860: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2871,7 +2873,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2875 "configure"
+#line 2877 "configure"
#include <string.h>
EOF
@@ -2889,7 +2891,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2893 "configure"
+#line 2895 "configure"
#include <stdlib.h>
EOF
@@ -2910,7 +2912,7 @@
else
-#line 2914 "configure"
+#line 2916 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2921,7 +2923,7 @@
exit (0); }
EOF
-if { (eval echo configure:2925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2948,15 +2950,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2952: checking for $ac_hdr" >&5
+echo "configure:2954: checking for $ac_hdr" >&5
-#line 2955 "configure"
+#line 2957 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2962: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2985,15 +2987,15 @@
do
-echo "configure:2989: checking for $ac_hdr" >&5
+echo "configure:2991: checking for $ac_hdr" >&5
-#line 2992 "configure"
+#line 2994 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2999: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3022,15 +3024,15 @@
do
-echo "configure:3026: checking for $ac_hdr" >&5
+echo "configure:3028: checking for $ac_hdr" >&5
-#line 3029 "configure"
+#line 3031 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3036: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3059,15 +3061,15 @@
do
-echo "configure:3063: checking for $ac_hdr" >&5
+echo "configure:3065: checking for $ac_hdr" >&5
-#line 3066 "configure"
+#line 3068 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3096,15 +3098,15 @@
do
-echo "configure:3100: checking for $ac_hdr" >&5
+echo "configure:3102: checking for $ac_hdr" >&5
-#line 3103 "configure"
+#line 3105 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3108: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3130,10 +3132,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3134: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3136: checking whether time.h and sys/time.h may both be included" >&5
-#line 3137 "configure"
+#line 3139 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3142,7 +3144,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3146: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3148: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3162,10 +3164,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3166: checking for off_t" >&5
+echo "configure:3168: checking for off_t" >&5
-#line 3169 "configure"
+#line 3171 "configure"
#if STDC_HEADERS
@@ -3192,10 +3194,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3196: checking for uid_t in sys/types.h" >&5
+echo "configure:3198: checking for uid_t in sys/types.h" >&5
-#line 3199 "configure"
+#line 3201 "configure"
EOF
@@ -3223,10 +3225,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3227: checking return type of signal handlers" >&5
+echo "configure:3229: checking return type of signal handlers" >&5
-#line 3230 "configure"
+#line 3232 "configure"
#include <signal.h>
@@ -3243,7 +3245,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3247: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3249: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3261,10 +3263,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3265: checking for Cygwin environment" >&5
+echo "configure:3267: checking for Cygwin environment" >&5
-#line 3268 "configure"
+#line 3270 "configure"
int main() {
@@ -3275,7 +3277,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3279: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3281: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3293,10 +3295,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3297: checking for $ac_func" >&5
+echo "configure:3299: checking for $ac_func" >&5
-#line 3300 "configure"
+#line 3302 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3319,7 +3321,7 @@
; return 0; }
EOF
-if { (eval echo configure:3323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3345,10 +3347,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3349: checking for $ac_func" >&5
+echo "configure:3351: checking for $ac_func" >&5
-#line 3352 "configure"
+#line 3354 "configure"
@@ -3371,7 +3373,7 @@
; return 0; }
EOF
-if { (eval echo configure:3375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3397,10 +3399,10 @@
for ac_func in drand48
do
-echo "configure:3401: checking for $ac_func" >&5
+echo "configure:3403: checking for $ac_func" >&5
-#line 3404 "configure"
+#line 3406 "configure"
@@ -3423,7 +3425,7 @@
; return 0; }
EOF
-if { (eval echo configure:3427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3449,10 +3451,10 @@
for ac_func in putenv setenv
do
-echo "configure:3453: checking for $ac_func" >&5
+echo "configure:3455: checking for $ac_func" >&5
-#line 3456 "configure"
+#line 3458 "configure"
@@ -3475,7 +3477,7 @@
; return 0; }
EOF
-if { (eval echo configure:3479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3501,10 +3503,10 @@
for ac_func in nanosleep
do
-echo "configure:3505: checking for $ac_func" >&5
+echo "configure:3507: checking for $ac_func" >&5
-#line 3508 "configure"
+#line 3510 "configure"
@@ -3527,7 +3529,7 @@
; return 0; }
EOF
-if { (eval echo configure:3531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3552,13 +3554,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3556: checking whether setpgrp takes no argument" >&5
+echo "configure:3558: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3562 "configure"
+#line 3564 "configure"
#ifdef HAVE_UNISTD_H
@@ -3578,7 +3580,7 @@
EOF
-if { (eval echo configure:3582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3606,16 +3608,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3610: checking for long long int" >&5
+echo "configure:3612: checking for long long int" >&5
-#line 3612 "configure"
+#line 3614 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3619: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3621: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3635,7 +3637,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3639: checking for W11" >&5
+echo "configure:3641: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3663,7 +3665,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3667: checking for X" >&5
+echo "configure:3669: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3723,12 +3725,12 @@
