[GRASS-SVN] r68351 - in grass/trunk/lib/python/ctypes: . ctypesgencore ctypesgencore/parser ctypesgencore/printer ctypesgencore/processor
Mon May 2 09:07:13 PDT 2016
Author: zarch
Date: 2016-05-02 09:07:13 -0700 (Mon, 02 May 2016)
New Revision: 68351
   grass/trunk/lib/python/ctypes/ctypesgen.py
   grass/trunk/lib/python/ctypes/ctypesgencore/__init__.py
   grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py
   grass/trunk/lib/python/ctypes/ctypesgencore/messages.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/__init__.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/parsetab.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py
   grass/trunk/lib/python/ctypes/ctypesgencore/printer/__init__.py
   grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py
   grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py
   grass/trunk/lib/python/ctypes/ctypesgencore/processor/__init__.py
ctypes: change syntax to support both python2 and python3
Modified: grass/trunk/lib/python/ctypes/ctypesgen.py
--- grass/trunk/lib/python/ctypes/ctypesgen.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgen.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -16,7 +16,7 @@
 import sys
 import ctypesgencore
-import ctypesgencore.messages as msgs
+from ctypesgencore import messages as msgs
 def option_callback_W(option, opt, value, parser):
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/__init__.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/__init__.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/__init__.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -48,15 +48,15 @@
            "messages", "options"]
 # Workhorse modules
-import parser
-import processor
-import printer
+from . import parser
+from . import processor
+from . import printer
 # Modules describing internal format
-import descriptions
-import ctypedescs
-import expressions
+from . import descriptions
+from . import ctypedescs
+from . import expressions
 # Helper modules
-import messages
-import options
+from . import messages
+from . import options
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/expressions.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -8,7 +8,7 @@
 import keyword
-from ctypedescs import *
+from .ctypedescs import *
 # Right now, the objects in this module are all oriented toward evaluation.
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/messages.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/messages.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/messages.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -19,6 +19,7 @@
 'rename' - a description has been renamed to avoid a name conflict
 'other' - catchall.
+from __future__ import print_function
 import sys
@@ -26,12 +27,12 @@
 def error_message(msg, cls=None):
-    print "Error: %s" % msg
+    print("Error: %s" % msg)
 def warning_message(msg, cls=None):
-    print "Warning: %s" % msg
+    print("Warning: %s" % msg)
 def status_message(msg):
-    print "Status: %s" % msg
+    print("Status: %s" % msg)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/__init__.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/__init__.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/__init__.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -14,7 +14,7 @@
-from datacollectingparser import DataCollectingParser
+from .datacollectingparser import DataCollectingParser
 def parse(headers, options):
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/cgrammar.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -10,6 +10,11 @@
   * http://www.open-std.org/JTC1/SC22/WG14/www/docs/n1124.pdf
+try:
+    from builtins import long
+except ImportError:
+    # python3
+    long = int
 __docformat__ = 'restructuredtext'
@@ -20,12 +25,12 @@
 import time
 import warnings
-import cdeclarations
+from . import cdeclarations
 import ctypesgencore.expressions as expressions
-import ctypesparser
-import preprocessor
-import yacc
+from . import preprocessor
+from . import yacc
 tokens = (
     'PP_DEFINE', 'PP_DEFINE_NAME', 'PP_DEFINE_MACRO_NAME', 'PP_MACRO_PARAM',
     'PP_STRINGIFY', 'PP_IDENTIFIER_PASTE', 'PP_END_DEFINE',
@@ -906,6 +911,7 @@
     '''type_name : specifier_qualifier_list
                  | specifier_qualifier_list abstract_declarator
+    from . import ctypesparser
     typ = p[1]
     if len(p) == 3:
         declarator = p[2]
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/cparser.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -6,7 +6,9 @@
 To use, subclass CParser and override its handle_* methods.  Then instantiate
 the class with a string to parse.
 import operator
@@ -16,10 +18,10 @@
 import time
 import warnings
-import cgrammar
-import yacc
+from . import cgrammar
+from . import yacc
@@ -131,7 +133,7 @@
         The parser will try to recover from errors by synchronising at the
         next semicolon.
-        print >> sys.stderr, '%s:%s %s' % (filename, lineno, message)
+        print('%s:%s %s' % (filename, lineno, message), file=sys.stderr)
     def handle_pp_error(self, message):
         '''The C preprocessor emitted an error.
@@ -139,14 +141,14 @@
         The default implementatin prints the error to stderr. If processing
         can continue, it will.
-        print >> sys.stderr, 'Preprocessor:', message
+        print('Preprocessor:', message, file=sys.stderr)
     def handle_status(self, message):
         '''Progress information.
         The default implementationg prints message to stderr.
-        print >> sys.stderr, message
+        print(message, file=sys.stderr)
     def handle_define(self, name, params, value, filename, lineno):
         '''#define `name` `value`
@@ -202,13 +204,13 @@
     def handle_define(self, name, value, filename, lineno):
-        print '#define name=%r, value=%r' % (name, value)
+        print('#define name=%r, value=%r' % (name, value))
     def handle_define_constant(self, name, value, filename, lineno):
-        print '#define constant name=%r, value=%r' % (name, value)
+        print('#define constant name=%r, value=%r' % (name, value))
     def handle_declaration(self, declaration, filename, lineno):
-        print declaration
+        print(declaration)
 if __name__ == '__main__':
     DebugCParser().parse(sys.argv[1], debug=True)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -12,8 +12,8 @@
 __all__ = ["CtypesParser"]
-from cdeclarations import *
-from cparser import *
+from .cdeclarations import *
+from .cparser import *
 from ctypesgencore.ctypedescs import *
 from ctypesgencore.expressions import *
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -6,11 +6,13 @@
 After parsing is complete, a DescriptionCollection object can be retrieved by
 calling DataCollectingParser.data().
 import os
 from tempfile import mkstemp
+from . import ctypesparser
 from ctypesgencore.descriptions import *
@@ -64,9 +66,9 @@
         fd, fname = mkstemp(suffix=".h")
         f = os.fdopen(fd, 'w+b')
         for header in self.options.other_headers:
-            print >>f, '#include <%s>' % header
+            print('#include <%s>' % header, file=f)
         for header in self.headers:
-            print >>f, '#include "%s"' % os.path.abspath(header)
+            print('#include "%s"' % os.path.abspath(header), file=f)
         f.flush()
         f.close()
         ctypesparser.CtypesParser.parse(self, fname, None)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -23,14 +23,53 @@
 # See the file LICENSE for a complete copy of the LGPL.
 __version__ = "2.2"
+try:
+    from builtins import bytes
+    PY3 = True
+    # python2
+    bytes = str
+import operator
 import os.path
 import re
 import sys
 import types
+import collections
+if PY3:
+    _meth_func = "__func__"
+    _meth_self = "__self__"
+    _func_closure = "__closure__"
+    _func_code = "__code__"
+    _func_defaults = "__defaults__"
+    _func_globals = "__globals__"
+else:
+    _meth_func = "im_func"
+    _meth_self = "im_self"
+    _func_closure = "func_closure"
+    _func_code = "func_code"
+    _func_defaults = "func_defaults"
+    _func_globals = "func_globals"
+# define compatible function to support PY2 & PY3
+get_mth_func = operator.attrgetter(_meth_func)
+get_mth_self = operator.attrgetter(_meth_self)
+get_func_closure = operator.attrgetter(_func_closure)
+get_func_code = operator.attrgetter(_func_code)
+get_func_defaults = operator.attrgetter(_func_defaults)
+get_func_globals = operator.attrgetter(_func_globals)
 # Regular expression used to match valid token names
 _is_identifier = re.compile(r'^[a-zA-Z0-9_]+$')
@@ -38,13 +77,8 @@
 # It's a little funky because I want to preserve backwards compatibility
 # with Python 2.0 where types.ObjectType is undefined.
-try:
-    _INSTANCETYPE = (types.InstanceType, types.ObjectType)
-except AttributeError:
-    _INSTANCETYPE = types.InstanceType
+_INSTANCETYPE = getattr(types, 'InstanceType', object)
-    class object:
-        pass       # Note: needed if no new-style classes present
 # Exception thrown when invalid token encountered and no default error
 # handler is defined.
@@ -192,7 +226,7 @@
     # readtab() - Read lexer information from a tab file
     def readtab(self, tabfile, fdict):
-        exec "import %s as lextab" % tabfile
+        exec("import %s as lextab" % tabfile)
         self.lextokens = lextab._lextokens
         self.lexreflags = lextab._lexreflags
         self.lexliterals = lextab._lexliterals
@@ -220,7 +254,7 @@
     # input() - Push a new string into the lexer
     def input(self, s):
-        if not (isinstance(s, types.StringType) or isinstance(s, types.UnicodeType)):
+        if not (isinstance(s, bytes) or isinstance(s, str)):
             raise ValueError("Expected a string")
         self.lexdata = s
         self.lexpos = 0
@@ -313,7 +347,7 @@
                     break
                 # if func not callable, it means it's an ignored token
-                if not callable(func):
+                if not isinstance(func, collections.Callable):
                     break
                 # If token is processed by a function, call it
@@ -335,7 +369,7 @@
                     # 20/Jan/2007
                     if newtok.type not in self.lextokens and len(newtok.type) > 1:
                         raise LexError("%s:%d: Rule '%s' returned an unknown token type '%s'" % (
-                            func.func_code.co_filename, func.func_code.co_firstlineno,
+                            get_func_code(func).co_filename, get_func_code(func).co_firstlineno,
                             func.__name__, newtok.type), lexdata[lexpos:])
                 return newtok
@@ -420,7 +454,7 @@
             if not prev:
                 counthash[name] = linen
             else:
-                print "%s:%d: Rule %s redefined. Previously defined on line %d" % (filename, linen, name, prev)
+                print("%s:%d: Rule %s redefined. Previously defined on line %d" % (filename, linen, name, prev))
                 noerror = 0
         linen += 1
     return noerror
@@ -486,7 +520,7 @@
                 # callback function to carry out the action
                 if f.find("ignore_") > 0:
                     lexindexfunc[i] = (None, None)
-                    print "IGNORE", f
+                    print("IGNORE", f)
                 else:
                     lexindexfunc[i] = (None, f[2:])
@@ -601,7 +635,7 @@
     if not tokens:
         raise SyntaxError("lex: module does not define 'tokens'")
-    if not (isinstance(tokens, types.ListType) or isinstance(tokens, types.TupleType)):
+    if not (isinstance(tokens, list) or isinstance(tokens, tuple)):
         raise SyntaxError("lex: tokens must be a list or tuple.")
     # Build a dictionary of valid token names
@@ -609,54 +643,54 @@
     if not optimize:
         for n in tokens:
             if not _is_identifier.match(n):
-                print "lex: Bad token name '%s'" % n
+                print("lex: Bad token name '%s'" % n)
                 error = 1
             if warn and n in lexobj.lextokens:
-                print "lex: Warning. Token '%s' multiply defined." % n
+                print("lex: Warning. Token '%s' multiply defined." % n)
             lexobj.lextokens[n] = None
     else:
         for n in tokens:
     if debug:
-        print "lex: tokens = '%s'" % lexobj.lextokens.keys()
+        print("lex: tokens = '%s'" % list(lexobj.lextokens.keys()))
     try:
         for c in literals:
-            if not (isinstance(c, types.StringType) or isinstance(
-                    c, types.UnicodeType)) or len(c) > 1:
-                print "lex: Invalid literal %s. Must be a single character" % repr(c)
+            if not (isinstance(c, bytes) or isinstance(
+                    c, str)) or len(c) > 1:
+                print("lex: Invalid literal %s. Must be a single character" % repr(c))
                 error = 1
                 continue
     except TypeError:
-        print "lex: Invalid literals specification. literals must be a sequence of characters."
+        print("lex: Invalid literals specification. literals must be a sequence of characters.")
         error = 1
     lexobj.lexliterals = literals
     # Build statemap
     if states:
-        if not (isinstance(states, types.TupleType) or isinstance(states, types.ListType)):
-            print "lex: states must be defined as a tuple or list."
+        if not (isinstance(states, tuple) or isinstance(states, list)):
+            print("lex: states must be defined as a tuple or list.")
             error = 1
         else:
             for s in states:
-                if not isinstance(s, types.TupleType) or len(s) != 2:
-                    print "lex: invalid state specifier %s. Must be a tuple (statename,'exclusive|inclusive')" % repr(s)
+                if not isinstance(s, tuple) or len(s) != 2:
+                    print("lex: invalid state specifier %s. Must be a tuple (statename,'exclusive|inclusive')" % repr(s))
                     error = 1
                     continue
                 name, statetype = s
-                if not isinstance(name, types.StringType):
-                    print "lex: state name %s must be a string" % repr(name)
+                if not isinstance(name, bytes):
+                    print("lex: state name %s must be a string" % repr(name))
                     error = 1
                     continue
                 if not (statetype == 'inclusive' or statetype == 'exclusive'):
-                    print "lex: state type for state %s must be 'inclusive' or 'exclusive'" % name
+                    print("lex: state type for state %s must be 'inclusive' or 'exclusive'" % name)
                     error = 1
                     continue
                 if name in stateinfo:
-                    print "lex: state '%s' already defined." % name
+                    print("lex: state '%s' already defined." % name)
                     error = 1
                     continue
                 stateinfo[name] = statetype
@@ -685,19 +719,19 @@
         states, tokname = _statetoken(f, stateinfo)
         toknames[f] = tokname
-        if callable(t):
+        if isinstance(t, collections.Callable):
             for s in states:
                 funcsym[s].append((f, t))
-        elif (isinstance(t, types.StringType) or isinstance(t, types.UnicodeType)):
+        elif (isinstance(t, bytes) or isinstance(t, str)):
             for s in states:
                 strsym[s].append((f, t))
         else:
-            print "lex: %s not defined as a function or string" % f
+            print("lex: %s not defined as a function or string" % f)
             error = 1
     # Sort the functions by line number
     for f in funcsym.values():
-        f.sort(lambda x, y: cmp(x[1].func_code.co_firstlineno, y[1].func_code.co_firstlineno))
+        f.sort(lambda x, y: cmp(get_func_code(x[1]).co_firstlineno, get_func_code(y[1]).co_firstlineno))
     # Sort the strings by regular expression length
     for s in strsym.values():
@@ -711,31 +745,31 @@
         # Add rules defined by functions first
         for fname, f in funcsym[state]:
-            line = f.func_code.co_firstlineno
-            file = f.func_code.co_filename
+            line = get_func_code(f).co_firstlineno
+            file = get_func_code(f).co_filename
             files[file] = None
             tokname = toknames[fname]
             ismethod = isinstance(f, types.MethodType)
             if not optimize:
-                nargs = f.func_code.co_argcount
+                nargs = get_func_code(f).co_argcount
                 if ismethod:
                     reqargs = 2
                 else:
                     reqargs = 1
                 if nargs > reqargs:
-                    print "%s:%d: Rule '%s' has too many arguments." % (file, line, f.__name__)
+                    print("%s:%d: Rule '%s' has too many arguments." % (file, line, f.__name__))
                     error = 1
                     continue
                 if nargs < reqargs:
-                    print "%s:%d: Rule '%s' requires an argument." % (file, line, f.__name__)
+                    print("%s:%d: Rule '%s' requires an argument." % (file, line, f.__name__))
                     error = 1
                     continue
                 if tokname == 'ignore':
-                    print "%s:%d: Rule '%s' must be defined as a string." % (file, line, f.__name__)
+                    print("%s:%d: Rule '%s' must be defined as a string." % (file, line, f.__name__))
                     error = 1
                     continue
@@ -748,25 +782,25 @@
                     try:
                         c = re.compile("(?P<%s>%s)" % (f.__name__, f.__doc__), re.VERBOSE | reflags)
                         if c.match(""):
-                            print "%s:%d: Regular expression for rule '%s' matches empty string." % (file, line, f.__name__)
+                            print("%s:%d: Regular expression for rule '%s' matches empty string." % (file, line, f.__name__))
                             error = 1
                             continue
                     except re.error as e:
-                        print "%s:%d: Invalid regular expression for rule '%s'. %s" % (file, line, f.__name__, e)
+                        print("%s:%d: Invalid regular expression for rule '%s'. %s" % (file, line, f.__name__, e))
                         if '#' in f.__doc__:
-                            print "%s:%d. Make sure '#' in rule '%s' is escaped with '\\#'." % (file, line, f.__name__)
+                            print("%s:%d. Make sure '#' in rule '%s' is escaped with '\\#'." % (file, line, f.__name__))
                         error = 1
                         continue
                     if debug:
-                        print "lex: Adding rule %s -> '%s' (state '%s')" % (f.__name__, f.__doc__, state)
+                        print("lex: Adding rule %s -> '%s' (state '%s')" % (f.__name__, f.__doc__, state))
                 # Okay. The regular expression seemed okay.  Let's append it to the master regular
                 # expression we're building
                 regex_list.append("(?P<%s>%s)" % (f.__name__, f.__doc__))
             else:
-                print "%s:%d: No regular expression defined for rule '%s'" % (file, line, f.__name__)
+                print("%s:%d: No regular expression defined for rule '%s'" % (file, line, f.__name__))
         # Now add all of the simple rules
         for name, r in strsym[state]:
@@ -783,29 +817,29 @@
                     continue
                 if tokname not in lexobj.lextokens and tokname.find("ignore_") < 0:
-                    print "lex: Rule '%s' defined for an unspecified token %s." % (name, tokname)
+                    print("lex: Rule '%s' defined for an unspecified token %s." % (name, tokname))
                     error = 1
                     continue
                 try:
                     c = re.compile("(?P<%s>%s)" % (name, r), re.VERBOSE | reflags)
                     if (c.match("")):
-                        print "lex: Regular expression for rule '%s' matches empty string." % name
+                        print("lex: Regular expression for rule '%s' matches empty string." % name)
                         error = 1
                         continue
-                    print "lex: Invalid regular expression for rule '%s'. %s" % (name, e)
+                    print("lex: Invalid regular expression for rule '%s'. %s" % (name, e))
                     if '#' in r:
-                        print "lex: Make sure '#' in rule '%s' is escaped with '\\#'." % name
+                        print("lex: Make sure '#' in rule '%s' is escaped with '\\#'." % name)
                     error = 1
                     continue
                 if debug:
-                    print "lex: Adding rule %s -> '%s' (state '%s')" % (name, r, state)
+                    print("lex: Adding rule %s -> '%s' (state '%s')" % (name, r, state))
             regex_list.append("(?P<%s>%s)" % (name, r))
         if not regex_list:
-            print "lex: No rules defined for state '%s'" % state
+            print("lex: No rules defined for state '%s'" % state)
             error = 1
         regexs[state] = regex_list
@@ -829,7 +863,7 @@
         lexobj.lexstateretext[state] = re_text
         if debug:
             for i in range(len(re_text)):
-                print "lex: state '%s'. regex[%d] = '%s'" % (state, i, re_text[i])
+                print("lex: state '%s'. regex[%d] = '%s'" % (state, i, re_text[i]))
     # For inclusive states, we need to add the INITIAL state
     for state, type in stateinfo.items():
@@ -849,15 +883,15 @@
     lexobj.lexstateerrorf = errorf
     lexobj.lexerrorf = errorf.get("INITIAL", None)
     if warn and not lexobj.lexerrorf:
-        print "lex: Warning. no t_error rule is defined."
+        print("lex: Warning. no t_error rule is defined.")
     # Check state information for ignore and error rules
     for s, stype in stateinfo.items():
         if stype == 'exclusive':
             if warn and s not in errorf:
-                print "lex: Warning. no error rule is defined for exclusive state '%s'" % s
+                print("lex: Warning. no error rule is defined for exclusive state '%s'" % s)
             if warn and s not in ignore and lexobj.lexignore:
-                print "lex: Warning. no ignore rule is defined for exclusive state '%s'" % s
+                print("lex: Warning. no ignore rule is defined for exclusive state '%s'" % s)
         elif stype == 'inclusive':
             if s not in errorf:
                 errorf[s] = errorf.get("INITIAL", None)
@@ -890,7 +924,7 @@
             data = f.read()
             f.close()
         except IndexError:
-            print "Reading from standard input (type EOF to end):"
+            print("Reading from standard input (type EOF to end):")
             data = sys.stdin.read()
     if lexer:
@@ -907,7 +941,7 @@
         tok = _token()
         if not tok:
             break
-        print "(%s,%r,%d,%d)" % (tok.type, tok.value, tok.lineno, tok.lexpos)
+        print("(%s,%r,%d,%d)" % (tok.type, tok.value, tok.lineno, tok.lexpos))
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/parsetab.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/parsetab.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/parsetab.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -1,282 +1,282 @@
-# /Users/tim/Desktop/ctypesgen/ctypesgencore/parser/parsetab.py
+# /home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/parsetab.py
 # This file is automatically generated. Do not edit.
 _lr_method = 'LALR'
-_lr_signature = 'Oz\xa0\xf9\xf3X\xd9Mf\x00\xfa"\xb3\xb7\xce,'
+_lr_signature = '\xf5\xb5\x15\x94n\xa6\xa1\xc6\n\xee\xd4t-/\xfcr'
-_lr_action_items = {'VOID': ([387, 15, 238, 332, 22, 3, 37, 359, 137, 64, 170, 286, 58, 51, 230, 353, 12, 2, 39, 73, 20, 60, 47, 54, 25, 65, 168, 56, 242, 81, 0, 13, 27, 72, 116, 278, 4, 133, 277, 231, 221, 9, 280, 279, 34, 186, 130, 169, 358, 227, 18, 123, 327, 1, 360, 117, 17, 36, 165, 205, 30, 8, 52, 196, 35, 356, 339, 140, 269, 235, 23, 283, 31, 167, 134, 260, 287, 87, 5, 6, 10, 32, 38, 66, 28, 163, 59, 49, 237, 26, 67, 172, ], [-253, -2, -169, -155, -3, 6, -132, -251, 6, 6, -141, 6, -222, -104, -171, -135, -118, 6, -121, -247, -167, 6, 6, 6, -120, -138, 6, -246, -219, 6, -1, -133, 6, 6, -254, 6, -163, -245, -243, 6, 6, -124, -136, -142, -125, 6, -170, 6, -134, -154, -126, -173, 6, 6, -252, -168, -130, -129, -244, -249, -241, -123, -156, -248, -128, -143, -220, 6, -221, -172, -117, -144, -127, 6, -223, -218, -250, 6, -131, -122, -119, -242, -164, 6, 6, -217, 6, -165, 6, -166, -137, 6, ]), 'DIV_ASSIGN': ([309, 155, 363, 91, 179, 366, 182, 180, 316, 217, 313, 75, 317, 181, 211, 10
 0, 102, 184, 388, 423, 77, 314, 420, 410, 99, 142, 78, 310, 318, 185, 213, 74, 90, 104, 292, 220, 84, 105, 110, 364, 368, 109, ], [-8, -4, -57, -19, -15, -25, -44, -16, -26, -17, -5, -18, -27, -14, -29, -22, -4, -45, -32, -35, -9, -7, -34, -33, -16, 251, -56, -6, -24, -47, -28, -20, -11, -10, -21, -46, -12, -13, -49, -48, -23, -43, ]), 'PP_DEFINE': ([205, 30, 116, 56, 51, 277, 287, 359, 260, 387, 163, 196, 32, 339, 360, 15, 242, 0, 165, 73, 269, 22, 1, 133, ], [-249, -241, -254, -246, -104, -243, -250, -251, -218, -253, -217, -248, -242, -220, -252, -2, -219, -1, -244, -247, -221, -3, 11, -245, ]), 'LE_OP': ([78, 310, 100, 368, 301, 184, 96, 311, 211, 90, 297, 309, 220, 298, 364, 75, 155, 318, 102, 182, 423, 305, 104, 91, 110, 74, 213, 99, 109, 299, 86, 185, 97, 105, 77, 410, 296, 179, 181, 363, 84, 295, 217, 420, 180, 312, 292, 366, 388, 317, 306, 308, 313, 316, 142, 314, 85, 307, 83, 300, ], [-56, -6, -22, -23, -67, -45, 201, 201, -29, -11, -59, -8, -46, -61, -48, -18, -4, -24, -4
 , -44, -35, -71, -10, -19, -49, -20, -28, -16, -43, -60, -68, -47, -58, -13, -9, -33, -64, -15, -14, -57, -12, -63, -17, -34, -16, 201, -21, -25, -32, -27, -69, -70, -5, -26, -56, -7, -62, -72, -65, -66, ]), '(': ([9, 280, 3, 324, 133, 145, 67, 22, 130, 276, 108, 218, 55, 254, 75, 155, 199, 60, 409, 314, 151, 248, 28, 358, 93, 36, 113, 405, 339, 25, 263, 360, 189, 102, 268, 210, 377, 14, 79, 165, 99, 257, 158, 223, 235, 380, 376, 250, 366, 187, 52, 117, 166, 231, 72, 397, 196, 87, 208, 17, 143, 30, 163, 353, 105, 13, 284, 57, 6, 141, 181, 193, 201, 260, 272, 379, 242, 46, 123, 44, 277, 289, 154, 247, 190, 255, 270, 135, 179, 114, 134, 84, 29, 228, 240, 49, 152, 82, 217, 331, 399, 5, 243, 316, 2, 91, 38, 213, 225, 387, 349, 15, 292, 357, 234, 35, 384, 198, 354, 171, 76, 186, 317, 23, 330, 0, 65, 8, 109, 211, 144, 342, 287, 41, 252, 61, 414, 293, 26, 140, 205, 249, 37, 51, 328, 137, 90, 408, 95, 34, 107, 261, 204, 381, 238, 47, 103, 346, 374, 183, 269, 382, 203, 10, 68, 80, 313, 262,
 371, 413, 159, 94, 20, 32, 259, 221, 164, 176, 367, 73, 344, 153, 267, 197, 58, 372, 194, 230, 340, 393, 161, 338, 127, 207, 219, 136, 7, 104, 378, 195, 150, 215, 56, 100, 258, 180, 266, 369, 192, 1, 359, 45, 147, 402, 191, 188, 253, 415, 246, 332, 18, 74, 309, 256, 264, 31, 43, 370, 392, 174, 251, 116, 202, 39, 310, 396, 216, 318, 139, 4, 69, 16, 81, 227, 224, 394, 406, 12, 77, 348, 368, 42, 245, 200, ], [-124, -136, -111, -199, -245, 257, -137, -3, -170, 137, -53, 72, 72, -94, -18, -4, -42, 137, 137, -7, 72, -100, -109, -134, -41, -129, 72, -234, -220, -120, 137, -252, 72, -4, -238, 72, 137, 16, 183, -244, -16, 137, 137, 327, -172, 137, -196, -91, -25, -145, -156, -168, 137, 231, 137, -231, -248, -148, 72, -130, -209, -241, -217, -135, -13, -133, 72, 16, -122, 137, -14, 72, 72, -218, 137, -215, -219, 70, -173, -178, -243, 72, -213, -99, 72, -97, -228, -210, -15, 221, -223, -12, 16, 72, 137, 54, 266, -52, -17, 327, -229, -131, -239, -26, -107, -19, -164, -28, 221, -253, 381, -2, -2
 1, 16, 231, -128, 137, 72, 72, 16, 183, 137, -27, -117, -195, -1, -138, -123, 215, -29, -226, 137, -250, -108, -96, -110, -233, 72, 54, 137, -249, -98, -132, -104, 72, 137, -11, 137, -51, -125, -55, -227, 72, 137, -169, 72, -54, 137, -197, 137, -221, 137, 72, -119, -179, 186, -5, 137, -194, -235, -211, -50, -167, -242, -225, 221, 16, 72, 137, -247, -216, -224, 137, 72, -222, -201, 72, -171, -240, -198, 272, -236, 231, 72, 137, -212, -174, -10, 137, -147, 264, 137, -246, -22, -237, -16, 137, 72, 72, 16, -251, -176, 137, 409, 72, 72, -90, -230, -93, -155, -126, -20, -8, 137, 137, -127, -175, -200, -202, 72, -92, -254, 72, -121, -6, -232, 137, -24, -208, -163, -177, 16, -146, -154, 72, 137, 137, -118, -9, -214, -23, -112, -95, 304, ]), 'STRUCT': ([15, 17, 140, 64, 221, 277, 238, 186, 39, 359, 12, 165, 283, 26, 360, 87, 170, 18, 227, 278, 37, 3, 27, 31, 123, 59, 54, 66, 32, 72, 237, 116, 231, 38, 242, 10, 51, 67, 117, 1, 235, 5, 353, 22, 260, 134, 205, 36, 269, 230, 133, 280, 356, 6, 28
 6, 73, 25, 327, 137, 279, 169, 56, 339, 65, 358, 0, 4, 35, 387, 196, 47, 60, 130, 9, 13, 172, 20, 49, 81, 30, 332, 23, 58, 163, 167, 52, 34, 168, 287, 2, 8, 28, ], [-2, -130, 33, 33, 33, -243, -169, 33, -121, -251, -118, -244, -144, -166, -252, 33, -141, -126, -154, 33, -132, 33, 33, -127, -173, 33, 33, 33, -242, 33, 33, -254, 33, -164, -219, -119, -104, -137, -168, 33, -172, -131, -135, -3, -218, -223, -249, -129, -221, -171, -245, -136, -143, -122, 33, -247, -120, 33, 33, -142, 33, -246, -220, -138, -134, -1, -163, -128, -253, -248, 33, 33, -170, -124, -133, 33, -167, -165, 33, -241, -155, -117, -222, -217, 33, -156, -125, 33, -250, 33, -123, 33, ]), ',': ([182, 244, 274, 90, 39, 100, 300, 372, 313, 395, 185, 318, 390, 345, 386, 370, 311, 38, 403, 347, 65, 75, 234, 4, 45, 106, 421, 323, 355, 220, 92, 315, 376, 238, 110, 402, 321, 13, 74, 301, 362, 132, 117, 173, 127, 235, 34, 96, 314, 423, 280, 213, 295, 142, 85, 331, 121, 177, 8, 49, 126, 179, 296, 25, 337, 3, 180, 5, 31, 322, 52
 , 112, 366, 422, 119, 398, 330, 388, 77, 383, 101, 41, 67, 316, 416, 162, 86, 374, 128, 123, 417, 364, 230, 102, 68, 305, 281, 307, 9, 35, 352, 20, 306, 332, 61, 122, 308, 26, 78, 6, 401, 275, 392, 43, 389, 297, 418, 28, 317, 343, 148, 184, 358, 368, 97, 400, 129, 155, 36, 42, 104, 419, 291, 124, 2, 64, 312, 410, 353, 282, 175, 292, 333, 10, 335, 391, 181, 62, 299, 89, 115, 232, 17, 285, 404, 12, 18, 44, 303, 385, 341, 334, 211, 83, 298, 37, 63, 351, 393, 223, 69, 363, 105, 412, 7, 130, 23, 84, 302, 109, 91, 420, 71, 309, 319, 217, 273, 350, 227, 99, 371, 233, 324, 320, 160, 310, ], [-44, 262, -116, -11, -121, -22, -66, -201, -5, 262, -47, -24, -31, 262, -150, -200, -75, -164, -37, 262, -138, -18, -191, -163, -176, -78, -36, 262, -152, -46, -84, -77, -196, -169, -49, -39, 262, -133, -20, -67, -256, -115, -168, -255, -186, -172, -125, -73, -7, -35, -136, -28, -63, -56, -62, -193, -161, 262, -123, -165, -182, -15, -64, -120, -183, -111, -16, -131, -127, -85, -156, -86, -25, 411, -159,
  262, -195, -32, -9, -204, -76, -108, -137, -26, 262, -88, -68, -197, 236, -173, -38, -48, -171, -4, -179, -71, -149, -72, -124, -128, 384, -167, -69, -155, -110, 229, -70, -166, -56, -122, -205, -203, -202, -175, -36, -59, 411, -109, -27, -102, 262, -45, -134, -23, -58, -207, 237, -4, -129, -112, -10, -40, -81, -187, -107, -115, -74, -33, -135, -151, 290, -21, -162, -119, -188, -87, -14, -113, -60, -80, -103, -185, -130, 357, 411, -118, -126, -178, -83, -153, -89, -160, -29, -65, -61, -132, 164, -206, -198, -192, -177, -57, -13, -36, -174, -170, -117, -12, -79, -43, -19, -34, -82, -8, -30, -17, -114, 262, -154, -16, -194, -184, -199, 367, -101, -6, ]), 'LONG': ([237, 286, 52, 51, 56, 31, 36, 353, 134, 205, 87, 9, 18, 287, 356, 67, 358, 17, 230, 130, 54, 123, 37, 27, 116, 35, 22, 10, 242, 137, 165, 231, 196, 278, 186, 277, 58, 3, 38, 283, 64, 23, 72, 238, 32, 47, 172, 59, 39, 4, 360, 117, 81, 140, 12, 260, 387, 168, 25, 5, 0, 167, 169, 66, 227, 327, 28, 280, 65, 8, 30, 339, 34, 73,
