[GRASS-SVN] r68166 - grass-addons/grass7/raster/r.randomforest
svn_grass at osgeo.org
Mon Mar 28 07:40:29 PDT 2016
Author: spawley
Date: 2016-03-28 07:40:29 -0700 (Mon, 28 Mar 2016)
New Revision: 68166
grass-addons/grass7/raster/r.randomforest/r.randomforest.py
normalize windows and linux line endings
Modified: grass-addons/grass7/raster/r.randomforest/r.randomforest.py
--- grass-addons/grass7/raster/r.randomforest/r.randomforest.py 2016-03-28 03:51:05 UTC (rev 68165)
+++ grass-addons/grass7/raster/r.randomforest/r.randomforest.py 2016-03-28 14:40:29 UTC (rev 68166)
@@ -141,6 +141,13 @@
roi_raster.close()
grass.run_command("g.remove", name = rfmask, flags = "f", type = "raster")
+def normalize_newlines(string):
+ # Windows and nix platforms have different line endings. DOS uses carriage return and
+ # line feed ("\r\n") as a line ending, which Unix uses just line feed ("\n").
+ # This script normalizes the line endings to unix format "\n"
+ import re
+ return re.sub(r'(\r\n|\r|\n)', '\n', string)
def main():
igroup = options['igroup']
roi = options['roi']
@@ -176,13 +183,9 @@
###################### Fetch individual raster names from group ###########################################
groupmaps = grass.read_command("i.group", group = igroup, flags = "g")
- if os.name == "nt":
- groupmaps = groupmaps[0:len(groupmaps)-2] # to remove the last line ending and return characters
- maplist = groupmaps.split('\r\n')
- else:
- groupmaps = groupmaps[0:len(groupmaps)-1] # to remove the last line ending and return characters
- maplist = groupmaps.split('\n')
+ groupmaps = normalize_newlines(groupmaps)
+ maplist = groupmaps.split('\n')
+ maplist = maplist[0:len(maplist)-1]
######################### Obtain information about GRASS rasters to be classified ######################
@@ -232,16 +235,8 @@
# determine cell storage type of training roi raster
roi_type = grass.read_command("r.info", map = roi, flags = 'g')
- roi_type = roi_type[0:len(roi_type)-2] # to remove the last line ending and return characters
- roi_type = str(roi_type)
- roi_list = roi_type.split('\r\n')
- else:
- roi_type = roi_type[0:len(roi_type)-1] # to remove the last line ending and return characters
- roi_list = roi_type.split('\n')
+ roi_type = normalize_newlines(str(roi_type))
+ roi_list = roi_type.split('\n')
dtype = roi_list[9].split('=')[1]
# check if training rois are valid for classification and regression