# First, try using that file with no special directory specified.
-#line 3727 "configure"
+#line 3729 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3797,14 +3799,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3801 "configure"
+#line 3803 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3909,17 +3911,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3913: checking whether -R must be followed by a space" >&5
+echo "configure:3915: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3916 "configure"
+#line 3918 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3935,14 +3937,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3939 "configure"
+#line 3941 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3974,13 +3976,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3978: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3980: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3984 "configure"
+#line 3986 "configure"
@@ -3991,7 +3993,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4012,13 +4014,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4016: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4018: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4022 "configure"
+#line 4024 "configure"
@@ -4029,7 +4031,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4057,10 +4059,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4061: checking for gethostbyname" >&5
+echo "configure:4063: checking for gethostbyname" >&5
-#line 4064 "configure"
+#line 4066 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4083,7 +4085,7 @@
; return 0; }
EOF
-if { (eval echo configure:4087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4103,13 +4105,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4107: checking for gethostbyname in -lnsl" >&5
+echo "configure:4109: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4113 "configure"
+#line 4115 "configure"
@@ -4120,7 +4122,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4149,10 +4151,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4153: checking for connect" >&5
+echo "configure:4155: checking for connect" >&5
-#line 4156 "configure"
+#line 4158 "configure"
which can conflict with char connect(); below. */
@@ -4175,7 +4177,7 @@
; return 0; }
EOF
-if { (eval echo configure:4179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4195,13 +4197,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4199: checking for connect in -lsocket" >&5
+echo "configure:4201: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4205 "configure"
+#line 4207 "configure"
@@ -4212,7 +4214,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4235,10 +4237,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4239: checking for remove" >&5
+echo "configure:4241: checking for remove" >&5
-#line 4242 "configure"
+#line 4244 "configure"
which can conflict with char remove(); below. */
@@ -4261,7 +4263,7 @@
; return 0; }
EOF
-if { (eval echo configure:4265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4281,13 +4283,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4285: checking for remove in -lposix" >&5
+echo "configure:4287: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4291 "configure"
+#line 4293 "configure"
@@ -4298,7 +4300,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4321,10 +4323,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4325: checking for shmat" >&5
+echo "configure:4327: checking for shmat" >&5
-#line 4328 "configure"
+#line 4330 "configure"
which can conflict with char shmat(); below. */
@@ -4347,7 +4349,7 @@
; return 0; }
EOF
-if { (eval echo configure:4351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4367,13 +4369,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4371: checking for shmat in -lipc" >&5
+echo "configure:4373: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4377 "configure"
+#line 4379 "configure"
@@ -4384,7 +4386,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4416,13 +4418,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4420: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4422: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4426 "configure"
+#line 4428 "configure"
@@ -4433,7 +4435,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4473,12 +4475,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4477: checking for library containing cuserid" >&5
+echo "configure:4479: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4482 "configure"
+#line 4484 "configure"
@@ -4489,7 +4491,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4500,7 +4502,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4504 "configure"
+#line 4506 "configure"
@@ -4511,7 +4513,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4537,10 +4539,10 @@
for ac_func in asprintf
do
-echo "configure:4541: checking for $ac_func" >&5
+echo "configure:4543: checking for $ac_func" >&5
-#line 4544 "configure"
+#line 4546 "configure"
@@ -4563,7 +4565,7 @@
; return 0; }
EOF
-if { (eval echo configure:4567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4590,10 +4592,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4594: checking for atan" >&5
+echo "configure:4596: checking for atan" >&5
-#line 4597 "configure"
+#line 4599 "configure"
which can conflict with char atan(); below. */
@@ -4616,7 +4618,7 @@
; return 0; }
EOF
-if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4634,13 +4636,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4638: checking for atan in -lm" >&5
+echo "configure:4640: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4644 "configure"
+#line 4646 "configure"
@@ -4651,7 +4653,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4657: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4678,10 +4680,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4682: checking for dlsym" >&5
+echo "configure:4684: checking for dlsym" >&5
-#line 4685 "configure"
+#line 4687 "configure"
which can conflict with char dlsym(); below. */
@@ -4704,7 +4706,7 @@
; return 0; }
EOF
-if { (eval echo configure:4708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4722,13 +4724,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4726: checking for dlsym in -ldl" >&5
+echo "configure:4728: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4732 "configure"
+#line 4734 "configure"
@@ -4739,7 +4741,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4766,10 +4768,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4770: checking for iconv" >&5
+echo "configure:4772: checking for iconv" >&5
-#line 4773 "configure"
+#line 4775 "configure"
which can conflict with char iconv(); below. */
@@ -4792,7 +4794,7 @@
; return 0; }
EOF
-if { (eval echo configure:4796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4810,13 +4812,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4814: checking for iconv in -liconv" >&5
+echo "configure:4816: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4820 "configure"
+#line 4822 "configure"
@@ -4827,7 +4829,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4846,13 +4848,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4850: checking for iconv in -lgiconv" >&5
+echo "configure:4852: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4856 "configure"
+#line 4858 "configure"
@@ -4863,7 +4865,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4882,10 +4884,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4886: checking for libiconv" >&5
+echo "configure:4888: checking for libiconv" >&5
-#line 4889 "configure"
+#line 4891 "configure"
which can conflict with char libiconv(); below. */
@@ -4908,7 +4910,7 @@
; return 0; }
EOF
-if { (eval echo configure:4912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4926,13 +4928,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4930: checking for libiconv in -liconv" >&5
+echo "configure:4932: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4936 "configure"
+#line 4938 "configure"
@@ -4943,7 +4945,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4962,13 +4964,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4966: checking for libiconv in -lgiconv" >&5
+echo "configure:4968: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4972 "configure"
+#line 4974 "configure"
@@ -4979,7 +4981,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5016,10 +5018,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5020: checking for socket" >&5
+echo "configure:5022: checking for socket" >&5
-#line 5023 "configure"
+#line 5025 "configure"
which can conflict with char socket(); below. */
@@ -5042,7 +5044,7 @@
; return 0; }
EOF
-if { (eval echo configure:5046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5060,13 +5062,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5064: checking for socket in -lsocket" >&5
+echo "configure:5066: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5070 "configure"
+#line 5072 "configure"
@@ -5077,7 +5079,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5125,7 +5127,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5129: checking for location of zlib includes" >&5