 13, 279, 26, 6, 133, 359, 269, 49, 221, 170, 15, 20, 332, 235, 60, 2, 163, 1, ], [18, 18, -156, -104, -246, -127, -129, -135, -223, -249, 18, -124, -126, -250, -143, -137, -134, -130, -171, -170, 18, -173, -132, 18, -254, -128, -3, -119, -219, 18, -244, 18, -248, 18, 18, -243, -222, 18, -164, -144, 18, -117, 18, -169, -242, 18, 18, 18, -121, -163, -252, -168, 18, 18, -118, -218, -253, 18, -120, -131, -1, 18, 18, 18, -154, 18, 18, -136, -138, -123, -241, -220, -125, -247, -133, -142, -166, -122, -245, -251, -221, -165, 18, -141, -2, -167, -155, -172, 18, 18, -217, 18, ]), 'ELLIPSIS': ([237, ], [336, ]), '<': ([423, 217, 301, 364, 109, 366, 313, 420, 368, 295, 85, 77, 102, 305, 292, 388, 96, 90, 184, 314, 312, 181, 104, 363, 316, 297, 299, 317, 155, 99, 213, 142, 91, 105, 179, 309, 78, 75, 410, 310, 182, 296, 306, 97, 185, 86, 298, 211, 83, 311, 300, 100, 308, 307, 318, 74, 84, 220, 180, 110, ], [-35, -17, -67, -48, -43, -25, -5, -34, -23, -63, -62, -9, -4, -71, -21, -32, 202, -11, -4
 5, -7, 202, -14, -10, -57, -26, -59, -60, -27, -4, -16, -28, -56, -19, -13, -15, -8, -56, -18, -33, -6, -44, -64, -69, -58, -47, -68, -61, -29, -65, 202, -66, -22, -70, -72, -24, -20, -12, -46, -16, -49, ]), 'GOTO': ([136, 394, 263, 153, 415, 399, 338, 414, 163, 268, 269, 260, 261, 51, 243, 258, 135, 159, 405, 60, 344, 147, 270, 58, 413, 240, 140, 408, 406, 346, 267, 348, 396, 259, 134, 397, 154, 242, 340, 378, 144, 143, 380, 379, 382, 339, 158, 139, ], [-212, 138, 138, -224, -230, -229, -236, -233, -217, -238, -221, -218, -227, -104, -239, -237, -210, -211, -234, 138, -216, 138, -228, -222, -235, 138, 138, 138, 138, 138, 138, -214, -232, -225, -223, -231, -213, -219, -240, 138, -226, -209, 138, -215, 138, -220, 138, -208, ]), 'ENUM': ([59, 3, 8, 327, 130, 72, 10, 260, 172, 169, 332, 13, 231, 9, 73, 279, 167, 163, 356, 81, 230, 137, 116, 47, 238, 269, 227, 133, 117, 37, 12, 170, 221, 237, 34, 87, 2, 360, 280, 66, 58, 168, 242, 277, 65, 23, 39, 28, 20, 22, 196, 5, 18, 32, 15, 31, 278
 , 1, 17, 205, 283, 123, 52, 25, 51, 6, 67, 30, 358, 35, 287, 339, 235, 60, 36, 387, 38, 54, 0, 165, 26, 64, 56, 359, 140, 353, 4, 134, 186, 49, 27, 286, ], [24, 24, -123, 24, -170, 24, -119, -218, 24, 24, -155, -133, 24, -124, -247, -142, 24, -217, -143, 24, -171, 24, -254, 24, -169, -221, -154, -245, -168, -132, -118, -141, 24, 24, -125, 24, 24, -252, -136, 24, -222, 24, -219, -243, -138, -117, -121, 24, -167, -3, -248, -131, -126, -242, -2, -127, 24, 24, -130, -249, -144, -173, -156, -120, -104, -122, -137, -241, -134, -128, -250, -220, -172, 24, -129, -253, -164, 24, -1, -244, -166, 24, -246, -251, 24, -135, -163, -223, 24, -165, 24, 24, ]), 'PERIOD': ([104, 309, 84, 109, 105, 91, 90, 179, 99, 213, 313, 77, 211, 155, 75, 100, 366, 310, 292, 368, 180, 217, 318, 317, 314, 181, 316, 102, 74, ], [-10, -8, -12, 212, -13, -19, -11, -15, -16, -28, -5, -9, -29, -4, -18, -22, -25, -6, -21, -23, -16, -17, -24, -27, -7, -14, -26, -4, -20, ]), 'PP_END_DEFINE': ([310, 306, 311, 100, 36, 101,
 112, 91, 361, 115, 74, 292, 88, 114, 371, 307, 84, 289, 280, 65, 83, 331, 17, 318, 5, 330, 391, 308, 305, 316, 6, 368, 364, 110, 358, 195, 388, 96, 97, 44, 312, 332, 303, 315, 86, 322, 180, 302, 222, 288, 353, 223, 43, 291, 67, 220, 179, 370, 317, 7, 366, 423, 182, 181, 31, 314, 4, 69, 106, 81, 71, 18, 372, 35, 309, 37, 217, 109, 313, 8, 75, 376, 187, 105, 393, 363, 52, 48, 211, 301, 298, 102, 184, 38, 185, 45, 77, 13, 68, 324, 227, 392, 420, 174, 104, 213, 225, 9, 90, 297, 410, 300, 47, 99, 374, 89, 85, 296, 92, 87, 34, 299, 78, 98, 295, ], [-6, -69, -75, -22, -129, -76, -86, -19, 387, -103, -20, -21, 196, -189, -194, -72, -12, 360, -136, -138, -65, -193, -130, -24, -131, -195, -87, -70, -71, -26, -122, -23, -48, -49, -134, -147, -32, -73, -58, -178, -74, -155, -83, -77, -68, -85, -16, -79, -190, 359, -135, -192, -175, -81, -137, -46, -15, -200, -27, -174, -25, -35, -44, -14, -127, -7, -163, -177, -78, -146, -82, -126, -201, -128, -8, -132, -17, -43, -5, -123, -18, -196, -145, -13,
  -198, -57, -156, 116, -29, -67, -61, -4, -45, -164, -47, -176, -9, -133, -179, -199, -154, -202, -34, 287, -10, -28, -191, -124, -11, -59, -33, -66, 73, -16, -197, -80, -62, -64, -84, -148, -125, -60, -56, 205, -63, ]), 'LEFT_OP': ([423, 142, 110, 299, 309, 308, 77, 292, 306, 75, 295, 305, 388, 86, 179, 217, 91, 364, 155, 220, 180, 105, 310, 213, 410, 104, 366, 90, 313, 211, 317, 97, 100, 316, 182, 84, 85, 298, 420, 296, 318, 314, 363, 185, 83, 184, 368, 74, 300, 307, 99, 181, 102, 109, 297, 301, 78, ], [-35, -56, -49, -60, -8, 193, -9, -21, 193, -18, -63, 193, -32, 193, -15, -17, -19, -48, -4, -46, -16, -13, -6, -28, -33, -10, -25, -11, -5, -29, -27, -58, -22, -26, -44, -12, -62, -61, -34, -64, -24, -7, -57, -47, -65, -45, -23, -20, -66, 193, -16, -14, -4, -43, -59, -67, -56, ]), 'DOUBLE': ([6, 278, 221, 4, 2, 27, 18, 286, 279, 186, 0, 358, 1, 10, 116, 327, 35, 140, 227, 37, 65, 167, 8, 9, 81, 353, 54, 73, 28, 280, 47, 133, 360, 66, 170, 20, 36, 58, 230, 64, 283, 231, 168, 169, 67
 , 56, 39, 72, 196, 130, 238, 12, 13, 31, 137, 242, 5, 277, 134, 387, 49, 172, 22, 3, 23, 332, 25, 38, 60, 356, 165, 15, 205, 237, 87, 30, 339, 34, 52, 59, 163, 269, 287, 26, 235, 32, 51, 260, 117, 17, 123, 359, ], [-122, 35, 35, -163, 35, 35, -126, 35, -142, 35, -1, -134, 35, -119, -254, 35, -128, 35, -154, -132, -138, 35, -123, -124, 35, -135, 35, -247, 35, -136, 35, -245, -252, 35, -141, -167, -129, -222, -171, 35, -144, 35, 35, 35, -137, -246, -121, 35, -248, -170, -169, -118, -133, -127, 35, -219, -131, -243, -223, -253, -165, 35, -3, 35, -117, -155, -120, -164, 35, -143, -244, -2, -249, 35, 35, -241, -220, -125, -156, 35, -217, -221, -250, -166, -172, -242, -104, -218, -168, -130, -173, -251, ]), 'INC_OP': ([210, 189, 255, 264, 159, 378, 188, 348, 366, 397, 245, 270, 408, 328, 102, 252, 317, 399, 316, 174, 224, 213, 242, 267, 191, 99, 380, 109, 140, 134, 415, 284, 163, 192, 257, 181, 256, 249, 77, 381, 346, 396, 262, 55, 84, 215, 94, 135, 394, 384, 247, 217, 208, 377, 379, 166,
  216, 74, 113, 259, 183, 91, 139, 251, 276, 155, 344, 180, 137, 413, 151, 266, 80, 190, 340, 405, 219, 248, 313, 47, 76, 141, 207, 153, 254, 79, 369, 338, 158, 318, 198, 197, 105, 204, 409, 269, 243, 60, 268, 176, 100, 202, 194, 143, 258, 51, 211, 90, 240, 144, 414, 228, 293, 107, 201, 367, 246, 179, 310, 58, 289, 339, 103, 218, 368, 382, 272, 261, 75, 104, 260, 253, 147, 309, 186, 72, 203, 82, 342, 136, 108, 250, 406, 154, 314, 193, 263, 292, 354, 95, ], [76, 76, -97, 76, -211, 76, 76, -214, -25, -231, -95, -228, 76, 76, -4, -96, -27, -229, -26, 76, 76, -28, -219, 76, 76, -16, 76, 213, 76, -223, -230, 76, -217, 76, 76, -14, 76, -98, -9, 76, 76, -232, 76, 76, -12, 76, -50, -210, 76, 76, -99, -17, 76, 76, -215, 76, 76, -20, 76, -225, 76, -19, -208, -92, 76, -4, -216, -16, 76, -235, 76, 76, 76, 76, -240, -234, 76, -100, -5, 76, 76, 76, 76, -224, -94, 76, 76, -236, 76, -24, 76, 76, -13, 76, 76, -221, -239, 76, -238, 76, -22, 76, 76, -209, -237, -104, -29, -11, 76, -226, -233, 76, 76, -
 55, 76, 76, -93, -15, -6, -222, 76, -220, -54, 76, -23, 76, 76, -227, -18, -10, -218, -90, 76, -8, 76, 76, 76, -52, 76, -212, -53, -91, 76, -213, -7, 76, 76, -21, 76, -51, ]), '|': ([316, 109, 105, 420, 104, 155, 314, 213, 301, 297, 317, 89, 296, 182, 85, 308, 309, 78, 305, 423, 211, 368, 300, 388, 100, 313, 96, 86, 97, 184, 185, 74, 315, 180, 311, 307, 292, 84, 366, 363, 77, 99, 181, 299, 142, 364, 303, 75, 310, 295, 306, 291, 91, 179, 102, 298, 83, 410, 318, 90, 220, 217, 110, 106, 312, 101, 302, 71, ], [-26, -43, -13, -34, -10, -4, -7, -28, -67, -59, -27, -80, -64, -44, -62, -70, -8, -56, -71, -35, -29, -23, -66, -32, -22, -5, -73, -68, -58, -45, -47, -20, -77, -16, -75, -72, -21, -12, -25, -57, -9, -16, -14, -60, -56, -48, 176, -18, -6, -63, -69, -81, -19, -15, -4, -61, -65, -33, -24, -11, -46, -17, -49, -78, -74, -76, -79, 176, ]), 'NE_OP': ([109, 364, 105, 213, 182, 297, 420, 104, 78, 317, 410, 313, 85, 155, 309, 74, 296, 86, 316, 101, 308, 97, 185, 423, 368, 300, 388, 100, 96
 , 184, 180, 211, 292, 305, 77, 84, 142, 311, 181, 307, 301, 310, 363, 99, 306, 298, 318, 90, 314, 75, 299, 110, 295, 91, 217, 179, 220, 83, 315, 102, 366, 312, ], [-43, -48, -13, -28, -44, -59, -34, -10, -56, -27, -33, -5, -62, -4, -8, -20, -64, -68, -26, 207, -70, -58, -47, -35, -23, -66, -32, -22, -73, -45, -16, -29, -21, -71, -9, -12, -56, -75, -14, -72, -67, -6, -57, -16, -69, -61, -24, -11, -7, -18, -60, -49, -63, -19, -17, -15, -46, -65, 207, -4, -25, -74, ]), 'SHORT': ([10, 81, 51, 36, 13, 339, 26, 27, 8, 30, 387, 196, 356, 230, 12, 231, 278, 260, 163, 54, 123, 67, 1, 170, 286, 73, 287, 242, 18, 15, 47, 0, 87, 6, 221, 34, 3, 37, 279, 137, 269, 238, 283, 327, 56, 58, 277, 31, 17, 59, 72, 205, 237, 9, 38, 20, 235, 169, 23, 167, 227, 186, 130, 168, 133, 165, 134, 49, 332, 22, 116, 35, 4, 353, 32, 64, 66, 140, 39, 25, 52, 280, 2, 28, 5, 172, 117, 358, 359, 65, 60, 360, ], [-119, 9, -104, -129, -133, -220, -166, 9, -123, -241, -253, -248, -143, -171, -118, 9, 9, -218, -217, 9, -17
 3, -137, 9, -141, 9, -247, -250, -219, -126, -2, 9, -1, 9, -122, 9, -125, 9, -132, -142, 9, -221, -169, -144, 9, -246, -222, -243, -127, -130, 9, 9, -249, 9, -124, -164, -167, -172, 9, -117, 9, -154, 9, -170, 9, -245, -244, -223, -165, -155, -3, -254, -128, -163, -135, -242, 9, 9, 9, -121, -120, -156, -136, 9, 9, -131, 9, -168, -134, -251, -138, 9, -252, ]), 'CONSTANT': ([55, 257, 163, 47, 144, 328, 263, 190, 197, 140, 399, 251, 176, 266, 354, 76, 203, 367, 409, 381, 137, 284, 378, 58, 192, 240, 174, 408, 380, 270, 51, 94, 154, 267, 369, 151, 253, 260, 259, 72, 250, 191, 258, 82, 242, 208, 248, 183, 202, 228, 60, 276, 194, 153, 166, 193, 136, 224, 159, 269, 158, 80, 396, 339, 204, 216, 377, 261, 107, 198, 346, 384, 188, 406, 338, 201, 141, 340, 147, 348, 186, 249, 215, 382, 219, 139, 207, 414, 394, 254, 262, 218, 247, 256, 344, 246, 415, 210, 143, 245, 413, 289, 135, 113, 79, 379, 252, 189, 272, 134, 293, 405, 255, 268, 264, 342, 103, 397, 243, 95, 108, ], [77, 77, -217, 77, -226, 7
 7, 77, 77, 77, 77, -229, -92, 77, 77, 77, 77, 77, 77, 77, 77, 77, 77, 77, -222, 77, 77, 77, 77, 77, -228, -104, -50, -213, 77, 77, 77, -90, -218, -225, 77, -91, 77, -237, -52, -219, 77, -100, 77, 77, 77, 77, 77, 77, -224, 77, 77, -212, 77, -211, -221, 77, 77, -232, -220, 77, 77, 77, -227, -55, 77, 77, 77, 77, 77, -236, 77, 77, -240, 77, -214, 77, -98, 77, 77, 77, -208, 77, -233, 77, -94, 77, 77, -99, 77, -216, -93, -230, 77, -209, -95, -235, 77, -210, 77, 77, -215, -96, 77, 77, -223, 77, -234, -97, -238, 77, 77, -54, -231, -239, -51, -53, ]), 'DEC_OP': ([397, 192, 190, 252, 258, 245, 109, 268, 90, 219, 246, 228, 211, 75, 250, 95, 409, 240, 249, 113, 270, 405, 256, 94, 310, 55, 316, 313, 100, 47, 276, 198, 269, 254, 259, 99, 354, 263, 314, 140, 379, 134, 208, 257, 266, 74, 108, 144, 76, 155, 215, 255, 210, 166, 193, 158, 413, 253, 176, 309, 243, 340, 396, 204, 186, 135, 213, 292, 247, 203, 348, 179, 107, 378, 242, 163, 394, 139, 218, 217, 79, 328, 384, 201, 194, 105, 143, 154, 82, 28
 4, 382, 137, 414, 260, 181, 103, 147, 191, 174, 262, 102, 408, 51, 202, 58, 267, 369, 289, 91, 72, 261, 399, 344, 338, 159, 248, 272, 264, 104, 293, 342, 188, 197, 153, 180, 381, 380, 84, 346, 207, 317, 224, 251, 151, 339, 216, 80, 367, 318, 406, 415, 189, 368, 366, 377, 141, 136, 77, 183, 60, ], [-231, 79, 79, -96, -237, -95, 211, -238, -11, 79, -93, 79, -29, -18, -91, -51, 79, 79, -98, 79, -228, -234, 79, -50, -6, 79, -26, -5, -22, 79, 79, 79, -221, -94, -225, -16, 79, 79, -7, 79, -215, -223, 79, 79, 79, -20, -53, -226, 79, -4, 79, -97, 79, 79, 79, 79, -235, -90, 79, -8, -239, -240, -232, 79, 79, -210, -28, -21, -99, 79, -214, -15, -55, 79, -219, -217, 79, -208, 79, -17, 79, 79, 79, 79, 79, -13, -209, -213, -52, 79, 79, 79, -233, -218, -14, -54, 79, 79, 79, 79, -4, 79, -104, 79, -222, 79, 79, 79, -19, 79, -227, -229, -216, -236, -211, -100, 79, 79, -10, 79, 79, 79, 79, -224, -16, 79, 79, -12, 79, 79, -27, 79, -92, 79, -220, 79, 79, 79, -24, 79, -230, 79, -23, -25, 79, 79, -212, -9
 , 79, 79, ]), 'STATIC': ([358, 130, 123, 49, 360, 327, 117, 37, 28, 25, 140, 3, 235, 359, 30, 205, 0, 237, 230, 6, 58, 339, 9, 27, 31, 12, 4, 8, 22, 39, 35, 1, 134, 56, 242, 387, 18, 51, 238, 32, 13, 64, 38, 36, 163, 59, 10, 60, 5, 260, 2, 287, 167, 221, 20, 52, 332, 227, 73, 17, 15, 280, 54, 196, 26, 116, 23, 67, 269, 65, 277, 353, 34, 133, 165, 231, ], [-134, -170, -173, -165, -252, 10, -168, -132, 10, -120, 10, 10, -172, -251, -241, -249, -1, 10, -171, -122, -222, -220, -124, 10, -127, -118, -163, -123, -3, -121, -128, 10, -223, -246, -219, -253, -126, -104, -169, -242, -133, 10, -164, -129, -217, 10, -119, 10, -131, -218, 10, -250, 10, 10, -167, -156, -155, -154, -247, -130, -2, -136, 10, -248, -166, -254, -117, -137, -221, -138, -243, -135, -125, -245, -244, 10, ]), 'EQ_OP': ([100, 308, 311, 314, 101, 301, 185, 423, 99, 307, 90, 142, 297, 77, 410, 220, 96, 78, 110, 295, 97, 298, 84, 184, 74, 363, 104, 83, 312, 299, 318, 315, 213, 366, 182, 305, 292, 364, 309, 300, 86, 316, 155,
  180, 306, 109, 85, 388, 296, 313, 105, 91, 181, 179, 211, 310, 102, 217, 420, 317, 368, 75, ], [-22, -70, -75, -7, 208, -67, -47, -35, -16, -72, -11, -56, -59, -9, -33, -46, -73, -56, -49, -63, -58, -61, -12, -45, -20, -57, -10, -65, -74, -60, -24, 208, -28, -25, -44, -71, -21, -48, -8, -66, -68, -26, -4, -16, -69, -43, -62, -32, -64, -5, -13, -19, -14, -15, -29, -6, -4, -17, -34, -27, -23, -18, ]), 'SIZEOF': ([80, 203, 192, 268, 247, 107, 284, 191, 396, 219, 253, 249, 339, 95, 415, 406, 381, 60, 269, 346, 190, 264, 243, 82, 263, 259, 207, 151, 158, 405, 163, 147, 58, 197, 262, 141, 55, 218, 266, 76, 137, 51, 293, 204, 188, 270, 245, 79, 380, 193, 378, 72, 342, 134, 240, 413, 379, 255, 246, 369, 338, 367, 408, 143, 103, 144, 250, 414, 377, 153, 409, 272, 251, 113, 397, 139, 216, 94, 267, 210, 194, 215, 166, 384, 189, 140, 260, 183, 174, 108, 394, 276, 201, 136, 399, 261, 256, 252, 328, 135, 248, 242, 154, 254, 186, 159, 257, 208, 340, 47, 354, 198, 289, 228, 258, 224, 382, 348, 176
 , 344, 202, ], [80, 80, 80, -238, -99, -55, 80, 80, -232, 80, -90, -98, -220, -51, -230, 80, 80, 80, -221, 80, 80, 80, -239, -52, 80, -225, 80, 80, 80, -234, -217, 80, -222, 80, 80, 80, 80, 80, 80, 80, 80, -104, 80, 80, 80, -228, -95, 80, 80, 80, 80, 80, 80, -223, 80, -235, -215, -97, -93, 80, -236, 80, 80, -209, -54, -226, -91, -233, 80, -224, 80, 80, -92, 80, -231, -208, 80, -50, 80, 80, 80, 80, 80, 80, 80, 80, -218, 80, 80, -53, 80, 80, 80, -212, -229, -227, 80, -96, 80, -210, -100, -219, -213, -94, 80, -211, 80, 80, -240, 80, 80, 80, 80, 80, -237, 80, 80, -214, 80, -216, 80, ]), '+': ([208, 109, 289, 245, 191, 60, 110, 405, 147, 144, 293, 252, 183, 269, 409, 268, 217, 318, 354, 100, 94, 105, 192, 246, 314, 83, 295, 243, 317, 414, 310, 248, 420, 179, 107, 264, 363, 316, 298, 366, 377, 276, 134, 301, 79, 99, 136, 257, 256, 166, 55, 84, 140, 190, 253, 261, 260, 339, 186, 213, 210, 263, 266, 182, 193, 348, 378, 368, 242, 142, 408, 309, 51, 394, 215, 296, 197, 284, 249, 113, 153, 299
 , 155, 340, 396, 204, 344, 218, 254, 228, 194, 159, 211, 85, 75, 154, 82, 135, 313, 220, 247, 240, 181, 180, 97, 74, 369, 262, 47, 207, 384, 258, 381, 76, 103, 216, 90, 80, 143, 388, 415, 379, 410, 338, 342, 267, 141, 270, 78, 72, 201, 300, 108, 91, 176, 399, 382, 406, 292, 189, 297, 188, 95, 203, 77, 272, 413, 163, 380, 104, 174, 102, 397, 139, 346, 328, 202, 224, 251, 151, 259, 185, 184, 137, 58, 367, 423, 198, 364, 158, 255, 219, 250, ], [82, -43, 82, -95, 82, 82, -49, -234, 82, -226, 82, -96, 82, -221, 82, -238, -17, -24, 82, -22, -50, -13, 82, -93, -7, 188, -63, -239, -27, -233, -6, -100, -34, -15, -55, 82, -57, -26, -61, -25, 82, 82, -223, 188, 82, -16, -212, 82, 82, 82, 82, -12, 82, 82, -90, -227, -218, -220, 82, -28, 82, 82, 82, -44, 82, -214, 82, -23, -219, -56, 82, -8, -104, 82, 82, -64, 82, 82, -98, 82, -224, -60, -4, -240, -232, 82, -216, 82, -94, 82, 82, -211, -29, -62, -18, -213, -52, -210, -5, -46, -99, 82, -14, -16, -58, -20, 82, 82, 82, 82, 82, -237, 82, 82, -54, 82
 , -11, 82, -209, -32, -230, -215, -33, -236, 82, 82, 82, -228, -56, 82, 82, 188, -53, -19, 82, -229, 82, 82, -21, 82, -59, 82, -51, 82, -9, 82, -235, -217, 82, -10, 82, -4, -231, -208, 82, 82, 82, 82, -92, 82, -225, -47, -45, 82, -222, 82, -35, 82, -48, 82, -97, 82, -91, ]), 'UNSIGNED': ([36, 235, 52, 8, 133, 18, 66, 287, 35, 170, 20, 49, 221, 205, 358, 22, 2, 10, 353, 277, 242, 231, 73, 140, 64, 67, 59, 39, 87, 134, 54, 196, 356, 137, 186, 283, 47, 3, 359, 165, 5, 60, 38, 227, 230, 116, 360, 4, 278, 65, 37, 32, 28, 12, 172, 23, 81, 387, 167, 17, 327, 13, 130, 27, 58, 168, 51, 30, 31, 0, 169, 117, 56, 279, 1, 237, 339, 238, 280, 260, 26, 286, 6, 72, 34, 123, 25, 163, 269, 9, 332, 15, ], [-129, -172, -156, -123, -245, -126, 17, -250, -128, -141, -167, -165, 17, -249, -134, -3, 17, -119, -135, -243, -219, 17, -247, 17, 17, -137, 17, -121, 17, -223, 17, -248, -143, 17, 17, -144, 17, 17, -251, -244, -131, 17, -164, -154, -171, -254, -252, -163, 17, -138, -132, -242, 17, -118, 17, -117,
 17, -253, 17, -130, 17, -133, -170, 17, -222, 17, -104, -241, -127, -1, 17, -168, -246, -142, 17, 17, -220, -169, -136, -218, -166, 17, -122, 17, -125, -173, -120, -217, -221, -124, -155, -2, ]), '/': ([84, 99, 155, 180, 77, 90, 368, 142, 388, 211, 75, 109, 217, 292, 313, 364, 91, 100, 423, 317, 78, 314, 295, 410, 213, 297, 102, 105, 110, 363, 184, 104, 309, 316, 318, 298, 97, 185, 420, 181, 310, 74, 179, 296, 299, 220, 182, 85, 366, ], [-12, -16, -4, -16, -9, -11, -23, -56, -32, -29, -18, -43, -17, -21, -5, -48, -19, -22, -35, -27, -56, -7, 192, -33, -28, -59, -4, -13, -49, -57, -45, -10, -8, -26, -24, -61, -58, -47, -34, -14, -6, -20, -15, 192, -60, -46, -44, 192, -25, ]), ';': ([42, 130, 90, 285, 316, 341, 38, 77, 63, 401, 67, 312, 342, 134, 301, 5, 182, 75, 4, 348, 52, 309, 397, 280, 83, 12, 17, 240, 303, 60, 317, 148, 74, 405, 162, 25, 263, 298, 2, 385, 311, 257, 158, 185, 306, 241, 99, 28, 184, 136, 10, 235, 410, 353, 36, 302, 299, 243, 117, 261, 84, 144, 260, 35, 220, 49, 380
 , 181, 64, 269, 339, 268, 26, 57, 242, 105, 6, 160, 34, 413, 135, 296, 414, 143, 87, 3, 244, 382, 19, 292, 155, 29, 115, 132, 217, 146, 163, 37, 106, 346, 8, 123, 408, 211, 140, 85, 310, 154, 171, 65, 343, 153, 338, 391, 91, 386, 179, 364, 314, 230, 399, 156, 363, 394, 187, 61, 238, 275, 109, 407, 180, 300, 41, 388, 270, 89, 18, 100, 379, 308, 396, 322, 97, 213, 273, 96, 23, 58, 71, 159, 81, 318, 281, 378, 142, 104, 258, 51, 102, 139, 62, 355, 112, 110, 147, 332, 20, 195, 420, 157, 297, 315, 13, 340, 274, 344, 291, 305, 78, 9, 358, 282, 313, 239, 86, 415, 31, 259, 295, 92, 307, 423, 39, 383, 267, 141, 406, 368, 227, 101, 366, ], [-112, -170, -11, 356, -26, -89, -164, -9, -106, -205, -137, -74, 144, -223, -67, -131, -44, -18, -163, -214, -156, -8, -231, -136, -65, -118, -130, 144, -83, 144, -27, 261, -20, -234, -88, -120, 144, -61, -107, -153, -75, 144, 144, -47, -69, 270, -16, -109, -45, -212, -119, -172, -33, -135, -129, -79, -60, -239, -168, -227, -12, -226, -218, -128, -46, -165,
  144, -14, -115, -221, -220, -238, -166, -105, -219, -13, -122, -101, -125, -235, -210, -64, -233, -209, -148, -111, 340, 144, 51, -21, -4, -105, -103, -115, -17, 258, -217, -132, -78, 144, -123, -173, 144, -29, 144, -62, -6, -213, 283, -138, -102, -224, -236, -87, -19, -150, -15, -48, -7, -171, -229, 268, -57, 144, -145, -110, -169, -203, -43, 414, -16, -66, -108, -32, -228, -80, -126, -22, -215, -70, -232, -85, -58, -28, -114, -73, -117, -222, -82, -211, -146, -24, -149, 144, -56, -10, -237, -104, -4, -208, -113, -152, -86, -49, 144, -155, -167, -147, -34, 270, -59, -77, -133, -240, -116, -216, -81, -71, -56, -124, -134, -151, -5, 338, -68, -230, -127, -225, -63, -84, -72, -35, -121, -204, 144, 243, 144, -23, -154, -76, -25, ]), '?': ([85, 155, 302, 77, 99, 91, 410, 90, 388, 100, 211, 96, 92, 217, 179, 101, 97, 420, 423, 89, 303, 317, 363, 110, 184, 313, 74, 180, 309, 291, 102, 305, 112, 185, 368, 301, 86, 297, 181, 142, 104, 78, 318, 314, 310, 306, 315, 84, 298, 312, 300, 220, 18
 2, 311, 307, 83, 366, 299, 75, 106, 295, 109, 316, 292, 105, 296, 364, 308, 322, 213, 71, ], [-62, -4, -79, -9, -16, -19, -33, -11, -32, -22, -29, -73, -84, -17, -15, -76, -58, -34, -35, -80, -83, -27, -57, -49, -45, -5, -20, -16, -8, -81, -4, -71, 219, -47, -23, -67, -68, -59, -14, -56, -10, -56, -24, -7, -6, -69, -77, -12, -61, -74, -66, -46, -44, -75, -72, -65, -25, -60, -18, -78, -63, -43, -26, -21, -13, -64, -48, -70, -85, -28, -82, ]), '$end': ([73, 339, 15, 165, 51, 359, 1, 0, 133, 387, 287, 116, 56, 32, 22, 277, 269, 242, 260, 196, 360, 30, 205, 163, ], [-247, -220, -2, -244, -104, -251, 0, -1, -245, -253, -250, -254, -246, -242, -3, -243, -221, -219, -218, -248, -252, -241, -249, -217, ]), 'FOR': ([340, 60, 135, 144, 268, 153, 143, 139, 338, 396, 378, 147, 346, 58, 397, 136, 260, 413, 394, 406, 339, 159, 134, 348, 154, 242, 51, 263, 259, 379, 158, 267, 344, 405, 408, 380, 163, 140, 240, 382, 261, 243, 415, 269, 399, 258, 270, 414, ], [-240, 145, -210, -226, -238, -224, -209
 , -208, -236, -232, 145, 145, 145, -222, -231, -212, -218, -235, 145, 145, -220, -211, -223, -214, -213, -219, -104, 145, -225, -215, 145, 145, -216, -234, 145, 145, -217, 145, 145, 145, -227, -239, -230, -221, -229, -237, -228, -233, ]), 'UNION': ([65, 242, 238, 37, 278, 287, 260, 13, 3, 23, 81, 137, 58, 387, 30, 34, 186, 56, 1, 140, 51, 66, 205, 38, 130, 116, 170, 269, 227, 64, 172, 72, 22, 17, 36, 286, 12, 280, 332, 39, 230, 353, 163, 0, 8, 60, 27, 35, 169, 5, 123, 231, 67, 10, 52, 20, 221, 47, 327, 32, 15, 358, 283, 73, 18, 26, 59, 167, 134, 235, 49, 168, 6, 9, 4, 359, 339, 237, 31, 277, 279, 360, 25, 133, 356, 165, 2, 87, 54, 28, 196, 117, ], [-138, -219, -169, -132, 21, -250, -218, -133, 21, -117, 21, 21, -222, -253, -241, -125, 21, -246, 21, 21, -104, 21, -249, -164, -170, -254, -141, -221, -154, 21, 21, 21, -3, -130, -129, 21, -118, -136, -155, -121, -171, -135, -217, -1, -123, 21, 21, -128, 21, -131, -173, 21, -137, -119, -156, -167, 21, 21, 21, -242, -2, -134, -144, -247,
 -126, -166, 21, 21, -223, -172, -165, 21, -122, -124, -163, -251, -220, 21, -127, -243, -142, -252, -120, -245, -143, -244, 21, 21, 21, 21, -248, -168, ]), 'ELSE': ([340, 269, 339, 258, 399, 159, 413, 136, 139, 414, 261, 415, 243, 397, 396, 163, 135, 348, 154, 344, 268, 338, 242, 144, 270, 405, 260, 143, 379, ], [-240, -221, -220, -237, 408, -211, -235, -212, -208, -233, -227, -230, -239, -231, -232, -217, -210, -214, -213, -216, -238, -236, -219, -226, -228, -234, -218, -209, -215, ]), '[': ([316, 376, 102, 313, 7, 44, 105, 4, 332, 104, 324, 25, 37, 353, 8, 13, 155, 2, 317, 81, 41, 18, 45, 117, 65, 231, 238, 43, 84, 3, 331, 38, 221, 49, 393, 318, 100, 34, 127, 74, 368, 20, 99, 77, 195, 69, 36, 370, 12, 28, 314, 109, 39, 371, 31, 330, 366, 234, 10, 180, 213, 5, 35, 309, 280, 292, 358, 374, 225, 90, 75, 223, 67, 114, 217, 87, 392, 52, 6, 17, 187, 61, 310, 91, 181, 9, 179, 26, 123, 68, 211, 372, 235, 42, 23, 130, 230, 227, ], [-26, -196, -4, -5, -174, -178, -13, -163, -155, -10, -199,
  -120, -132, -135, -123, -133, -4, -107, -27, -146, -108, -126, -176, -168, -138, 224, -169, -175, -12, -111, 328, -164, 224, 55, -198, -24, -22, -125, 224, -20, -23, -167, -16, -9, -147, -177, -129, -200, -118, -109, -7, 216, -121, -194, -127, -195, -25, 224, -119, -16, -28, -131, -128, -8, -136, -21, -134, -197, 224, -11, -18, 328, -137, 224, -17, -148, -202, -156, -122, -130, -145, -110, -6, -19, -14, -124, -15, 55, -173, -179, -29, -201, -172, -112, -117, -170, -171, -154, ]), 'OR_OP': ([96, 77, 86, 312, 142, 363, 97, 155, 316, 410, 305, 110, 184, 368, 314, 84, 104, 309, 211, 318, 307, 83, 185, 423, 292, 310, 179, 366, 78, 91, 71, 100, 89, 303, 297, 101, 180, 220, 420, 92, 85, 105, 74, 90, 302, 298, 102, 388, 308, 301, 313, 75, 109, 217, 181, 364, 295, 291, 300, 112, 317, 322, 296, 213, 315, 99, 306, 299, 106, 311, 182, ], [-73, -9, -68, -74, -56, -57, -58, -4, -26, -33, -71, -49, -45, -23, -7, -12, -10, -8, -29, -24, -72, -65, -47, -35, -21, -6, -15, -25, -56, -19, -82, -22, -8
 0, -83, -59, -76, -16, -46, -34, -84, -62, -13, -20, -11, -79, -61, -4, -32, -70, -67, -5, -18, -43, -17, -14, -48, -63, -81, -66, 218, -27, -85, -64, -28, -77, -16, -69, -60, -78, -75, -44, ]), 'SUB_ASSIGN': ([363, 105, 77, 318, 292, 366, 78, 213, 423, 109, 317, 368, 313, 211, 388, 185, 91, 314, 104, 142, 102, 310, 410, 420, 184, 99, 182, 316, 309, 179, 364, 75, 110, 74, 220, 180, 181, 90, 84, 155, 100, 217, ], [-57, -13, -9, -24, -21, -25, -56, -28, -35, -43, -27, -23, -5, -29, -32, -47, -19, -7, -10, 245, -4, -6, -33, -34, -45, -16, -44, -26, -8, -15, -48, -18, -49, -20, -46, -16, -14, -11, -12, -4, -22, -17, ]), 'XOR_ASSIGN': ([366, 102, 182, 91, 78, 388, 100, 309, 179, 185, 213, 420, 142, 313, 105, 292, 181, 74, 310, 104, 99, 423, 220, 410, 110, 84, 217, 77, 184, 316, 75, 180, 155, 109, 317, 368, 364, 90, 363, 314, 318, 211, ], [-25, -4, -44, -19, -56, -32, -22, -8, -15, -47, -28, -34, 247, -5, -13, -21, -14, -20, -6, -10, -16, -35, -46, -33, -49, -12, -17, -9, -45, -26, -18, -
 16, -4, -43, -27, -23, -48, -11, -57, -7, -24, -29, ]), 'INT': ([2, 137, 47, 32, 358, 27, 59, 140, 5, 117, 65, 260, 227, 72, 221, 3, 9, 81, 283, 360, 332, 359, 18, 1, 28, 230, 279, 66, 163, 8, 30, 116, 170, 64, 280, 231, 238, 37, 13, 20, 133, 0, 58, 34, 73, 52, 54, 186, 56, 167, 169, 196, 205, 38, 49, 67, 287, 277, 36, 15, 327, 12, 387, 356, 339, 26, 39, 22, 51, 134, 235, 353, 165, 60, 130, 87, 168, 31, 172, 6, 17, 35, 269, 286, 123, 242, 4, 237, 10, 278, 23, 25, ], [34, 34, 34, -242, -134, 34, 34, 34, -131, -168, -138, -218, -154, 34, 34, 34, -124, 34, -144, -252, -155, -251, -126, 34, 34, -171, -142, 34, -217, -123, -241, -254, -141, 34, -136, 34, -169, -132, -133, -167, -245, -1, -222, -125, -247, -156, 34, 34, -246, 34, 34, -248, -249, -164, -165, -137, -250, -243, -129, -2, 34, -118, -253, -143, -220, -166, -121, -3, -104, -223, -172, -135, -244, 34, -170, 34, 34, -127, 34, -122, -130, -128, -221, 34, -173, -219, -163, 34, -119, 34, -117, -120, ]), 'SIGNED': ([31, 356, 6, 168,
 137, 28, 25, 287, 0, 36, 167, 358, 196, 327, 235, 8, 123, 170, 35, 27, 277, 2, 38, 237, 360, 10, 227, 32, 56, 134, 87, 359, 116, 260, 59, 30, 242, 34, 283, 67, 230, 186, 13, 81, 20, 3, 163, 23, 387, 269, 22, 5, 66, 165, 73, 205, 140, 17, 278, 286, 47, 130, 54, 279, 51, 37, 26, 65, 12, 9, 172, 49, 39, 15, 280, 169, 332, 58, 1, 231, 60, 238, 353, 133, 18, 339, 221, 64, 4, 117, 52, 72, ], [-127, -143, -122, 36, 36, 36, -120, -250, -1, -129, 36, -134, -248, 36, -172, -123, -173, -141, -128, 36, -243, 36, -164, 36, -252, -119, -154, -242, -246, -223, 36, -251, -254, -218, 36, -241, -219, -125, -144, -137, -171, 36, -133, 36, -167, 36, -217, -117, -253, -221, -3, -131, 36, -244, -247, -249, 36, -130, 36, 36, 36, -170, 36, -142, -104, -132, -166, -138, -118, -124, 36, -165, -121, -2, -136, 36, -155, -222, 36, 36, 36, -169, -135, -245, -126, -220, 36, 36, -163, -168, -156, 36, ]), 'CONTINUE': ([58, 340, 243, 408, 154, 269, 144, 143, 258, 338, 394, 136, 159, 263, 413, 339, 382, 259, 153, 344
 , 399, 268, 242, 406, 158, 415, 135, 240, 405, 147, 414, 134, 163, 267, 60, 140, 260, 396, 346, 261, 270, 380, 379, 397, 139, 378, 51, 348, ], [-222, -240, -239, 146, -213, -221, -226, -209, -237, -236, 146, -212, -211, 146, -235, -220, 146, -225, -224, -216, -229, -238, -219, 146, 146, -230, -210, 146, -234, 146, -233, -223, -217, 146, 146, 146, -218, -232, 146, -227, -228, 146, -215, -231, -208, 146, -104, -214, ]), 'MUL_ASSIGN': ([318, 105, 420, 100, 317, 314, 78, 91, 292, 366, 181, 182, 104, 179, 185, 99, 142, 155, 220, 309, 84, 74, 310, 410, 213, 75, 184, 368, 316, 180, 313, 363, 423, 217, 364, 77, 110, 102, 388, 211, 90, 109, ], [-24, -13, -34, -22, -27, -7, -56, -19, -21, -25, -14, -44, -10, -15, -47, -16, 250, -4, -46, -8, -12, -20, -6, -33, -28, -18, -45, -23, -26, -16, -5, -57, -35, -17, -48, -9, -49, -4, -32, -29, -11, -43, ]), '{': ([267, 24, 346, 238, 408, 52, 379, 58, 159, 136, 258, 243, 405, 158, 339, 344, 276, 51, 139, 384, 380, 261, 144, 415, 64, 269, 26, 340, 406,
 135, 163, 414, 140, 338, 67, 230, 134, 394, 270, 348, 154, 27, 60, 396, 33, 235, 397, 167, 240, 117, 260, 21, 263, 20, 40, 268, 378, 166, 413, 59, 147, 399, 49, 242, 153, 123, 382, 130, 143, 259, 65, ], [60, 53, 60, -169, 60, 118, -215, -222, -211, -212, -237, -239, -234, 60, -220, -216, 276, -104, -208, 276, 60, -227, -226, -230, 60, -221, -166, -240, 60, -210, -217, -233, 60, -236, 172, -171, -223, 60, -228, -214, -213, 60, 60, -232, -139, -172, -231, 60, 60, -168, -218, -140, 60, -167, 66, -238, 60, 276, -235, 60, 60, -229, -165, -219, -224, -173, 60, -170, -209, -225, 168, ]), 'RIGHT_OP': ([155, 363, 86, 74, 77, 307, 78, 313, 211, 317, 305, 308, 309, 296, 297, 104, 388, 300, 301, 213, 105, 109, 185, 97, 85, 179, 91, 182, 420, 83, 75, 410, 217, 220, 314, 366, 318, 306, 310, 364, 299, 110, 292, 99, 295, 102, 142, 90, 184, 298, 100, 180, 84, 316, 368, 423, 181, ], [-4, -57, 194, -20, -9, 194, -56, -5, -29, -27, 194, 194, -8, -64, -59, -10, -32, -66, -67, -28, -13, -43, -47, -58, -6
 2, -15, -19, -44, -34, -65, -18, -33, -17, -46, -7, -25, -24, 194, -6, -48, -60, -49, -21, -16, -63, -4, -56, -11, -45, -61, -22, -16, -12, -26, -23, -35, -14, ]), 'REGISTER': ([2, 260, 13, 17, 54, 39, 130, 360, 4, 387, 237, 205, 64, 280, 52, 167, 231, 238, 196, 49, 287, 0, 73, 133, 165, 123, 36, 65, 358, 58, 31, 6, 9, 20, 59, 227, 1, 277, 8, 27, 5, 163, 38, 67, 28, 140, 339, 22, 51, 230, 37, 235, 359, 25, 353, 23, 3, 26, 221, 10, 60, 117, 332, 134, 242, 116, 32, 30, 12, 34, 15, 35, 18, 327, 269, 56, ], [39, -218, -133, -130, 39, -121, -170, -252, -163, -253, 39, -249, 39, -136, -156, 39, 39, -169, -248, -165, -250, -1, -247, -245, -244, -173, -129, -138, -134, -222, -127, -122, -124, -167, 39, -154, 39, -243, -123, 39, -131, -217, -164, -137, 39, 39, -220, -3, -104, -171, -132, -172, -251, -120, -135, -117, 39, -166, 39, -119, 39, -168, -155, -223, -219, -254, -242, -241, -118, -125, -2, -128, -126, 39, -221, -246, ]), 'RIGHT_ASSIGN': ([142, 410, 77, 420, 423, 99, 185, 155, 104, 21
 1, 213, 182, 220, 366, 364, 316, 363, 78, 313, 91, 388, 318, 310, 292, 105, 110, 75, 74, 181, 100, 309, 102, 84, 90, 217, 317, 179, 184, 109, 368, 180, 314, ], [255, -33, -9, -34, -35, -16, -47, -4, -10, -29, -28, -44, -46, -25, -48, -26, -57, -56, -5, -19, -32, -24, -6, -21, -13, -49, -18, -20, -14, -22, -8, -4, -12, -11, -17, -27, -15, -45, -43, -23, -16, -7, ]), 'DEFAULT': ([159, 140, 258, 260, 153, 154, 379, 380, 269, 339, 136, 270, 344, 405, 267, 378, 382, 58, 134, 348, 414, 242, 147, 243, 397, 346, 263, 408, 158, 394, 51, 406, 143, 261, 139, 338, 259, 60, 268, 340, 413, 135, 163, 415, 399, 144, 396, 240, ], [-211, 149, -237, -218, -224, -213, -215, 149, -221, -220, -212, -228, -216, -234, 149, 149, 149, -222, -223, -214, -233, -219, 149, -239, -231, 149, 149, 149, 149, 149, -104, 149, -209, -227, -208, -236, -225, 149, -238, -240, -235, -210, -217, -230, -229, -226, -232, 149, ]), 'CHAR': ([15, 18, 133, 137, 58, 4, 13, 31, 280, 231, 26, 60, 37, 387, 278, 49, 332, 66, 12, 1, 39
 , 165, 169, 5, 279, 9, 17, 269, 186, 23, 34, 140, 54, 130, 65, 20, 116, 47, 51, 230, 73, 81, 87, 172, 22, 67, 205, 163, 3, 170, 286, 38, 28, 134, 32, 8, 260, 59, 2, 356, 242, 360, 35, 287, 30, 25, 227, 52, 56, 235, 6, 10, 358, 0, 359, 27, 283, 72, 123, 238, 168, 237, 196, 36, 277, 117, 353, 221, 339, 327, 64, 167, ], [-2, -126, -245, 8, -222, -163, -133, -127, -136, 8, -166, 8, -132, -253, 8, -165, -155, 8, -118, 8, -121, -244, 8, -131, -142, -124, -130, -221, 8, -117, -125, 8, 8, -170, -138, -167, -254, 8, -104, -171, -247, 8, 8, 8, -3, -137, -249, -217, 8, -141, 8, -164, 8, -223, -242, -123, -218, 8, 8, -143, -219, -252, -128, -250, -241, -120, -154, -156, -246, -172, -122, -119, -134, -1, -251, 8, -144, 8, -173, -169, 8, 8, -248, -129, -243, -168, -135, 8, -220, 8, 8, 8, ]), 'WHILE': ([382, 147, 338, 413, 153, 259, 258, 344, 139, 405, 136, 134, 415, 397, 267, 339, 394, 379, 380, 396, 240, 159, 261, 399, 243, 348, 260, 140, 408, 154, 406, 51, 143, 270, 242, 378, 163, 58, 269, 268,
