[GRASS-SVN] r68349 - in grass/trunk/lib/python/ctypes/ctypesgencore: . parser printer processor
svn_grass at osgeo.org
Mon May 2 09:06:47 PDT 2016
Author: zarch
Date: 2016-05-02 09:06:47 -0700 (Mon, 02 May 2016)
New Revision: 68349
grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py
grass/trunk/lib/python/ctypes/ctypesgencore/libraryloader.py
grass/trunk/lib/python/ctypes/ctypesgencore/options.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py
grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py
grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py
grass/trunk/lib/python/ctypes/ctypesgencore/processor/dependencies.py
grass/trunk/lib/python/ctypes/ctypesgencore/processor/operations.py
grass/trunk/lib/python/ctypes/ctypesgencore/processor/pipeline.py
ctypes: sort import library order
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -6,9 +6,11 @@
which returns a Python string representing that expression.
-from ctypedescs import *
import keyword
+from ctypedescs import *
# Right now, the objects in this module are all oriented toward evaluation.
# However, they don't have to be, since ctypes objects are mutable. For example,
# shouldn't it be possible to translate the macro:
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/libraryloader.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/libraryloader.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/libraryloader.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -32,10 +32,11 @@
# POSSIBILITY OF SUCH DAMAGE.
+import glob
import os.path
import re
import sys
-import glob
import ctypes
import ctypes.util
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/options.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/options.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/options.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -8,9 +8,10 @@
for convenience.
+import copy
import optparse
-import copy
default_values = {
"other_headers": [],
"modules": [],
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -20,11 +20,11 @@
import time
import warnings
+import cdeclarations
+import ctypesgencore.expressions as expressions
+import ctypesparser
import preprocessor
import yacc
-import ctypesparser
-import ctypesgencore.expressions as expressions
-import cdeclarations
tokens = (
'PP_DEFINE', 'PP_DEFINE_NAME', 'PP_DEFINE_MACRO_NAME', 'PP_MACRO_PARAM',
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -16,11 +16,12 @@
import time
import warnings
+import cgrammar
import preprocessor
import yacc
-import cgrammar
# Lexer
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -12,9 +12,9 @@
__all__ = ["CtypesParser"]
+from cdeclarations import *
from cparser import *
from ctypesgencore.ctypedescs import *
-from cdeclarations import *
from ctypesgencore.expressions import *
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -7,13 +7,14 @@
calling DataCollectingParser.data().
+import os
+from tempfile import mkstemp
import ctypesparser
+from ctypesgencore.ctypedescs import *
from ctypesgencore.descriptions import *
-from ctypesgencore.ctypedescs import *
from ctypesgencore.messages import *
-from tempfile import mkstemp
-import os
class DataCollectingParser(ctypesparser.CtypesParser,
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -26,10 +26,10 @@
__version__ = "2.2"
+import os.path
import re
import sys
import types
-import os.path
# Regular expression used to match valid token names
_is_identifier = re.compile(r'^[a-zA-Z0-9_]+$')
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -15,10 +15,11 @@
import shlex
import sys
import tokenize
+import traceback
+import ctypes
import lex
import yacc
-import traceback
-import ctypes
from lex import TOKEN
tokens = (
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -13,16 +13,18 @@
import os
import re
import shlex
+import subprocess
import sys
import tokenize
+import traceback
+import ctypes
import lex
+import pplexer
import yacc
-import traceback
-import subprocess
-import ctypes
-import pplexer
# Lexers
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -69,11 +69,11 @@
error_count = 3 # Number of symbols that must be shifted to leave recovery mode
+import cStringIO
+import os.path
import re
+import sys
import types
-import sys
-import cStringIO
-import os.path
# <tm> 1 July 2008
try:
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -1,6 +1,7 @@
-import ctypes
import os
import sys
+import ctypes
from ctypes import *
_int_types = (c_int16, c_int32)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -2,15 +2,15 @@
import os
import sys
+import test # So we can find the path to local files in the printer package
import time
+import ctypesgencore.libraryloader # So we can get the path to it
-import ctypesgencore.libraryloader # So we can get the path to it
-import test # So we can find the path to local files in the printer package
def path_to_local_file(name, known_local_module=test):
basedir = os.path.dirname(known_local_module.__file__)
return os.path.join(basedir, name)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/processor/dependencies.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/processor/dependencies.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/processor/dependencies.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -5,8 +5,8 @@
descriptions.
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/processor/operations.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/processor/operations.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/processor/operations.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -6,15 +6,17 @@
ctypesgencore.processor.pipeline calls the operations module.
-import ctypes
+import keyword
+import os
import re
-import os
import sys
-import keyword
+import ctypes
# Processor functions
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/processor/pipeline.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/processor/pipeline.py 2016-05-02 16:06:24 UTC (rev 68348)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/processor/pipeline.py 2016-05-02 16:06:47 UTC (rev 68349)
@@ -1,13 +1,15 @@
#!/usr/bin/env python
+import os
+import re
import ctypes
-import re
-import os
-from ctypesgencore.processor.operations import *
-from ctypesgencore.processor.dependencies import find_dependencies
+from ctypesgencore.processor.dependencies import find_dependencies
+from ctypesgencore.processor.operations import *
A brief explanation of the processing steps:
1. The dependencies module builds a dependency graph for the descriptions.