+echo "configure:5131: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5151,15 +5153,15 @@
do
-echo "configure:5155: checking for $ac_hdr" >&5
+echo "configure:5157: checking for $ac_hdr" >&5
-#line 5158 "configure"
+#line 5160 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5193,7 +5195,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5197: checking for location of zlib library" >&5
+echo "configure:5199: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5218,13 +5220,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5222: checking for deflate in -lz" >&5
+echo "configure:5224: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5228 "configure"
+#line 5230 "configure"
@@ -5235,7 +5237,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5277,7 +5279,7 @@
echo $ac_n "checking whether to use bzlib""... $ac_c" 1>&6
-echo "configure:5281: checking whether to use bzlib" >&5
+echo "configure:5283: checking whether to use bzlib" >&5
echo "$ac_t"""$with_bzlib"" 1>&6
case "$with_bzlib" in
"no") USE_BZIP2= ;;
@@ -5297,7 +5299,7 @@
echo $ac_n "checking for location of bzlib includes""... $ac_c" 1>&6
-echo "configure:5301: checking for location of bzlib includes" >&5
+echo "configure:5303: checking for location of bzlib includes" >&5
case "$with_bzlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-bzlib-includes." 1>&2; exit 1; }
@@ -5323,15 +5325,15 @@
do
-echo "configure:5327: checking for $ac_hdr" >&5
+echo "configure:5329: checking for $ac_hdr" >&5
-#line 5330 "configure"
+#line 5332 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5337: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5365,7 +5367,7 @@
echo $ac_n "checking for location of bzlib library""... $ac_c" 1>&6
-echo "configure:5369: checking for location of bzlib library" >&5
+echo "configure:5371: checking for location of bzlib library" >&5
case "$with_bzlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-bzlib-libs." 1>&2; exit 1; }
@@ -5390,13 +5392,13 @@
echo $ac_n "checking for BZ2_bzBuffToBuffCompress in -lbz2""... $ac_c" 1>&6
-echo "configure:5394: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
+echo "configure:5396: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
ac_lib_var=`echo bz2'_'BZ2_bzBuffToBuffCompress | sed 'y%./+-%__p_%'`
LIBS="-lbz2 $LIBS"
-#line 5400 "configure"
+#line 5402 "configure"
@@ -5407,7 +5409,7 @@
BZ2_bzBuffToBuffCompress()
; return 0; }
EOF
-if { (eval echo configure:5411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5457,7 +5459,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5461: checking for location of External PROJ.4 includes" >&5
+echo "configure:5463: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5483,15 +5485,15 @@
do
-echo "configure:5487: checking for $ac_hdr" >&5
+echo "configure:5489: checking for $ac_hdr" >&5
-#line 5490 "configure"
+#line 5492 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5528,7 +5530,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5532: checking External PROJ.4 version" >&5
+echo "configure:5534: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5536,7 +5538,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5540 "configure"
+#line 5542 "configure"
#include <stdio.h>
@@ -5548,7 +5550,7 @@
EOF
-if { (eval echo configure:5552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5573,7 +5575,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5577: checking for location of External PROJ.4 library" >&5
+echo "configure:5579: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5598,13 +5600,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5602: checking for pj_get_def in -lproj" >&5
+echo "configure:5604: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5608 "configure"
+#line 5610 "configure"
@@ -5615,7 +5617,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5649,7 +5651,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5653: checking for location of External PROJ.4 data files" >&5
+echo "configure:5655: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5673,14 +5675,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5677: checking for epsg" >&5
+echo "configure:5679: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5684: checking for $PROJSHARE/epsg" >&5
+echo "configure:5686: checking for $PROJSHARE/epsg" >&5
@@ -5712,7 +5714,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5716: checking for $ac_word" >&5
+echo "configure:5718: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5752,7 +5754,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5756: checking whether to use regex" >&5
+echo "configure:5758: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5772,7 +5774,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5776: checking for location of regex includes" >&5
+echo "configure:5778: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5798,15 +5800,15 @@
do
-echo "configure:5802: checking for $ac_hdr" >&5
+echo "configure:5804: checking for $ac_hdr" >&5
-#line 5805 "configure"
+#line 5807 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5812: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5840,7 +5842,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5844: checking for location of regex library" >&5
+echo "configure:5846: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5865,10 +5867,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5869: checking for regcomp" >&5
+echo "configure:5871: checking for regcomp" >&5
-#line 5872 "configure"
+#line 5874 "configure"
which can conflict with char regcomp(); below. */
@@ -5891,7 +5893,7 @@
; return 0; }
EOF
-if { (eval echo configure:5895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5918,13 +5920,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5922: checking for regcomp in -lregex" >&5
+echo "configure:5924: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5928 "configure"
+#line 5930 "configure"
@@ -5935,7 +5937,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5985,7 +5987,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5989: checking whether to use Readline" >&5
+echo "configure:5991: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -6006,7 +6008,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6010: checking for location of Readline includes" >&5
+echo "configure:6012: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6032,15 +6034,15 @@
do
-echo "configure:6036: checking for $ac_hdr" >&5
+echo "configure:6038: checking for $ac_hdr" >&5
-#line 6039 "configure"
+#line 6041 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6076,15 +6078,15 @@
do
-echo "configure:6080: checking for $ac_hdr" >&5
+echo "configure:6082: checking for $ac_hdr" >&5
-#line 6083 "configure"
+#line 6085 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6090: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6118,7 +6120,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6122: checking for location of Readline library" >&5
+echo "configure:6124: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6143,13 +6145,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6147: checking for readline in -lreadline" >&5
+echo "configure:6149: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6153 "configure"
+#line 6155 "configure"
@@ -6160,7 +6162,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6195,13 +6197,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6199: checking for add_history in -lhistory" >&5
+echo "configure:6201: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6205 "configure"
+#line 6207 "configure"
@@ -6212,7 +6214,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6254,7 +6256,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6258: checking whether to use GDAL" >&5
+echo "configure:6260: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6272,7 +6274,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6276: checking for $ac_word" >&5
+echo "configure:6278: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6327,14 +6329,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6331 "configure"
+#line 6333 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6343,14 +6345,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6347 "configure"
+#line 6349 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6382,7 +6384,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6386: checking whether to use libLAS" >&5
+echo "configure:6388: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6399,7 +6401,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6403: checking for $ac_word" >&5
+echo "configure:6405: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6449,14 +6451,14 @@
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
-#line 6453 "configure"
+#line 6455 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6464,14 +6466,14 @@
rm -rf conftest*
-#line 6468 "configure"
+#line 6470 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6504,7 +6506,7 @@