  340, 414, 135, 60, 158, 271, 263, 346, 144, ], [150, 150, -236, -235, -224, -225, -237, -216, -208, -234, -212, -223, -230, -231, 150, -220, 150, -215, 150, -232, 150, -211, -227, -229, -239, -214, -218, 150, 150, -213, 150, -104, -209, -228, -219, 150, -217, -222, -221, -238, -240, -233, -210, 150, 150, 349, 150, 150, -226, ]), 'EXTERN': ([163, 4, 31, 23, 117, 34, 67, 242, 56, 13, 10, 32, 133, 54, 59, 227, 269, 130, 65, 359, 1, 280, 36, 358, 15, 123, 235, 26, 167, 6, 230, 51, 238, 12, 339, 49, 134, 60, 73, 58, 5, 353, 38, 2, 387, 231, 332, 237, 3, 0, 30, 27, 116, 28, 360, 327, 9, 39, 37, 64, 8, 196, 35, 18, 277, 140, 221, 260, 17, 165, 22, 287, 205, 20, 25, 52, ], [-217, -163, -127, -117, -168, -125, -137, -219, -246, -133, -119, -242, -245, 12, 12, -154, -221, -170, -138, -251, 12, -136, -129, -134, -2, -173, -172, -166, 12, -122, -171, -104, -169, -118, -220, -165, -223, 12, -247, -222, -131, -135, -164, 12, -253, 12, -155, 12, 12, -1, -241, 12, -254, 12, -252, 12, -124, -121, -
 132, 12, -123, -248, -128, -126, -243, 12, 12, -218, -130, -244, -3, -250, -249, -167, -120, -156, ]), 'RETURN': ([158, 396, 406, 348, 260, 143, 147, 339, 340, 159, 269, 399, 394, 135, 163, 414, 139, 405, 379, 415, 134, 243, 344, 136, 259, 397, 242, 382, 240, 140, 60, 258, 408, 144, 51, 378, 263, 338, 154, 153, 267, 413, 346, 380, 270, 58, 268, 261, ], [141, -232, 141, -214, -218, -209, 141, -220, -240, -211, -221, -229, 141, -210, -217, -233, -208, -234, -215, -230, -223, -239, -216, -212, -225, -231, -219, 141, 141, 141, 141, -237, 141, -226, -104, 141, 141, -236, -213, -224, 141, -235, 141, 141, -228, -222, -238, -227, ]), '__ASM__': ([198, 381, 408, 174, 240, 135, 269, 258, 144, 202, 284, 382, 260, 79, 252, 47, 137, 257, 369, 218, 276, 80, 147, 228, 189, 191, 380, 151, 338, 396, 378, 176, 249, 399, 203, 261, 246, 263, 108, 243, 340, 190, 253, 192, 342, 55, 377, 51, 219, 136, 141, 94, 270, 339, 262, 354, 183, 264, 414, 328, 367, 215, 379, 154, 384, 82, 293, 140, 254, 267, 158, 14
 3, 58, 406, 242, 409, 113, 210, 268, 103, 289, 250, 139, 216, 413, 405, 245, 107, 60, 415, 272, 256, 247, 348, 204, 207, 255, 193, 166, 346, 153, 201, 134, 259, 76, 194, 251, 394, 248, 224, 397, 95, 197, 344, 186, 72, 208, 163, 266, 188, 159, ], [93, 93, 93, 93, 93, -210, -221, -237, -226, 93, 93, 93, -218, 93, -96, 93, 93, 93, 93, 93, 93, 93, 93, 93, 93, 93, 93, 93, -236, -232, 93, 93, -98, -229, 93, -227, -93, 93, -53, -239, -240, 93, -90, 93, 93, 93, 93, -104, 93, -212, 93, -50, -228, -220, 93, 93, 93, 93, -233, 93, 93, 93, -215, -213, 93, -52, 93, 93, -94, 93, 93, -209, -222, 93, -219, 93, 93, 93, -238, -54, 93, -91, -208, 93, -235, -234, -95, -55, 93, -230, 93, 93, -99, -214, 93, 93, -97, 93, 93, 93, -224, 93, -223, -225, 93, 93, -92, 93, -100, 93, -231, -51, 93, -216, 93, 93, 93, -217, 93, 93, -211, ]), 'CASE': ([378, 153, 259, 163, 258, 139, 134, 242, 396, 339, 147, 51, 380, 58, 159, 399, 136, 269, 379, 154, 408, 243, 270, 267, 397, 405, 413, 382, 135, 143, 394, 340, 260, 144
 , 158, 140, 414, 344, 240, 268, 263, 406, 338, 346, 60, 415, 348, 261, ], [151, -224, -225, -217, -237, -208, -223, -219, -232, -220, 151, -104, 151, -222, -211, -229, -212, -221, -215, -213, 151, -239, -228, 151, -231, -234, -235, 151, -210, -209, 151, -240, -218, -226, 151, 151, -233, -216, 151, -238, 151, 151, -236, 151, 151, -230, -214, -227, ]), 'PP_DEFINE_MACRO_NAME': ([11, ], [46, ]), '&': ([106, 74, 256, 224, 83, 91, 308, 276, 397, 202, 210, 95, 94, 240, 85, 381, 318, 211, 219, 113, 306, 191, 198, 260, 153, 315, 184, 192, 140, 384, 388, 257, 142, 338, 215, 84, 369, 254, 154, 340, 242, 312, 216, 409, 220, 188, 413, 382, 134, 251, 313, 163, 261, 423, 99, 316, 292, 185, 78, 379, 245, 270, 213, 420, 76, 104, 289, 174, 255, 317, 218, 262, 248, 189, 197, 90, 135, 58, 252, 166, 314, 77, 300, 247, 399, 108, 293, 301, 194, 79, 364, 363, 368, 302, 310, 179, 298, 183, 190, 406, 414, 307, 250, 249, 253, 207, 299, 246, 267, 139, 180, 366, 342, 243, 264, 272, 60, 378, 144, 103, 284, 339,
 102, 295, 258, 143, 408, 367, 96, 193, 296, 311, 354, 107, 75, 268, 137, 309, 141, 101, 109, 377, 82, 203, 396, 72, 80, 405, 158, 100, 186, 176, 348, 217, 410, 228, 204, 97, 105, 182, 51, 328, 269, 47, 55, 201, 344, 394, 86, 136, 181, 208, 147, 155, 266, 151, 159, 415, 305, 346, 259, 297, 263, 380, 110, ], [210, -20, 94, 94, -65, -19, -70, 94, -231, 94, 94, -51, -50, 94, -62, 94, -24, -29, 94, 94, -69, 94, 94, -218, -224, -77, -45, 94, 94, 94, -32, 94, -56, -236, 94, -12, 94, -94, -213, -240, -219, -74, 94, 94, -46, 94, -235, 94, -223, -92, -5, -217, -227, -35, -16, -26, -21, -47, -56, -215, -95, -228, -28, -34, 94, -10, 94, 94, -97, -27, 94, 94, -100, 94, 94, -11, -210, -222, -96, 94, -7, -9, -66, -99, -229, -53, 94, -67, 94, 94, -48, -57, -23, 210, -6, -15, -61, 94, 94, 94, -233, -72, -91, -98, -90, 94, -60, -93, 94, -208, -16, -25, 94, -239, 94, 94, 94, 94, -226, -54, 94, -220, -4, -63, -237, -209, 94, 94, -73, 94, -64, -75, 94, -55, -18, -238, 94, -8, 94, -76, -43, 94, -52, 94,
 -232, 94, 94, -234, 94, -22, 94, 94, -214, -17, -33, 94, 94, -58, -13, -44, -104, 94, -221, 94, 94, 94, -216, 94, -68, -212, -14, 94, 94, -4, 94, 94, -211, -230, -71, 94, -225, -59, 94, 94, -49, ]), '*': ([266, 52, 297, 202, 208, 176, 127, 195, 163, 253, 268, 287, 204, 185, 191, 277, 2, 270, 396, 245, 213, 260, 219, 187, 104, 174, 231, 196, 256, 247, 56, 81, 218, 192, 141, 179, 284, 134, 360, 84, 109, 353, 39, 10, 180, 240, 41, 227, 332, 414, 133, 44, 12, 249, 264, 354, 255, 388, 34, 251, 4, 346, 314, 413, 269, 55, 23, 113, 262, 76, 250, 158, 0, 205, 243, 348, 198, 166, 137, 28, 261, 280, 15, 105, 210, 35, 140, 197, 296, 381, 171, 257, 263, 420, 193, 99, 379, 8, 31, 366, 228, 221, 415, 151, 68, 36, 378, 87, 342, 90, 58, 51, 380, 6, 408, 143, 367, 201, 344, 293, 310, 299, 267, 79, 85, 18, 242, 5, 289, 136, 298, 1, 272, 7, 72, 259, 317, 292, 164, 29, 110, 215, 100, 186, 246, 399, 217, 147, 384, 309, 220, 188, 38, 207, 9, 357, 363, 82, 318, 423, 37, 43, 394, 30, 254, 135, 359, 338, 387
 , 65, 22, 116, 406, 409, 42, 16, 358, 3, 61, 364, 313, 339, 405, 224, 25, 211, 316, 77, 252, 102, 410, 73, 216, 165, 184, 139, 13, 32, 114, 276, 382, 107, 75, 94, 369, 97, 144, 368, 103, 189, 74, 80, 182, 328, 67, 153, 377, 258, 159, 108, 57, 194, 95, 181, 155, 60, 142, 340, 47, 91, 397, 78, 183, 248, 17, 203, 154, 295, 190, ], [95, -156, -59, 95, 95, 95, 7, -147, -217, -90, -238, -250, 95, -47, 95, -243, -107, -228, -232, -95, -28, -218, 95, -145, -10, 95, 7, -248, 95, -99, -246, -146, 95, 95, 95, -15, 95, -223, -252, -12, -43, -135, -121, -119, -16, 95, -108, -154, -155, -233, -245, -178, -118, -98, 95, 95, -97, -32, -125, -92, -163, 95, -7, -235, -221, 95, -117, 95, 95, 95, -91, 95, -1, -249, -239, -214, 95, 95, 95, -109, -227, -136, -2, -13, 95, -128, 95, 95, 190, 95, 7, 95, 95, -34, 95, -16, -215, -123, -127, -25, 95, 7, -230, 95, -179, -129, 95, -148, 95, -11, -222, -104, 95, -122, 95, -209, 95, 95, -216, 95, -6, -60, 95, 95, 190, -126, -219, -131, 95, -212, -61, 7, 95, 7, 95,
  -225, -27, -21, 7, 7, -49, 95, -22, 95, -93, -229, -17, 95, 95, -8, -46, 95, -164, 95, -124, 7, -57, -52, -24, -35, -132, 7, 95, -241, -94, -210, -251, -236, -253, -138, -3, -254, 95, 95, -112, 7, -134, -111, -110, -48, -5, -220, -234, 95, -120, -29, -26, -9, -96, -4, -33, -247, 95, -244, -45, -208, -133, -242, 7, 95, 95, -55, -18, -50, 95, -58, -226, -23, -54, 95, -20, 95, -44, 95, -137, -224, 95, -237, -211, -53, 7, 95, -51, -14, -4, 95, -56, -240, 95, -19, -231, -56, 95, -100, -130, 95, -213, 190, 95, ]), 'SWITCH': ([414, 139, 380, 147, 270, 143, 242, 134, 154, 340, 267, 394, 379, 382, 263, 261, 348, 406, 144, 339, 413, 243, 158, 344, 163, 396, 378, 268, 415, 259, 258, 397, 60, 51, 338, 135, 408, 399, 269, 159, 58, 346, 405, 260, 136, 140, 153, 240, ], [-233, -208, 152, 152, -228, -209, -219, -223, -213, -240, 152, 152, -215, 152, 152, -227, -214, 152, -226, -220, -235, -239, 152, -216, -217, -232, 152, -238, -230, -225, -237, -231, 152, -104, -236, -210, 152, -229, -221, -211,
 -222, 152, -234, -218, -212, 152, -224, 152, ]), 'AND_ASSIGN': ([217, 292, 318, 181, 179, 110, 368, 102, 316, 309, 109, 105, 99, 184, 74, 142, 104, 90, 314, 185, 78, 388, 363, 182, 180, 423, 155, 100, 420, 310, 84, 213, 220, 91, 77, 364, 75, 211, 410, 366, 313, 317, ], [-17, -21, -24, -14, -15, -49, -23, -4, -26, -8, -43, -13, -16, -45, -20, 249, -10, -11, -7, -47, -56, -32, -57, -44, -16, -35, -4, -22, -34, -6, -12, -28, -46, -19, -9, -48, -18, -29, -33, -25, -5, -27, ]), 'IDENTIFIER': ([9, 141, 280, 344, 293, 21, 246, 384, 242, 82, 194, 257, 346, 55, 30, 23, 0, 259, 243, 164, 139, 16, 215, 24, 134, 65, 58, 33, 5, 144, 408, 38, 127, 67, 79, 209, 108, 107, 1, 138, 397, 103, 216, 409, 42, 17, 332, 143, 342, 212, 159, 45, 360, 394, 37, 43, 254, 268, 252, 387, 207, 51, 53, 382, 190, 3, 186, 192, 94, 231, 147, 191, 47, 196, 406, 248, 195, 188, 287, 61, 73, 54, 165, 118, 10, 253, 367, 358, 214, 381, 264, 31, 203, 154, 80, 340, 270, 357, 52, 405, 224, 174, 25, 396, 234, 189, 151, 227, 414
 , 266, 153, 284, 12, 187, 198, 276, 137, 245, 210, 60, 35, 202, 208, 183, 269, 247, 163, 81, 262, 95, 258, 236, 36, 204, 353, 251, 18, 57, 260, 140, 133, 197, 369, 176, 13, 44, 249, 263, 277, 255, 338, 34, 15, 219, 39, 14, 41, 4, 68, 240, 56, 113, 250, 116, 205, 72, 158, 2, 28, 379, 261, 267, 339, 206, 22, 229, 171, 256, 354, 76, 380, 136, 218, 193, 328, 377, 40, 8, 7, 166, 272, 69, 289, 378, 413, 135, 359, 87, 399, 32, 348, 6, 228, 415, 29, 201, ], [-124, 102, -136, -216, 102, -140, -93, 102, -219, -52, 102, 102, 155, 102, -241, -117, -1, -225, -239, 20, -208, 20, 102, 52, -223, -138, -222, -139, -131, -226, 155, -164, 20, -137, 102, 102, -53, -55, 20, 239, -231, -54, 102, 102, -112, -130, -155, -209, 102, 316, -211, -176, -252, 155, -132, -175, -94, -238, -96, -253, 102, -104, 121, 155, 102, -111, 102, 102, -50, 20, 155, 102, 102, -248, 155, -100, -147, 102, -250, -110, -247, 124, -244, 121, -119, -90, 102, -134, 317, 102, 102, -127, 102, -213, 102, -240, -228, 20, -156, -234, 102
 , 102, -120, -232, 20, 102, 102, -154, -233, 102, -224, 102, -118, -145, 102, 102, 102, -95, 102, 155, -128, 102, 102, 102, -221, -99, -217, -146, 102, -51, -237, 335, -129, 102, -135, -92, -126, 20, -218, 155, -245, 102, 102, 102, -133, -178, -98, 155, -243, -97, -236, -125, -2, 102, -121, 20, -108, -163, -179, 155, -246, 102, -91, -254, -249, 102, 155, -107, -109, -215, -227, 155, -220, 102, -3, 121, 20, 102, 102, 102, 155, -212, 102, 102, 102, 102, 67, -123, -174, 102, 102, -177, 102, 155, -235, -210, -251, -148, -229, -242, -214, -122, 102, -230, 20, 102, ]), 'ADD_ASSIGN': ([420, 317, 104, 109, 313, 78, 155, 213, 91, 179, 181, 185, 182, 423, 90, 314, 100, 220, 180, 316, 364, 363, 77, 105, 366, 309, 142, 310, 410, 75, 368, 217, 211, 74, 102, 388, 292, 184, 318, 84, 99, 110, ], [-34, -27, -10, -43, -5, -56, -4, -28, -19, -15, -14, -47, -44, -35, -11, -7, -22, -46, -16, -26, -48, -57, -9, -13, -25, -8, 254, -6, -33, -18, -23, -17, -29, -20, -4, -32, -21, -45, -24, -12, -16, -49, ])
 , '>': ([300, 85, 86, 296, 102, 181, 77, 298, 105, 307, 364, 410, 423, 309, 313, 211, 317, 182, 213, 388, 366, 292, 220, 155, 74, 314, 363, 306, 318, 312, 91, 110, 217, 83, 308, 90, 310, 96, 100, 179, 75, 305, 109, 311, 97, 180, 99, 184, 299, 420, 142, 104, 297, 368, 84, 301, 316, 295, 185, 78, ], [-66, -62, -68, -64, -4, -14, -9, -61, -13, -72, -48, -33, -35, -8, -5, -29, -27, -44, -28, -32, -25, -21, -46, -4, -20, -7, -57, -69, -24, 204, -19, -49, -17, -65, -70, -11, -6, 204, -22, -15, -18, -71, -43, 204, -58, -16, -16, -45, -60, -34, -56, -10, -59, -23, -12, -67, -26, -63, -47, -56, ]), 'PP_MACRO_PARAM': ([263, 354, 103, 82, 207, 245, 414, 144, 203, 58, 139, 174, 84, 289, 215, 108, 186, 76, 254, 192, 74, 290, 216, 143, 369, 47, 250, 202, 381, 276, 266, 141, 377, 258, 189, 158, 247, 113, 137, 218, 261, 219, 90, 206, 328, 270, 382, 188, 269, 51, 260, 135, 153, 183, 204, 367, 264, 346, 257, 190, 268, 107, 217, 406, 134, 396, 240, 154, 256, 293, 197, 380, 413, 253, 259, 99, 94, 210,
 163, 272, 246, 198, 201, 267, 348, 176, 339, 262, 249, 394, 405, 384, 224, 151, 340, 415, 255, 193, 344, 111, 181, 378, 338, 105, 194, 147, 408, 209, 80, 60, 243, 180, 191, 379, 251, 284, 166, 399, 409, 136, 140, 79, 252, 70, 55, 208, 242, 95, 228, 397, 248, 159, 342, 179, 72, ], [99, 99, -54, -52, 99, -95, -233, -226, 99, -222, -208, 99, -12, 99, 99, -53, 99, 99, -94, 99, 180, 362, 99, -209, 99, 99, -91, 99, 99, 99, 99, 99, 99, -237, 99, 99, -99, 99, 99, 99, -227, 99, -11, 309, 99, -228, 99, 99, -221, -104, -218, -210, -224, 99, 99, 99, 99, 99, 99, 99, -238, -55, -17, 99, -223, -232, 99, -213, 99, 99, 99, 99, -235, -90, -225, -16, -50, 99, -217, 99, -93, 99, 99, 99, -214, 99, -220, 99, -98, 99, -234, 99, 99, 99, -240, -230, -97, 99, -216, 217, -14, 99, -236, -13, 99, 99, 99, 314, 99, 99, -239, -16, 99, -215, -92, 99, 99, -229, 99, -212, 99, 99, -96, 173, 99, 99, -219, -51, 99, -231, -100, -211, 99, -15, 99, ]), 'GE_OP': ([211, 110, 84, 297, 90, 184, 83, 317, 104, 78, 306, 312, 300,
  182, 180, 155, 299, 181, 179, 109, 423, 301, 307, 102, 77, 97, 213, 142, 75, 364, 86, 308, 316, 388, 96, 363, 366, 314, 292, 220, 99, 217, 74, 310, 313, 305, 296, 420, 295, 311, 100, 91, 368, 185, 85, 105, 298, 318, 410, 309, ], [-29, -49, -12, -59, -11, -45, -65, -27, -10, -56, -69, 203, -66, -44, -16, -4, -60, -14, -15, -43, -35, -67, -72, -4, -9, -58, -28, -56, -18, -48, -68, -70, -26, -32, 203, -57, -25, -7, -21, -46, -16, -17, -20, -6, -5, -71, -64, -34, -63, 203, -22, -19, -23, -47, -62, -13, -61, -24, -33, -8, ]), '^': ([366, 179, 315, 298, 296, 91, 97, 100, 155, 99, 312, 420, 363, 110, 104, 388, 299, 185, 182, 96, 90, 317, 311, 220, 410, 75, 85, 297, 306, 301, 184, 423, 314, 308, 313, 180, 291, 307, 310, 102, 78, 142, 292, 295, 74, 316, 302, 106, 211, 368, 109, 213, 300, 181, 305, 89, 364, 309, 101, 318, 77, 217, 86, 84, 105, 83, ], [-25, -15, -77, -61, -64, -19, -58, -22, -4, -16, -74, -34, -57, -49, -10, -32, -60, -47, -44, -73, -11, -27, -75, -46, -33, -18, -62, -59, -69
 , -67, -45, -35, -7, -70, -5, -16, 197, -72, -6, -4, -56, -56, -21, -63, -20, -26, -79, -78, -29, -23, -43, -28, -66, -14, -71, 197, -48, -8, -76, -24, -9, -17, -68, -12, -13, -65, ]), 'MOD_ASSIGN': ([142, 182, 74, 368, 104, 185, 110, 155, 84, 100, 181, 184, 211, 388, 318, 292, 217, 363, 423, 213, 109, 420, 77, 90, 314, 364, 310, 316, 220, 78, 105, 313, 366, 180, 99, 102, 91, 410, 317, 179, 75, 309, ], [246, -44, -20, -23, -10, -47, -49, -4, -12, -22, -14, -45, -29, -32, -24, -21, -17, -57, -35, -28, -43, -34, -9, -11, -7, -48, -6, -26, -46, -56, -13, -5, -25, -16, -16, -4, -19, -33, -27, -15, -18, -8, ]), ':': ([297, 5, 97, 235, 318, 291, 99, 86, 162, 403, 317, 142, 310, 90, 110, 358, 364, 78, 292, 84, 309, 52, 83, 220, 195, 332, 301, 75, 296, 31, 123, 388, 187, 74, 322, 302, 115, 323, 130, 238, 36, 391, 265, 180, 184, 105, 308, 365, 419, 299, 341, 313, 8, 343, 316, 303, 307, 100, 104, 306, 295, 49, 38, 9, 92, 357, 20, 109, 298, 37, 227, 89, 149, 185, 71, 87, 117, 77, 81, 311, 412,
  363, 102, 423, 404, 101, 65, 368, 213, 160, 217, 420, 67, 4, 96, 211, 179, 417, 353, 418, 230, 35, 282, 171, 106, 18, 402, 315, 34, 389, 300, 182, 112, 314, 366, 85, 26, 305, 13, 410, 181, 155, 17, 6, 312, 91, 280, ], [-59, -131, -58, -172, -24, -81, -16, -68, -88, -37, -27, -56, -6, -11, -49, -134, -48, -56, -21, -12, -8, -156, -65, -46, -147, -155, -67, -18, -64, -127, -173, -32, -145, -20, -85, -79, -103, 369, -170, -169, -129, -87, 346, -16, -45, -13, -70, 389, -40, -60, -89, -5, -123, -102, -26, -83, -72, -22, -10, -69, -63, -165, -164, -124, -84, 284, -167, -43, -61, -132, -154, -80, 263, -47, -82, -148, -168, -9, -146, -75, -36, -57, -4, -35, 412, -76, -138, -23, -28, -101, -17, -34, -137, -163, -73, -29, -15, -38, -135, 421, -171, -128, 354, 284, -78, -126, -39, -77, -125, -36, -66, -44, -86, -7, -25, -62, -166, -71, -133, -33, -14, 267, -130, -122, -74, -19, -136, ]), 'TYPE_NAME': ([13, 65, 51, 67, 167, 286, 47, 327, 35, 32, 278, 169, 279, 60, 130, 21, 37, 31, 28, 260, 227
 , 5, 359, 12, 137, 235, 165, 56, 87, 283, 172, 59, 242, 54, 30, 168, 20, 140, 353, 22, 8, 221, 116, 387, 4, 6, 64, 205, 10, 2, 134, 360, 339, 230, 123, 36, 66, 38, 356, 3, 33, 231, 27, 9, 196, 163, 34, 39, 15, 1, 17, 238, 269, 81, 40, 18, 133, 58, 52, 25, 237, 358, 49, 277, 186, 287, 26, 72, 73, 280, 170, 117, 0, 332, 23, ], [-133, -138, -104, -137, 13, 13, 13, 13, -128, -242, 13, 13, -142, 13, -170, -140, -132, -127, 13, -218, -154, -131, -251, -118, 13, -172, -244, -246, 13, -144, 13, 13, -219, 13, -241, 13, -167, 13, -135, -3, -123, 13, -254, -253, -163, -122, 13, -249, -119, 13, -223, -252, -220, -171, -173, -129, 13, -164, -143, 13, -139, 13, 13, -124, -248, -217, -125, -121, -2, 13, -130, -169, -221, 13, 65, -126, -245, -222, -156, -120, 13, -134, -165, -243, 13, -250, -166, 13, -247, -136, -141, -168, -1, -155, -117, ]), 'OR_ASSIGN': ([211, 179, 420, 110, 91, 99, 102, 310, 78, 142, 213, 423, 185, 184, 368, 388, 317, 75, 182, 90, 364, 410, 314, 100, 180, 155, 309, 217, 109, 84
 , 74, 105, 220, 104, 316, 363, 366, 318, 181, 77, 313, 292, ], [-29, -15, -34, -49, -19, -16, -4, -6, -56, 248, -28, -35, -47, -45, -23, -32, -27, -18, -44, -11, -48, -33, -7, -22, -16, -4, -8, -17, -43, -12, -20, -13, -46, -10, -26, -57, -25, -24, -14, -9, -5, -21, ]), 'BREAK': ([263, 258, 269, 242, 158, 378, 260, 399, 397, 58, 270, 346, 382, 379, 261, 134, 154, 139, 408, 51, 135, 153, 344, 348, 259, 396, 338, 243, 268, 415, 380, 406, 163, 340, 267, 414, 159, 405, 240, 394, 339, 144, 147, 136, 60, 140, 143, 413, ], [156, -237, -221, -219, 156, 156, -218, -229, -231, -222, -228, 156, 156, -215, -227, -223, -213, -208, 156, -104, -210, -224, -216, -214, -225, -232, -236, -239, -238, -230, 156, 156, -217, -240, 156, -233, -211, -234, 156, 156, -220, -226, 156, -212, 156, 156, -209, -235, ]), 'VOLATILE': ([237, 205, 170, 66, 353, 130, 360, 47, 327, 260, 8, 26, 4, 235, 59, 339, 356, 38, 387, 140, 23, 17, 117, 242, 358, 279, 93, 1, 0, 54, 18, 5, 169, 287, 35, 168, 221, 6, 186, 37, 52, 12
 3, 283, 25, 133, 269, 81, 7, 31, 277, 116, 56, 87, 9, 231, 13, 165, 12, 227, 20, 60, 27, 65, 137, 359, 72, 230, 58, 278, 3, 286, 172, 43, 51, 22, 2, 332, 68, 73, 39, 15, 64, 280, 32, 238, 196, 163, 167, 34, 67, 134, 28, 44, 36, 10, 49, 30, ], [38, -249, -141, 38, -135, -170, -252, 38, 38, -218, -123, -166, -163, -172, 38, -220, -143, -164, -253, 38, -117, -130, -168, -219, -134, -142, 199, 38, -1, 38, -126, -131, 38, -250, -128, 38, 38, -122, 38, -132, -156, -173, -144, -120, -245, -221, 38, 38, -127, -243, -254, -246, 38, -124, 38, -133, -244, -118, -154, -167, 38, 38, -138, 38, -251, 38, -171, -222, 38, 38, 38, 38, 38, -104, -3, 38, -155, -179, -247, -121, -2, 38, -136, -242, -169, -248, -217, 38, -125, -137, -223, 38, -178, -129, -119, -165, -241, ]), 'error': ([136, 380, 378, 153, 147, 346, 338, 399, 261, 344, 342, 58, 159, 51, 267, 382, 139, 260, 414, 242, 154, 143, 408, 135, 413, 394, 158, 163, 257, 396, 144, 340, 243, 269, 259, 134, 379, 140, 270, 263, 11, 348, 268, 405, 240,
  397, 60, 258, 415, 406, 339, ], [-212, 241, 241, -224, 241, 241, -236, -229, -227, -216, 241, -222, -211, -104, 241, 241, -208, -218, -233, -219, -213, -209, 241, -210, -235, 241, 241, -217, 241, -232, -226, -240, -239, -221, -225, -223, -215, 241, -228, 241, 48, -214, -238, -234, 241, -231, 157, -237, -230, 241, -220, ]), '~': ([397, 113, 103, 58, 380, 189, 252, 246, 79, 256, 262, 263, 254, 194, 413, 251, 344, 139, 202, 382, 183, 249, 147, 82, 204, 144, 201, 191, 394, 207, 384, 215, 186, 154, 340, 243, 141, 405, 188, 342, 339, 136, 284, 193, 261, 381, 76, 269, 293, 266, 159, 248, 268, 399, 276, 60, 289, 47, 242, 94, 55, 258, 219, 406, 250, 174, 240, 379, 253, 414, 151, 192, 198, 107, 255, 137, 367, 216, 409, 203, 396, 80, 158, 224, 260, 135, 176, 166, 245, 153, 143, 377, 210, 190, 354, 328, 247, 218, 208, 163, 257, 140, 197, 72, 259, 348, 378, 338, 369, 267, 264, 346, 51, 270, 408, 108, 134, 228, 95, 272, 415, ], [-231, 103, -54, -222, 103, 103, -96, -93, 103, 103, 103, 103, -94,
 103, -235, -92, -216, -208, 103, 103, 103, -98, 103, -52, 103, -226, 103, 103, 103, 103, 103, 103, 103, -213, -240, -239, 103, -234, 103, 103, -220, -212, 103, 103, -227, 103, 103, -221, 103, 103, -211, -100, -238, -229, 103, 103, 103, 103, -219, -50, 103, -237, 103, 103, -91, 103, 103, -215, -90, -233, 103, 103, 103, -55, -97, 103, 103, 103, 103, 103, -232, 103, 103, 103, -218, -210, 103, 103, -95, -224, -209, 103, 103, 103, 103, 103, -99, 103, 103, -217, 103, 103, 103, 103, -225, -214, 103, -236, 103, 103, 103, 103, -104, -228, 103, -53, -223, 103, -51, 103, -230, ]), 'DO': ([243, 346, 339, 153, 163, 338, 136, 158, 396, 415, 380, 51, 258, 405, 242, 382, 397, 159, 263, 267, 240, 259, 408, 270, 134, 140, 340, 348, 143, 144, 413, 135, 378, 379, 154, 399, 147, 414, 260, 139, 60, 269, 394, 268, 406, 344, 261, 58, ], [-239, 158, -220, -224, -217, -236, -212, 158, -232, -230, 158, -104, -237, -234, -219, 158, -231, -211, 158, 158, 158, -225, 158, -228, -223, 158, -240, -214, -209, -226,
 -235, -210, 158, -215, -213, -229, 158, -233, -218, -208, 158, -221, 158, -238, 158, -216, -227, -222, ]), 'CONST': ([359, 205, 81, 31, 9, 49, 2, 32, 196, 37, 72, 20, 59, 10, 242, 18, 358, 231, 15, 117, 60, 235, 123, 26, 360, 6, 34, 260, 230, 356, 54, 353, 25, 27, 3, 8, 167, 67, 269, 133, 332, 227, 140, 237, 283, 56, 4, 38, 43, 186, 64, 12, 51, 39, 44, 68, 221, 278, 5, 7, 134, 47, 52, 280, 87, 163, 327, 339, 168, 286, 13, 58, 36, 23, 66, 287, 73, 169, 116, 17, 0, 137, 279, 238, 130, 22, 170, 65, 172, 387, 30, 35, 277, 28, 1, 165, ], [-251, -249, 4, -127, -124, -165, 4, -242, -248, -132, 4, -167, 4, -119, -219, -126, -134, 4, -2, -168, 4, -172, -173, -166, -252, -122, -125, -218, -171, -143, 4, -135, -120, 4, 4, -123, 4, -137, -221, -245, -155, -154, 4, 4, -144, -246, -163, -164, 4, 4, 4, -118, -104, -121, -178, -179, 4, 4, -131, 4, -223, 4, -156, -136, 4, -217, 4, -220, 4, 4, -133, -222, -129, -117, 4, -250, -247, 4, -254, -130, -1, 4, -142, -169, -170, -3, -141, -138, 4, -253, -241
 , -128, -243, 4, 4, -244, ]), '!': ([107, 246, 204, 242, 147, 269, 189, 262, 208, 58, 176, 243, 254, 263, 183, 108, 379, 270, 51, 338, 342, 380, 405, 159, 79, 293, 80, 215, 139, 396, 339, 193, 381, 256, 197, 249, 47, 369, 260, 95, 399, 354, 144, 250, 408, 247, 163, 201, 348, 397, 216, 272, 266, 413, 186, 194, 328, 382, 257, 198, 82, 289, 261, 367, 76, 414, 253, 255, 409, 224, 153, 202, 267, 406, 218, 113, 136, 140, 143, 60, 207, 377, 240, 174, 141, 134, 340, 190, 228, 384, 219, 344, 251, 94, 137, 276, 284, 394, 191, 210, 378, 135, 258, 55, 158, 252, 245, 203, 154, 264, 192, 268, 415, 188, 103, 248, 259, 166, 72, 151, 346, ], [-55, -93, 107, -219, 107, -221, 107, 107, 107, -222, 107, -239, -94, 107, 107, -53, -215, -228, -104, -236, 107, 107, -234, -211, 107, 107, 107, 107, -208, -232, -220, 107, 107, 107, 107, -98, 107, 107, -218, -51, -229, 107, -226, -91, 107, -99, -217, 107, -214, -231, 107, 107, 107, -235, 107, 107, 107, 107, 107, 107, -52, 107, -227, 107, 107, -233, -90, -97, 1
 07, 107, -224, 107, 107, 107, 107, 107, -212, 107, -209, 107, 107, 107, 107, 107, 107, -223, -240, 107, 107, 107, 107, -216, -92, -50, 107, 107, 107, 107, 107, 107, 107, -210, -237, 107, 107, -96, -95, 107, -213, 107, 107, -238, -230, 107, -54, -100, -225, 107, 107, 107, 107, ]), '%': ([364, 295, 314, 90, 388, 179, 217, 292, 75, 110, 77, 180, 420, 309, 299, 296, 84, 423, 109, 220, 368, 363, 142, 74, 78, 99, 102, 100, 310, 297, 182, 184, 318, 316, 366, 298, 185, 97, 317, 313, 155, 104, 91, 85, 211, 181, 213, 410, 105, ], [-48, 191, -7, -11, -32, -15, -17, -21, -18, -49, -9, -16, -34, -8, -60, 191, -12, -35, -43, -46, -23, -57, -56, -20, -56, -16, -4, -22, -6, -59, -44, -45, -24, -26, -25, -61, -47, -58, -27, -5, -4, -10, -19, 191, -29, -14, -28, -33, -13, ]), ')': ([68, 106, 391, 175, 12, 416, 310, 318, 179, 217, 70, 331, 261, 309, 423, 280, 177, 97, 403, 42, 392, 52, 371, 418, 6, 54, 332, 213, 50, 184, 130, 223, 299, 231, 13, 311, 294, 195, 127, 325, 335, 373, 92, 388, 238, 312, 20,
  75, 398, 123, 419, 215, 44, 74, 84, 337, 316, 185, 38, 86, 162, 233, 31, 364, 296, 389, 350, 142, 5, 104, 114, 358, 99, 227, 173, 307, 144, 319, 28, 124, 420, 322, 69, 292, 187, 305, 330, 100, 17, 65, 211, 336, 78, 128, 303, 341, 180, 9, 345, 366, 376, 422, 365, 234, 102, 182, 300, 77, 317, 297, 101, 295, 343, 49, 225, 393, 368, 160, 96, 71, 85, 8, 3, 320, 178, 7, 126, 306, 347, 23, 61, 67, 109, 395, 37, 220, 110, 41, 370, 270, 363, 89, 404, 232, 181, 291, 18, 410, 129, 313, 25, 90, 2, 10, 34, 39, 87, 377, 324, 230, 43, 81, 314, 390, 372, 91, 301, 221, 112, 417, 402, 105, 412, 302, 235, 117, 315, 36, 298, 308, 35, 83, 125, 362, 421, 45, 327, 326, 374, 353, 222, 26, 4, ], [-179, -78, -87, 289, -118, 419, -6, -24, -15, -17, 174, -193, -227, -8, -35, -136, 292, -58, -37, -112, -202, -156, -194, 420, -122, 123, -155, -28, 117, -45, -170, -192, -60, 324, -133, -75, 364, -147, -186, 370, -188, 392, -84, -32, -169, -74, -167, -18, 407, -173, -40, 318, -178, -20, -12, -183, -26, -47, -164,
  -68, -88, -184, -127, -48, -64, -36, 382, -56, -131, -10, -189, -134, -16, -154, -255, -72, -226, -30, -109, -187, -34, -85, -177, -21, -145, -71, -195, -22, -130, -138, -29, -181, -56, 235, -83, -89, -16, -124, 378, -25, -196, 423, 388, -191, -4, -44, -66, -9, -27, -59, -76, -63, -102, -165, -191, -198, -23, -101, -73, -82, -62, -123, -111, 366, 293, -174, -182, -69, 380, -117, -110, -137, -43, 406, -132, -46, -49, -108, -200, -228, -57, -80, 410, -185, -14, -81, -126, -33, -180, -5, -120, -11, -107, -119, -125, -121, -148, 394, -199, -171, -175, -146, -7, -31, -201, -19, -67, 324, -86, -38, -39, -13, -36, -79, -172, -168, -77, -129, -61, -70, -128, -65, 230, -256, -36, -176, 372, 371, -197, -135, -190, -166, -163, ]), '-': ([378, 240, 364, 83, 409, 202, 252, 197, 247, 261, 97, 219, 248, 110, 72, 414, 250, 310, 245, 309, 354, 318, 99, 183, 94, 313, 154, 176, 180, 262, 379, 413, 296, 184, 181, 203, 207, 381, 190, 55, 297, 104, 76, 377, 420, 408, 301, 316, 51, 201, 251, 328, 263, 75
 , 79, 74, 155, 246, 249, 292, 188, 396, 182, 174, 108, 243, 314, 135, 254, 298, 348, 340, 186, 399, 185, 95, 338, 85, 107, 159, 255, 367, 192, 384, 368, 346, 394, 253, 220, 289, 256, 344, 105, 77, 267, 369, 210, 228, 216, 264, 423, 363, 242, 218, 217, 189, 415, 103, 91, 143, 82, 134, 60, 136, 342, 47, 397, 339, 166, 109, 299, 163, 194, 405, 268, 272, 58, 366, 78, 100, 388, 224, 258, 276, 193, 269, 257, 295, 211, 266, 270, 158, 84, 140, 410, 139, 208, 293, 260, 259, 317, 141, 300, 102, 90, 142, 406, 137, 382, 113, 80, 153, 215, 380, 144, 204, 213, 191, 179, 151, 198, 147, 284, ], [108, 108, -48, 189, 108, 108, -96, 108, -99, -227, -58, 108, -100, -49, 108, -233, -91, -6, -95, -8, 108, -24, -16, 108, -50, -5, -213, 108, -16, 108, -215, -235, -64, -45, -14, 108, 108, 108, 108, 108, -59, -10, 108, 108, -34, 108, 189, -26, -104, 108, -92, 108, 108, -18, 108, -20, -4, -93, -98, -21, 108, -232, -44, 108, -53, -239, -7, -210, -94, -61, -214, -240, 108, -229, -47, -51, -236, -62, -55, -211,
 -97, 108, 108, 108, -23, 108, 108, -90, -46, 108, 108, -216, -13, -9, 108, 108, 108, 108, 108, 108, -35, -57, -219, 108, -17, 108, -230, -54, -19, -209, -52, -223, 108, -212, 108, 108, -231, -220, 108, -43, -60, -217, 108, -234, -238, 108, -222, -25, -56, -22, -32, 108, -237, 108, 108, -221, 108, -63, -29, 108, -228, 108, -12, 108, -33, -208, 108, 108, -218, -225, -27, 108, 189, -4, -11, -56, 108, 108, 108, 108, 108, -224, 108, 108, -226, 108, -28, 108, -15, 108, 108, 108, 108, ]), 'CHARACTER_CONSTANT': ([380, 414, 250, 204, 245, 186, 191, 151, 284, 94, 154, 252, 140, 413, 247, 248, 381, 72, 377, 272, 201, 183, 176, 382, 379, 249, 203, 207, 55, 174, 76, 344, 408, 51, 254, 396, 415, 251, 338, 263, 79, 158, 293, 289, 346, 394, 240, 253, 188, 369, 210, 262, 108, 243, 144, 348, 340, 242, 218, 399, 189, 107, 159, 367, 192, 82, 134, 342, 378, 256, 397, 219, 166, 267, 228, 216, 264, 194, 405, 58, 135, 255, 193, 269, 257, 103, 143, 266, 270, 60, 136, 47, 339, 163, 141, 268, 354, 406, 137, 3
 28, 224, 276, 113, 153, 139, 208, 260, 190, 259, 258, 384, 147, 198, 409, 202, 80, 215, 197, 261, 95, 246, ], [104, -233, -91, 104, -95, 104, 104, 104, 104, -50, -213, -96, 104, -235, -99, -100, 104, 104, 104, 104, 104, 104, 104, 104, -215, -98, 104, 104, 104, 104, 104, -216, 104, -104, -94, -232, -230, -92, -236, 104, 104, 104, 104, 104, 104, 104, 104, -90, 104, 104, 104, 104, -53, -239, -226, -214, -240, -219, 104, -229, 104, -55, -211, 104, 104, -52, -223, 104, 104, 104, -231, 104, 104, 104, 104, 104, 104, 104, -234, -222, -210, -97, 104, -221, 104, -54, -209, 104, -228, 104, -212, 104, -220, -217, 104, -238, 104, 104, 104, 104, 104, 104, 104, -224, -208, 104, -218, 104, -225, -237, 104, 104, 104, 104, 104, 104, 104, 104, -227, -51, -93, ]), 'PP_STRINGIFY': ([139, 242, 176, 82, 58, 268, 381, 103, 94, 99, 367, 259, 84, 163, 147, 272, 204, 354, 382, 344, 328, 174, 266, 183, 394, 269, 255, 399, 413, 249, 263, 409, 134, 396, 72, 180, 193, 190, 107, 218, 252, 202, 408, 136, 210, 194,
 217, 113, 257, 256, 51, 189, 188, 47, 207, 208, 379, 108, 228, 151, 95, 270, 105, 247, 181, 415, 348, 250, 342, 405, 159, 143, 253, 397, 186, 135, 240, 377, 243, 198, 219, 339, 261, 245, 260, 144, 264, 154, 79, 191, 262, 216, 267, 215, 369, 197, 254, 414, 140, 346, 246, 289, 338, 380, 224, 384, 192, 158, 90, 74, 284, 248, 153, 406, 60, 141, 378, 55, 179, 76, 166, 258, 340, 203, 137, 293, 80, 251, 201, 276, ], [-208, -219, 111, -52, -222, -238, 111, -54, -50, -16, 111, -225, -12, -217, 111, 111, 111, 111, 111, -216, 111, 111, 111, 111, 111, -221, -97, -229, -235, -98, 111, 111, -223, -232, 111, -16, 111, 111, -55, 111, -96, 111, 111, -212, 111, 111, -17, 111, 111, 111, -104, 111, 111, 111, 111, 111, -215, -53, 111, 111, -51, -228, -13, -99, -14, -230, -214, -91, 111, -234, -211, -209, -90, -231, 111, -210, 111, 111, -239, 111, 111, -220, -227, -95, -218, -226, 111, -213, 111, 111, 111, 111, 111, 111, 111, 111, -94, -233, 111, 111, -93, 111, -236, 111, 111, 111, 111, 111, -11, 111, 11
 1, -100, -224, 111, 111, 111, 111, 111, -15, 111, 111, -237, -240, 111, 111, 111, 111, -92, 111, 111, ]), 'PTR_OP': ([211, 109, 84, 309, 317, 217, 74, 181, 77, 91, 213, 90, 104, 102, 292, 313, 100, 368, 99, 179, 314, 180, 310, 366, 316, 318, 105, 75, 155, ], [-29, 214, -12, -8, -27, -17, -20, -14, -9, -19, -28, -11, -10, -4, -21, -5, -22, -23, -16, -15, -7, -16, -6, -25, -26, -24, -13, -18, -4, ]), '=': ([117, 26, 132, 104, 99, 182, 185, 90, 142, 78, 220, 109, 313, 49, 155, 213, 91, 179, 316, 121, 423, 366, 314, 100, 363, 235, 180, 238, 64, 130, 230, 102, 388, 105, 123, 211, 364, 84, 410, 317, 110, 368, 20, 310, 420, 309, 75, 74, 292, 184, 217, 181, 77, 318, ], [-168, -166, 166, -10, -16, -44, -47, -11, 253, -56, -46, -43, -5, -165, -4, -28, -19, -15, -26, 228, -35, -25, -7, -22, -57, -172, -16, -169, 166, -170, -171, -4, -32, -13, -173, -29, -48, -12, -33, -27, -49, -23, -167, -6, -34, -8, -18, -20, -21, -45, -17, -14, -9, -24, ]), 'TYPEDEF': ([58, 52, 242, 359, 358, 3, 123, 35, 28