# PDAL option
echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
-echo "configure:6508: checking whether to use PDAL" >&5
+echo "configure:6510: checking whether to use PDAL" >&5
# new and currently used way to switch language to C++
# AC_LANG_PUSH(C++)
@@ -6532,7 +6534,7 @@
# Extract the first word of "pdal-config", so it can be a program name with args.
set dummy pdal-config; ac_word=$2
-echo "configure:6536: checking for $ac_word" >&5
+echo "configure:6538: checking for $ac_word" >&5
case "$PDAL_CONFIG" in
@@ -6582,14 +6584,14 @@
CFLAGS="$CFLAGS $PDAL_CFLAGS"
CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
-#line 6586 "configure"
+#line 6588 "configure"
#include <pdal/PointTable.hpp>
int main() {
pdal::PointTable table;
; return 0; }
EOF
-if { (eval echo configure:6593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6597,14 +6599,14 @@
rm -rf conftest*
-#line 6601 "configure"
+#line 6603 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
PDAL_LIBS="$PDAL_LIBS"
else
@@ -6654,7 +6656,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6658: checking whether to use NetCDF" >&5
+echo "configure:6660: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6671,7 +6673,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6675: checking for $ac_word" >&5
+echo "configure:6677: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6718,14 +6720,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6722 "configure"
+#line 6724 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6733,14 +6735,14 @@
rm -rf conftest*
-#line 6737 "configure"
+#line 6739 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6771,7 +6773,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6775: checking whether to use GEOS" >&5
+echo "configure:6777: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6789,7 +6791,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6793: checking for $ac_word" >&5
+echo "configure:6795: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6837,15 +6839,15 @@
do
-echo "configure:6841: checking for $ac_hdr" >&5
+echo "configure:6843: checking for $ac_hdr" >&5
-#line 6844 "configure"
+#line 6846 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6884,13 +6886,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6888: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6890: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6894 "configure"
+#line 6896 "configure"
@@ -6901,7 +6903,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6945,7 +6947,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6949: checking whether to use TIFF" >&5
+echo "configure:6951: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6965,7 +6967,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6969: checking for location of TIFF includes" >&5
+echo "configure:6971: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6991,15 +6993,15 @@
do
-echo "configure:6995: checking for $ac_hdr" >&5
+echo "configure:6997: checking for $ac_hdr" >&5
-#line 6998 "configure"
+#line 7000 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7003: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7033,7 +7035,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7037: checking for location of TIFF library" >&5
+echo "configure:7039: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7064,13 +7066,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7068: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7070: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7074 "configure"
+#line 7076 "configure"
@@ -7081,7 +7083,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7100,13 +7102,13 @@
-echo "configure:7104: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7106: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7110 "configure"
+#line 7112 "configure"
@@ -7117,7 +7119,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7136,13 +7138,13 @@
-echo "configure:7140: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7142: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7146 "configure"
+#line 7148 "configure"
@@ -7153,7 +7155,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7172,13 +7174,13 @@
-echo "configure:7176: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7178: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7182 "configure"
+#line 7184 "configure"
@@ -7189,7 +7191,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7208,13 +7210,13 @@
-echo "configure:7212: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7214: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 7218 "configure"
+#line 7220 "configure"
@@ -7225,7 +7227,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7244,13 +7246,13 @@
-echo "configure:7248: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7250: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7254 "configure"
+#line 7256 "configure"
@@ -7261,7 +7263,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7280,13 +7282,13 @@
-echo "configure:7284: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7286: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7290 "configure"
+#line 7292 "configure"
@@ -7297,7 +7299,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7316,13 +7318,13 @@
-echo "configure:7320: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7322: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7326 "configure"
+#line 7328 "configure"
@@ -7333,7 +7335,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7431,7 +7433,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7435: checking whether to use PNG" >&5
+echo "configure:7437: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7450,7 +7452,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7454: checking for location of PNG includes" >&5
+echo "configure:7456: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7476,15 +7478,15 @@
do
-echo "configure:7480: checking for $ac_hdr" >&5
+echo "configure:7482: checking for $ac_hdr" >&5
-#line 7483 "configure"
+#line 7485 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7518,7 +7520,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7522: checking for location of PNG library" >&5
+echo "configure:7524: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7543,13 +7545,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7547: checking for png_read_image in -lpng" >&5
+echo "configure:7549: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7553 "configure"
+#line 7555 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7560,7 +7562,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7602,7 +7604,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7606: checking whether to use PostgreSQL" >&5
+echo "configure:7608: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7629,7 +7631,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7633: checking for location of PostgreSQL includes" >&5
+echo "configure:7635: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7655,15 +7657,15 @@
do
-echo "configure:7659: checking for $ac_hdr" >&5
+echo "configure:7661: checking for $ac_hdr" >&5
-#line 7662 "configure"
+#line 7664 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7701,7 +7703,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7705: checking for location of PostgreSQL library" >&5
+echo "configure:7707: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7730,13 +7732,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7734: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7736: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7740 "configure"
+#line 7742 "configure"
@@ -7747,7 +7749,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7766,13 +7768,13 @@
-echo "configure:7770: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7772: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7776 "configure"
+#line 7778 "configure"
@@ -7783,7 +7785,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7802,13 +7804,13 @@
-echo "configure:7806: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7808: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7812 "configure"
+#line 7814 "configure"
@@ -7819,7 +7821,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7838,13 +7840,13 @@
-echo "configure:7842: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7844: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7848 "configure"
+#line 7850 "configure"
@@ -7855,7 +7857,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7912,13 +7914,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7916: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7918: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7922 "configure"
+#line 7924 "configure"
@@ -7929,7 +7931,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7951,13 +7953,13 @@
-echo "configure:7955: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7957: checking for PQcmdTuples in -lpq" >&5
-#line 7961 "configure"
+#line 7963 "configure"
@@ -7968,7 +7970,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8011,7 +8013,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8015: checking whether to use MySQL" >&5
+echo "configure:8017: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -8031,7 +8033,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8035: checking for location of MySQL includes" >&5
+echo "configure:8037: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8057,15 +8059,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8061: checking for $ac_hdr" >&5
+echo "configure:8063: checking for $ac_hdr" >&5
-#line 8064 "configure"
+#line 8066 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8102,7 +8104,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8106: checking for location of MySQL library" >&5
+echo "configure:8108: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8133,13 +8135,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8137: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8139: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 8143 "configure"
+#line 8145 "configure"
@@ -8150,7 +8152,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8169,13 +8171,13 @@
-echo "configure:8173: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8175: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8179 "configure"
+#line 8181 "configure"
@@ -8186,7 +8188,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8205,13 +8207,13 @@
-echo "configure:8209: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8211: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8215 "configure"
+#line 8217 "configure"
@@ -8222,7 +8224,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8241,13 +8243,13 @@
-echo "configure:8245: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8247: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8251 "configure"
+#line 8253 "configure"
@@ -8258,7 +8260,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8277,13 +8279,13 @@
-echo "configure:8281: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8283: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8287 "configure"
+#line 8289 "configure"
@@ -8294,7 +8296,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8313,13 +8315,13 @@
-echo "configure:8317: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8319: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8323 "configure"
+#line 8325 "configure"
@@ -8330,7 +8332,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8349,13 +8351,13 @@
-echo "configure:8353: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8355: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8359 "configure"
+#line 8361 "configure"
@@ -8366,7 +8368,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8385,13 +8387,13 @@
-echo "configure:8389: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8391: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8395 "configure"
+#line 8397 "configure"
@@ -8402,7 +8404,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8492,7 +8494,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8496: checking for $ac_word" >&5
+echo "configure:8498: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8541,10 +8543,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8545: checking for mysql_server_init" >&5
+echo "configure:8547: checking for mysql_server_init" >&5
-#line 8548 "configure"
+#line 8550 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -8570,7 +8572,7 @@
; return 0; }
EOF
-if { (eval echo configure:8574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8622,7 +8624,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8626: checking whether to use SQLite" >&5
+echo "configure:8628: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8642,7 +8644,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8646: checking for location of SQLite includes" >&5
+echo "configure:8648: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8668,15 +8670,15 @@
do
-echo "configure:8672: checking for $ac_hdr" >&5
+echo "configure:8674: checking for $ac_hdr" >&5
-#line 8675 "configure"
+#line 8677 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8719,7 +8721,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8723: checking for location of SQLite library" >&5
+echo "configure:8725: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8748,13 +8750,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8752: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8754: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8758 "configure"
+#line 8760 "configure"
@@ -8765,7 +8767,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8784,13 +8786,13 @@
-echo "configure:8788: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8790: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8794 "configure"
+#line 8796 "configure"
@@ -8801,7 +8803,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8820,13 +8822,13 @@
-echo "configure:8824: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8826: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8830 "configure"
+#line 8832 "configure"
@@ -8837,7 +8839,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8856,13 +8858,13 @@
-echo "configure:8860: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8862: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8866 "configure"
+#line 8868 "configure"
@@ -8873,7 +8875,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8948,7 +8950,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:8952: checking whether to use OpenGL" >&5
+echo "configure:8954: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -8982,7 +8984,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:8986: checking for location of OpenGL includes" >&5
+echo "configure:8988: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9008,15 +9010,15 @@
do
-echo "configure:9012: checking for $ac_hdr" >&5
+echo "configure:9014: checking for $ac_hdr" >&5
-#line 9015 "configure"
+#line 9017 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9022: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9050,7 +9052,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9054: checking for location of OpenGL library" >&5
+echo "configure:9056: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9079,13 +9081,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9083: checking for glBegin in -lGL" >&5
+echo "configure:9085: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9089 "configure"
+#line 9091 "configure"
@@ -9096,7 +9098,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9115,13 +9117,13 @@
-echo "configure:9119: checking for glBegin in -lGL" >&5
+echo "configure:9121: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9125 "configure"
+#line 9127 "configure"
@@ -9132,7 +9134,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9151,13 +9153,13 @@
-echo "configure:9155: checking for glBegin in -lGL" >&5
+echo "configure:9157: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9161 "configure"
+#line 9163 "configure"
@@ -9168,7 +9170,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9187,13 +9189,13 @@
-echo "configure:9191: checking for glBegin in -lGL" >&5
+echo "configure:9193: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9197 "configure"
+#line 9199 "configure"
@@ -9204,7 +9206,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9266,13 +9268,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9270: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9272: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9276 "configure"
+#line 9278 "configure"
@@ -9283,7 +9285,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9302,13 +9304,13 @@
-echo "configure:9306: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9308: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9312 "configure"
+#line 9314 "configure"
@@ -9319,7 +9321,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9366,10 +9368,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9370: checking for glXCreatePbuffer" >&5
+echo "configure:9372: checking for glXCreatePbuffer" >&5
-#line 9373 "configure"
+#line 9375 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9392,7 +9394,7 @@
; return 0; }
EOF
-if { (eval echo configure:9396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9429,10 +9431,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9433: checking for glXCreateGLXPixmap" >&5
+echo "configure:9435: checking for glXCreateGLXPixmap" >&5
-#line 9436 "configure"
+#line 9438 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9455,7 +9457,7 @@
; return 0; }
EOF
-if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9498,7 +9500,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9502: checking for location of OpenGL framework" >&5
+echo "configure:9504: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9522,15 +9524,15 @@
do
-echo "configure:9526: checking for $ac_hdr" >&5
+echo "configure:9528: checking for $ac_hdr" >&5
-#line 9529 "configure"
+#line 9531 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9566,10 +9568,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9570: checking for glBegin" >&5
+echo "configure:9572: checking for glBegin" >&5
-#line 9573 "configure"
+#line 9575 "configure"
which can conflict with char glBegin(); below. */
@@ -9592,7 +9594,7 @@
; return 0; }
EOF
-if { (eval echo configure:9596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9629,10 +9631,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9633: checking for gluBeginCurve" >&5
+echo "configure:9635: checking for gluBeginCurve" >&5
-#line 9636 "configure"
+#line 9638 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9655,7 +9657,7 @@
; return 0; }
EOF
-if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9703,7 +9705,7 @@