 7, 34, 28, 227, 196, 38, 231, 26, 130, 165, 64, 327, 269, 15, 2, 37, 6, 205, 25, 51, 230, 133, 54, 73, 235, 280, 10, 5, 27, 31, 30, 117, 18, 332, 134, 221, 20, 8, 260, 67, 9, 13, 1, 387, 56, 60, 49, 23, 32, 237, 36, 116, 59, 140, 238, 339, 163, 17, 167, 277, 353, 12, 22, 65, 0, 4, 39, 360, ], [-222, -156, -219, -251, -134, 23, -173, -128, -250, -125, 23, -154, -248, -164, 23, -166, -170, -244, 23, 23, -221, -2, 23, -132, -122, -249, -120, -104, -171, -245, 23, -247, -172, -136, -119, -131, 23, -127, -241, -168, -126, -155, -223, 23, -167, -123, -218, -137, -124, -133, 23, -253, -246, 23, -165, -117, -242, 23, -129, -254, 23, 23, -169, -220, -217, -130, 23, -243, -135, -118, -3, -138, -1, -163, -121, -252, ]), 'AUTO': ([130, 287, 140, 60, 3, 133, 242, 31, 353, 116, 235, 327, 28, 34, 59, 8, 56, 269, 37, 27, 65, 18, 339, 221, 231, 13, 17, 39, 36, 332, 6, 10, 277, 230, 35, 26, 38, 32, 227, 67, 30, 64, 280, 15, 9, 360, 359, 25, 12, 73, 165, 387, 1, 49, 2, 117, 260, 123, 205, 5, 51, 23, 2
 38, 20, 237, 196, 4, 167, 58, 358, 22, 163, 52, 0, 134, 54, ], [-170, -250, 25, 25, 25, -245, -219, -127, -135, -254, -172, 25, 25, -125, 25, -123, -246, -221, -132, 25, -138, -126, -220, 25, 25, -133, -130, -121, -129, -155, -122, -119, -243, -171, -128, -166, -164, -242, -154, -137, -241, 25, -136, -2, -124, -252, -251, -120, -118, -247, -244, -253, 25, -165, 25, -168, -218, -173, -249, -131, -104, -117, -169, -167, 25, -248, -163, 25, -222, -134, -3, -217, -156, -1, -223, 25, ]), 'AND_OP': ([142, 101, 301, 97, 86, 308, 423, 77, 213, 364, 366, 109, 75, 295, 420, 311, 220, 211, 363, 84, 217, 296, 90, 110, 100, 300, 96, 106, 99, 302, 92, 83, 185, 89, 314, 104, 322, 299, 74, 105, 310, 410, 71, 307, 91, 368, 155, 313, 180, 292, 312, 303, 298, 309, 182, 306, 184, 318, 179, 317, 102, 291, 388, 297, 181, 315, 305, 85, 316, 78, ], [-56, -76, -67, -58, -68, -70, -35, -9, -28, -48, -25, -43, -18, -63, -34, -75, -46, -29, -57, -12, -17, -64, -11, -49, -22, -66, -73, -78, -16, -79, 198, -65,
 -47, -80, -7, -10, 198, -60, -20, -13, -6, -33, -82, -72, -19, -23, -4, -5, -16, -21, -74, -83, -61, -8, -44, -69, -45, -24, -15, -27, -4, -81, -32, -59, -14, -77, -71, -62, -26, -56, ]), ']': ([106, 316, 301, 303, 423, 102, 322, 368, 410, 296, 420, 77, 211, 74, 364, 363, 220, 292, 109, 180, 217, 112, 302, 298, 305, 99, 321, 160, 295, 89, 311, 318, 86, 300, 104, 83, 329, 309, 105, 97, 185, 131, 110, 315, 92, 224, 312, 181, 75, 313, 55, 328, 343, 308, 307, 96, 184, 71, 115, 182, 85, 388, 341, 375, 179, 101, 306, 213, 366, 314, 297, 391, 84, 78, 317, 299, 291, 100, 91, 90, 162, 142, 310, ], [-78, -26, -67, -83, -35, -4, -85, -23, -33, -64, -34, -9, -29, -20, -48, -57, -46, -21, -43, -16, -17, -86, -79, -61, -71, -16, 368, -101, -63, -80, -75, -24, -68, -66, -10, -65, 376, -8, -13, -58, -47, 238, -49, -77, -84, 330, -74, -14, -18, -5, 130, 374, -102, -70, -72, -73, -45, -82, -103, -44, -62, -32, -89, 393, -15, -76, -69, -28, -25, -7, -59, -87, -12, -56, -27, -60, -81, -22, -19, -11, -8
 8, -56, -6, ]), 'IF': ([260, 399, 382, 269, 413, 344, 406, 147, 380, 144, 134, 346, 58, 408, 405, 394, 51, 379, 259, 415, 268, 396, 340, 378, 60, 154, 240, 140, 261, 159, 242, 135, 263, 153, 243, 258, 139, 414, 267, 348, 338, 397, 158, 163, 143, 136, 339, 270, ], [-218, -229, 161, -221, -235, -216, 161, 161, 161, -226, -223, 161, -222, 161, -234, 161, -104, -215, -225, -230, -238, -232, -240, 161, 161, -213, 161, 161, -227, -211, -219, -210, 161, -224, -239, -237, -208, -233, 161, -214, -236, -231, 161, -217, -209, -212, -220, -228, ]), 'STRING_LITERAL': ([414, 134, 252, 412, 255, 193, 90, 105, 228, 216, 257, 249, 409, 179, 394, 260, 243, 210, 103, 76, 369, 55, 219, 245, 269, 354, 380, 192, 413, 208, 348, 84, 248, 218, 263, 289, 163, 201, 60, 136, 204, 242, 108, 268, 251, 151, 186, 51, 250, 240, 190, 207, 276, 94, 180, 256, 99, 377, 72, 189, 224, 258, 259, 166, 344, 95, 397, 264, 399, 284, 338, 405, 153, 415, 421, 408, 194, 346, 113, 367, 139, 342, 254, 340, 406, 411, 159, 147, 389,
  215, 174, 253, 135, 379, 158, 262, 188, 378, 107, 141, 267, 246, 143, 80, 197, 47, 74, 396, 144, 304, 261, 82, 328, 191, 217, 381, 247, 181, 339, 154, 198, 384, 58, 183, 203, 272, 137, 79, 266, 176, 293, 202, 382, 270, 140, ], [-233, -223, -96, 90, -97, 90, -11, -13, 90, 90, 90, -98, 90, -15, 90, -218, -239, 90, -54, 90, 90, 90, 90, -95, -221, 90, 90, 90, -235, 90, -214, -12, -100, 90, 90, 90, -217, 90, 90, -212, 90, -219, -53, -238, -92, 90, 90, -104, -91, 90, 90, 90, 90, -50, -16, 90, -16, 90, 90, 90, 90, -237, -225, 90, -216, -51, -231, 90, -229, 90, -236, -234, -224, -230, 90, 90, 90, 90, 90, 90, -208, 90, -94, -240, 90, 90, -211, 90, 90, 90, 90, -90, -210, -215, 90, 90, 90, 90, -55, 90, 90, -93, -209, 90, 90, 90, 90, -232, -226, 90, -227, -52, 90, 90, -17, 90, -99, -14, -220, -213, 90, 90, -222, 90, 90, 90, 90, 90, 90, 90, 90, 90, 90, -228, 90, ]), 'PP_IDENTIFIER_PASTE': ([102, 314, 99, 309, 155, ], [209, 206, 206, 206, 209, ]), 'PP_DEFINE_NAME': ([11, ], [47, ]), 'FLOAT': ([6
 4, 13, 186, 231, 165, 56, 1, 35, 39, 10, 277, 9, 360, 36, 49, 32, 237, 238, 227, 332, 168, 52, 278, 133, 287, 60, 116, 134, 283, 66, 23, 12, 356, 196, 260, 54, 6, 72, 73, 28, 58, 130, 4, 17, 0, 205, 359, 20, 81, 235, 123, 221, 167, 3, 51, 353, 358, 18, 387, 286, 172, 34, 170, 137, 65, 269, 22, 37, 26, 31, 27, 327, 163, 47, 25, 30, 59, 242, 140, 2, 67, 8, 169, 5, 279, 87, 339, 280, 117, 15, 230, 38, ], [31, -133, 31, 31, -244, -246, 31, -128, -121, -119, -243, -124, -252, -129, -165, -242, 31, -169, -154, -155, 31, -156, 31, -245, -250, 31, -254, -223, -144, 31, -117, -118, -143, -248, -218, 31, -122, 31, -247, 31, -222, -170, -163, -130, -1, -249, -251, -167, 31, -172, -173, 31, 31, 31, -104, -135, -134, -126, -253, 31, 31, -125, -141, 31, -138, -221, -3, -132, -166, -127, 31, 31, -217, 31, -120, -241, 31, -219, 31, 31, -137, -123, 31, -131, -142, 31, -220, -136, -168, -2, -171, -164, ]), 'LEFT_ASSIGN': ([314, 184, 180, 317, 313, 316, 366, 109, 364, 99, 318, 102, 410, 368, 100, 78,
 179, 423, 104, 309, 142, 74, 420, 110, 84, 292, 211, 388, 181, 220, 185, 90, 213, 182, 217, 310, 363, 105, 91, 155, 77, 75, ], [-7, -45, -16, -27, -5, -26, -25, -43, -48, -16, -24, -4, -33, -23, -22, -56, -15, -35, -10, -8, 252, -20, -34, -49, -12, -21, -29, -32, -14, -46, -47, -11, -28, -44, -17, -6, -57, -13, -19, -4, -9, -18, ]), '}': ([157, 283, 292, 379, 413, 181, 269, 278, 275, 344, 261, 112, 242, 322, 303, 296, 383, 391, 71, 384, 159, 300, 102, 286, 142, 364, 85, 211, 220, 51, 60, 139, 109, 120, 154, 163, 338, 260, 106, 115, 119, 279, 352, 258, 312, 298, 313, 84, 340, 302, 311, 268, 317, 414, 366, 91, 420, 179, 136, 363, 397, 77, 333, 122, 243, 74, 368, 162, 135, 240, 217, 226, 401, 396, 169, 356, 351, 299, 182, 308, 270, 309, 339, 348, 306, 334, 291, 388, 104, 147, 89, 90, 99, 315, 105, 144, 400, 97, 399, 140, 185, 101, 297, 110, 423, 213, 301, 310, 78, 295, 307, 316, 75, 410, 259, 405, 121, 341, 96, 58, 184, 305, 314, 180, 100, 170, 134, 143, 318, 86, 415, 83, 153, 92, 229,
  ], [269, -144, -21, -215, -235, -14, -221, 353, -203, -216, -227, -86, -219, -85, -83, -64, -204, -87, -82, 401, -211, -66, -4, 358, -56, -48, -62, -29, -46, -104, 163, -208, -43, 227, -213, -217, -236, -218, -78, -103, -159, -142, 383, -237, -74, -61, -5, -12, -240, -79, -75, -238, -27, -233, -25, -19, -34, -15, -212, -57, -231, -9, -162, -157, -239, -20, -23, -88, -210, 339, -17, 332, -205, -232, 280, -143, -206, -60, -44, -70, -228, -8, -220, -214, -69, -160, -81, -32, -10, 260, -80, -11, -16, -77, -13, -226, -207, -58, -229, 242, -47, -76, -59, -49, -35, -28, -67, -6, -56, -63, -72, -26, -18, -33, -225, -234, -161, -89, -73, -222, -45, -71, -7, -16, -22, -141, -223, -209, -24, -68, -230, -65, -224, -84, -158, ]), }
+_lr_action_items = {'VOID':([387,15,238,332,22,3,37,359,137,64,170,286,58,51,230,353,12,2,39,73,20,60,47,54,25,65,168,56,242,81,0,13,27,72,116,278,4,133,277,231,221,9,280,279,34,186,130,169,358,227,18,123,327,1,360,117,17,36,165,205,30,8,52,196,35,356,339,140,269,235,23,283,31,167,134,260,287,87,5,6,10,32,38,66,28,163,59,49,237,26,67,172,],[-253,-2,-169,-155,-3,6,-132,-251,6,6,-141,6,-222,-104,-171,-135,-118,6,-121,-247,-167,6,6,6,-120,-138,6,-246,-219,6,-1,-133,6,6,-254,6,-163,-245,-243,6,6,-124,-136,-142,-125,6,-170,6,-134,-154,-126,-173,6,6,-252,-168,-130,-129,-244,-249,-241,-123,-156,-248,-128,-143,-220,6,-221,-172,-117,-144,-127,6,-223,-218,-250,6,-131,-122,-119,-242,-164,6,6,-217,6,-165,6,-166,-137,6,]),'DIV_ASSIGN':([309,155,363,91,179,366,182,180,316,217,313,75,317,181,211,100,102,184,388,423,77,314,420,410,99,142,78,310,318,185,213,74,90,104,292,220,84,105,110,364,368,109,],[-8,-4,-57,-19,-15,-25,-44,-16,-26,-17,-5,-18,-27,-14,-29,-22,-4,-45,-32,-35,-9,-7,-34,-33,-16,251,-5
 6,-6,-24,-47,-28,-20,-11,-10,-21,-46,-12,-13,-49,-48,-23,-43,]),'PP_DEFINE':([205,30,116,56,51,277,287,359,260,387,163,196,32,339,360,15,242,0,165,73,269,22,1,133,],[-249,-241,-254,-246,-104,-243,-250,-251,-218,-253,-217,-248,-242,-220,-252,-2,-219,-1,-244,-247,-221,-3,11,-245,]),'LE_OP':([78,310,100,368,301,184,96,311,211,90,297,309,220,298,364,75,155,318,102,182,423,305,104,91,110,74,213,99,109,299,86,185,97,105,77,410,296,179,181,363,84,295,217,420,180,312,292,366,388,317,306,308,313,316,142,314,85,307,83,300,],[-56,-6,-22,-23,-67,-45,201,201,-29,-11,-59,-8,-46,-61,-48,-18,-4,-24,-4,-44,-35,-71,-10,-19,-49,-20,-28,-16,-43,-60,-68,-47,-58,-13,-9,-33,-64,-15,-14,-57,-12,-63,-17,-34,-16,201,-21,-25,-32,-27,-69,-70,-5,-26,-56,-7,-62,-72,-65,-66,]),'(':([9,280,3,324,133,145,67,22,130,276,108,218,55,254,75,155,199,60,243,409,314,151,248,28,358,93,36,113,405,339,25,263,360,189,102,268,210,377,14,79,165,99,257,158,223,235,380,376,250,366,187,52,117,166,231,72,397,196,87,208,17,143,30,163
 ,353,105,13,284,57,6,141,181,193,201,260,272,379,242,46,123,44,277,289,154,247,190,255,270,135,179,114,134,84,29,228,240,49,152,82,217,331,399,5,316,2,91,38,213,225,387,349,15,292,357,234,35,384,198,354,171,76,186,317,23,330,0,65,8,109,211,144,342,287,41,252,61,414,293,26,140,205,249,37,51,328,137,90,408,95,34,107,261,204,381,238,47,103,346,374,183,269,382,203,10,68,80,313,262,371,413,159,94,20,32,259,221,164,176,367,73,344,153,267,197,58,372,194,230,340,393,161,338,127,207,219,136,7,104,378,195,150,215,56,100,258,180,266,369,192,1,359,45,147,402,191,188,253,415,246,332,18,74,309,256,264,31,43,370,392,174,251,116,202,39,310,396,216,318,139,4,69,16,81,227,224,394,406,12,77,348,368,42,245,200,],[-124,-136,-111,-199,-245,257,-137,-3,-170,137,-53,72,72,-94,-18,-4,-42,137,-239,137,-7,72,-100,-109,-134,-41,-129,72,-234,-220,-120,137,-252,72,-4,-238,72,137,16,183,-244,-16,137,137,327,-172,137,-196,-91,-25,-145,-156,-168,137,231,137,-231,-248,-148,72,-130,-209,-241,-217,-135,-13,-133,72,16,
 -122,137,-14,72,72,-218,137,-215,-219,70,-173,-178,-243,72,-213,-99,72,-97,-228,-210,-15,221,-223,-12,16,72,137,54,266,-52,-17,327,-229,-131,-26,-107,-19,-164,-28,221,-253,381,-2,-21,16,231,-128,137,72,72,16,183,137,-27,-117,-195,-1,-138,-123,215,-29,-226,137,-250,-108,-96,-110,-233,72,54,137,-249,-98,-132,-104,72,137,-11,137,-51,-125,-55,-227,72,137,-169,72,-54,137,-197,137,-221,137,72,-119,-179,186,-5,137,-194,-235,-211,-50,-167,-242,-225,221,16,72,137,-247,-216,-224,137,72,-222,-201,72,-171,-240,-198,272,-236,231,72,137,-212,-174,-10,137,-147,264,137,-246,-22,-237,-16,137,72,72,16,-251,-176,137,409,72,72,-90,-230,-93,-155,-126,-20,-8,137,137,-127,-175,-200,-202,72,-92,-254,72,-121,-6,-232,137,-24,-208,-163,-177,16,-146,-154,72,137,137,-118,-9,-214,-23,-112,-95,304,]),'STRUCT':([15,17,140,64,221,277,238,186,39,359,12,165,283,26,360,87,170,18,227,278,37,3,27,31,123,59,54,66,32,72,237,116,231,38,242,10,51,67,117,1,235,5,353,22,260,134,205,36,269,230,133,280,356,6,286,73,25,327,137,2
 79,169,56,339,65,358,0,4,35,387,196,47,60,130,9,13,172,20,49,81,30,332,23,58,163,167,52,34,168,287,2,8,28,],[-2,-130,33,33,33,-243,-169,33,-121,-251,-118,-244,-144,-166,-252,33,-141,-126,-154,33,-132,33,33,-127,-173,33,33,33,-242,33,33,-254,33,-164,-219,-119,-104,-137,-168,33,-172,-131,-135,-3,-218,-223,-249,-129,-221,-171,-245,-136,-143,-122,33,-247,-120,33,33,-142,33,-246,-220,-138,-134,-1,-163,-128,-253,-248,33,33,-170,-124,-133,33,-167,-165,33,-241,-155,-117,-222,-217,33,-156,-125,33,-250,33,-123,33,]),',':([182,244,274,90,39,100,300,372,313,395,185,318,390,345,386,370,311,38,403,347,65,75,234,4,45,106,421,323,355,220,92,315,376,238,110,402,321,13,74,301,362,132,117,173,127,235,34,96,314,423,280,213,295,142,85,331,121,177,8,49,126,179,296,25,337,180,5,31,322,52,112,366,422,119,398,330,388,77,383,101,41,67,316,416,162,86,374,128,123,417,364,230,102,68,305,281,307,9,35,352,20,306,332,61,122,308,26,78,6,401,275,392,43,389,297,418,28,317,343,148,184,358,368,97,400,129,155,36,42,104,
 419,291,124,2,64,312,410,353,282,175,292,333,10,335,391,181,62,299,89,115,232,17,285,404,12,18,44,303,385,341,334,211,83,298,37,63,351,393,223,69,363,3,105,412,7,130,23,84,302,109,91,420,71,309,319,217,273,350,227,99,371,233,324,320,160,310,],[-44,262,-116,-11,-121,-22,-66,-201,-5,262,-47,-24,-31,262,-150,-200,-75,-164,-37,262,-138,-18,-191,-163,-176,-78,-36,262,-152,-46,-84,-77,-196,-169,-49,-39,262,-133,-20,-67,-256,-115,-168,-255,-186,-172,-125,-73,-7,-35,-136,-28,-63,-56,-62,-193,-161,262,-123,-165,-182,-15,-64,-120,-183,-16,-131,-127,-85,-156,-86,-25,411,-159,262,-195,-32,-9,-204,-76,-108,-137,-26,262,-88,-68,-197,236,-173,-38,-48,-171,-4,-179,-71,-149,-72,-124,-128,384,-167,-69,-155,-110,229,-70,-166,-56,-122,-205,-203,-202,-175,-36,-59,411,-109,-27,-102,262,-45,-134,-23,-58,-207,237,-4,-129,-112,-10,-40,-81,-187,-107,-115,-74,-33,-135,-151,290,-21,-162,-119,-188,-87,-14,-113,-60,-80,-103,-185,-130,357,411,-118,-126,-178,-83,-153,-89,-160,-29,-65,-61,-132,164,-206,-198,-192,-1
 77,-57,-111,-13,-36,-174,-170,-117,-12,-79,-43,-19,-34,-82,-8,-30,-17,-114,262,-154,-16,-194,-184,-199,367,-101,-6,]),'LONG':([237,286,52,51,56,31,36,353,134,205,87,9,18,287,356,67,358,17,230,130,54,123,37,27,116,35,22,10,137,165,231,196,278,186,277,58,3,38,283,64,23,72,238,32,47,172,59,39,4,360,117,81,140,12,242,260,387,168,25,5,0,167,169,66,227,327,28,280,65,8,30,339,34,73,13,279,26,6,133,359,269,49,221,170,15,20,332,235,60,2,163,1,],[18,18,-156,-104,-246,-127,-129,-135,-223,-249,18,-124,-126,-250,-143,-137,-134,-130,-171,-170,18,-173,-132,18,-254,-128,-3,-119,18,-244,18,-248,18,18,-243,-222,18,-164,-144,18,-117,18,-169,-242,18,18,18,-121,-163,-252,-168,18,18,-118,-219,-218,-253,18,-120,-131,-1,18,18,18,-154,18,18,-136,-138,-123,-241,-220,-125,-247,-133,-142,-166,-122,-245,-251,-221,-165,18,-141,-2,-167,-155,-172,18,18,-217,18,]),'ELLIPSIS':([237,],[336,]),'<':([423,217,301,364,109,366,313,420,368,295,85,77,102,305,292,388,96,90,184,314,312,181,104,363,316,297,299,317,155,99,213,1
 42,91,105,179,309,78,75,410,310,182,296,306,97,185,86,298,211,83,311,300,100,308,307,318,74,84,220,180,110,],[-35,-17,-67,-48,-43,-25,-5,-34,-23,-63,-62,-9,-4,-71,-21,-32,202,-11,-45,-7,202,-14,-10,-57,-26,-59,-60,-27,-4,-16,-28,-56,-19,-13,-15,-8,-56,-18,-33,-6,-44,-64,-69,-58,-47,-68,-61,-29,-65,202,-66,-22,-70,-72,-24,-20,-12,-46,-16,-49,]),'GOTO':([136,394,263,153,415,399,338,414,163,268,269,260,261,51,243,258,135,159,405,60,344,147,270,58,413,240,140,408,406,346,267,348,396,259,134,397,154,242,340,378,144,143,380,379,382,339,158,139,],[-212,138,138,-224,-230,-229,-236,-233,-217,-238,-221,-218,-227,-104,-239,-237,-210,-211,-234,138,-216,138,-228,-222,-235,138,138,138,138,138,138,-214,-232,-225,-223,-231,-213,-219,-240,138,-226,-209,138,-215,138,-220,138,-208,]),'ENUM':([59,3,8,327,130,72,10,260,172,169,332,13,231,9,73,279,167,163,356,81,230,137,116,47,238,269,227,133,117,37,12,170,221,237,34,87,2,360,280,66,58,168,242,277,65,23,39,28,20,22,196,5,18,32,15,31,278,1,17,205,283,123,
 52,25,51,6,67,30,358,35,287,339,235,60,36,387,38,54,0,165,26,64,56,359,140,353,4,134,186,49,27,286,],[24,24,-123,24,-170,24,-119,-218,24,24,-155,-133,24,-124,-247,-142,24,-217,-143,24,-171,24,-254,24,-169,-221,-154,-245,-168,-132,-118,-141,24,24,-125,24,24,-252,-136,24,-222,24,-219,-243,-138,-117,-121,24,-167,-3,-248,-131,-126,-242,-2,-127,24,24,-130,-249,-144,-173,-156,-120,-104,-122,-137,-241,-134,-128,-250,-220,-172,24,-129,-253,-164,24,-1,-244,-166,24,-246,-251,24,-135,-163,-223,24,-165,24,24,]),'PERIOD':([104,309,84,109,105,91,90,179,99,213,313,77,211,155,75,100,366,310,292,368,180,217,318,317,314,181,316,102,74,],[-10,-8,-12,212,-13,-19,-11,-15,-16,-28,-5,-9,-29,-4,-18,-22,-25,-6,-21,-23,-16,-17,-24,-27,-7,-14,-26,-4,-20,]),'PP_END_DEFINE':([310,306,311,100,36,101,112,91,361,115,74,292,88,114,371,307,84,289,280,65,83,331,17,318,5,330,391,308,305,316,6,368,364,110,358,195,388,96,97,44,312,332,303,315,86,322,180,302,222,288,353,223,43,291,67,220,179,370,317,7,366,423,182,181,31,
 314,4,69,106,81,71,18,372,35,309,37,217,109,313,8,75,376,187,105,393,363,52,48,211,301,298,102,184,38,185,45,77,13,68,324,227,392,420,174,104,213,225,9,90,297,410,300,47,99,374,89,85,296,92,87,34,299,78,98,295,],[-6,-69,-75,-22,-129,-76,-86,-19,387,-103,-20,-21,196,-189,-194,-72,-12,360,-136,-138,-65,-193,-130,-24,-131,-195,-87,-70,-71,-26,-122,-23,-48,-49,-134,-147,-32,-73,-58,-178,-74,-155,-83,-77,-68,-85,-16,-79,-190,359,-135,-192,-175,-81,-137,-46,-15,-200,-27,-174,-25,-35,-44,-14,-127,-7,-163,-177,-78,-146,-82,-126,-201,-128,-8,-132,-17,-43,-5,-123,-18,-196,-145,-13,-198,-57,-156,116,-29,-67,-61,-4,-45,-164,-47,-176,-9,-133,-179,-199,-154,-202,-34,287,-10,-28,-191,-124,-11,-59,-33,-66,73,-16,-197,-80,-62,-64,-84,-148,-125,-60,-56,205,-63,]),'LEFT_OP':([423,142,110,299,309,308,77,292,306,75,295,305,388,86,179,217,91,364,155,220,180,105,310,213,410,104,366,90,313,211,317,97,100,316,182,84,85,298,420,296,318,314,363,185,83,184,368,74,300,307,99,181,102,109,297,301,78,],[-35,-56,-4
 9,-60,-8,193,-9,-21,193,-18,-63,193,-32,193,-15,-17,-19,-48,-4,-46,-16,-13,-6,-28,-33,-10,-25,-11,-5,-29,-27,-58,-22,-26,-44,-12,-62,-61,-34,-64,-24,-7,-57,-47,-65,-45,-23,-20,-66,193,-16,-14,-4,-43,-59,-67,-56,]),'DOUBLE':([6,278,221,4,2,27,18,286,279,186,0,358,1,10,116,327,35,140,227,37,65,167,8,9,81,353,54,73,28,280,47,133,360,66,170,20,36,58,230,64,283,231,168,169,67,56,39,72,196,130,238,12,13,31,137,242,5,277,134,387,49,172,22,3,23,332,25,38,60,356,165,15,205,237,87,30,339,34,52,59,163,269,287,26,235,32,51,260,117,17,123,359,],[-122,35,35,-163,35,35,-126,35,-142,35,-1,-134,35,-119,-254,35,-128,35,-154,-132,-138,35,-123,-124,35,-135,35,-247,35,-136,35,-245,-252,35,-141,-167,-129,-222,-171,35,-144,35,35,35,-137,-246,-121,35,-248,-170,-169,-118,-133,-127,35,-219,-131,-243,-223,-253,-165,35,-3,35,-117,-155,-120,-164,35,-143,-244,-2,-249,35,35,-241,-220,-125,-156,35,-217,-221,-250,-166,-172,-242,-104,-218,-168,-130,-173,-251,]),'INC_OP':([210,189,255,264,159,378,188,348,366,397,245,
 270,408,328,102,252,317,399,316,174,224,213,242,267,191,99,380,109,140,134,415,284,163,192,257,181,256,249,77,381,346,396,262,55,84,215,94,135,394,384,247,217,208,377,379,166,216,74,113,259,183,91,139,251,276,155,344,180,137,413,151,266,80,190,340,405,219,248,313,47,76,141,207,153,254,79,369,338,158,318,198,197,105,204,409,269,243,60,268,176,100,194,143,258,51,211,90,240,144,414,228,293,107,201,367,246,179,310,58,289,339,103,218,368,382,272,261,75,104,260,253,147,309,186,72,203,82,342,136,108,250,406,154,314,202,193,263,292,354,95,],[76,76,-97,76,-211,76,76,-214,-25,-231,-95,-228,76,76,-4,-96,-27,-229,-26,76,76,-28,-219,76,76,-16,76,213,76,-223,-230,76,-217,76,76,-14,76,-98,-9,76,76,-232,76,76,-12,76,-50,-210,76,76,-99,-17,76,76,-215,76,76,-20,76,-225,76,-19,-208,-92,76,-4,-216,-16,76,-235,76,76,76,76,-240,-234,76,-100,-5,76,76,76,76,-224,-94,76,76,-236,76,-24,76,76,-13,76,76,-221,-239,76,-238,76,-22,76,-209,-237,-104,-29,-11,76,-226,-233,76,76,-55,76,76,-93,-15,-6,-222,76,-220,-54,
 76,-23,76,76,-227,-18,-10,-218,-90,76,-8,76,76,76,-52,76,-212,-53,-91,76,-213,-7,76,76,76,-21,76,-51,]),'|':([316,109,105,420,104,155,314,213,301,297,317,89,296,182,85,308,309,78,305,423,211,368,300,388,100,313,96,86,97,184,185,74,315,180,311,307,292,84,366,363,77,99,181,299,142,364,303,75,310,295,306,291,91,179,102,298,83,410,318,90,220,217,110,106,312,101,302,71,],[-26,-43,-13,-34,-10,-4,-7,-28,-67,-59,-27,-80,-64,-44,-62,-70,-8,-56,-71,-35,-29,-23,-66,-32,-22,-5,-73,-68,-58,-45,-47,-20,-77,-16,-75,-72,-21,-12,-25,-57,-9,-16,-14,-60,-56,-48,176,-18,-6,-63,-69,-81,-19,-15,-4,-61,-65,-33,-24,-11,-46,-17,-49,-78,-74,-76,-79,176,]),'NE_OP':([109,364,105,213,182,297,420,104,78,317,410,313,85,155,309,74,296,86,316,101,308,97,185,423,368,300,388,100,96,184,180,211,292,305,77,84,142,311,181,307,301,310,363,99,306,298,318,90,314,75,299,110,295,91,217,179,220,83,315,102,366,312,],[-43,-48,-13,-28,-44,-59,-34,-10,-56,-27,-33,-5,-62,-4,-8,-20,-64,-68,-26,207,-70,-58,-47,-35,-23,-66,-32,-22,-7
 3,-45,-16,-29,-21,-71,-9,-12,-56,-75,-14,-72,-67,-6,-57,-16,-69,-61,-24,-11,-7,-18,-60,-49,-63,-19,-17,-15,-46,-65,207,-4,-25,-74,]),'SHORT':([10,81,51,36,13,339,26,27,8,30,387,196,356,230,12,231,278,260,163,54,123,67,1,170,286,73,287,242,18,15,47,0,87,6,221,34,3,37,279,137,269,238,283,327,56,58,277,31,17,59,72,205,237,9,38,20,235,169,23,167,227,186,130,168,133,165,134,49,332,22,116,35,4,353,32,64,66,140,39,25,52,280,2,28,5,172,117,358,359,65,60,360,],[-119,9,-104,-129,-133,-220,-166,9,-123,-241,-253,-248,-143,-171,-118,9,9,-218,-217,9,-173,-137,9,-141,9,-247,-250,-219,-126,-2,9,-1,9,-122,9,-125,9,-132,-142,9,-221,-169,-144,9,-246,-222,-243,-127,-130,9,9,-249,9,-124,-164,-167,-172,9,-117,9,-154,9,-170,9,-245,-244,-223,-165,-155,-3,-254,-128,-163,-135,-242,9,9,9,-121,-120,-156,-136,9,9,-131,9,-168,-134,-251,-138,9,-252,]),'CONSTANT':([55,257,163,47,144,328,263,190,197,140,399,251,176,266,354,76,203,367,409,381,137,284,378,58,192,240,174,408,380,270,51,94,154,267,369,151,253,260,259,7
 2,250,191,258,82,242,208,248,183,202,228,60,276,194,153,166,193,136,224,159,269,158,80,396,339,204,216,377,261,107,198,346,384,188,406,338,201,141,340,147,348,186,249,215,382,219,139,207,414,394,254,262,218,247,256,344,246,415,210,143,245,413,289,135,113,79,379,252,189,272,134,293,405,255,268,264,342,103,397,243,95,108,],[77,77,-217,77,-226,77,77,77,77,77,-229,-92,77,77,77,77,77,77,77,77,77,77,77,-222,77,77,77,77,77,-228,-104,-50,-213,77,77,77,-90,-218,-225,77,-91,77,-237,-52,-219,77,-100,77,77,77,77,77,77,-224,77,77,-212,77,-211,-221,77,77,-232,-220,77,77,77,-227,-55,77,77,77,77,77,-236,77,77,-240,77,-214,77,-98,77,77,77,-208,77,-233,77,-94,77,77,-99,77,-216,-93,-230,77,-209,-95,-235,77,-210,77,77,-215,-96,77,77,-223,77,-234,-97,-238,77,77,-54,-231,-239,-51,-53,]),'DEC_OP':([397,192,190,252,258,245,109,268,90,219,246,228,211,75,250,95,409,240,249,113,270,405,256,94,310,55,316,313,100,47,276,198,269,254,259,99,354,263,314,140,379,134,208,257,266,74,108,144,76,155,215,255,210,166,193
 ,158,413,253,176,309,243,340,396,204,186,135,213,292,247,203,348,179,107,378,242,394,139,218,217,79,328,384,201,194,105,143,154,82,284,382,137,414,260,181,103,147,191,174,262,102,408,51,202,58,267,369,289,91,72,261,399,344,338,159,248,272,163,264,104,293,342,188,197,153,180,381,380,84,346,207,317,224,251,151,339,216,80,367,318,406,415,189,368,366,377,141,136,77,183,60,],[-231,79,79,-96,-237,-95,211,-238,-11,79,-93,79,-29,-18,-91,-51,79,79,-98,79,-228,-234,79,-50,-6,79,-26,-5,-22,79,79,79,-221,-94,-225,-16,79,79,-7,79,-215,-223,79,79,79,-20,-53,-226,79,-4,79,-97,79,79,79,79,-235,-90,79,-8,-239,-240,-232,79,79,-210,-28,-21,-99,79,-214,-15,-55,79,-219,79,-208,79,-17,79,79,79,79,79,-13,-209,-213,-52,79,79,79,-233,-218,-14,-54,79,79,79,79,-4,79,-104,79,-222,79,79,79,-19,79,-227,-229,-216,-236,-211,-100,79,-217,79,-10,79,79,79,79,-224,-16,79,79,-12,79,79,-27,79,-92,79,-220,79,79,79,-24,79,-230,79,-23,-25,79,79,-212,-9,79,79,]),'STATIC':([358,130,123,49,360,327,117,37,28,25,140,3,235,359,3
 0,205,0,237,230,6,58,339,9,27,31,12,4,8,22,39,35,1,134,56,242,387,18,51,238,32,13,64,38,36,163,59,10,60,5,260,2,287,167,221,20,52,332,227,73,17,15,280,54,196,26,116,23,67,269,65,277,353,34,133,165,231,],[-134,-170,-173,-165,-252,10,-168,-132,10,-120,10,10,-172,-251,-241,-249,-1,10,-171,-122,-222,-220,-124,10,-127,-118,-163,-123,-3,-121,-128,10,-223,-246,-219,-253,-126,-104,-169,-242,-133,10,-164,-129,-217,10,-119,10,-131,-218,10,-250,10,10,-167,-156,-155,-154,-247,-130,-2,-136,10,-248,-166,-254,-117,-137,-221,-138,-243,-135,-125,-245,-244,10,]),'EQ_OP':([100,308,311,314,101,301,185,423,99,307,90,142,297,77,410,220,96,78,110,295,97,298,84,184,74,363,104,83,312,299,318,315,213,366,182,305,292,364,309,300,86,316,155,180,306,109,85,388,296,313,105,91,181,179,211,310,102,217,420,317,368,75,],[-22,-70,-75,-7,208,-67,-47,-35,-16,-72,-11,-56,-59,-9,-33,-46,-73,-56,-49,-63,-58,-61,-12,-45,-20,-57,-10,-65,-74,-60,-24,208,-28,-25,-44,-71,-21,-48,-8,-66,-68,-26,-4,-16,-69,-43,-62,-32,-64,-5,-13
 ,-19,-14,-15,-29,-6,-4,-17,-34,-27,-23,-18,]),'SIZEOF':([80,203,192,268,247,107,284,191,396,219,253,249,339,95,415,406,381,60,269,346,190,264,243,82,263,259,207,151,158,405,163,147,58,197,262,141,55,218,266,76,137,51,293,204,188,270,245,79,380,193,378,72,342,134,240,413,379,255,246,369,338,367,408,143,103,144,250,414,377,153,409,272,251,113,397,139,216,94,267,210,194,215,166,384,189,140,260,183,174,108,394,276,201,136,399,261,256,252,328,135,248,242,154,254,186,159,257,208,340,47,354,198,289,228,258,224,382,348,176,344,202,],[80,80,80,-238,-99,-55,80,80,-232,80,-90,-98,-220,-51,-230,80,80,80,-221,80,80,80,-239,-52,80,-225,80,80,80,-234,-217,80,-222,80,80,80,80,80,80,80,80,-104,80,80,80,-228,-95,80,80,80,80,80,80,-223,80,-235,-215,-97,-93,80,-236,80,80,-209,-54,-226,-91,-233,80,-224,80,80,-92,80,-231,-208,80,-50,80,80,80,80,80,80,80,80,-218,80,80,-53,80,80,80,-212,-229,-227,80,-96,80,-210,-100,-219,-213,-94,80,-211,80,80,-240,80,80,80,80,80,-237,80,80,-214,80,-216,80,]),'+':([208,109
 ,289,245,191,60,110,405,147,144,293,252,183,269,409,268,217,318,354,100,94,105,192,246,314,83,295,243,317,414,310,248,420,179,107,264,363,316,298,366,377,276,134,301,79,99,136,257,256,166,55,84,140,190,253,261,260,339,186,213,210,263,266,182,193,348,378,368,242,142,408,309,51,394,215,296,197,284,249,113,153,299,155,340,396,204,344,218,254,228,194,159,211,85,75,154,82,135,313,220,247,240,181,180,97,74,369,262,47,207,384,258,381,76,103,216,90,80,143,388,415,379,410,338,342,267,141,270,78,72,201,300,108,91,176,399,382,406,292,189,297,188,95,203,77,272,413,163,380,104,174,102,397,139,346,328,202,224,251,151,259,185,184,137,58,367,423,198,364,158,255,219,250,],[82,-43,82,-95,82,82,-49,-234,82,-226,82,-96,82,-221,82,-238,-17,-24,82,-22,-50,-13,82,-93,-7,188,-63,-239,-27,-233,-6,-100,-34,-15,-55,82,-57,-26,-61,-25,82,82,-223,188,82,-16,-212,82,82,82,82,-12,82,82,-90,-227,-218,-220,82,-28,82,82,82,-44,82,-214,82,-23,-219,-56,82,-8,-104,82,82,-64,82,82,-98,82,-224,-60,-4,-240,-232,82,-216,82
 ,-94,82,82,-211,-29,-62,-18,-213,-52,-210,-5,-46,-99,82,-14,-16,-58,-20,82,82,82,82,82,-237,82,82,-54,82,-11,82,-209,-32,-230,-215,-33,-236,82,82,82,-228,-56,82,82,188,-53,-19,82,-229,82,82,-21,82,-59,82,-51,82,-9,82,-235,-217,82,-10,82,-4,-231,-208,82,82,82,82,-92,82,-225,-47,-45,82,-222,82,-35,82,-48,82,-97,82,-91,]),'UNSIGNED':([36,235,52,8,133,18,66,287,35,170,20,49,221,205,358,22,2,10,353,277,242,231,73,140,64,67,59,39,87,134,54,196,356,137,186,283,47,3,359,165,5,60,38,227,230,116,360,4,278,65,37,32,28,12,172,23,81,387,167,17,327,13,130,27,58,168,51,30,31,0,169,117,56,279,1,237,339,238,280,260,26,286,6,72,34,123,25,163,269,9,332,15,],[-129,-172,-156,-123,-245,-126,17,-250,-128,-141,-167,-165,17,-249,-134,-3,17,-119,-135,-243,-219,17,-247,17,17,-137,17,-121,17,-223,17,-248,-143,17,17,-144,17,17,-251,-244,-131,17,-164,-154,-171,-254,-252,-163,17,-138,-132,-242,17,-118,17,-117,17,-253,17,-130,17,-133,-170,17,-222,17,-104,-241,-127,-1,17,-168,-246,-142,17,17,-220,-169,-136,-218,-16
 6,17,-122,17,-125,-173,-120,-217,-221,-124,-155,-2,]),'/':([84,99,155,180,77,90,368,142,388,211,75,109,217,292,313,364,91,100,423,317,78,314,295,410,213,297,102,105,110,363,184,104,309,316,318,298,97,185,420,181,310,74,179,296,299,220,182,85,366,],[-12,-16,-4,-16,-9,-11,-23,-56,-32,-29,-18,-43,-17,-21,-5,-48,-19,-22,-35,-27,-56,-7,192,-33,-28,-59,-4,-13,-49,-57,-45,-10,-8,-26,-24,-61,-58,-47,-34,-14,-6,-20,-15,192,-60,-46,-44,192,-25,]),';':([42,130,90,285,316,341,38,77,63,401,67,312,342,134,301,5,182,75,4,348,52,309,397,280,83,12,17,240,303,60,317,148,74,405,162,25,263,298,2,385,311,257,158,185,306,241,99,28,184,136,10,235,410,353,36,302,299,243,117,261,84,144,260,35,220,49,380,181,64,269,339,268,26,57,242,105,6,160,34,413,135,296,414,143,87,3,244,382,19,292,155,29,115,132,217,146,163,37,106,346,8,123,408,211,140,85,310,154,171,65,343,153,338,391,91,386,179,364,314,230,399,156,363,394,187,61,238,275,109,407,180,300,41,388,270,89,18,100,379,308,396,322,97,213,273,96,23,58,71,159,81,
 318,281,378,142,104,258,51,102,139,62,355,112,110,147,332,20,195,420,282,157,297,315,13,340,274,344,291,305,78,9,358,313,239,86,415,31,259,295,92,307,423,39,383,267,141,406,368,227,101,366,],[-112,-170,-11,356,-26,-89,-164,-9,-106,-205,-137,-74,144,-223,-67,-131,-44,-18,-163,-214,-156,-8,-231,-136,-65,-118,-130,144,-83,144,-27,261,-20,-234,-88,-120,144,-61,-107,-153,-75,144,144,-47,-69,270,-16,-109,-45,-212,-119,-172,-33,-135,-129,-79,-60,-239,-168,-227,-12,-226,-218,-128,-46,-165,144,-14,-115,-221,-220,-238,-166,-105,-219,-13,-122,-101,-125,-235,-210,-64,-233,-209,-148,-111,340,144,51,-21,-4,-105,-103,-115,-17,258,-217,-132,-78,144,-123,-173,144,-29,144,-62,-6,-213,283,-138,-102,-224,-236,-87,-19,-150,-15,-48,-7,-171,-229,268,-57,144,-145,-110,-169,-203,-43,414,-16,-66,-108,-32,-228,-80,-126,-22,-215,-70,-232,-85,-58,-28,-114,-73,-117,-222,-82,-211,-146,-24,-149,144,-56,-10,-237,-104,-4,-208,-113,-152,-86,-49,144,-155,-167,-147,-34,-151,270,-59,-77,-133,-240,-116,-216,-81,-71,-56,-
 124,-134,-5,338,-68,-230,-127,-225,-63,-84,-72,-35,-121,-204,144,243,144,-23,-154,-76,-25,]),'?':([85,155,302,77,99,91,410,90,388,100,211,96,92,217,179,101,97,420,423,89,303,317,363,110,184,313,74,180,309,291,102,305,112,185,368,301,86,297,181,142,104,78,318,314,310,306,315,84,298,312,300,220,182,311,307,83,366,299,75,106,295,109,316,292,105,296,364,308,322,213,71,],[-62,-4,-79,-9,-16,-19,-33,-11,-32,-22,-29,-73,-84,-17,-15,-76,-58,-34,-35,-80,-83,-27,-57,-49,-45,-5,-20,-16,-8,-81,-4,-71,219,-47,-23,-67,-68,-59,-14,-56,-10,-56,-24,-7,-6,-69,-77,-12,-61,-74,-66,-46,-44,-75,-72,-65,-25,-60,-18,-78,-63,-43,-26,-21,-13,-64,-48,-70,-85,-28,-82,]),'$end':([73,339,15,165,51,359,1,0,133,387,287,116,56,32,22,277,269,242,260,196,360,30,205,163,],[-247,-220,-2,-244,-104,-251,0,-1,-245,-253,-250,-254,-246,-242,-3,-243,-221,-219,-218,-248,-252,-241,-249,-217,]),'FOR':([340,60,135,144,268,153,143,139,338,396,378,147,346,58,397,136,260,413,394,406,339,159,134,348,154,242,51,263,259,379,158,267,344
 ,405,408,380,163,140,240,382,261,243,415,269,399,258,270,414,],[-240,145,-210,-226,-238,-224,-209,-208,-236,-232,145,145,145,-222,-231,-212,-218,-235,145,145,-220,-211,-223,-214,-213,-219,-104,145,-225,-215,145,145,-216,-234,145,145,-217,145,145,145,-227,-239,-230,-221,-229,-237,-228,-233,]),'UNION':([65,242,238,37,278,287,260,13,3,23,81,137,58,387,30,34,186,56,1,140,51,66,205,38,130,116,170,269,227,64,172,72,22,17,36,286,12,280,332,39,230,353,163,0,8,60,27,35,169,31,5,123,231,67,10,52,20,221,47,327,32,15,358,283,73,18,26,59,167,134,235,49,168,6,9,4,359,339,237,277,279,360,25,133,356,165,2,87,54,28,196,117,],[-138,-219,-169,-132,21,-250,-218,-133,21,-117,21,21,-222,-253,-241,-125,21,-246,21,21,-104,21,-249,-164,-170,-254,-141,-221,-154,21,21,21,-3,-130,-129,21,-118,-136,-155,-121,-171,-135,-217,-1,-123,21,21,-128,21,-127,-131,-173,21,-137,-119,-156,-167,21,21,21,-242,-2,-134,-144,-247,-126,-166,21,21,-223,-172,-165,21,-122,-124,-163,-251,-220,21,-243,-142,-252,-120,-245,-143,-244,21