-echo "configure:9707: checking for location of OpenGL includes" >&5
+echo "configure:9709: checking for location of OpenGL includes" >&5
@@ -9729,15 +9731,15 @@
do
-echo "configure:9733: checking for $ac_hdr" >&5
+echo "configure:9735: checking for $ac_hdr" >&5
-#line 9736 "configure"
+#line 9738 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9771,7 +9773,7 @@
-echo "configure:9775: checking for location of OpenGL library" >&5
+echo "configure:9777: checking for location of OpenGL library" >&5
@@ -9796,18 +9798,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9800: checking for OpenGL library" >&5
+echo "configure:9802: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9804 "configure"
+#line 9806 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9831,18 +9833,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9835: checking for GLU library" >&5
+echo "configure:9837: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9839 "configure"
+#line 9841 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -9891,7 +9893,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9895: checking whether to use ODBC" >&5
+echo "configure:9897: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -9910,7 +9912,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9914: checking for location of ODBC includes" >&5
+echo "configure:9916: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9936,15 +9938,15 @@
do
-echo "configure:9940: checking for $ac_hdr" >&5
+echo "configure:9942: checking for $ac_hdr" >&5
-#line 9943 "configure"
+#line 9945 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9950: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9978,7 +9980,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:9982: checking for location of ODBC library" >&5
+echo "configure:9984: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10003,13 +10005,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10007: checking for SQLConnect in -lodbc" >&5
+echo "configure:10009: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10013 "configure"
+#line 10015 "configure"
@@ -10020,7 +10022,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10045,13 +10047,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10049: checking for SQLConnect in -liodbc" >&5
+echo "configure:10051: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10055 "configure"
+#line 10057 "configure"
@@ -10062,7 +10064,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10087,11 +10089,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10091: checking for ODBC library" >&5
+echo "configure:10093: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10095 "configure"
+#line 10097 "configure"
#include <windows.h>
#include <sql.h>
@@ -10099,7 +10101,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10148,7 +10150,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10152: checking whether to use FFTW" >&5
+echo "configure:10154: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10167,7 +10169,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10171: checking for location of FFTW includes" >&5
+echo "configure:10173: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10193,15 +10195,15 @@
do
-echo "configure:10197: checking for $ac_hdr" >&5
+echo "configure:10199: checking for $ac_hdr" >&5
-#line 10200 "configure"
+#line 10202 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10207: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10229,15 +10231,15 @@
do
-echo "configure:10233: checking for $ac_hdr" >&5
+echo "configure:10235: checking for $ac_hdr" >&5
-#line 10236 "configure"
+#line 10238 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10265,15 +10267,15 @@
do
-echo "configure:10269: checking for $ac_hdr" >&5
+echo "configure:10271: checking for $ac_hdr" >&5
-#line 10272 "configure"
+#line 10274 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10277: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10319,7 +10321,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10323: checking for location of FFTW library" >&5
+echo "configure:10325: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10344,13 +10346,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10348: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10350: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10354 "configure"
+#line 10356 "configure"
@@ -10361,7 +10363,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10386,13 +10388,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10390: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10392: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10396 "configure"
+#line 10398 "configure"
@@ -10403,7 +10405,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10428,13 +10430,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10432: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10434: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10438 "configure"
+#line 10440 "configure"
@@ -10445,7 +10447,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10502,7 +10504,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10506: checking whether to use BLAS" >&5
+echo "configure:10508: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10523,7 +10525,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10527: checking for location of BLAS includes" >&5
+echo "configure:10529: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10543,7 +10545,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10547: checking for location of BLAS library" >&5
+echo "configure:10549: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10569,15 +10571,15 @@
do
-echo "configure:10573: checking for $ac_hdr" >&5
+echo "configure:10575: checking for $ac_hdr" >&5
-#line 10576 "configure"
+#line 10578 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10612,13 +10614,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10616: checking for dnrm2_ in -lblas" >&5
+echo "configure:10618: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10622 "configure"
+#line 10624 "configure"
@@ -10629,7 +10631,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10648,13 +10650,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10652: checking for dnrm2_ in -lblas" >&5
+echo "configure:10654: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10658 "configure"
+#line 10660 "configure"
@@ -10665,7 +10667,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10709,13 +10711,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10713: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10715: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10719 "configure"
+#line 10721 "configure"
@@ -10726,7 +10728,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10741,13 +10743,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10745: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10747: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10751 "configure"
+#line 10753 "configure"
@@ -10758,7 +10760,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10773,13 +10775,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10777: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10779: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10783 "configure"
+#line 10785 "configure"
@@ -10790,7 +10792,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10836,16 +10838,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10840: checking for sgemm in $vlib_flags" >&5
+echo "configure:10842: checking for sgemm in $vlib_flags" >&5
-#line 10842 "configure"
+#line 10844 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10863,13 +10865,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10867: checking for sgemm_ in -lblas" >&5
+echo "configure:10869: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 10873 "configure"
+#line 10875 "configure"
@@ -10880,7 +10882,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10895,13 +10897,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10899: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10901: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 10905 "configure"
+#line 10907 "configure"
@@ -10912,7 +10914,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:10916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10927,13 +10929,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10931: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10933: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 10937 "configure"
+#line 10939 "configure"
@@ -10944,7 +10946,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10978,13 +10980,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:10982: checking for acosp in -lsunmath" >&5
+echo "configure:10984: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 10988 "configure"
+#line 10990 "configure"
@@ -10995,7 +10997,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11010,13 +11012,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11014: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11016: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11020 "configure"
+#line 11022 "configure"
@@ -11027,7 +11029,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11057,13 +11059,13 @@
# Generic BLAS library
-echo "configure:11061: checking for sgemm_ in -lblas" >&5
+echo "configure:11063: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11067 "configure"