 ,21,21,21,-248,-168,]),'ELSE':([340,269,339,258,399,159,413,136,139,414,261,415,243,397,396,163,135,348,154,344,268,338,242,144,270,405,260,143,379,],[-240,-221,-220,-237,408,-211,-235,-212,-208,-233,-227,-230,-239,-231,-232,-217,-210,-214,-213,-216,-238,-236,-219,-226,-228,-234,-218,-209,-215,]),'[':([316,376,102,313,7,44,105,4,332,104,324,25,37,353,8,13,155,2,317,81,41,18,45,117,65,231,238,43,84,3,331,38,221,49,393,318,100,34,127,74,368,20,99,77,195,69,36,370,12,28,314,109,39,371,31,330,366,234,10,180,213,5,35,309,280,292,358,374,225,90,75,223,67,114,217,87,392,52,6,17,187,61,310,91,181,9,179,26,123,68,211,372,235,42,23,130,230,227,],[-26,-196,-4,-5,-174,-178,-13,-163,-155,-10,-199,-120,-132,-135,-123,-133,-4,-107,-27,-146,-108,-126,-176,-168,-138,224,-169,-175,-12,-111,328,-164,224,55,-198,-24,-22,-125,224,-20,-23,-167,-16,-9,-147,-177,-129,-200,-118,-109,-7,216,-121,-194,-127,-195,-25,224,-119,-16,-28,-131,-128,-8,-136,-21,-134,-197,224,-11,-18,328,-137,224,-17,-148,-202,-156,-1
 22,-130,-145,-110,-6,-19,-14,-124,-15,55,-173,-179,-29,-201,-172,-112,-117,-170,-171,-154,]),'OR_OP':([96,77,86,312,142,363,97,155,316,410,305,110,184,368,314,84,104,309,211,318,307,83,185,423,292,310,179,366,78,91,71,100,89,303,297,101,180,220,420,92,85,105,74,90,302,298,102,388,308,301,313,75,109,217,181,364,295,291,300,112,317,322,296,213,315,99,306,299,106,311,182,],[-73,-9,-68,-74,-56,-57,-58,-4,-26,-33,-71,-49,-45,-23,-7,-12,-10,-8,-29,-24,-72,-65,-47,-35,-21,-6,-15,-25,-56,-19,-82,-22,-80,-83,-59,-76,-16,-46,-34,-84,-62,-13,-20,-11,-79,-61,-4,-32,-70,-67,-5,-18,-43,-17,-14,-48,-63,-81,-66,218,-27,-85,-64,-28,-77,-16,-69,-60,-78,-75,-44,]),'SUB_ASSIGN':([363,105,77,318,292,366,78,213,423,109,317,368,313,211,388,185,91,314,104,142,102,310,410,180,420,184,99,182,316,309,179,364,75,110,74,220,181,90,84,155,100,217,],[-57,-13,-9,-24,-21,-25,-56,-28,-35,-43,-27,-23,-5,-29,-32,-47,-19,-7,-10,245,-4,-6,-33,-16,-34,-45,-16,-44,-26,-8,-15,-48,-18,-49,-20,-46,-14,-11,-12,-4,-22,-17,]),'
 XOR_ASSIGN':([366,102,182,91,78,388,100,309,179,185,213,420,142,313,105,292,181,74,310,104,99,423,220,410,110,84,217,77,184,316,75,180,155,109,317,368,364,90,363,314,318,211,],[-25,-4,-44,-19,-56,-32,-22,-8,-15,-47,-28,-34,247,-5,-13,-21,-14,-20,-6,-10,-16,-35,-46,-33,-49,-12,-17,-9,-45,-26,-18,-16,-4,-43,-27,-23,-48,-11,-57,-7,-24,-29,]),'INT':([2,137,47,32,358,27,59,140,5,117,65,260,227,72,221,3,9,81,283,360,332,359,18,1,28,230,279,66,163,8,30,116,170,64,280,231,238,37,13,20,133,0,58,34,73,52,54,186,56,167,169,196,205,38,49,67,287,277,36,15,327,12,387,356,339,26,39,22,51,134,235,353,165,60,130,87,168,31,172,6,17,35,269,286,123,242,4,237,10,278,23,25,],[34,34,34,-242,-134,34,34,34,-131,-168,-138,-218,-154,34,34,34,-124,34,-144,-252,-155,-251,-126,34,34,-171,-142,34,-217,-123,-241,-254,-141,34,-136,34,-169,-132,-133,-167,-245,-1,-222,-125,-247,-156,34,34,-246,34,34,-248,-249,-164,-165,-137,-250,-243,-129,-2,34,-118,-253,-143,-220,-166,-121,-3,-104,-223,-172,-135,-244,34,-170,34,34,-
 127,34,-122,-130,-128,-221,34,-173,-219,-163,34,-119,34,-117,-120,]),'SIGNED':([31,356,6,168,137,28,25,287,0,36,167,358,196,327,235,8,123,170,35,27,277,2,38,237,360,10,227,32,56,134,87,359,116,260,59,30,242,34,283,67,230,186,13,81,20,3,163,23,387,269,22,5,66,165,73,205,140,17,278,286,47,130,54,279,51,37,26,65,12,9,172,49,39,15,280,169,332,58,1,231,60,238,353,133,18,339,221,64,4,117,52,72,],[-127,-143,-122,36,36,36,-120,-250,-1,-129,36,-134,-248,36,-172,-123,-173,-141,-128,36,-243,36,-164,36,-252,-119,-154,-242,-246,-223,36,-251,-254,-218,36,-241,-219,-125,-144,-137,-171,36,-133,36,-167,36,-217,-117,-253,-221,-3,-131,36,-244,-247,-249,36,-130,36,36,36,-170,36,-142,-104,-132,-166,-138,-118,-124,36,-165,-121,-2,-136,36,-155,-222,36,36,36,-169,-135,-245,-126,-220,36,36,-163,-168,-156,36,]),'CONTINUE':([58,340,243,408,154,269,144,143,258,338,394,136,159,263,413,339,382,259,153,344,399,268,242,406,158,415,135,240,405,147,414,134,163,267,60,140,260,396,346,261,270,380,379,397,139,378,51,34
 8,],[-222,-240,-239,146,-213,-221,-226,-209,-237,-236,146,-212,-211,146,-235,-220,146,-225,-224,-216,-229,-238,-219,146,146,-230,-210,146,-234,146,-233,-223,-217,146,146,146,-218,-232,146,-227,-228,146,-215,-231,-208,146,-104,-214,]),'MUL_ASSIGN':([318,105,420,100,317,314,78,91,292,366,181,182,104,179,185,99,142,155,220,309,84,74,310,410,213,75,184,368,316,180,313,363,423,217,364,77,110,102,388,211,90,109,],[-24,-13,-34,-22,-27,-7,-56,-19,-21,-25,-14,-44,-10,-15,-47,-16,250,-4,-46,-8,-12,-20,-6,-33,-28,-18,-45,-23,-26,-16,-5,-57,-35,-17,-48,-9,-49,-4,-32,-29,-11,-43,]),'{':([267,24,346,238,408,52,379,58,159,136,258,243,405,158,339,344,276,51,139,384,380,261,144,415,64,269,26,340,406,135,163,414,140,338,67,230,134,394,270,348,154,27,60,396,33,235,397,167,240,117,260,21,263,20,40,268,378,166,413,59,147,399,49,242,153,123,382,130,143,259,65,],[60,53,60,-169,60,118,-215,-222,-211,-212,-237,-239,-234,60,-220,-216,276,-104,-208,276,60,-227,-226,-230,60,-221,-166,-240,60,-210,-217,-233,60,
 -236,172,-171,-223,60,-228,-214,-213,60,60,-232,-139,-172,-231,60,60,-168,-218,-140,60,-167,66,-238,60,276,-235,60,60,-229,-165,-219,-224,-173,60,-170,-209,-225,168,]),'RIGHT_OP':([155,363,86,74,77,307,78,313,211,317,305,308,309,296,297,104,388,300,301,213,105,109,185,97,85,179,91,182,420,83,75,410,217,220,314,366,318,306,310,364,299,110,292,99,295,102,142,90,184,298,100,180,84,316,368,423,181,],[-4,-57,194,-20,-9,194,-56,-5,-29,-27,194,194,-8,-64,-59,-10,-32,-66,-67,-28,-13,-43,-47,-58,-62,-15,-19,-44,-34,-65,-18,-33,-17,-46,-7,-25,-24,194,-6,-48,-60,-49,-21,-16,-63,-4,-56,-11,-45,-61,-22,-16,-12,-26,-23,-35,-14,]),'REGISTER':([2,260,13,17,54,39,130,360,4,387,237,205,64,280,52,167,231,238,196,49,287,0,73,133,165,123,36,65,358,58,31,6,9,20,59,227,1,277,8,27,5,163,38,67,28,140,339,34,22,51,230,37,235,359,25,353,23,3,221,10,60,117,26,332,134,242,116,32,30,12,15,35,18,327,269,56,],[39,-218,-133,-130,39,-121,-170,-252,-163,-253,39,-249,39,-136,-156,39,39,-169,-248,-165,-250,-1,-247,-245
 ,-244,-173,-129,-138,-134,-222,-127,-122,-124,-167,39,-154,39,-243,-123,39,-131,-217,-164,-137,39,39,-220,-125,-3,-104,-171,-132,-172,-251,-120,-135,-117,39,39,-119,39,-168,-166,-155,-223,-219,-254,-242,-241,-118,-2,-128,-126,39,-221,-246,]),'RIGHT_ASSIGN':([142,410,77,420,423,99,185,155,104,211,213,182,220,366,364,316,363,78,313,91,388,318,310,292,105,110,75,74,181,100,309,102,84,90,217,317,179,184,109,368,180,314,],[255,-33,-9,-34,-35,-16,-47,-4,-10,-29,-28,-44,-46,-25,-48,-26,-57,-56,-5,-19,-32,-24,-6,-21,-13,-49,-18,-20,-14,-22,-8,-4,-12,-11,-17,-27,-15,-45,-43,-23,-16,-7,]),'DEFAULT':([159,140,258,260,153,154,379,380,269,339,136,270,344,405,267,378,382,58,134,348,414,242,147,243,397,346,263,408,158,394,51,406,143,261,139,338,259,60,268,340,413,135,163,415,399,144,396,240,],[-211,149,-237,-218,-224,-213,-215,149,-221,-220,-212,-228,-216,-234,149,149,149,-222,-223,-214,-233,-219,149,-239,-231,149,149,149,149,149,-104,149,-209,-227,-208,-236,-225,149,-238,-240,-235,-210,-217,-230,
 -229,-226,-232,149,]),'CHAR':([15,18,133,137,58,4,13,31,280,26,60,37,387,278,49,332,66,12,1,39,231,165,169,5,279,9,17,269,186,23,34,140,54,130,65,20,116,47,51,230,73,81,87,172,22,67,205,163,3,170,286,38,28,134,32,8,260,59,2,356,242,360,35,287,30,25,227,52,56,235,6,10,358,0,359,27,283,72,123,238,168,237,196,36,277,117,353,221,339,327,64,167,],[-2,-126,-245,8,-222,-163,-133,-127,-136,-166,8,-132,-253,8,-165,-155,8,-118,8,-121,8,-244,8,-131,-142,-124,-130,-221,8,-117,-125,8,8,-170,-138,-167,-254,8,-104,-171,-247,8,8,8,-3,-137,-249,-217,8,-141,8,-164,8,-223,-242,-123,-218,8,8,-143,-219,-252,-128,-250,-241,-120,-154,-156,-246,-172,-122,-119,-134,-1,-251,8,-144,8,-173,-169,8,8,-248,-129,-243,-168,-135,8,-220,8,8,8,]),'WHILE':([382,147,338,413,269,153,259,258,344,139,405,136,134,415,397,267,339,394,379,380,396,240,159,399,243,348,260,140,408,154,406,51,143,270,242,378,163,58,268,340,414,135,60,158,271,261,263,346,144,],[150,150,-236,-235,-221,-224,-225,-237,-216,-208,-234,-212,-223,-230,-2
 31,150,-220,150,-215,150,-232,150,-211,-229,-239,-214,-218,150,150,-213,150,-104,-209,-228,-219,150,-217,-222,-238,-240,-233,-210,150,150,349,-227,150,150,-226,]),'EXTERN':([163,4,31,23,117,34,67,242,56,13,10,32,133,54,59,227,269,130,65,359,1,280,36,358,15,123,235,26,167,6,230,51,238,12,339,49,134,60,73,58,5,353,38,2,387,231,332,237,3,0,30,27,116,28,360,327,9,39,37,64,8,196,35,18,277,140,221,260,17,165,22,287,205,20,25,52,],[-217,-163,-127,-117,-168,-125,-137,-219,-246,-133,-119,-242,-245,12,12,-154,-221,-170,-138,-251,12,-136,-129,-134,-2,-173,-172,-166,12,-122,-171,-104,-169,-118,-220,-165,-223,12,-247,-222,-131,-135,-164,12,-253,12,-155,12,12,-1,-241,12,-254,12,-252,12,-124,-121,-132,12,-123,-248,-128,-126,-243,12,12,-218,-130,-244,-3,-250,-249,-167,-120,-156,]),'RETURN':([158,396,406,348,260,143,147,339,340,159,269,399,394,135,163,414,139,405,379,415,134,243,259,344,136,397,242,382,240,140,60,258,408,144,51,378,263,338,154,153,267,413,346,380,270,58,268,261,],[141,-232,141,-214,
 -218,-209,141,-220,-240,-211,-221,-229,141,-210,-217,-233,-208,-234,-215,-230,-223,-239,-225,-216,-212,-231,-219,141,141,141,141,-237,141,-226,-104,141,141,-236,-213,-224,141,-235,141,141,-228,-222,-238,-227,]),'__ASM__':([198,381,408,174,240,135,269,258,144,202,284,382,260,79,252,47,137,257,369,218,276,80,147,228,189,191,380,151,338,396,378,176,249,399,203,261,246,263,108,243,340,190,253,192,342,55,377,51,219,136,141,94,270,339,262,354,183,264,414,328,367,215,379,154,384,82,293,140,254,267,158,143,58,406,242,409,113,210,268,103,289,250,139,216,413,405,245,107,60,415,272,256,247,348,204,207,255,193,166,346,153,201,134,259,76,194,251,394,248,224,397,95,197,344,186,72,208,163,266,188,159,],[93,93,93,93,93,-210,-221,-237,-226,93,93,93,-218,93,-96,93,93,93,93,93,93,93,93,93,93,93,93,93,-236,-232,93,93,-98,-229,93,-227,-93,93,-53,-239,-240,93,-90,93,93,93,93,-104,93,-212,93,-50,-228,-220,93,93,93,93,-233,93,93,93,-215,-213,93,-52,93,93,-94,93,93,-209,-222,93,-219,93,93,93,-238,-54,93,-91
 ,-208,93,-235,-234,-95,-55,93,-230,93,93,-99,-214,93,93,-97,93,93,93,-224,93,-223,-225,93,93,-92,93,-100,93,-231,-51,93,-216,93,93,93,-217,93,93,-211,]),'CASE':([378,153,259,163,258,139,134,242,396,339,147,51,380,58,159,399,136,269,379,154,408,243,270,267,397,405,413,382,135,143,394,340,260,144,158,140,414,344,240,268,263,406,338,346,60,415,348,261,],[151,-224,-225,-217,-237,-208,-223,-219,-232,-220,151,-104,151,-222,-211,-229,-212,-221,-215,-213,151,-239,-228,151,-231,-234,-235,151,-210,-209,151,-240,-218,-226,151,151,-233,-216,151,-238,151,151,-236,151,151,-230,-214,-227,]),'PP_DEFINE_MACRO_NAME':([11,],[46,]),'&':([106,74,256,224,83,91,308,276,397,202,210,95,94,240,85,381,318,211,219,113,306,191,198,260,153,315,184,192,140,384,388,257,142,338,215,84,369,254,154,340,242,312,216,409,220,188,413,382,134,251,313,163,261,423,99,316,292,185,78,379,245,270,213,420,76,104,289,174,255,317,218,262,248,189,197,90,135,58,252,166,314,77,300,247,399,108,293,301,194,79,364,82,363,368,302,310,17
 9,298,183,190,406,414,307,250,249,253,207,299,246,267,139,180,366,342,243,264,272,60,378,144,103,284,339,102,295,258,143,408,367,96,193,296,311,354,107,75,268,137,309,141,101,109,377,203,396,72,80,405,158,100,186,176,348,217,410,228,204,97,105,182,51,328,269,47,55,201,344,394,86,136,181,208,147,155,266,151,159,415,305,346,259,297,263,380,110,],[210,-20,94,94,-65,-19,-70,94,-231,94,94,-51,-50,94,-62,94,-24,-29,94,94,-69,94,94,-218,-224,-77,-45,94,94,94,-32,94,-56,-236,94,-12,94,-94,-213,-240,-219,-74,94,94,-46,94,-235,94,-223,-92,-5,-217,-227,-35,-16,-26,-21,-47,-56,-215,-95,-228,-28,-34,94,-10,94,94,-97,-27,94,94,-100,94,94,-11,-210,-222,-96,94,-7,-9,-66,-99,-229,-53,94,-67,94,94,-48,-52,-57,-23,210,-6,-15,-61,94,94,94,-233,-72,-91,-98,-90,94,-60,-93,94,-208,-16,-25,94,-239,94,94,94,94,-226,-54,94,-220,-4,-63,-237,-209,94,94,-73,94,-64,-75,94,-55,-18,-238,94,-8,94,-76,-43,94,94,-232,94,94,-234,94,-22,94,94,-214,-17,-33,94,94,-58,-13,-44,-104,94,-221,94,94,94,-216,94,-68,-212,-14,94,
 94,-4,94,94,-211,-230,-71,94,-225,-59,94,94,-49,]),'*':([266,52,297,202,208,176,127,195,163,253,268,287,204,185,191,277,2,270,396,245,213,260,219,187,104,174,231,196,256,247,56,81,218,141,179,284,134,360,84,109,353,39,10,180,240,41,227,332,414,133,44,12,249,264,354,255,388,34,251,4,346,314,413,269,55,23,113,262,76,250,158,0,205,243,348,198,166,137,28,261,280,15,105,210,35,140,197,296,381,171,257,263,420,193,99,379,8,31,366,228,221,415,151,68,36,378,87,342,90,58,51,380,6,408,143,367,201,344,293,310,299,267,79,85,18,242,5,289,136,298,1,272,7,72,259,317,292,164,29,110,215,100,186,246,399,217,147,384,309,220,188,38,207,9,357,363,82,318,423,37,43,394,30,254,135,359,338,387,65,22,116,406,409,42,16,358,3,61,364,313,339,405,224,25,211,316,77,252,102,410,73,216,165,184,139,13,32,114,276,382,107,75,94,369,97,144,368,103,189,74,80,182,328,67,153,377,258,159,192,108,57,194,95,181,155,60,142,340,47,91,397,78,183,248,17,203,154,295,190,],[95,-156,-59,95,95,95,7,-147,-217,-90,-238,-250,95,-47,95,-
 243,-107,-228,-232,-95,-28,-218,95,-145,-10,95,7,-248,95,-99,-246,-146,95,95,-15,95,-223,-252,-12,-43,-135,-121,-119,-16,95,-108,-154,-155,-233,-245,-178,-118,-98,95,95,-97,-32,-125,-92,-163,95,-7,-235,-221,95,-117,95,95,95,-91,95,-1,-249,-239,-214,95,95,95,-109,-227,-136,-2,-13,95,-128,95,95,190,95,7,95,95,-34,95,-16,-215,-123,-127,-25,95,7,-230,95,-179,-129,95,-148,95,-11,-222,-104,95,-122,95,-209,95,95,-216,95,-6,-60,95,95,190,-126,-219,-131,95,-212,-61,7,95,7,95,-225,-27,-21,7,7,-49,95,-22,95,-93,-229,-17,95,95,-8,-46,95,-164,95,-124,7,-57,-52,-24,-35,-132,7,95,-241,-94,-210,-251,-236,-253,-138,-3,-254,95,95,-112,7,-134,-111,-110,-48,-5,-220,-234,95,-120,-29,-26,-9,-96,-4,-33,-247,95,-244,-45,-208,-133,-242,7,95,95,-55,-18,-50,95,-58,-226,-23,-54,95,-20,95,-44,95,-137,-224,95,-237,-211,95,-53,7,95,-51,-14,-4,95,-56,-240,95,-19,-231,-56,95,-100,-130,95,-213,190,95,]),'SWITCH':([414,139,380,147,270,143,242,134,154,340,267,394,379,382,263,261,348,406,144,339,413,243,158,344,163,396
 ,378,268,415,259,258,397,60,51,338,135,408,399,269,159,58,346,405,260,136,140,153,240,],[-233,-208,152,152,-228,-209,-219,-223,-213,-240,152,152,-215,152,152,-227,-214,152,-226,-220,-235,-239,152,-216,-217,-232,152,-238,-230,-225,-237,-231,152,-104,-236,-210,152,-229,-221,-211,-222,152,-234,-218,-212,152,-224,152,]),'AND_ASSIGN':([217,292,318,181,179,110,368,102,316,309,109,105,99,184,74,142,104,90,314,185,78,388,363,182,180,423,155,100,420,310,84,213,220,91,77,364,75,211,410,366,313,317,],[-17,-21,-24,-14,-15,-49,-23,-4,-26,-8,-43,-13,-16,-45,-20,249,-10,-11,-7,-47,-56,-32,-57,-44,-16,-35,-4,-22,-34,-6,-12,-28,-46,-19,-9,-48,-18,-29,-33,-25,-5,-27,]),'IDENTIFIER':([9,141,280,344,293,21,246,384,242,82,194,257,346,55,30,23,0,259,243,164,139,16,215,24,134,65,58,33,5,144,408,38,127,272,67,79,209,108,107,1,138,397,103,216,409,42,17,332,143,342,212,159,45,360,394,37,43,254,268,252,387,207,51,53,382,190,3,186,192,94,231,147,191,47,196,406,248,195,188,287,61,73,54,165,118,10,253,367,358,21
 4,381,264,31,203,154,80,340,270,357,52,405,224,174,25,396,234,189,151,227,414,266,153,284,12,187,198,276,137,245,210,60,35,202,208,183,269,247,163,81,262,95,258,236,36,204,353,251,18,57,260,140,133,197,369,176,13,44,249,263,277,255,338,34,15,219,39,14,41,4,68,240,56,113,250,116,205,72,158,2,28,379,261,267,339,206,22,229,171,256,354,76,380,136,218,193,328,377,40,8,7,166,69,289,378,413,135,359,87,399,32,348,6,228,415,29,201,],[-124,102,-136,-216,102,-140,-93,102,-219,-52,102,102,155,102,-241,-117,-1,-225,-239,20,-208,20,102,52,-223,-138,-222,-139,-131,-226,155,-164,20,102,-137,102,102,-53,-55,20,239,-231,-54,102,102,-112,-130,-155,-209,102,316,-211,-176,-252,155,-132,-175,-94,-238,-96,-253,102,-104,121,155,102,-111,102,102,-50,20,155,102,102,-248,155,-100,-147,102,-250,-110,-247,124,-244,121,-119,-90,102,-134,317,102,102,-127,102,-213,102,-240,-228,20,-156,-234,102,102,-120,-232,20,102,102,-154,-233,102,-224,102,-118,-145,102,102,102,-95,102,155,-128,102,102,102,-221,-99,-217,-146,102
 ,-51,-237,335,-129,102,-135,-92,-126,20,-218,155,-245,102,102,102,-133,-178,-98,155,-243,-97,-236,-125,-2,102,-121,20,-108,-163,-179,155,-246,102,-91,-254,-249,102,155,-107,-109,-215,-227,155,-220,102,-3,121,20,102,102,102,155,-212,102,102,102,102,67,-123,-174,102,-177,102,155,-235,-210,-251,-148,-229,-242,-214,-122,102,-230,20,102,]),'ADD_ASSIGN':([420,317,104,109,313,78,155,213,91,179,181,185,142,182,423,90,314,100,220,180,316,364,363,77,105,366,309,310,410,75,368,217,211,74,102,388,292,184,318,84,99,110,],[-34,-27,-10,-43,-5,-56,-4,-28,-19,-15,-14,-47,254,-44,-35,-11,-7,-22,-46,-16,-26,-48,-57,-9,-13,-25,-8,-6,-33,-18,-23,-17,-29,-20,-4,-32,-21,-45,-24,-12,-16,-49,]),'>':([300,85,86,296,102,181,77,298,105,307,364,410,423,309,313,211,317,182,213,388,366,292,220,155,74,314,363,306,318,312,91,110,217,83,308,90,310,96,100,179,75,305,109,311,97,180,99,184,299,420,142,104,297,368,84,301,316,295,185,78,],[-66,-62,-68,-64,-4,-14,-9,-61,-13,-72,-48,-33,-35,-8,-5,-29,-27,-44,-28,-32,-25,-2
 1,-46,-4,-20,-7,-57,-69,-24,204,-19,-49,-17,-65,-70,-11,-6,204,-22,-15,-18,-71,-43,204,-58,-16,-16,-45,-60,-34,-56,-10,-59,-23,-12,-67,-26,-63,-47,-56,]),'PP_MACRO_PARAM':([263,354,103,82,207,245,414,144,203,58,139,174,84,289,215,108,186,76,254,192,74,290,216,143,369,47,250,202,381,276,266,141,377,258,189,158,247,113,137,218,261,219,90,206,328,270,382,188,269,51,260,135,153,183,204,367,264,346,257,190,268,107,217,406,134,396,240,154,256,293,197,380,413,253,259,99,94,210,163,272,246,198,201,267,348,176,339,262,249,394,405,384,224,151,340,415,255,193,344,111,181,378,338,105,194,147,408,209,80,60,243,180,191,379,251,284,166,399,409,136,140,79,252,70,55,208,242,95,228,397,248,159,342,179,72,],[99,99,-54,-52,99,-95,-233,-226,99,-222,-208,99,-12,99,99,-53,99,99,-94,99,180,362,99,-209,99,99,-91,99,99,99,99,99,99,-237,99,99,-99,99,99,99,-227,99,-11,309,99,-228,99,99,-221,-104,-218,-210,-224,99,99,99,99,99,99,99,-238,-55,-17,99,-223,-232,99,-213,99,99,99,99,-235,-90,-225,-16,-50,99,-217,99,-
 93,99,99,99,-214,99,-220,99,-98,99,-234,99,99,99,-240,-230,-97,99,-216,217,-14,99,-236,-13,99,99,99,314,99,99,-239,-16,99,-215,-92,99,99,-229,99,-212,99,99,-96,173,99,99,-219,-51,99,-231,-100,-211,99,-15,99,]),'GE_OP':([211,110,84,297,90,184,83,317,104,78,306,312,300,182,180,155,299,181,179,109,423,301,307,102,77,97,213,142,75,364,86,308,316,388,96,363,366,314,292,220,99,217,74,310,313,305,296,420,295,311,100,91,368,185,85,105,298,318,410,309,],[-29,-49,-12,-59,-11,-45,-65,-27,-10,-56,-69,203,-66,-44,-16,-4,-60,-14,-15,-43,-35,-67,-72,-4,-9,-58,-28,-56,-18,-48,-68,-70,-26,-32,203,-57,-25,-7,-21,-46,-16,-17,-20,-6,-5,-71,-64,-34,-63,203,-22,-19,-23,-47,-62,-13,-61,-24,-33,-8,]),'^':([366,179,315,298,296,91,97,100,155,99,312,420,363,110,104,388,299,185,182,96,90,317,311,220,410,75,85,297,306,301,184,423,314,308,313,180,291,307,310,102,78,142,292,295,74,316,302,106,211,368,109,213,300,181,305,89,364,309,101,318,77,217,86,84,105,83,],[-25,-15,-77,-61,-64,-19,-58,-22,-4,-16,-74,-34,-57,-
 49,-10,-32,-60,-47,-44,-73,-11,-27,-75,-46,-33,-18,-62,-59,-69,-67,-45,-35,-7,-70,-5,-16,197,-72,-6,-4,-56,-56,-21,-63,-20,-26,-79,-78,-29,-23,-43,-28,-66,-14,-71,197,-48,-8,-76,-24,-9,-17,-68,-12,-13,-65,]),'MOD_ASSIGN':([142,182,74,368,104,185,110,155,84,100,181,184,211,388,318,292,217,363,423,213,109,420,77,90,314,364,310,316,220,78,105,313,366,180,99,102,91,410,317,179,75,309,],[246,-44,-20,-23,-10,-47,-49,-4,-12,-22,-14,-45,-29,-32,-24,-21,-17,-57,-35,-28,-43,-34,-9,-11,-7,-48,-6,-26,-46,-56,-13,-5,-25,-16,-16,-4,-19,-33,-27,-15,-18,-8,]),':':([297,5,97,235,318,291,99,86,162,403,317,142,310,90,110,358,364,78,292,84,309,52,83,220,195,332,301,75,296,31,123,388,187,74,322,302,115,323,130,238,36,391,265,180,184,105,308,365,419,299,341,313,8,343,316,303,307,100,104,306,295,49,38,9,92,357,20,109,298,37,227,89,149,185,71,87,117,77,81,311,412,363,102,423,404,101,65,368,213,160,217,420,67,4,96,211,179,417,353,418,230,35,282,171,106,18,402,315,34,389,300,182,112,314,366,85,26,305,13,410,
 181,155,17,6,312,91,280,],[-59,-131,-58,-172,-24,-81,-16,-68,-88,-37,-27,-56,-6,-11,-49,-134,-48,-56,-21,-12,-8,-156,-65,-46,-147,-155,-67,-18,-64,-127,-173,-32,-145,-20,-85,-79,-103,369,-170,-169,-129,-87,346,-16,-45,-13,-70,389,-40,-60,-89,-5,-123,-102,-26,-83,-72,-22,-10,-69,-63,-165,-164,-124,-84,284,-167,-43,-61,-132,-154,-80,263,-47,-82,-148,-168,-9,-146,-75,-36,-57,-4,-35,412,-76,-138,-23,-28,-101,-17,-34,-137,-163,-73,-29,-15,-38,-135,421,-171,-128,354,284,-78,-126,-39,-77,-125,-36,-66,-44,-86,-7,-25,-62,-166,-71,-133,-33,-14,267,-130,-122,-74,-19,-136,]),'TYPE_NAME':([13,65,51,67,167,286,47,327,35,32,278,169,279,60,130,21,37,31,28,260,227,5,359,12,137,235,165,56,87,283,172,59,242,54,30,168,20,140,353,22,8,221,116,387,4,6,64,205,10,2,134,360,339,230,123,36,66,38,356,3,33,231,27,9,196,163,34,39,15,1,17,238,269,81,40,18,133,58,52,25,237,358,49,277,186,287,26,72,73,280,170,117,0,332,23,],[-133,-138,-104,-137,13,13,13,13,-128,-242,13,13,-142,13,-170,-140,-132,-127,13,-218,-154,-
 131,-251,-118,13,-172,-244,-246,13,-144,13,13,-219,13,-241,13,-167,13,-135,-3,-123,13,-254,-253,-163,-122,13,-249,-119,13,-223,-252,-220,-171,-173,-129,13,-164,-143,13,-139,13,13,-124,-248,-217,-125,-121,-2,13,-130,-169,-221,13,65,-126,-245,-222,-156,-120,13,-134,-165,-243,13,-250,-166,13,-247,-136,-141,-168,-1,-155,-117,]),'OR_ASSIGN':([211,179,420,110,91,99,102,310,78,142,213,423,185,184,368,388,317,75,182,90,364,410,314,100,180,155,309,217,109,84,74,105,220,104,316,363,366,318,181,77,313,292,],[-29,-15,-34,-49,-19,-16,-4,-6,-56,248,-28,-35,-47,-45,-23,-32,-27,-18,-44,-11,-48,-33,-7,-22,-16,-4,-8,-17,-43,-12,-20,-13,-46,-10,-26,-57,-25,-24,-14,-9,-5,-21,]),'BREAK':([263,258,269,242,158,378,260,399,397,58,270,346,382,379,261,134,154,139,408,51,135,153,344,348,259,396,338,243,268,415,380,406,163,340,267,414,159,405,240,394,339,144,147,136,60,140,143,413,],[156,-237,-221,-219,156,156,-218,-229,-231,-222,-228,156,156,-215,-227,-223,-213,-208,156,-104,-210,-224,-216,-214,-225,-232,-236
 ,-239,-238,-230,156,156,-217,-240,156,-233,-211,-234,156,156,-220,-226,156,-212,156,156,-209,-235,]),'VOLATILE':([237,205,170,66,353,130,360,47,327,260,8,26,4,235,59,339,356,38,387,140,23,17,117,242,358,279,93,1,0,54,18,5,169,287,35,168,221,6,186,37,52,123,283,25,133,269,81,7,31,277,116,56,87,9,231,13,165,12,227,20,60,27,65,137,359,72,230,58,278,3,286,172,43,51,22,2,332,68,73,39,15,64,280,32,238,196,163,167,34,67,134,28,44,36,10,49,30,],[38,-249,-141,38,-135,-170,-252,38,38,-218,-123,-166,-163,-172,38,-220,-143,-164,-253,38,-117,-130,-168,-219,-134,-142,199,38,-1,38,-126,-131,38,-250,-128,38,38,-122,38,-132,-156,-173,-144,-120,-245,-221,38,38,-127,-243,-254,-246,38,-124,38,-133,-244,-118,-154,-167,38,38,-138,38,-251,38,-171,-222,38,38,38,38,38,-104,-3,38,-155,-179,-247,-121,-2,38,-136,-242,-169,-248,-217,38,-125,-137,-223,38,-178,-129,-119,-165,-241,]),'error':([136,380,378,153,147,346,338,399,261,344,342,58,159,51,267,382,139,260,414,242,154,143,408,135,413,394,158,163,257,396,144,
 340,243,269,259,134,379,140,270,263,11,348,268,405,240,397,60,258,415,406,339,],[-212,241,241,-224,241,241,-236,-229,-227,-216,241,-222,-211,-104,241,241,-208,-218,-233,-219,-213,-209,241,-210,-235,241,241,-217,241,-232,-226,-240,-239,-221,-225,-223,-215,241,-228,241,48,-214,-238,-234,241,-231,157,-237,-230,241,-220,]),'~':([397,113,103,58,380,189,252,246,79,256,262,263,254,194,413,251,344,139,202,382,183,249,147,82,204,144,201,191,394,207,384,215,186,154,340,243,141,405,188,342,339,136,284,193,261,381,76,269,293,266,159,248,268,399,276,60,289,47,242,94,55,258,219,406,250,174,240,379,253,414,151,192,198,107,255,137,367,216,409,203,396,80,158,224,260,135,176,166,245,153,143,377,210,190,354,328,247,218,208,163,257,140,197,72,259,348,378,338,369,267,264,346,51,270,408,108,134,228,95,272,415,],[-231,103,-54,-222,103,103,-96,-93,103,103,103,103,-94,103,-235,-92,-216,-208,103,103,103,-98,103,-52,103,-226,103,103,103,103,103,103,103,-213,-240,-239,103,-234,103,103,-220,-212,103,103,-227,10
 3,103,-221,103,103,-211,-100,-238,-229,103,103,103,103,-219,-50,103,-237,103,103,-91,103,103,-215,-90,-233,103,103,103,-55,-97,103,103,103,103,103,-232,103,103,103,-218,-210,103,103,-95,-224,-209,103,103,103,103,103,-99,103,103,-217,103,103,103,103,-225,-214,103,-236,103,103,103,103,-104,-228,103,-53,-223,103,-51,103,-230,]),'DO':([243,346,339,153,163,338,136,158,396,415,380,51,258,405,242,382,397,159,263,267,240,259,408,270,134,140,340,348,143,144,413,135,378,379,154,399,147,414,260,139,60,269,394,268,406,344,261,58,],[-239,158,-220,-224,-217,-236,-212,158,-232,-230,158,-104,-237,-234,-219,158,-231,-211,158,158,158,-225,158,-228,-223,158,-240,-214,-209,-226,-235,-210,158,-215,-213,-229,158,-233,-218,-208,158,-221,158,-238,158,-216,-227,-222,]),'CONST':([359,205,81,31,9,49,2,32,196,37,72,20,59,10,242,18,358,231,15,117,60,235,123,26,68,360,6,34,260,230,356,54,353,25,27,3,8,167,67,269,133,332,227,140,237,283,56,4,38,43,186,64,12,51,39,44,221,278,5,7,134,47,52,280,87,163,327,339,168,28
 6,13,58,36,23,66,287,73,169,116,17,0,137,279,238,130,22,170,65,172,387,30,35,277,28,1,165,],[-251,-249,4,-127,-124,-165,4,-242,-248,-132,4,-167,4,-119,-219,-126,-134,4,-2,-168,4,-172,-173,-166,-179,-252,-122,-125,-218,-171,-143,4,-135,-120,4,4,-123,4,-137,-221,-245,-155,-154,4,4,-144,-246,-163,-164,4,4,4,-118,-104,-121,-178,4,4,-131,4,-223,4,-156,-136,4,-217,4,-220,4,4,-133,-222,-129,-117,4,-250,-247,4,-254,-130,-1,4,-142,-169,-170,-3,-141,-138,4,-253,-241,-128,-243,4,4,-244,]),'!':([107,246,204,242,147,269,189,262,208,58,176,243,254,263,183,108,379,270,51,338,342,380,405,159,79,293,80,215,139,396,339,193,381,256,197,249,47,369,260,95,399,354,144,250,408,247,163,201,348,397,216,272,266,413,186,194,328,382,257,198,82,289,261,367,76,414,253,255,409,224,153,202,267,406,218,113,136,140,143,60,207,377,240,174,141,134,340,190,228,384,219,344,251,94,137,276,284,394,191,210,378,135,258,55,158,252,245,203,154,264,192,268,415,188,103,248,259,166,72,151,346,],[-55,-93,107,-219,107,-221,107,107
 ,107,-222,107,-239,-94,107,107,-53,-215,-228,-104,-236,107,107,-234,-211,107,107,107,107,-208,-232,-220,107,107,107,107,-98,107,107,-218,-51,-229,107,-226,-91,107,-99,-217,107,-214,-231,107,107,107,-235,107,107,107,107,107,107,-52,107,-227,107,107,-233,-90,-97,107,107,-224,107,107,107,107,107,-212,107,-209,107,107,107,107,107,107,-223,-240,107,107,107,107,-216,-92,-50,107,107,107,107,107,107,107,-210,-237,107,107,-96,-95,107,-213,107,107,-238,-230,107,-54,-100,-225,107,107,107,107,]),'%':([364,295,314,90,388,179,217,292,75,110,77,180,420,309,299,296,84,423,109,220,368,363,142,74,78,99,102,100,310,297,182,184,318,316,366,298,185,97,317,313,155,104,91,85,211,181,213,410,105,],[-48,191,-7,-11,-32,-15,-17,-21,-18,-49,-9,-16,-34,-8,-60,191,-12,-35,-43,-46,-23,-57,-56,-20,-56,-16,-4,-22,-6,-59,-44,-45,-24,-26,-25,-61,-47,-58,-27,-5,-4,-10,-19,191,-29,-14,-28,-33,-13,]),')':([68,106,391,175,12,416,310,318,179,217,70,331,261,309,423,280,177,97,403,42,392,52,371,418,6,54,332,213,50,184,130,2
 23,299,231,13,311,294,195,127,325,335,373,92,388,238,312,20,75,398,123,419,215,44,74,84,337,316,185,38,86,162,233,31,364,296,389,350,142,5,104,114,358,99,227,173,307,144,319,28,124,420,322,69,292,187,305,330,100,17,65,211,336,78,128,303,341,180,9,345,366,376,422,365,234,102,182,300,77,317,297,101,295,343,49,225,393,368,160,96,71,85,8,3,320,178,7,126,306,347,23,61,67,109,395,37,220,110,41,370,270,363,89,404,232,181,291,18,410,129,313,25,90,2,10,34,39,87,377,324,230,43,81,314,390,372,91,301,221,112,417,402,105,412,302,235,117,315,36,298,308,35,83,125,362,421,45,327,326,374,353,222,26,4,],[-179,-78,-87,289,-118,419,-6,-24,-15,-17,174,-193,-227,-8,-35,-136,292,-58,-37,-112,-202,-156,-194,420,-122,123,-155,-28,117,-45,-170,-192,-60,324,-133,-75,364,-147,-186,370,-188,392,-84,-32,-169,-74,-167,-18,407,-173,-40,318,-178,-20,-12,-183,-26,-47,-164,-68,-88,-184,-127,-48,-64,-36,382,-56,-131,-10,-189,-134,-16,-154,-255,-72,-226,-30,-109,-187,-34,-85,-177,-21,-145,-71,-195,-22,-130,-138,-29,-18
 1,-56,235,-83,-89,-16,-124,378,-25,-196,423,388,-191,-4,-44,-66,-9,-27,-59,-76,-63,-102,-165,-191,-198,-23,-101,-73,-82,-62,-123,-111,366,293,-174,-182,-69,380,-117,-110,-137,-43,406,-132,-46,-49,-108,-200,-228,-57,-80,410,-185,-14,-81,-126,-33,-180,-5,-120,-11,-107,-119,-125,-121,-148,394,-199,-171,-175,-146,-7,-31,-201,-19,-67,324,-86,-38,-39,-13,-36,-79,-172,-168,-77,-129,-61,-70,-128,-65,230,-256,-36,-176,372,371,-197,-135,-190,-166,-163,]),'-':([378,240,364,83,409,202,252,197,247,261,97,219,248,110,72,414,250,310,245,309,354,318,99,183,94,313,154,176,180,262,379,413,296,184,181,203,207,381,190,55,297,104,76,377,420,408,301,316,51,201,251,328,263,75,79,74,155,246,249,292,188,396,182,174,108,243,314,135,254,298,348,340,186,399,185,95,338,85,107,159,255,367,192,384,368,346,394,253,220,289,256,344,105,77,267,369,210,228,216,264,423,363,242,218,217,189,415,103,91,143,82,134,60,136,342,47,397,339,166,109,299,163,194,405,268,272,58,366,78,100,388,224,258,276,193,269,257,295,211,266,27
 0,158,84,140,410,139,208,293,260,259,317,141,300,102,90,142,406,137,382,113,80,153,215,380,144,204,213,191,179,151,198,147,284,],[108,108,-48,189,108,108,-96,108,-99,-227,-58,108,-100,-49,108,-233,-91,-6,-95,-8,108,-24,-16,108,-50,-5,-213,108,-16,108,-215,-235,-64,-45,-14,108,108,108,108,108,-59,-10,108,108,-34,108,189,-26,-104,108,-92,108,108,-18,108,-20,-4,-93,-98,-21,108,-232,-44,108,-53,-239,-7,-210,-94,-61,-214,-240,108,-229,-47,-51,-236,-62,-55,-211,-97,108,108,108,-23,108,108,-90,-46,108,108,-216,-13,-9,108,108,108,108,108,108,-35,-57,-219,108,-17,108,-230,-54,-19,-209,-52,-223,108,-212,108,108,-231,-220,108,-43,-60,-217,108,-234,-238,108,-222,-25,-56,-22,-32,108,-237,108,108,-221,108,-63,-29,108,-228,108,-12,108,-33,-208,108,108,-218,-225,-27,108,189,-4,-11,-56,108,108,108,108,108,-224,108,108,-226,108,-28,108,-15,108,108,108,108,]),'CHARACTER_CONSTANT':([380,414,250,204,245,186,191,151,284,94,154,252,140,413,247,248,381,72,377,272,201,183,176,382,379,249,203,207,55,174,76,3
 44,408,51,254,396,415,251,338,263,79,158,293,289,346,394,240,253,188,369,210,262,108,243,144,348,340,242,218,399,189,107,159,367,192,82,134,342,378,256,397,219,166,267,228,216,264,194,405,58,135,255,193,269,257,103,143,266,270,60,136,47,339,163,141,268,354,406,137,328,224,276,113,153,139,208,260,190,259,258,384,147,198,409,202,80,215,197,261,95,246,],[104,-233,-91,104,-95,104,104,104,104,-50,-213,-96,104,-235,-99,-100,104,104,104,104,104,104,104,104,-215,-98,104,104,104,104,104,-216,104,-104,-94,-232,-230,-92,-236,104,104,104,104,104,104,104,104,-90,104,104,104,104,-53,-239,-226,-214,-240,-219,104,-229,104,-55,-211,104,104,-52,-223,104,104,104,-231,104,104,104,104,104,104,104,-234,-222,-210,-97,104,-221,104,-54,-209,104,-228,104,-212,104,-220,-217,104,-238,104,104,104,104,104,104,104,-224,-208,104,-218,104,-225,-237,104,104,104,104,104,104,104,104,-227,-51,-93,]),'PP_STRINGIFY':([139,242,176,82,58,268,381,103,94,99,367,259,84,163,147,272,204,354,382,344,328,174,266,183,394,269,255,3
 99,413,249,263,409,134,396,72,180,193,190,107,218,252,202,408,136,210,194,217,113,257,256,51,189,188,47,207,208,379,108,228,151,95,270,105,247,181,415,348,250,342,405,159,143,253,397,186,135,240,377,243,198,219,339,261,245,260,144,264,154,79,191,262,216,267,215,369,197,254,414,140,346,246,289,338,380,224,384,192,158,90,74,284,248,153,406,60,141,378,55,179,76,166,258,340,203,137,293,80,251,201,276,],[-208,-219,111,-52,-222,-238,111,-54,-50,-16,111,-225,-12,-217,111,111,111,111,111,-216,111,111,111,111,111,-221,-97,-229,-235,-98,111,111,-223,-232,111,-16,111,111,-55,111,-96,111,111,-212,111,111,-17,111,111,111,-104,111,111,111,111,111,-215,-53,111,111,-51,-228,-13,-99,-14,-230,-214,-91,111,-234,-211,-209,-90,-231,111,-210,111,111,-239,111,111,-220,-227,-95,-218,-226,111,-213,111,111,111,111,111,111,111,111,-94,-233,111,111,-93,111,-236,111,111,111,111,111,-11,111,111,-100,-224,111,111,111,111,111,-15,111,111,-237,-240,111,111,111,111,-92,111,111,]),'PTR_OP':([211,109,84,309,317,217,74
 ,181,77,91,213,90,104,102,292,313,100,368,99,179,314,180,310,366,316,318,105,75,155,],[-29,214,-12,-8,-27,-17,-20,-14,-9,-19,-28,-11,-10,-4,-21,-5,-22,-23,-16,-15,-7,-16,-6,-25,-26,-24,-13,-18,-4,]),'=':([117,26,104,99,182,185,90,142,78,220,109,313,49,155,213,91,179,316,132,121,423,366,314,100,363,235,180,238,64,130,230,102,388,105,123,211,364,84,410,317,110,368,20,310,420,309,75,74,292,184,217,181,77,318,],[-168,-166,-10,-16,-44,-47,-11,253,-56,-46,-43,-5,-165,-4,-28,-19,-15,-26,166,228,-35,-25,-7,-22,-57,-172,-16,-169,166,-170,-171,-4,-32,-13,-173,-29,-48,-12,-33,-27,-49,-23,-167,-6,-34,-8,-18,-20,-21,-45,-17,-14,-9,-24,]),'TYPEDEF':([58,52,242,359,358,3,123,35,287,34,28,227,196,38,231,26,130,165,64,327,269,15,2,37,6,205,25,51,230,133,54,73,235,280,10,5,27,31,30,117,18,332,134,221,20,8,260,67,9,13,1,387,56,60,49,23,32,237,36,116,59,140,238,339,163,17,167,277,353,12,22,65,0,4,39,360,],[-222,-156,-219,-251,-134,23,-173,-128,-250,-125,23,-154,-248,-164,23,-166,-170,-244,23,23,-221,-2
 ,23,-132,-122,-249,-120,-104,-171,-245,23,-247,-172,-136,-119,-131,23,-127,-241,-168,-126,-155,-223,23,-167,-123,-218,-137,-124,-133,23,-253,-246,23,-165,-117,-242,23,-129,-254,23,23,-169,-220,-217,-130,23,-243,-135,-118,-3,-138,-1,-163,-121,-252,]),'AUTO':([130,287,140,60,3,133,242,31,353,116,235,327,28,34,59,8,56,269,37,27,65,18,339,221,231,13,17,39,36,332,6,10,277,230,35,26,38,32,227,67,30,64,280,15,9,360,359,25,12,73,165,387,1,49,2,117,260,123,205,5,51,23,238,20,237,196,4,167,58,358,22,163,52,0,134,54,],[-170,-250,25,25,25,-245,-219,-127,-135,-254,-172,25,25,-125,25,-123,-246,-221,-132,25,-138,-126,-220,25,25,-133,-130,-121,-129,-155,-122,-119,-243,-171,-128,-166,-164,-242,-154,-137,-241,25,-136,-2,-124,-252,-251,-120,-118,-247,-244,-253,25,-165,25,-168,-218,-173,-249,-131,-104,-117,-169,-167,25,-248,-163,25,-222,-134,-3,-217,-156,-1,-223,25,]),'AND_OP':([142,101,301,97,86,308,423,77,213,364,366,109,75,295,420,311,220,211,363,84,217,296,90,110,100,300,96,106,99,302,92,83,185,89,
 314,104,322,299,74,105,310,410,71,307,91,368,155,313,180,292,312,303,298,309,182,306,184,318,179,317,102,291,388,297,181,315,305,85,316,78,],[-56,-76,-67,-58,-68,-70,-35,-9,-28,-48,-25,-43,-18,-63,-34,-75,-46,-29,-57,-12,-17,-64,-11,-49,-22,-66,-73,-78,-16,-79,198,-65,-47,-80,-7,-10,198,-60,-20,-13,-6,-33,-82,-72,-19,-23,-4,-5,-16,-21,-74,-83,-61,-8,-44,-69,-45,-24,-15,-27,-4,-81,-32,-59,-14,-77,-71,-62,-26,-56,]),']':([106,316,301,303,423,102,322,368,410,296,420,77,211,74,364,363,220,292,109,180,217,112,302,298,305,99,321,160,295,89,311,318,86,300,104,83,329,309,105,97,185,131,110,315,92,224,312,181,75,313,55,328,343,308,307,96,184,71,115,182,85,388,341,375,179,101,306,213,366,314,297,391,84,78,317,299,291,100,91,90,162,142,310,],[-78,-26,-67,-83,-35,-4,-85,-23,-33,-64,-34,-9,-29,-20,-48,-57,-46,-21,-43,-16,-17,-86,-79,-61,-71,-16,368,-101,-63,-80,-75,-24,-68,-66,-10,-65,376,-8,-13,-58,-47,238,-49,-77,-84,330,-74,-14,-18,-5,130,374,-102,-70,-72,-73,-45,-82,-103,-44,-62,-32,-89,393,
 -15,-76,-69,-28,-25,-7,-59,-87,-12,-56,-27,-60,-81,-22,-19,-11,-88,-56,-6,]),'IF':([260,399,382,269,413,344,406,147,380,144,134,346,58,408,405,394,51,379,259,415,268,396,340,378,60,154,240,140,261,159,242,135,263,153,243,258,139,414,267,348,338,397,158,270,163,143,136,339,],[-218,-229,161,-221,-235,-216,161,161,161,-226,-223,161,-222,161,-234,161,-104,-215,-225,-230,-238,-232,-240,161,161,-213,161,161,-227,-211,-219,-210,161,-224,-239,-237,-208,-233,161,-214,-236,-231,161,-228,-217,-209,-212,-220,]),'STRING_LITERAL':([414,134,252,412,255,193,90,105,228,216,257,249,409,179,394,260,243,210,103,76,369,55,219,245,269,354,380,192,413,208,348,84,248,218,263,289,163,201,60,136,204,242,108,268,251,151,186,51,250,240,190,207,276,94,180,256,99,377,72,189,224,258,259,166,344,95,397,399,284,338,405,153,264,415,421,408,194,346,113,367,139,342,254,340,406,411,159,147,389,215,174,253,135,379,158,262,188,378,107,141,267,246,143,80,197,47,74,396,144,304,261,82,328,191,217,381,247,181,339,154,198,384
 ,58,183,203,272,137,79,266,176,293,202,382,270,140,],[-233,-223,-96,90,-97,90,-11,-13,90,90,90,-98,90,-15,90,-218,-239,90,-54,90,90,90,90,-95,-221,90,90,90,-235,90,-214,-12,-100,90,90,90,-217,90,90,-212,90,-219,-53,-238,-92,90,90,-104,-91,90,90,90,90,-50,-16,90,-16,90,90,90,90,-237,-225,90,-216,-51,-231,-229,90,-236,-234,-224,90,-230,90,90,90,90,90,90,-208,90,-94,-240,90,90,-211,90,90,90,90,-90,-210,-215,90,90,90,90,-55,90,90,-93,-209,90,90,90,90,-232,-226,90,-227,-52,90,90,-17,90,-99,-14,-220,-213,90,90,-222,90,90,90,90,90,90,90,90,90,90,-228,90,]),'PP_IDENTIFIER_PASTE':([102,314,99,309,155,],[209,206,206,206,209,]),'PP_DEFINE_NAME':([11,],[47,]),'FLOAT':([64,13,186,231,165,56,1,35,39,10,277,9,360,36,49,32,237,238,227,332,168,52,278,133,287,60,116,134,283,66,23,12,356,196,260,54,6,72,73,28,58,130,4,17,0,205,359,20,81,235,123,221,167,3,51,353,358,18,387,286,172,34,170,137,65,269,22,37,26,31,27,327,163,47,25,30,59,242,140,2,67,8,169,5,279,87,339,280,117,15,230,38,],[31,-133,31,31,-24
 4,-246,31,-128,-121,-119,-243,-124,-252,-129,-165,-242,31,-169,-154,-155,31,-156,31,-245,-250,31,-254,-223,-144,31,-117,-118,-143,-248,-218,31,-122,31,-247,31,-222,-170,-163,-130,-1,-249,-251,-167,31,-172,-173,31,31,31,-104,-135,-134,-126,-253,31,31,-125,-141,31,-138,-221,-3,-132,-166,-127,31,31,-217,31,-120,-241,31,-219,31,31,-137,-123,31,-131,-142,31,-220,-136,-168,-2,-171,-164,]),'LEFT_ASSIGN':([314,184,180,317,313,316,366,109,364,99,318,102,410,368,100,78,179,423,104,309,142,74,420,110,84,292,211,388,181,220,185,90,213,182,217,310,363,105,91,155,77,75,],[-7,-45,-16,-27,-5,-26,-25,-43,-48,-16,-24,-4,-33,-23,-22,-56,-15,-35,-10,-8,252,-20,-34,-49,-12,-21,-29,-32,-14,-46,-47,-11,-28,-44,-17,-6,-57,-13,-19,-4,-9,-18,]),'}':([157,283,292,379,413,181,269,278,275,344,261,112,242,322,303,296,383,391,71,384,159,300,102,286,142,364,85,211,220,51,60,139,109,120,154,163,338,260,106,115,119,279,352,258,312,298,313,84,340,302,311,268,317,414,366,91,420,179,136,363,397,77,333,122,243,74,368,16
 2,135,240,217,226,401,396,169,356,351,299,182,308,270,309,339,348,306,334,291,388,104,147,89,90,99,315,105,144,400,97,399,140,185,101,297,110,423,213,301,310,78,295,307,316,75,410,259,405,121,341,96,58,184,305,314,180,100,170,134,143,318,86,415,83,153,92,229,],[269,-144,-21,-215,-235,-14,-221,353,-203,-216,-227,-86,-219,-85,-83,-64,-204,-87,-82,401,-211,-66,-4,358,-56,-48,-62,-29,-46,-104,163,-208,-43,227,-213,-217,-236,-218,-78,-103,-159,-142,383,-237,-74,-61,-5,-12,-240,-79,-75,-238,-27,-233,-25,-19,-34,-15,-212,-57,-231,-9,-162,-157,-239,-20,-23,-88,-210,339,-17,332,-205,-232,280,-143,-206,-60,-44,-70,-228,-8,-220,-214,-69,-160,-81,-32,-10,260,-80,-11,-16,-77,-13,-226,-207,-58,-229,242,-47,-76,-59,-49,-35,-28,-67,-6,-56,-63,-72,-26,-18,-33,-225,-234,-161,-89,-73,-222,-45,-71,-7,-16,-22,-141,-223,-209,-24,-68,-230,-65,-224,-84,-158,]),}
-_lr_action = {}
+_lr_action = { }
 for _k, _v in _lr_action_items.items():
-    for _x, _y in zip(_v[0], _v[1]):
-        _lr_action[(_x, _k)] = _y
+   for _x,_y in zip(_v[0],_v[1]):
+       _lr_action[(_x,_k)] = _y
 del _lr_action_items
-_lr_goto_items = {'expression_statement': ([240, 257, 382, 267, 140, 406, 380, 342, 263, 60, 408, 147, 378, 346, 158, 394, ], [135, 342, 135, 135, 135, 135, 135, 377, 135, 135, 135, 135, 135, 135, 135, 135, ]), 'storage_class_specifier': ([140, 27, 28, 327, 167, 221, 60, 54, 59, 64, 2, 3, 1, 237, 231, ], [2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, ]), 'declaration_list': ([64, 60, 27, ], [167, 140, 59, ]), 'type_qualifier': ([60, 72, 87, 28, 169, 47, 27, 327, 221, 59, 54, 278, 7, 81, 43, 2, 237, 140, 168, 64, 231, 286, 172, 167, 3, 66, 186, 1, 137, ], [3, 87, 87, 3, 87, 87, 3, 3, 3, 3, 3, 87, 44, 87, 68, 3, 3, 3, 87, 3, 3, 87, 87, 3, 3, 87, 87, 3, 87, ]), 'constant': ([262, 380, 186, 176, 191, 408, 377, 266, 207, 409, 60, 183, 367, 80, 203, 202, 328, 276, 394, 166, 293, 272, 151, 76, 194, 378, 289, 158, 201, 147, 72, 190, 369, 228, 346, 79, 264, 197, 204, 381, 55, 224, 193, 257, 198, 382, 284, 174, 256, 47, 216, 141, 267, 384, 192, 189, 240, 140, 263, 137, 188, 354, 218, 208, 406,
  219, 342, 113, 210, 215, ], [91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, 91, ]), 'volatile_opt': ([93, ], [200, ]), 'unary_expression': ([256, 208, 47, 166, 346, 192, 197, 202, 141, 189, 194, 263, 215, 289, 198, 158, 201, 219, 409, 381, 207, 60, 369, 367, 193, 257, 176, 191, 137, 328, 174, 151, 276, 394, 384, 382, 408, 380, 342, 183, 76, 80, 203, 262, 147, 218, 354, 204, 377, 272, 224, 113, 210, 186, 284, 72, 228, 190, 79, 264, 216, 55, 267, 266, 293, 406, 240, 140, 188, 378, ], [142, 78, 78, 142, 142, 78, 78, 78, 142, 78, 78, 142, 142, 78, 78, 142, 78, 142, 142, 142, 78, 142, 78, 142, 78, 142, 78, 78, 142, 78, 78, 78, 142, 142, 142, 142, 142, 142, 142, 142, 182, 185, 78, 142, 142, 78, 78, 78, 142, 142, 78, 78, 78, 142, 78, 142, 78, 78, 184, 142, 142, 78
 , 142, 142, 78, 142, 142, 142, 78, 142, ]), 'struct_or_union_specifier': ([221, 2, 59, 278, 168, 27, 64, 169, 87, 137, 231, 72, 1, 66, 54, 186, 47, 81, 167, 28, 172, 237, 3, 140, 60, 286, 327, ], [5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, ]), 'exclusive_or_expression': ([262, 272, 264, 408, 328, 384, 219, 224, 228, 72, 216, 141, 342, 367, 284, 377, 166, 289, 218, 267, 276, 257, 266, 198, 186, 140, 55, 60, 382, 256, 147, 176, 240, 47, 158, 381, 215, 137, 394, 369, 378, 354, 380, 263, 183, 174, 406, 346, 151, 409, ], [89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 291, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, 89, ]), 'identifier_list': ([54, ], [128, ]), 'define': ([1, ], [22, ]), 'initializer': ([384, 276, 166, ], [400, 351, 274, ]), 'macro_param': ([240, 147, 186, 151, 208, 198, 191, 384, 193, 257, 60, 203, 140, 380, 408, 79, 381, 262, 55, 17
 6, 276, 210, 194, 201, 378, 47, 224, 293, 202, 80, 189, 328, 346, 190, 174, 219, 256, 166, 266, 264, 216, 367, 192, 272, 197, 284, 409, 377, 158, 267, 72, 369, 406, 215, 137, 76, 342, 188, 141, 354, 218, 382, 207, 228, 183, 394, 204, 263, 113, 289, 74, ], [105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 105, 179, ]), 'struct_declaration_list': ([172, 168, 66, ], [286, 278, 169, ]), 'macro_parameter_list': ([70, ], [175, ]), 'struct_declaration': ([66, 168, 172, 278, 169, 286, ], [170, 170, 170, 279, 279, 279, ]), 'abstract_declarator': ([221, 114, 231, 127, ], [326, 222, 326, 232, ]), 'iteration_statement': ([406, 382, 240, 378, 60, 263, 158, 380, 140, 267, 147, 394, 408, 346, ], [136, 136,
 136, 136, 136, 136, 136, 136, 136, 136, 136, 136, 136, 136, ]), 'and_expression': ([262, 377, 151, 342, 408, 394, 198, 137, 328, 60, 219, 381, 228, 367, 47, 257, 158, 224, 369, 276, 197, 141, 240, 183, 263, 264, 346, 266, 384, 289, 174, 176, 186, 354, 409, 215, 216, 55, 218, 166, 378, 267, 72, 256, 140, 380, 284, 382, 272, 147, 406, ], [106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 302, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, 106, ]), 'assignment_expression': ([276, 394, 272, 216, 147, 367, 256, 380, 158, 262, 266, 264, 342, 408, 263, 183, 381, 406, 166, 377, 72, 140, 60, 378, 409, 215, 240, 346, 267, 186, 384, 137, 257, 141, 382, 219, ], [275, 160, 160, 160, 160, 390, 341, 160, 160, 343, 160, 160, 160, 160, 160, 160, 160, 160, 275, 160, 160, 160, 160, 160, 160, 319, 160, 160, 160, 160, 275, 160, 160, 160, 160, 160, ]), 'exter
 nal_declaration': ([1, ], [15, ]), 'type_specifier': ([237, 140, 28, 172, 167, 81, 221, 59, 47, 286, 3, 60, 87, 137, 27, 64, 231, 327, 66, 54, 72, 278, 168, 169, 1, 186, 2, ], [28, 28, 28, 81, 28, 81, 28, 28, 81, 81, 28, 28, 81, 81, 28, 28, 28, 28, 81, 28, 81, 81, 81, 81, 28, 81, 28, ]), 'compound_statement': ([140, 60, 378, 394, 147, 408, 406, 346, 59, 263, 382, 158, 267, 167, 240, 27, 64, 380, ], [143, 143, 143, 143, 143, 143, 143, 143, 133, 143, 143, 143, 143, 277, 143, 56, 165, 143, ]), 'inclusive_or_expression': ([60, 382, 47, 218, 409, 183, 272, 228, 377, 408, 328, 224, 166, 380, 284, 55, 186, 289, 151, 256, 346, 369, 367, 147, 240, 216, 266, 262, 158, 267, 276, 378, 219, 198, 140, 72, 406, 381, 354, 263, 257, 394, 342, 384, 264, 215, 141, 137, 174, ], [71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 303, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, 71, ]), 'enumerator_list_iso': ([1
 18, 53, ], [122, 122, ]), 'selection_statement': ([408, 346, 394, 378, 263, 267, 147, 240, 158, 406, 140, 60, 380, 382, ], [159, 159, 159, 159, 159, 159, 159, 159, 159, 159, 159, 159, 159, 159, ]), 'postfix_expression': ([197, 394, 192, 137, 328, 194, 263, 378, 141, 151, 60, 189, 369, 380, 219, 207, 262, 240, 193, 228, 406, 257, 377, 342, 266, 381, 183, 202, 147, 190, 346, 47, 367, 204, 176, 408, 224, 293, 384, 79, 276, 208, 272, 201, 210, 409, 166, 203, 267, 186, 72, 216, 140, 198, 188, 55, 289, 264, 218, 382, 354, 174, 76, 113, 284, 256, 158, 80, 215, 191, ], [109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, 109, ]), 'asm_expression': ([151, 215, 409, 210, 276, 377, 183, 141, 378, 224, 80,
 198, 192, 166, 262, 194, 72, 113, 406, 257, 189, 384, 394, 219, 354, 263, 240, 346, 284, 60, 207, 201, 203, 408, 382, 174, 264, 272, 176, 204, 266, 197, 216, 193, 328, 267, 190, 369, 228, 186, 381, 256, 147, 342, 380, 188, 158, 47, 55, 293, 208, 218, 289, 76, 79, 137, 191, 140, 202, 367, ], [110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, ]), 'declaration_impl': ([167, 27, 64, 59, 1, 60, 140, ], [19, 19, 19, 19, 19, 19, 19, ]), 'type_name': ([186, 137, 72, 47, ], [294, 178, 178, 88, ]), 'relational_expression': ([276, 408, 378, 289, 216, 264, 382, 183, 263, 380, 224, 240, 377, 219, 262, 409, 158, 197, 210, 346, 394, 166, 55, 384, 381, 257, 207, 147, 267, 369, 215, 367, 198, 186, 174, 35
 4, 72, 272, 328, 47, 60, 137, 141, 140, 406, 218, 284, 208, 176, 256, 266, 342, 151, 228, ], [96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 311, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 96, 312, 96, 96, 96, 96, 96, 96, ]), 'statement': ([158, 60, 394, 140, 267, 380, 263, 147, 408, 240, 382, 406, 346, 378, ], [271, 153, 405, 153, 348, 397, 344, 259, 415, 259, 399, 413, 379, 396, ]), 'parameter_declaration': ([54, 327, 231, 237, 221, ], [126, 126, 126, 337, 126, ]), 'cast_expression': ([186, 293, 266, 406, 174, 224, 384, 202, 257, 189, 240, 113, 218, 193, 262, 55, 377, 198, 166, 216, 264, 194, 137, 382, 203, 276, 378, 215, 210, 219, 267, 197, 147, 381, 354, 409, 158, 208, 176, 256, 342, 188, 141, 207, 192, 272, 72, 204, 284, 228, 191, 346, 289, 394, 151, 408, 369, 60, 140, 47, 183, 263, 380, 328, 201, 190, 367, ], [97, 363, 97, 97, 97, 97, 97, 97, 97, 97, 97, 220, 97, 97, 97, 97, 97, 97, 97, 9
 7, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 299, 97, 97, 97, 97, 97, 298, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 97, 297, 97, ]), 'init_declarator': ([29, 164, 57, ], [62, 273, 62, ]), 'struct_declarator_list': ([171, ], [285, ]), 'multiplicative_expression': ([384, 367, 60, 55, 47, 166, 201, 406, 346, 204, 197, 72, 228, 203, 409, 262, 198, 381, 219, 194, 263, 207, 377, 257, 378, 137, 276, 210, 202, 189, 267, 158, 342, 256, 208, 218, 140, 141, 394, 188, 380, 183, 382, 328, 224, 272, 264, 174, 216, 289, 186, 354, 408, 215, 151, 369, 193, 147, 266, 240, 176, 284, ], [85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 296, 85, 85, 85, 85, 85, 85, 85, 85, 85, 295, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, ]), 'unary_operator': ([284, 141, 176, 224, 369, 384, 293, 276, 409, 240, 201, 210, 194, 354, 203, 186, 72,
  60, 189, 380, 188, 198, 55, 219, 218, 202, 207, 382, 190, 406, 76, 204, 113, 257, 256, 147, 158, 377, 151, 215, 208, 272, 137, 408, 183, 166, 262, 378, 267, 47, 140, 79, 191, 192, 193, 228, 264, 342, 80, 266, 197, 394, 216, 328, 381, 289, 263, 346, 174, 367, ], [113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, 113, ]), 'assignment_operator': ([142, ], [256, ]), 'struct_or_union': ([59, 140, 286, 3, 27, 327, 167, 72, 137, 237, 172, 81, 231, 60, 2, 221, 169, 66, 47, 186, 54, 168, 1, 28, 87, 64, 278, ], [40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, 40, ]), 'type_qualifier_list': ([7, ], [43, ]), 'enumerator': ([118, 229, 53, ], [119, 33
 4, 119, ]), 'string_literal': ([203, 276, 210, 381, 389, 216, 256, 151, 176, 367, 202, 421, 382, 80, 377, 219, 412, 408, 380, 266, 354, 201, 394, 207, 406, 272, 192, 411, 262, 218, 369, 189, 224, 346, 263, 183, 198, 158, 215, 47, 240, 72, 190, 140, 228, 60, 384, 304, 188, 264, 378, 208, 191, 267, 409, 166, 289, 76, 204, 193, 113, 79, 257, 141, 137, 147, 55, 194, 74, 293, 342, 328, 174, 186, 284, 197, ], [84, 84, 84, 84, 402, 84, 84, 84, 84, 84, 84, 402, 84, 84, 84, 84, 402, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 402, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 365, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 181, 84, 84, 84, 84, 84, 84, 84, ]), 'parameter_type_list': ([221, 327, 54, 231, ], [325, 373, 125, 325, ]), 'pointer': ([29, 164, 231, 171, 127, 16, 57, 43, 221, 7, 357, 1, 114, ], [14, 14, 234, 14, 234, 14, 14, 69, 225, 45, 14, 14, 225, ]), 'direct_declarator': ([29, 1, 14, 16, 357, 231, 57, 164, 127, 171, 23
 4, ], [26, 26, 49, 26, 26, 26, 26, 26, 26, 26, 49, ]), 'declarator': ([127, 164, 1, 231, 16, 357, 57, 171, 29, ], [233, 132, 27, 50, 50, 282, 132, 282, 64, ]), 'argument_expression_list': ([215, ], [320, ]), 'str_opt_expr_pair_list': ([412, 421, 389, ], [418, 422, 404, ]), 'direct_abstract_declarator': ([114, 225, 234, 231, 127, 221, ], [223, 331, 331, 223, 223, 223, ]), 'additive_expression': ([377, 289, 262, 207, 272, 47, 257, 346, 264, 328, 394, 218, 208, 256, 147, 408, 381, 224, 367, 266, 216, 382, 183, 369, 276, 342, 186, 201, 60, 174, 193, 141, 176, 240, 409, 197, 203, 204, 210, 72, 263, 384, 219, 202, 284, 378, 354, 137, 380, 194, 140, 166, 267, 151, 215, 406, 158, 198, 55, 228, ], [83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 300, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, 301, 83, 83, 83, 83, 83, 83, 83, 83, 83, 83, ]), 'constant_expression': ([354, 289, 151, 174, 284, 47
 , 224, 55, 228, 328, ], [385, 361, 265, 288, 355, 98, 329, 131, 333, 375, ]), 'primary_expression': ([166, 176, 293, 266, 408, 240, 147, 228, 158, 276, 267, 191, 218, 204, 367, 55, 289, 208, 256, 257, 72, 284, 224, 79, 328, 194, 219, 377, 197, 198, 192, 216, 141, 342, 76, 394, 151, 272, 380, 202, 381, 378, 264, 262, 113, 409, 369, 80, 137, 382, 215, 210, 346, 186, 384, 174, 203, 354, 207, 201, 190, 193, 47, 188, 189, 60, 140, 183, 263, 406, ], [100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, ]), 'declaration_specifiers': ([59, 237, 28, 327, 60, 140, 54, 1, 167, 3, 231, 64, 27, 2, 221, ], [57, 127, 61, 127, 57, 57, 127, 29, 57, 42, 127, 57, 57, 41, 127, ]), 'declaration': ([59, 27, 60, 1
 67, 1, 140, 64, ], [134, 58, 58, 134, 30, 134, 58, ]), 'logical_and_expression': ([328, 406, 60, 262, 140, 141, 256, 284, 354, 218, 183, 263, 384, 174, 224, 369, 267, 381, 147, 378, 166, 394, 276, 72, 342, 55, 47, 346, 382, 137, 272, 264, 377, 409, 380, 216, 228, 289, 219, 186, 266, 240, 367, 408, 215, 257, 151, 158, ], [92, 92, 92, 92, 92, 92, 92, 92, 92, 322, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, 92, ]), 'init_declarator_list': ([29, 57, ], [63, 63, ]), 'shift_expression': ([176, 208, 186, 384, 224, 228, 382, 276, 151, 72, 377, 216, 342, 201, 367, 380, 140, 141, 409, 406, 47, 346, 263, 60, 202, 257, 369, 240, 266, 354, 207, 219, 284, 215, 408, 264, 256, 55, 378, 394, 197, 147, 210, 289, 381, 267, 137, 166, 198, 218, 204, 328, 272, 203, 158, 262, 183, 174, ], [86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 305, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 306, 86, 86, 86, 8
 6, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 86, 308, 86, 86, 307, 86, 86, 86, 86, ]), 'equality_expression': ([381, 284, 224, 378, 137, 380, 266, 216, 166, 267, 276, 151, 346, 158, 198, 55, 60, 272, 289, 257, 186, 328, 406, 176, 409, 147, 197, 408, 210, 384, 367, 183, 354, 218, 342, 140, 215, 369, 174, 228, 377, 382, 262, 141, 240, 47, 264, 72, 263, 394, 256, 219, ], [101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 315, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, 101, ]), 'jump_statement': ([378, 267, 60, 147, 394, 382, 408, 240, 158, 406, 263, 380, 346, 140, ], [154, 154, 154, 154, 154, 154, 154, 154, 154, 154, 154, 154, 154, 154, ]), 'struct_declarator': ([171, 357, ], [281, 386, ]), 'function_definition': ([1, ], [32, ]), 'parameter_list': ([54, 327, 221, 231, ], [129, 129, 129, 129, ])
 , 'enum_specifier': ([87, 231, 64, 27, 327, 66, 47, 59, 140, 168, 54, 172, 1, 137, 167, 3, 169, 60, 72, 278, 28, 186, 237, 286, 81, 2, 221, ], [37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, 37, ]), 'str_opt_expr_pair': ([411, 421, 412, 389, ], [417, 403, 403, 403, ]), 'enumerator_list': ([118, 53, ], [226, 120, ]), 'labeled_statement': ([408, 380, 240, 60, 267, 394, 406, 346, 382, 378, 158, 147, 140, 263, ], [139, 139, 139, 139, 139, 139, 139, 139, 139, 139, 139, 139, 139, 139, ]), 'logical_or_expression': ([328, 55, 408, 406, 174, 224, 384, 257, 276, 377, 240, 166, 262, 378, 264, 215, 137, 381, 151, 216, 382, 141, 267, 369, 158, 284, 219, 256, 342, 147, 394, 409, 272, 346, 289, 72, 60, 183, 140, 263, 380, 47, 367, 354, 228, 186, 266, ], [112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112, 112,
 112, 112, 112, 112, 112, 112, 112, 112, 112, ]), 'specifier_qualifier_list': ([168, 169, 172, 72, 186, 137, 286, 66, 278, 81, 47, 87, ], [171, 171, 171, 114, 114, 114, 171, 171, 171, 187, 114, 195, ]), 'multi_string_literal': ([140, 72, 186, 267, 203, 346, 166, 183, 201, 409, 276, 293, 224, 176, 204, 193, 367, 47, 190, 202, 207, 381, 219, 408, 266, 342, 151, 264, 263, 194, 406, 228, 240, 354, 147, 192, 197, 80, 380, 369, 189, 60, 257, 256, 141, 284, 378, 218, 55, 328, 137, 158, 198, 394, 216, 215, 262, 210, 113, 76, 174, 272, 208, 382, 191, 289, 79, 188, 384, 377, ], [74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, 74, ]), 'translation_unit': ([0, ], [1, ]), 'initializer_list': ([276, ], [352, ]), 'conditional_expression': ([266, 257, 240, 141, 215, 272, 183,
  147, 328, 394, 216, 354, 406, 72, 140, 378, 369, 47, 276, 267, 384, 367, 263, 174, 151, 137, 289, 186, 408, 342, 158, 228, 219, 262, 380, 382, 264, 166, 409, 224, 377, 381, 346, 256, 55, 284, 60, ], [162, 162, 162, 162, 162, 162, 162, 162, 115, 162, 162, 115, 162, 162, 162, 162, 391, 115, 162, 162, 162, 162, 162, 115, 115, 162, 115, 162, 162, 162, 162, 115, 162, 162, 162, 162, 162, 162, 162, 115, 162, 162, 162, 162, 115, 115, 162, ]), 'statement_list': ([140, 60, ], [240, 147, ]), 'identifier': ([408, 293, 342, 208, 203, 218, 188, 183, 263, 380, 60, 140, 207, 266, 267, 141, 176, 256, 240, 284, 210, 113, 193, 369, 224, 219, 55, 381, 204, 197, 406, 346, 354, 206, 147, 137, 377, 158, 378, 189, 192, 272, 216, 47, 384, 209, 166, 394, 276, 174, 409, 367, 190, 382, 328, 202, 198, 257, 80, 264, 79, 228, 72, 201, 289, 191, 186, 262, 215, 194, 76, 151, ], [75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 310,
 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 313, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, 75, ]), 'expression': ([257, 266, 378, 394, 158, 140, 381, 409, 342, 216, 72, 380, 219, 406, 408, 264, 186, 377, 267, 272, 147, 183, 346, 141, 60, 382, 137, 240, 263, ], [148, 347, 148, 148, 148, 148, 398, 416, 148, 321, 177, 148, 323, 148, 148, 345, 177, 395, 148, 350, 148, 177, 148, 244, 148, 148, 177, 148, 148, ]), }
+_lr_goto_items = {'expression_statement':([240,257,382,267,140,406,380,342,263,60,408,147,378,346,158,394,],[135,342,135,135,135,135,135,377,135,135,135,135,135,135,135,135,]),'storage_class_specifier':([140,27,28,327,167,221,60,54,59,64,2,3,1,237,231,],[2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,]),'declaration_list':([64,60,27,],[167,140,59,]),'type_qualifier':([60,72,87,28,169,47,27,327,221,59,54,278,7,81,43,2,237,140,168,64,231,286,172,167,3,66,186,1,137,],[3,87,87,3,87,87,3,3,3,3,3,87,44,87,68,3,3,3,87,3,3,87,87,3,3,87,87,3,87,]),'constant':([262,380,186,176,191,408,377,266,207,409,60,183,367,80,203,202,328,276,394,166,293,272,151,76,194,378,289,158,201,147,72,190,369,228,346,79,264,197,204,381,55,224,193,257,198,382,284,174,256,47,216,141,267,384,192,189,240,140,263,137,188,354,218,208,406,219,342,113,210,215,],[91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,91,
 91,91,91,91,91,91,91,91,91,91,]),'volatile_opt':([93,],[200,]),'unary_expression':([256,208,47,166,346,192,197,202,141,189,194,263,215,289,198,158,201,219,409,381,207,60,369,367,193,257,176,191,137,328,174,151,276,394,384,382,408,380,342,183,76,80,203,262,147,218,354,204,377,272,224,113,210,186,284,72,228,190,79,264,216,55,267,266,293,406,240,140,188,378,],[142,78,78,142,142,78,78,78,142,78,78,142,142,78,78,142,78,142,142,142,78,142,78,142,78,142,78,78,142,78,78,78,142,142,142,142,142,142,142,142,182,185,78,142,142,78,78,78,142,142,78,78,78,142,78,142,78,78,184,142,142,78,142,142,78,142,142,142,78,142,]),'struct_or_union_specifier':([221,2,59,278,168,27,64,169,87,137,231,72,1,66,54,186,47,81,167,28,172,237,3,140,60,286,327,],[5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,]),'exclusive_or_expression':([262,272,264,408,328,384,219,224,228,72,216,141,342,367,284,377,166,289,218,267,276,257,266,198,186,140,55,60,382,256,147,176,240,47,158,381,215,137,394,369,378,354,380,263,183,
 174,406,346,151,409,],[89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,291,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,89,]),'identifier_list':([54,],[128,]),'define':([1,],[22,]),'initializer':([384,276,166,],[400,351,274,]),'macro_param':([240,147,186,151,208,198,191,384,193,257,60,203,140,380,408,79,381,262,55,176,276,210,194,201,378,47,224,293,202,80,189,328,346,190,174,219,256,166,266,264,216,367,192,272,197,284,409,377,158,267,72,369,406,215,137,76,342,188,141,354,218,382,207,228,183,394,204,263,113,289,74,],[105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,105,179,]),'struct_declaration_list':([172,168,66,],[286,278,169,]),'macro_parameter_list':([70,],[175,]),'struct_declaration':([66,168,172,278,169,
 286,],[170,170,170,279,279,279,]),'abstract_declarator':([221,114,231,127,],[326,222,326,232,]),'iteration_statement':([406,382,240,378,60,263,158,380,140,267,147,394,408,346,],[136,136,136,136,136,136,136,136,136,136,136,136,136,136,]),'and_expression':([262,377,151,342,408,394,198,137,328,60,219,381,228,367,47,257,158,224,369,197,141,240,183,263,264,346,266,384,289,174,176,186,276,354,409,215,216,55,218,166,378,267,72,256,140,380,284,382,272,147,406,],[106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,302,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,106,]),'assignment_expression':([276,394,272,216,147,367,256,380,158,262,266,264,342,408,263,183,381,406,166,377,72,140,60,378,409,215,240,346,267,186,384,137,257,141,382,219,],[275,160,160,160,160,390,341,160,160,343,160,160,160,160,160,160,160,160,275,160,160,160,160,160,160,319,160,160,160,160,275,160,160,160,160,160,]),'external_dec
 laration':([1,],[15,]),'type_specifier':([237,140,28,172,167,81,221,59,47,286,3,60,87,137,27,64,231,327,66,54,72,278,168,169,1,186,2,],[28,28,28,81,28,81,28,28,81,81,28,28,81,81,28,28,28,28,81,28,81,81,81,81,28,81,28,]),'compound_statement':([140,60,378,394,147,408,406,346,59,263,382,158,267,167,240,27,64,380,],[143,143,143,143,143,143,143,143,133,143,143,143,143,277,143,56,165,143,]),'inclusive_or_expression':([60,382,47,218,409,183,272,228,377,408,328,224,166,380,284,55,186,289,151,256,346,369,367,147,240,216,266,262,158,267,276,378,219,198,140,72,406,381,354,263,257,394,342,384,264,215,141,137,174,],[71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,303,71,71,71,71,71,71,71,71,71,71,71,71,71,71,71,]),'enumerator_list_iso':([118,53,],[122,122,]),'selection_statement':([408,346,394,378,263,267,147,240,158,406,140,60,380,382,],[159,159,159,159,159,159,159,159,159,159,159,159,159,159,]),'postfix_expression':([197,394,192,137,328,194,26
 3,378,141,151,60,189,369,380,219,207,262,240,193,228,406,257,377,342,266,381,183,202,147,190,346,47,367,204,176,408,224,293,384,79,276,208,272,201,210,409,166,203,267,186,72,216,140,198,188,55,289,264,218,382,354,174,76,113,284,256,158,80,215,191,],[109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,109,]),'asm_expression':([151,215,409,210,276,377,183,141,378,224,80,198,192,166,262,194,72,113,406,257,189,384,394,219,354,263,240,346,284,60,207,201,203,408,382,174,264,272,176,204,266,197,216,193,328,267,190,369,228,186,381,256,147,342,380,188,158,47,55,293,208,218,289,76,79,137,191,140,202,367,],[110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,1
 10,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,110,]),'declaration_impl':([167,27,64,59,1,60,140,],[19,19,19,19,19,19,19,]),'type_name':([186,137,72,47,],[294,178,178,88,]),'relational_expression':([276,408,378,289,216,264,382,183,263,380,224,240,377,219,262,409,158,197,210,346,394,166,55,384,381,257,207,147,267,369,215,367,198,186,174,354,72,272,328,47,60,137,141,140,406,218,284,208,176,256,266,342,151,228,],[96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,311,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,96,312,96,96,96,96,96,96,]),'statement':([158,60,394,140,267,380,263,147,408,240,382,406,346,378,],[271,153,405,153,348,397,344,259,415,259,399,413,379,396,]),'parameter_declaration':([54,327,231,237,221,],[126,126,126,337,126,]),'cast_expression':([186,293,266,406,174,224,384,202,257,189,240,113,218,193,262,55,377,198,166,216,194,137,382,203,276,378,215,210,219,267,197,147,381,354
 ,409,158,208,176,256,342,188,141,207,192,272,72,204,284,228,191,346,289,394,151,408,369,60,140,47,183,264,263,380,328,201,190,367,],[97,363,97,97,97,97,97,97,97,97,97,220,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,299,97,97,97,97,97,298,97,97,97,97,97,97,97,97,97,97,97,97,97,97,97,297,97,]),'init_declarator':([29,164,57,],[62,273,62,]),'struct_declarator_list':([171,],[285,]),'multiplicative_expression':([384,367,60,55,47,166,201,406,346,204,197,72,228,203,409,262,198,381,219,194,263,207,377,257,378,137,276,210,202,189,267,158,342,256,208,218,140,141,394,188,380,183,382,328,224,272,264,174,216,289,186,354,408,215,151,369,193,147,266,240,176,284,],[85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,296,85,85,85,85,85,85,85,85,85,295,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,85,]),'unary_operator':([284,141,176,224,369,384,293,276,409,240,201,210,194,354,203,186,72,60,189,380,188
 ,198,55,219,218,202,207,382,190,406,76,204,113,257,256,147,158,377,151,215,208,272,137,408,183,166,262,378,267,47,140,79,191,192,193,228,264,342,80,266,197,394,216,328,381,289,263,346,174,367,],[113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,113,]),'assignment_operator':([142,],[256,]),'struct_or_union':([59,140,286,3,27,327,167,72,137,237,172,81,231,60,2,221,169,66,47,186,54,168,1,28,87,64,278,],[40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,]),'type_qualifier_list':([7,],[43,]),'enumerator':([118,229,53,],[119,334,119,]),'string_literal':([203,276,210,381,389,216,256,151,176,367,202,421,382,80,377,219,412,408,380,266,354,201,394,207,406,272,192,411,262,218,369,189,224,346,263,183,198,158,215,47,240,72,190,140,228,60,384,3
 04,188,264,378,208,191,267,409,166,289,76,204,193,113,79,257,141,137,147,55,194,74,293,342,328,174,186,284,197,],[84,84,84,84,402,84,84,84,84,84,84,402,84,84,84,84,402,84,84,84,84,84,84,84,84,84,84,402,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,365,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,84,181,84,84,84,84,84,84,84,]),'parameter_type_list':([221,327,54,231,],[325,373,125,325,]),'pointer':([29,164,231,171,127,16,57,43,221,7,357,1,114,],[14,14,234,14,234,14,14,69,225,45,14,14,225,]),'direct_declarator':([29,1,14,16,357,231,57,164,127,171,234,],[26,26,49,26,26,26,26,26,26,26,49,]),'declarator':([127,164,1,231,16,357,57,171,29,],[233,132,27,50,50,282,132,282,64,]),'argument_expression_list':([215,],[320,]),'str_opt_expr_pair_list':([412,421,389,],[418,422,404,]),'direct_abstract_declarator':([114,225,234,231,127,221,],[223,331,331,223,223,223,]),'additive_expression':([377,289,262,207,272,47,257,346,264,328,394,218,208,256,147,408,381,224,367,266,216,382,1