+#line 11069 "configure"
@@ -11074,7 +11076,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11113,7 +11115,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11117: checking whether to use LAPACK" >&5
+echo "configure:11119: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11138,7 +11140,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11142: checking for location of LAPACK includes" >&5
+echo "configure:11144: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11158,7 +11160,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11162: checking for location of LAPACK library" >&5
+echo "configure:11164: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11184,15 +11186,15 @@
do
-echo "configure:11188: checking for $ac_hdr" >&5
+echo "configure:11190: checking for $ac_hdr" >&5
-#line 11191 "configure"
+#line 11193 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11198: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11224,10 +11226,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11228: checking for dsegv_" >&5
+echo "configure:11230: checking for dsegv_" >&5
-#line 11231 "configure"
+#line 11233 "configure"
which can conflict with char dsegv_(); below. */
@@ -11250,7 +11252,7 @@
; return 0; }
EOF
-if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11277,13 +11279,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11281: checking for desgv_ in -llapack" >&5
+echo "configure:11283: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11287 "configure"
+#line 11289 "configure"
@@ -11294,7 +11296,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11326,13 +11328,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11330: checking for dgesv_ in -llapack" >&5
+echo "configure:11332: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11336 "configure"
+#line 11338 "configure"
@@ -11343,7 +11345,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11362,13 +11364,13 @@
-echo "configure:11366: checking for dgesv_ in -llapack" >&5
+echo "configure:11368: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11372 "configure"
+#line 11374 "configure"
@@ -11379,7 +11381,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11435,7 +11437,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11439: checking whether to use Cairo" >&5
+echo "configure:11441: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11467,7 +11469,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11471: checking for location of cairo includes" >&5
+echo "configure:11473: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11493,15 +11495,15 @@
do
-echo "configure:11497: checking for $ac_hdr" >&5
+echo "configure:11499: checking for $ac_hdr" >&5
-#line 11500 "configure"
+#line 11502 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11537,7 +11539,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11541: checking for location of cairo library" >&5
+echo "configure:11543: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11557,7 +11559,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11561: checking for cairo linking flags" >&5
+echo "configure:11563: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11573,10 +11575,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11577: checking for cairo_create" >&5
+echo "configure:11579: checking for cairo_create" >&5
-#line 11580 "configure"
+#line 11582 "configure"
which can conflict with char cairo_create(); below. */
@@ -11599,7 +11601,7 @@
; return 0; }
EOF
-if { (eval echo configure:11603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11633,10 +11635,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11637: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11639: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11640 "configure"
+#line 11642 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11659,7 +11661,7 @@
; return 0; }
EOF
-if { (eval echo configure:11663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11692,10 +11694,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11696: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11698: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11699 "configure"
+#line 11701 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11718,7 +11720,7 @@
; return 0; }
EOF
-if { (eval echo configure:11722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11760,7 +11762,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11764: checking whether to use FreeType" >&5
+echo "configure:11766: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11779,7 +11781,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11783: checking for location of FreeType includes" >&5
+echo "configure:11785: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11805,15 +11807,15 @@
do
-echo "configure:11809: checking for $ac_hdr" >&5
+echo "configure:11811: checking for $ac_hdr" >&5
-#line 11812 "configure"
+#line 11814 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11847,7 +11849,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11851: checking for location of FreeType library" >&5
+echo "configure:11853: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11872,13 +11874,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11876: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11878: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 11882 "configure"
+#line 11884 "configure"
@@ -11889,7 +11891,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:11893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11930,7 +11932,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11934: checking whether to use NLS" >&5
+echo "configure:11936: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -11950,10 +11952,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:11954: checking for gettext" >&5
+echo "configure:11956: checking for gettext" >&5
-#line 11957 "configure"
+#line 11959 "configure"
which can conflict with char gettext(); below. */
@@ -11976,7 +11978,7 @@
; return 0; }
EOF
-if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -11994,13 +11996,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:11998: checking for gettext in -lintl" >&5
+echo "configure:12000: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12004 "configure"
+#line 12006 "configure"
@@ -12011,7 +12013,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12046,7 +12048,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12050: checking whether to use C++" >&5
+echo "configure:12052: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12062,7 +12064,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12066: checking for $ac_word" >&5
+echo "configure:12068: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12091,7 +12093,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12095: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12097: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12102,12 +12104,12 @@
cat > conftest.$ac_ext << EOF
-#line 12106 "configure"
+#line 12108 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12133,19 +12135,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12137: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12139: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12142: checking whether we are using GNU C++" >&5
+echo "configure:12144: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12163,7 +12165,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12167: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12169: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12191,58 +12193,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 12205 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 12223 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12230: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -12255,7 +12206,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12259: checking whether to use openDWG" >&5
+echo "configure:12210: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12275,7 +12226,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12279: checking for location of openDGW includes" >&5
+echo "configure:12230: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12301,15 +12252,15 @@
do
-echo "configure:12305: checking for $ac_hdr" >&5
+echo "configure:12256: checking for $ac_hdr" >&5
-#line 12308 "configure"
+#line 12259 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12343,7 +12294,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12347: checking for location of openDWG library" >&5
+echo "configure:12298: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12384,7 +12335,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12388: checking whether to use POSIX threads" >&5
+echo "configure:12339: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12404,7 +12355,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12408: checking for location of POSIX threads includes" >&5
+echo "configure:12359: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12430,15 +12381,15 @@
do
-echo "configure:12434: checking for $ac_hdr" >&5
+echo "configure:12385: checking for $ac_hdr" >&5
-#line 12437 "configure"
+#line 12388 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12393: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12472,7 +12423,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12476: checking for location of POSIX threads library" >&5
+echo "configure:12427: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12497,10 +12448,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12501: checking for pthread_create" >&5
+echo "configure:12452: checking for pthread_create" >&5
-#line 12504 "configure"
+#line 12455 "configure"
which can conflict with char pthread_create(); below. */
@@ -12523,7 +12474,7 @@
; return 0; }
EOF
-if { (eval echo configure:12527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12550,13 +12501,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12554: checking for pthread_create in -lpthread" >&5
+echo "configure:12505: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12560 "configure"
+#line 12511 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12567,7 +12518,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12617,7 +12568,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12621: checking whether to use OpenMP" >&5
+echo "configure:12572: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12638,7 +12589,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12642: checking for location of OpenMP includes" >&5
+echo "configure:12593: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12664,15 +12615,15 @@
do
-echo "configure:12668: checking for $ac_hdr" >&5
+echo "configure:12619: checking for $ac_hdr" >&5
-#line 12671 "configure"
+#line 12622 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12676: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12710,7 +12661,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12714: checking for location of OpenMP library" >&5
+echo "configure:12665: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12735,10 +12686,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12739: checking for GOMP_parallel_start" >&5
+echo "configure:12690: checking for GOMP_parallel_start" >&5
-#line 12742 "configure"
+#line 12693 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12761,7 +12712,7 @@
; return 0; }
EOF
-if { (eval echo configure:12765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12788,13 +12739,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12792: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12743: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12798 "configure"
+#line 12749 "configure"
@@ -12805,7 +12756,7 @@
; return 0; }
EOF
-if { (eval echo configure:12809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12878,7 +12829,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12882: checking whether to use OpenCL" >&5
+echo "configure:12833: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -12898,7 +12849,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12902: checking for location of OpenCL includes" >&5
+echo "configure:12853: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12925,15 +12876,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12929: checking for $ac_hdr" >&5
+echo "configure:12880: checking for $ac_hdr" >&5
-#line 12932 "configure"
+#line 12883 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12973,10 +12924,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12977: checking for clGetPlatformInfo" >&5
+echo "configure:12928: checking for clGetPlatformInfo" >&5
-#line 12980 "configure"
+#line 12931 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -12999,7 +12950,7 @@
; return 0; }
EOF
-if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13038,15 +12989,15 @@
do
-echo "configure:13042: checking for $ac_hdr" >&5
+echo "configure:12993: checking for $ac_hdr" >&5
-#line 13045 "configure"
+#line 12996 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13079,7 +13030,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13083: checking for location of OpenCL library" >&5
+echo "configure:13034: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13103,13 +13054,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13107: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13058: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13113 "configure"
+#line 13064 "configure"
@@ -13120,7 +13071,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13180,7 +13131,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13184: checking for special C compiler options needed for large files" >&5
+echo "configure:13135: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13188,7 +13139,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13192 "configure"
+#line 13143 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13204,7 +13155,7 @@
; return 0; }
EOF
-if { (eval echo configure:13208: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13159: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13213,7 +13164,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13217 "configure"
+#line 13168 "configure"
@@ -13229,7 +13180,7 @@
; return 0; }
EOF
-if { (eval echo configure:13233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13184: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13256,11 +13207,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13260: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13211: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13264 "configure"
+#line 13215 "configure"
@@ -13276,14 +13227,14 @@
; return 0; }
EOF
-if { (eval echo configure:13280: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13231: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13287 "configure"
+#line 13238 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13301,7 +13252,7 @@
; return 0; }
EOF
-if { (eval echo configure:13305: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13256: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13327,11 +13278,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13331: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13282: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13335 "configure"
+#line 13286 "configure"
@@ -13347,14 +13298,14 @@
; return 0; }
EOF
-if { (eval echo configure:13351: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13302: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13358 "configure"
+#line 13309 "configure"
#define _LARGE_FILES 1
@@ -13372,7 +13323,7 @@
; return 0; }
EOF
-if { (eval echo configure:13376: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13327: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13398,25 +13349,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13402: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13353: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13406 "configure"
+#line 13357 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13413: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13364: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13420 "configure"
+#line 13371 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13425,7 +13376,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13380: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13457,25 +13408,25 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13461: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13412: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13465 "configure"
+#line 13416 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13472: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13423: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13479 "configure"
+#line 13430 "configure"
#include <stdio.h>
@@ -13484,7 +13435,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13488: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13439: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13514,18 +13465,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13518: checking for fseeko" >&5
+echo "configure:13469: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13522 "configure"
+#line 13473 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13542,10 +13493,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13546: checking if system supports Large Files at all" >&5
+echo "configure:13497: checking if system supports Large Files at all" >&5
-#line 13549 "configure"
+#line 13500 "configure"
#include <stdio.h>
@@ -13577,7 +13528,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13581: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13532: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2016-03-25 05:50:23 UTC (rev 68140)
+++ grass/trunk/configure.in 2016-03-25 08:32:44 UTC (rev 68141)
@@ -126,12 +126,14 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
changequote([,])
-GRASS_VERSION_SVN=00000
+GRASS_VERSION_SVN="exported"
AC_PATH_PROG(SVN_VERSION, svnversion, no)
if test "$SVN_VERSION" != "no" ; then
GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
if test "$GRASS_VERSION_SVN" = "exported" -o "$GRASS_VERSION_SVN" = "Unversioned directory" ; then
- GRASS_VERSION_SVN=00000
+ GRASS_VERSION_SVN="exported"
+ else
+ GRASS_VERSION_SVN="r$GRASS_VERSION_SVN"
fi
fi
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile 2016-03-25 05:50:23 UTC (rev 68140)
+++ grass/trunk/lib/init/Makefile 2016-03-25 08:32:44 UTC (rev 68141)
@@ -96,7 +96,7 @@
$(ETC)/VERSIONNUMBER:
rm -f $@
@if [ -n "$(GRASS_VERSION_SVN)" ] ; then \
- echo "$(GRASS_VERSION_NUMBER) r$(GRASS_VERSION_SVN)" > $@ ; \
+ echo "$(GRASS_VERSION_NUMBER) $(GRASS_VERSION_SVN)" > $@ ; \
else \
echo "$(GRASS_VERSION_NUMBER)" > $@ ; \
fi