 83,369,276,342,186,201,60,174,193,141,176,240,409,197,203,204,210,72,263,384,219,202,284,378,354,137,380,194,140,166,267,151,215,406,158,198,55,228,],[83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,300,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,83,301,83,83,83,83,83,83,83,83,83,83,]),'constant_expression':([354,289,151,174,284,47,224,55,228,328,],[385,361,265,288,355,98,329,131,333,375,]),'primary_expression':([166,176,293,266,408,240,147,228,158,276,267,191,218,204,367,55,289,208,256,257,72,284,224,79,328,194,219,377,197,198,192,216,141,342,76,394,151,272,380,202,381,378,264,262,113,409,369,80,137,382,215,210,346,186,384,174,203,354,207,201,190,193,47,188,189,60,140,183,263,406,],[100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100,100
 ,100,100,100,100,100,100,]),'declaration_specifiers':([59,237,28,327,60,140,54,1,167,3,231,64,27,2,221,],[57,127,61,127,57,57,127,29,57,42,127,57,57,41,127,]),'declaration':([59,27,60,167,1,140,64,],[134,58,58,134,30,134,58,]),'logical_and_expression':([328,406,60,262,140,141,256,284,354,218,183,263,384,174,224,369,267,381,147,378,166,394,276,72,342,55,47,346,382,137,272,264,377,409,380,216,228,289,219,186,266,240,367,408,215,257,151,158,],[92,92,92,92,92,92,92,92,92,322,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,92,]),'init_declarator_list':([29,57,],[63,63,]),'shift_expression':([176,208,186,384,224,228,382,276,151,72,377,216,342,201,367,380,140,141,409,406,47,346,263,60,202,257,369,240,266,354,219,284,215,408,264,207,256,55,378,394,197,147,210,289,381,267,137,166,198,218,204,328,272,203,158,262,183,174,],[86,86,86,86,86,86,86,86,86,86,86,86,86,305,86,86,86,86,86,86,86,86,86,86,306,86,86,86,86,86,86,86,86,86,86,86
 ,86,86,86,86,86,86,86,86,86,86,86,86,86,86,308,86,86,307,86,86,86,86,]),'equality_expression':([381,284,224,378,137,380,266,216,166,267,276,151,346,158,198,55,60,272,289,257,186,328,406,176,409,147,197,408,210,384,367,183,354,218,342,140,215,369,174,228,377,382,262,141,240,47,264,72,263,394,256,219,],[101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,315,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,101,]),'jump_statement':([378,267,60,147,394,382,408,240,158,406,263,380,346,140,],[154,154,154,154,154,154,154,154,154,154,154,154,154,154,]),'struct_declarator':([171,357,],[281,386,]),'function_definition':([1,],[32,]),'parameter_list':([54,327,221,231,],[129,129,129,129,]),'enum_specifier':([87,231,64,27,327,66,47,59,140,168,54,172,1,137,167,3,169,60,72,278,28,186,237,286,81,2,221,],[37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,37,]),'str_opt_expr_p
 air':([411,421,412,389,],[417,403,403,403,]),'enumerator_list':([118,53,],[226,120,]),'labeled_statement':([408,380,240,60,267,394,406,346,382,378,158,147,140,263,],[139,139,139,139,139,139,139,139,139,139,139,139,139,139,]),'logical_or_expression':([328,55,408,406,174,224,384,257,276,377,240,228,166,262,378,264,215,137,381,151,216,382,141,267,369,158,284,219,256,342,147,394,409,272,346,289,72,60,183,140,263,380,47,367,354,186,266,],[112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,112,]),'specifier_qualifier_list':([168,169,172,72,186,137,286,66,278,81,47,87,],[171,171,171,114,114,114,171,171,171,187,114,195,]),'multi_string_literal':([140,72,186,267,203,346,166,183,201,409,276,293,224,176,257,204,193,367,47,190,202,207,381,219,408,266,342,151,264,263,194,406,228,240,354,147,192,197,80,380,369,189,60,256,141,284,378,218,55,328,137,158,198,394,216,21
 5,262,210,113,76,174,272,208,382,191,289,79,188,384,377,],[74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,74,]),'translation_unit':([0,],[1,]),'initializer_list':([276,],[352,]),'conditional_expression':([266,257,240,141,215,272,183,147,328,394,216,354,406,72,140,378,369,47,276,267,384,367,263,174,151,137,289,186,408,342,158,228,219,262,380,382,264,166,409,224,377,381,346,256,55,284,60,],[162,162,162,162,162,162,162,162,115,162,162,115,162,162,162,162,391,115,162,162,162,162,162,115,115,162,115,162,162,162,162,115,162,162,162,162,162,162,162,115,162,162,162,162,115,115,162,]),'statement_list':([140,60,],[240,147,]),'identifier':([408,293,342,208,203,218,188,183,263,380,60,140,207,266,267,141,176,256,240,284,210,113,193,369,224,219,55,381,204,197,406,346,354,206,147,137,377,158,378,189,192,272,216,47,384,209,166,394,276,174,40
 9,367,190,382,328,202,198,257,80,264,79,228,72,201,289,191,186,262,215,194,76,151,],[75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,310,75,75,75,75,75,75,75,75,75,75,75,313,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,75,]),'expression':([257,266,378,394,158,140,381,409,342,216,72,380,219,406,408,264,186,377,267,272,147,183,346,141,60,382,137,240,263,],[148,347,148,148,148,148,398,416,148,321,177,148,323,148,148,345,177,395,148,350,148,177,148,244,148,148,177,148,148,]),}
-_lr_goto = {}
+_lr_goto = { }
 for _k, _v in _lr_goto_items.items():
-        _lr_goto[(_x, _k)] = _y
+       _lr_goto[(_x,_k)] = _y
 del _lr_goto_items
 _lr_productions = [
-    ("S'", 1, None, None, None),
-    ('translation_unit', 0, 'p_translation_unit', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 57),
-    ('translation_unit', 2, 'p_translation_unit', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 58),
-    ('translation_unit', 2, 'p_translation_unit', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 59),
-    ('identifier', 1, 'p_identifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 67),
-    ('identifier', 3, 'p_identifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 68),
-    ('identifier', 3, 'p_identifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 69),
-    ('identifier', 3, 'p_identifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 70),
-    ('identifier', 3, 'p_identifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 71),
-    ('constant', 1, 'p_constant', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 87),
-    ('constant', 1, 'p_constant', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 88),
-    ('string_literal', 1, 'p_string_literal', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 111),
-    ('multi_string_literal', 1, 'p_multi_string_literal', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 115),
-    ('multi_string_literal', 1, 'p_multi_string_literal', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 116),
-    ('multi_string_literal', 2, 'p_multi_string_literal', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 117),
-    ('multi_string_literal', 2, 'p_multi_string_literal', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 118),
-    ('macro_param', 1, 'p_macro_param', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 127),
-    ('macro_param', 2, 'p_macro_param', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 128),
-    ('primary_expression', 1, 'p_primary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 136),
-    ('primary_expression', 1, 'p_primary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 137),
-    ('primary_expression', 1, 'p_primary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 138),
-    ('primary_expression', 3, 'p_primary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 139),
-    ('postfix_expression', 1, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 147),
-    ('postfix_expression', 4, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 148),
-    ('postfix_expression', 3, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 149),
-    ('postfix_expression', 4, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 150),
-    ('postfix_expression', 3, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 151),
-    ('postfix_expression', 3, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 152),
-    ('postfix_expression', 2, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 153),
-    ('postfix_expression', 2, 'p_postfix_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 154),
-    ('argument_expression_list', 1, 'p_argument_expression_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 187),
-    ('argument_expression_list', 3, 'p_argument_expression_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 188),
-    ('asm_expression', 5, 'p_asm_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 197),
-    ('asm_expression', 7, 'p_asm_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 198),
-    ('asm_expression', 9, 'p_asm_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 199),
-    ('asm_expression', 11, 'p_asm_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 200),
-    ('str_opt_expr_pair_list', 0, 'p_str_opt_expr_pair_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 212),
-    ('str_opt_expr_pair_list', 1, 'p_str_opt_expr_pair_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 213),
-    ('str_opt_expr_pair_list', 3, 'p_str_opt_expr_pair_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 214),
-    ('str_opt_expr_pair', 1, 'p_str_opt_expr_pair', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 218),
-    ('str_opt_expr_pair', 4, 'p_str_opt_expr_pair', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 219),
-    ('volatile_opt', 0, 'p_volatile_opt', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 223),
-    ('volatile_opt', 1, 'p_volatile_opt', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 224),
-    ('unary_expression', 1, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 239),
-    ('unary_expression', 2, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 240),
-    ('unary_expression', 2, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 241),
-    ('unary_expression', 2, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 242),
-    ('unary_expression', 2, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 243),
-    ('unary_expression', 4, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 244),
-    ('unary_expression', 1, 'p_unary_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 245),
-    ('unary_operator', 1, 'p_unary_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 262),
-    ('unary_operator', 1, 'p_unary_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 263),
-    ('unary_operator', 1, 'p_unary_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 264),
-    ('unary_operator', 1, 'p_unary_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 265),
-    ('unary_operator', 1, 'p_unary_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 266),
-    ('unary_operator', 1, 'p_unary_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 267),
-    ('cast_expression', 1, 'p_cast_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 272),
-    ('cast_expression', 4, 'p_cast_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 273),
-    ('multiplicative_expression', 1, 'p_multiplicative_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 287),
-    ('multiplicative_expression', 3, 'p_multiplicative_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 288),
-    ('multiplicative_expression', 3, 'p_multiplicative_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 289),
-    ('multiplicative_expression', 3, 'p_multiplicative_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 290),
-    ('additive_expression', 1, 'p_additive_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 305),
-    ('additive_expression', 3, 'p_additive_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 306),
-    ('additive_expression', 3, 'p_additive_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 307),
-    ('shift_expression', 1, 'p_shift_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 322),
-    ('shift_expression', 3, 'p_shift_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 323),
-    ('shift_expression', 3, 'p_shift_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 324),
-    ('relational_expression', 1, 'p_relational_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 341),
-    ('relational_expression', 3, 'p_relational_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 342),
-    ('relational_expression', 3, 'p_relational_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 343),
-    ('relational_expression', 3, 'p_relational_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 344),
-    ('relational_expression', 3, 'p_relational_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 345),
-    ('equality_expression', 1, 'p_equality_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 360),
-    ('equality_expression', 3, 'p_equality_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 361),
-    ('equality_expression', 3, 'p_equality_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 362),
-    ('and_expression', 1, 'p_and_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 372),
-    ('and_expression', 3, 'p_and_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 373),
-    ('exclusive_or_expression', 1, 'p_exclusive_or_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 382),
-    ('exclusive_or_expression', 3, 'p_exclusive_or_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 383),
-    ('inclusive_or_expression', 1, 'p_inclusive_or_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 392),
-    ('inclusive_or_expression', 3, 'p_inclusive_or_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 393),
-    ('logical_and_expression', 1, 'p_logical_and_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 402),
-    ('logical_and_expression', 3, 'p_logical_and_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 403),
-    ('logical_or_expression', 1, 'p_logical_or_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 412),
-    ('logical_or_expression', 3, 'p_logical_or_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 413),
-    ('conditional_expression', 1, 'p_conditional_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 422),
-    ('conditional_expression', 5, 'p_conditional_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 423),
-    ('assignment_expression', 1, 'p_assignment_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 444),
-    ('assignment_expression', 3, 'p_assignment_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 445),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 460),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 461),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 462),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 463),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 464),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 465),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 466),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 467),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 468),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 469),
-    ('assignment_operator', 1, 'p_assignment_operator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 470),
-    ('expression', 1, 'p_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 475),
-    ('expression', 3, 'p_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 476),
-    ('constant_expression', 1, 'p_constant_expression', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 482),
-    ('declaration', 2, 'p_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 487),
-    ('declaration_impl', 1, 'p_declaration_impl', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 494),
-    ('declaration_impl', 2, 'p_declaration_impl', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 495),
-    ('declaration_specifiers', 1, 'p_declaration_specifiers', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 519),
-    ('declaration_specifiers', 2, 'p_declaration_specifiers', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 520),
-    ('declaration_specifiers', 1, 'p_declaration_specifiers', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 521),
-    ('declaration_specifiers', 2, 'p_declaration_specifiers', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 522),
-    ('declaration_specifiers', 1, 'p_declaration_specifiers', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 523),
-    ('declaration_specifiers', 2, 'p_declaration_specifiers', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 524),
-    ('init_declarator_list', 1, 'p_init_declarator_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 532),
-    ('init_declarator_list', 3, 'p_init_declarator_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 533),
-    ('init_declarator', 1, 'p_init_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 541),
-    ('init_declarator', 3, 'p_init_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 542),
-    ('storage_class_specifier', 1, 'p_storage_class_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 549),
-    ('storage_class_specifier', 1, 'p_storage_class_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 550),
-    ('storage_class_specifier', 1, 'p_storage_class_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 551),
-    ('storage_class_specifier', 1, 'p_storage_class_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 552),
-    ('storage_class_specifier', 1, 'p_storage_class_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 553),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 558),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 559),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 560),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 561),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 562),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 563),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 564),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 565),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 566),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 567),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 568),
-    ('type_specifier', 1, 'p_type_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 569),
-    ('struct_or_union_specifier', 5, 'p_struct_or_union_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 578),
-    ('struct_or_union_specifier', 5, 'p_struct_or_union_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 579),
-    ('struct_or_union_specifier', 4, 'p_struct_or_union_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 580),
-    ('struct_or_union_specifier', 2, 'p_struct_or_union_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 581),
-    ('struct_or_union_specifier', 2, 'p_struct_or_union_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 582),
-    ('struct_or_union', 1, 'p_struct_or_union', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 598),
-    ('struct_or_union', 1, 'p_struct_or_union', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 599),
-    ('struct_declaration_list', 1, 'p_struct_declaration_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 604),
-    ('struct_declaration_list', 2, 'p_struct_declaration_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 605),
-    ('struct_declaration', 3, 'p_struct_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 613),
-    ('struct_declaration', 2, 'p_struct_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 614),
-    ('specifier_qualifier_list', 2, 'p_specifier_qualifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 628),
-    ('specifier_qualifier_list', 1, 'p_specifier_qualifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 629),
-    ('specifier_qualifier_list', 2, 'p_specifier_qualifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 630),
-    ('specifier_qualifier_list', 1, 'p_specifier_qualifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 631),
-    ('struct_declarator_list', 1, 'p_struct_declarator_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 640),
-    ('struct_declarator_list', 3, 'p_struct_declarator_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 641),
-    ('struct_declarator', 1, 'p_struct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 649),
-    ('struct_declarator', 2, 'p_struct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 650),
-    ('struct_declarator', 3, 'p_struct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 651),
-    ('enum_specifier', 4, 'p_enum_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 662),
-    ('enum_specifier', 5, 'p_enum_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 663),
-    ('enum_specifier', 2, 'p_enum_specifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 664),
-    ('enumerator_list', 1, 'p_enumerator_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 677),
-    ('enumerator_list', 2, 'p_enumerator_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 678),
-    ('enumerator_list_iso', 1, 'p_enumerator_list_iso', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 685),
-    ('enumerator_list_iso', 3, 'p_enumerator_list_iso', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 686),
-    ('enumerator', 1, 'p_enumerator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 694),
-    ('enumerator', 3, 'p_enumerator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 695),
-    ('type_qualifier', 1, 'p_type_qualifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 703),
-    ('type_qualifier', 1, 'p_type_qualifier', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 704),
-    ('declarator', 2, 'p_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 709),
-    ('declarator', 1, 'p_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 710),
-    ('direct_declarator', 1, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 722),
-    ('direct_declarator', 3, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 723),
-    ('direct_declarator', 4, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 724),
-    ('direct_declarator', 3, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 725),
-    ('direct_declarator', 4, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 726),
-    ('direct_declarator', 4, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 727),
-    ('direct_declarator', 3, 'p_direct_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 728),
-    ('pointer', 1, 'p_pointer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 757),
-    ('pointer', 2, 'p_pointer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 758),
-    ('pointer', 2, 'p_pointer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 759),
-    ('pointer', 3, 'p_pointer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 760),
-    ('type_qualifier_list', 1, 'p_type_qualifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 777),
-    ('type_qualifier_list', 2, 'p_type_qualifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 778),
-    ('parameter_type_list', 1, 'p_parameter_type_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 786),
-    ('parameter_type_list', 3, 'p_parameter_type_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 787),
-    ('parameter_list', 1, 'p_parameter_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 796),
-    ('parameter_list', 3, 'p_parameter_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 797),
-    ('parameter_declaration', 2, 'p_parameter_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 805),
-    ('parameter_declaration', 2, 'p_parameter_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 806),
-    ('parameter_declaration', 1, 'p_parameter_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 807),
-    ('identifier_list', 1, 'p_identifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 815),
-    ('identifier_list', 3, 'p_identifier_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 816),
-    ('type_name', 1, 'p_type_name', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 828),
-    ('type_name', 2, 'p_type_name', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 829),
-    ('abstract_declarator', 1, 'p_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 845),
-    ('abstract_declarator', 1, 'p_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 846),
-    ('abstract_declarator', 2, 'p_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 847),
-    ('direct_abstract_declarator', 3, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 866),
-    ('direct_abstract_declarator', 2, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 867),
-    ('direct_abstract_declarator', 3, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 868),
-    ('direct_abstract_declarator', 3, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 869),
-    ('direct_abstract_declarator', 4, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 870),
-    ('direct_abstract_declarator', 2, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 871),
-    ('direct_abstract_declarator', 3, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 872),
-    ('direct_abstract_declarator', 3, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 873),
-    ('direct_abstract_declarator', 4, 'p_direct_abstract_declarator', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 874),
-    ('initializer', 1, 'p_initializer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 911),
-    ('initializer', 3, 'p_initializer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 912),
-    ('initializer', 4, 'p_initializer', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 913),
-    ('initializer_list', 1, 'p_initializer_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 917),
-    ('initializer_list', 3, 'p_initializer_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 918),
-    ('statement', 1, 'p_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 922),
-    ('statement', 1, 'p_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 923),
-    ('statement', 1, 'p_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 924),
-    ('statement', 1, 'p_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 925),
-    ('statement', 1, 'p_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 926),
-    ('statement', 1, 'p_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 927),
-    ('labeled_statement', 3, 'p_labeled_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 931),
-    ('labeled_statement', 4, 'p_labeled_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 932),
-    ('labeled_statement', 3, 'p_labeled_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 933),
-    ('compound_statement', 2, 'p_compound_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 937),
-    ('compound_statement', 3, 'p_compound_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 938),
-    ('compound_statement', 3, 'p_compound_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 939),
-    ('compound_statement', 4, 'p_compound_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 940),
-    ('compound_statement', 3, 'p_compound_statement_error', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 944),
-    ('declaration_list', 1, 'p_declaration_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 949),
-    ('declaration_list', 2, 'p_declaration_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 950),
-    ('statement_list', 1, 'p_statement_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 954),
-    ('statement_list', 2, 'p_statement_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 955),
-    ('expression_statement', 1, 'p_expression_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 959),
-    ('expression_statement', 2, 'p_expression_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 960),
-    ('expression_statement', 2, 'p_expression_statement_error', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 963),
-    ('selection_statement', 5, 'p_selection_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 968),
-    ('selection_statement', 7, 'p_selection_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 969),
-    ('selection_statement', 5, 'p_selection_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 970),
-    ('iteration_statement', 5, 'p_iteration_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 974),
-    ('iteration_statement', 7, 'p_iteration_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 975),
-    ('iteration_statement', 6, 'p_iteration_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 976),
-    ('iteration_statement', 7, 'p_iteration_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 977),
-    ('jump_statement', 3, 'p_jump_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 981),
-    ('jump_statement', 2, 'p_jump_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 982),
-    ('jump_statement', 2, 'p_jump_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 983),
-    ('jump_statement', 2, 'p_jump_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 984),
-    ('jump_statement', 3, 'p_jump_statement', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 985),
-    ('external_declaration', 1, 'p_external_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 989),
-    ('external_declaration', 1, 'p_external_declaration', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 990),
-    ('function_definition', 4, 'p_function_definition', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 996),
-    ('function_definition', 3, 'p_function_definition', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 997),
-    ('function_definition', 3, 'p_function_definition', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 998),
-    ('function_definition', 2, 'p_function_definition', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 999),
-    ('define', 3, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1003),
-    ('define', 4, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1004),
-    ('define', 4, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1005),
-    ('define', 5, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1006),
-    ('define', 6, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1007),
-    ('define', 6, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1008),
-    ('define', 7, 'p_define', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1009),
-    ('define', 3, 'p_define_error', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1042),
-    ('macro_parameter_list', 1, 'p_macro_parameter_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1071),
-    ('macro_parameter_list', 3, 'p_macro_parameter_list', '/Users/tim/Desktop/ctypesgen/ctypesgencore/parser/cgrammar.py', 1072),
+  ("S'",1,None,None,None),
+  ('translation_unit',0,'p_translation_unit','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',63),
+  ('translation_unit',2,'p_translation_unit','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',64),
+  ('translation_unit',2,'p_translation_unit','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',65),
+  ('identifier',1,'p_identifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',74),
+  ('identifier',3,'p_identifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',75),
+  ('identifier',3,'p_identifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',76),
+  ('identifier',3,'p_identifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',77),
+  ('identifier',3,'p_identifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',78),
+  ('constant',1,'p_constant','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',95),
+  ('constant',1,'p_constant','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',96),
+  ('string_literal',1,'p_string_literal','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',120),
+  ('multi_string_literal',1,'p_multi_string_literal','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',125),
+  ('multi_string_literal',1,'p_multi_string_literal','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',126),
+  ('multi_string_literal',2,'p_multi_string_literal','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',127),
+  ('multi_string_literal',2,'p_multi_string_literal','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',128),
+  ('macro_param',1,'p_macro_param','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',141),
+  ('macro_param',2,'p_macro_param','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',142),
+  ('primary_expression',1,'p_primary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',151),
+  ('primary_expression',1,'p_primary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',152),
+  ('primary_expression',1,'p_primary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',153),
+  ('primary_expression',3,'p_primary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',154),
+  ('postfix_expression',1,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',163),
+  ('postfix_expression',4,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',164),
+  ('postfix_expression',3,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',165),
+  ('postfix_expression',4,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',166),
+  ('postfix_expression',3,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',167),
+  ('postfix_expression',3,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',168),
+  ('postfix_expression',2,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',169),
+  ('postfix_expression',2,'p_postfix_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',170),
+  ('argument_expression_list',1,'p_argument_expression_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',207),
+  ('argument_expression_list',3,'p_argument_expression_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',208),
+  ('asm_expression',5,'p_asm_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',218),
+  ('asm_expression',7,'p_asm_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',219),
+  ('asm_expression',9,'p_asm_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',220),
+  ('asm_expression',11,'p_asm_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',221),
+  ('str_opt_expr_pair_list',0,'p_str_opt_expr_pair_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',234),
+  ('str_opt_expr_pair_list',1,'p_str_opt_expr_pair_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',235),
+  ('str_opt_expr_pair_list',3,'p_str_opt_expr_pair_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',236),
+  ('str_opt_expr_pair',1,'p_str_opt_expr_pair','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',241),
+  ('str_opt_expr_pair',4,'p_str_opt_expr_pair','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',242),
+  ('volatile_opt',0,'p_volatile_opt','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',247),
+  ('volatile_opt',1,'p_volatile_opt','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',248),
+  ('unary_expression',1,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',264),
+  ('unary_expression',2,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',265),
+  ('unary_expression',2,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',266),
+  ('unary_expression',2,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',267),
+  ('unary_expression',2,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',268),
+  ('unary_expression',4,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',269),
+  ('unary_expression',1,'p_unary_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',270),
+  ('unary_operator',1,'p_unary_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',288),
+  ('unary_operator',1,'p_unary_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',289),
+  ('unary_operator',1,'p_unary_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',290),
+  ('unary_operator',1,'p_unary_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',291),
+  ('unary_operator',1,'p_unary_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',292),
+  ('unary_operator',1,'p_unary_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',293),
+  ('cast_expression',1,'p_cast_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',299),
+  ('cast_expression',4,'p_cast_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',300),
+  ('multiplicative_expression',1,'p_multiplicative_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',315),
+  ('multiplicative_expression',3,'p_multiplicative_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',316),
+  ('multiplicative_expression',3,'p_multiplicative_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',317),
+  ('multiplicative_expression',3,'p_multiplicative_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',318),
+  ('additive_expression',1,'p_additive_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',334),
+  ('additive_expression',3,'p_additive_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',335),
+  ('additive_expression',3,'p_additive_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',336),
+  ('shift_expression',1,'p_shift_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',352),
+  ('shift_expression',3,'p_shift_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',353),
+  ('shift_expression',3,'p_shift_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',354),
+  ('relational_expression',1,'p_relational_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',372),
+  ('relational_expression',3,'p_relational_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',373),
+  ('relational_expression',3,'p_relational_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',374),
+  ('relational_expression',3,'p_relational_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',375),
+  ('relational_expression',3,'p_relational_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',376),
+  ('equality_expression',1,'p_equality_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',392),
+  ('equality_expression',3,'p_equality_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',393),
+  ('equality_expression',3,'p_equality_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',394),
+  ('and_expression',1,'p_and_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',405),
+  ('and_expression',3,'p_and_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',406),
+  ('exclusive_or_expression',1,'p_exclusive_or_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',419),
+  ('exclusive_or_expression',3,'p_exclusive_or_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',420),
+  ('inclusive_or_expression',1,'p_inclusive_or_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',433),
+  ('inclusive_or_expression',3,'p_inclusive_or_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',434),
+  ('logical_and_expression',1,'p_logical_and_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',447),
+  ('logical_and_expression',3,'p_logical_and_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',448),
+  ('logical_or_expression',1,'p_logical_or_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',461),
+  ('logical_or_expression',3,'p_logical_or_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',462),
+  ('conditional_expression',1,'p_conditional_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',475),
+  ('conditional_expression',5,'p_conditional_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',476),
+  ('assignment_expression',1,'p_assignment_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',498),
+  ('assignment_expression',3,'p_assignment_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',499),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',515),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',516),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',517),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',518),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',519),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',520),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',521),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',522),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',523),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',524),
+  ('assignment_operator',1,'p_assignment_operator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',525),
+  ('expression',1,'p_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',531),
+  ('expression',3,'p_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',532),
+  ('constant_expression',1,'p_constant_expression','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',539),
+  ('declaration',2,'p_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',545),
+  ('declaration_impl',1,'p_declaration_impl','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',553),
+  ('declaration_impl',2,'p_declaration_impl','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',554),
+  ('declaration_specifiers',1,'p_declaration_specifiers','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',579),
+  ('declaration_specifiers',2,'p_declaration_specifiers','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',580),
+  ('declaration_specifiers',1,'p_declaration_specifiers','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',581),
+  ('declaration_specifiers',2,'p_declaration_specifiers','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',582),
+  ('declaration_specifiers',1,'p_declaration_specifiers','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',583),
+  ('declaration_specifiers',2,'p_declaration_specifiers','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',584),
+  ('init_declarator_list',1,'p_init_declarator_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',593),
+  ('init_declarator_list',3,'p_init_declarator_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',594),
+  ('init_declarator',1,'p_init_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',603),
+  ('init_declarator',3,'p_init_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',604),
+  ('storage_class_specifier',1,'p_storage_class_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',612),
+  ('storage_class_specifier',1,'p_storage_class_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',613),
+  ('storage_class_specifier',1,'p_storage_class_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',614),
+  ('storage_class_specifier',1,'p_storage_class_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',615),
+  ('storage_class_specifier',1,'p_storage_class_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',616),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',622),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',623),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',624),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',625),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',626),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',627),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',628),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',629),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',630),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',631),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',632),
+  ('type_specifier',1,'p_type_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',633),
+  ('struct_or_union_specifier',5,'p_struct_or_union_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',643),
+  ('struct_or_union_specifier',5,'p_struct_or_union_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',644),
+  ('struct_or_union_specifier',4,'p_struct_or_union_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',645),
+  ('struct_or_union_specifier',2,'p_struct_or_union_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',646),
+  ('struct_or_union_specifier',2,'p_struct_or_union_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',647),
+  ('struct_or_union',1,'p_struct_or_union','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',664),
+  ('struct_or_union',1,'p_struct_or_union','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',665),
+  ('struct_declaration_list',1,'p_struct_declaration_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',671),
+  ('struct_declaration_list',2,'p_struct_declaration_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',672),
+  ('struct_declaration',3,'p_struct_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',681),
+  ('struct_declaration',2,'p_struct_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',682),
+  ('specifier_qualifier_list',2,'p_specifier_qualifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',697),
+  ('specifier_qualifier_list',1,'p_specifier_qualifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',698),
+  ('specifier_qualifier_list',2,'p_specifier_qualifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',699),
+  ('specifier_qualifier_list',1,'p_specifier_qualifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',700),
+  ('struct_declarator_list',1,'p_struct_declarator_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',710),
+  ('struct_declarator_list',3,'p_struct_declarator_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',711),
+  ('struct_declarator',1,'p_struct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',720),
+  ('struct_declarator',2,'p_struct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',721),
+  ('struct_declarator',3,'p_struct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',722),
+  ('enum_specifier',4,'p_enum_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',734),
+  ('enum_specifier',5,'p_enum_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',735),
+  ('enum_specifier',2,'p_enum_specifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',736),
+  ('enumerator_list',1,'p_enumerator_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',750),
+  ('enumerator_list',2,'p_enumerator_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',751),
+  ('enumerator_list_iso',1,'p_enumerator_list_iso','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',759),
+  ('enumerator_list_iso',3,'p_enumerator_list_iso','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',760),
+  ('enumerator',1,'p_enumerator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',769),
+  ('enumerator',3,'p_enumerator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',770),
+  ('type_qualifier',1,'p_type_qualifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',779),
+  ('type_qualifier',1,'p_type_qualifier','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',780),
+  ('declarator',2,'p_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',786),
+  ('declarator',1,'p_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',787),
+  ('direct_declarator',1,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',800),
+  ('direct_declarator',3,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',801),
+  ('direct_declarator',4,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',802),
+  ('direct_declarator',3,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',803),
+  ('direct_declarator',4,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',804),
+  ('direct_declarator',4,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',805),
+  ('direct_declarator',3,'p_direct_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',806),
+  ('pointer',1,'p_pointer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',835),
+  ('pointer',2,'p_pointer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',836),
+  ('pointer',2,'p_pointer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',837),
+  ('pointer',3,'p_pointer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',838),
+  ('type_qualifier_list',1,'p_type_qualifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',856),
+  ('type_qualifier_list',2,'p_type_qualifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',857),
+  ('parameter_type_list',1,'p_parameter_type_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',866),
+  ('parameter_type_list',3,'p_parameter_type_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',867),
+  ('parameter_list',1,'p_parameter_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',876),
+  ('parameter_list',3,'p_parameter_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',877),
+  ('parameter_declaration',2,'p_parameter_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',886),
+  ('parameter_declaration',2,'p_parameter_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',887),
+  ('parameter_declaration',1,'p_parameter_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',888),
+  ('identifier_list',1,'p_identifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',897),
+  ('identifier_list',3,'p_identifier_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',898),
+  ('type_name',1,'p_type_name','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',911),
+  ('type_name',2,'p_type_name','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',912),
+  ('abstract_declarator',1,'p_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',930),
+  ('abstract_declarator',1,'p_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',931),
+  ('abstract_declarator',2,'p_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',932),
+  ('direct_abstract_declarator',3,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',952),
+  ('direct_abstract_declarator',2,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',953),
+  ('direct_abstract_declarator',3,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',954),
+  ('direct_abstract_declarator',3,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',955),
+  ('direct_abstract_declarator',4,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',956),
+  ('direct_abstract_declarator',2,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',957),
+  ('direct_abstract_declarator',3,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',958),
+  ('direct_abstract_declarator',3,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',959),
+  ('direct_abstract_declarator',4,'p_direct_abstract_declarator','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',960),
+  ('initializer',1,'p_initializer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',998),
+  ('initializer',3,'p_initializer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',999),
+  ('initializer',4,'p_initializer','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1000),
+  ('initializer_list',1,'p_initializer_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1005),
+  ('initializer_list',3,'p_initializer_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1006),
+  ('statement',1,'p_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1011),
+  ('statement',1,'p_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1012),
+  ('statement',1,'p_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1013),
+  ('statement',1,'p_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1014),
+  ('statement',1,'p_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1015),
+  ('statement',1,'p_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1016),
+  ('labeled_statement',3,'p_labeled_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1021),
+  ('labeled_statement',4,'p_labeled_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1022),
+  ('labeled_statement',3,'p_labeled_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1023),
+  ('compound_statement',2,'p_compound_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1028),
+  ('compound_statement',3,'p_compound_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1029),
+  ('compound_statement',3,'p_compound_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1030),
+  ('compound_statement',4,'p_compound_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1031),
+  ('compound_statement',3,'p_compound_statement_error','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1036),
+  ('declaration_list',1,'p_declaration_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1042),
+  ('declaration_list',2,'p_declaration_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1043),
+  ('statement_list',1,'p_statement_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1048),
+  ('statement_list',2,'p_statement_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1049),
+  ('expression_statement',1,'p_expression_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1054),
+  ('expression_statement',2,'p_expression_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1055),
+  ('expression_statement',2,'p_expression_statement_error','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1060),
+  ('selection_statement',5,'p_selection_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1066),
+  ('selection_statement',7,'p_selection_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1067),
+  ('selection_statement',5,'p_selection_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1068),
+  ('iteration_statement',5,'p_iteration_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1073),
+  ('iteration_statement',7,'p_iteration_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1074),
+  ('iteration_statement',6,'p_iteration_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1075),
+  ('iteration_statement',7,'p_iteration_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1076),
+  ('jump_statement',3,'p_jump_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1081),
+  ('jump_statement',2,'p_jump_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1082),
+  ('jump_statement',2,'p_jump_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1083),
+  ('jump_statement',2,'p_jump_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1084),
+  ('jump_statement',3,'p_jump_statement','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1085),
+  ('external_declaration',1,'p_external_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1090),
+  ('external_declaration',1,'p_external_declaration','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1091),
+  ('function_definition',4,'p_function_definition','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1098),
+  ('function_definition',3,'p_function_definition','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1099),
+  ('function_definition',3,'p_function_definition','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1100),
+  ('function_definition',2,'p_function_definition','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1101),
+  ('define',3,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1106),
+  ('define',4,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1107),
+  ('define',4,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1108),
+  ('define',5,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1109),
+  ('define',6,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1110),
+  ('define',6,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1111),
+  ('define',7,'p_define','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1112),
+  ('define',3,'p_define_error','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1146),
+  ('macro_parameter_list',1,'p_macro_parameter_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1176),
+  ('macro_parameter_list',3,'p_macro_parameter_list','/home/pietro/docdat/src/gis/grass_git/lib/python/ctypes/ctypesgencore/parser/cgrammar.py',1177),
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -10,6 +10,14 @@
 __docformat__ = 'restructuredtext'
+try:
+    from builtins import long
+    PY2 = True
+except ImportError:
+    # python3
+    PY2 = False
+    long = int
 import os
 import re
 import shlex
@@ -18,9 +26,9 @@
 import traceback
 import ctypes
-import lex
-import yacc
-from lex import TOKEN
+from . import lex
+from . import yacc
+from .lex import TOKEN
 tokens = (
     'HEADER_NAME', 'IDENTIFIER', 'PP_NUMBER', 'CHARACTER_CONSTANT',
@@ -142,7 +150,10 @@
 def punctuator_regex(punctuators):
     punctuator_regexes = [v[0] for v in punctuators.values()]
-    punctuator_regexes.sort(lambda a, b: -cmp(len(a), len(b)))
+    if PY2:
+        punctuator_regexes.sort(lambda a, b: -cmp(len(a), len(b)))
+    else:
+        punctuator_regexes.sort(key=lambda a: -len(a))
     return '(%s)' % '|'.join(punctuator_regexes)
 # Process line-number directives from the preprocessor
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/preprocessor.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -19,10 +19,10 @@
 import traceback
 import ctypes
-import lex
-import pplexer
-import yacc
+from . import lex
+from . import pplexer
+from . import yacc
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/yacc.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -51,6 +51,7 @@
 # consider to be good Python "coding style."   Modify the code at your
 # own risk!
+from __future__ import print_function
 __version__ = "2.2"
@@ -69,12 +70,19 @@
 error_count = 3                # Number of symbols that must be shifted to leave recovery mode
-import cStringIO
+try:
+    import cStringIO as io
+    import io
+import imp
 import os.path
 import re
 import sys
 import types
+from .lex import get_func_code
 # <tm> 1 July 2008
 try:
     import hashlib
@@ -137,7 +145,7 @@
         self.stack = stack
     def __getitem__(self, n):
-        if isinstance(n, types.IntType):
+        if isinstance(n, int):
             if n >= 0:
                 return self.slice[n].value
             else:
@@ -169,10 +177,10 @@
     def pushback(self, n):
         if n <= 0:
-            raise ValueError, "Expected a positive value"
+            raise ValueError("Expected a positive value")
         if n > (len(self.slice) - 1):
-            raise ValueError, "Can't push %d tokens. Only %d are available." % (n, len(
-                self.slice) - 1)
+            raise ValueError("Can't push %d tokens. Only %d are available." % (n, len(
+                self.slice) - 1))
         for i in range(0, n):
             self.pbstack.append(self.slice[-i - 1])
@@ -235,7 +243,7 @@
         # If no lexer was given, we will try to use the lex module
         if not lexer:
-            import lex
+            from . import lex
             lexer = lex.lexer
         pslice.lexer = lexer
@@ -267,7 +275,7 @@
             # is already set, we just use that. Otherwise, we'll pull
             # the next token off of the lookaheadstack or from the lexer
             if debug > 1:
-                print 'state', statestack[-1]
+                print('state', statestack[-1])
             if not lookahead:
                 if not lookaheadstack:
                     lookahead = get_token()     # Get the next token
@@ -287,7 +295,7 @@
             t = actions.get((s, ltype), None)
             if debug > 1:
-                print 'action', t
+                print('action', t)
             if t is not None:
                 if t > 0:
                     # shift a symbol on the stack
@@ -452,7 +460,7 @@
                 continue
             # Call an error function here
-            raise RuntimeError, "yacc: internal parser error!!!\n"
+            raise RuntimeError("yacc: internal parser error!!!\n")
 #                          === Parser Construction ===
@@ -522,13 +530,13 @@
         if n[0:2] == 'p_':
             sys.stderr.write("yacc: Warning. '%s' not defined as a function\n" % n)
-        if 1 and isinstance(v, types.FunctionType) and v.func_code.co_argcount == 1:
+        if 1 and isinstance(v, types.FunctionType) and get_func_code(v).co_argcount == 1:
             try:
                 doc = v.__doc__.split(" ")
                 if doc[1] == ':':
                     sys.stderr.write(
                         "%s:%d: Warning. Possible grammar rule '%s' defined without p_ prefix.\n" %
-                        (v.func_code.co_filename, v.func_code.co_firstlineno, n))
+                        (get_func_code(v).co_filename, get_func_code(v).co_firstlineno, n))
             except Exception:
                 pass
@@ -584,8 +592,8 @@
     # File objects used when creating the parser.out debugging file
     global _vf, _vfc
-    _vf = cStringIO.StringIO()
-    _vfc = cStringIO.StringIO()
+    _vf = io.StringIO()
+    _vfc = io.StringIO()
 # class Production:
@@ -807,8 +815,8 @@
 def add_function(f):
-    line = f.func_code.co_firstlineno
-    file = f.func_code.co_filename
+    line = get_func_code(f).co_firstlineno
+    file = get_func_code(f).co_filename
     error = 0
     if isinstance(f, types.MethodType):
@@ -816,11 +824,11 @@
     else:
         reqdargs = 1
-    if f.func_code.co_argcount > reqdargs:
+    if get_func_code(f).co_argcount > reqdargs:
         sys.stderr.write("%s:%d: Rule '%s' has too many arguments.\n" % (file, line, f.__name__))
         return -1
-    if f.func_code.co_argcount < reqdargs:
+    if get_func_code(f).co_argcount < reqdargs:
         sys.stderr.write("%s:%d: Rule '%s' requires an argument.\n" % (file, line, f.__name__))
         return -1
@@ -879,7 +887,7 @@
     (Unused terminals have already had their warning.)
     Reachable = {}
-    for s in Terminals.keys() + Nonterminals.keys():
+    for s in list(Terminals.keys()) + list(Nonterminals.keys()):
         Reachable[s] = 0
     mark_reachable_from(Productions[0].prod[0], Reachable)
@@ -1912,7 +1920,7 @@
                                 actionp[st, a] = p
             except Exception as e:
-                raise YaccError, "Hosed in lr_parse_table", e
+                raise YaccError("Hosed in lr_parse_table").with_traceback(e)
         # Print the actions associated with each terminal
         if yaccdebug:
@@ -2077,16 +2085,16 @@
         f.close()
     except IOError as e:
-        print "Unable to create '%s'" % filename
-        print e
+        print("Unable to create '%s'" % filename)
+        print(e)
         return
 def lr_read_tables(module=tab_module, optimize=0):
     global _lr_action, _lr_goto, _lr_productions, _lr_method
     try:
-        exec "import %s as parsetab" % module
+        fmod = imp.find_module('parsetab', sys.path + ['ctypesgencore/parser/', ])
+        parsetab = imp.load_module('parsetab', *fmod)
         if (optimize) or (Signature.digest() == parsetab._lr_signature):
             _lr_action = parsetab._lr_action
             _lr_goto = parsetab._lr_goto
@@ -2104,10 +2112,7 @@
 # it's a little funky because I want to preserve backwards compatibility
 # with Python 2.0 where types.ObjectType is undefined.
-try:
-    _INSTANCETYPE = (types.InstanceType, types.ObjectType)
-except AttributeError:
-    _INSTANCETYPE = types.InstanceType
+_INSTANCETYPE = getattr(types, 'InstanceType', object)
 # yacc(module)
@@ -2145,7 +2150,7 @@
             for i in _items:
                 ldict[i[0]] = i[1]
         else:
-            raise ValueError, "Expected a module"
+            raise ValueError("Expected a module")
     else:
         # No module given.  We might be able to get information from the caller.
@@ -2191,36 +2196,36 @@
             tokens = ldict.get("tokens", None)
         if not tokens:
-            raise YaccError, "module does not define a list 'tokens'"
-        if not (isinstance(tokens, types.ListType) or isinstance(tokens, types.TupleType)):
-            raise YaccError, "tokens must be a list or tuple."
+            raise YaccError("module does not define a list 'tokens'")
+        if not (isinstance(tokens, list) or isinstance(tokens, tuple)):
+            raise YaccError("tokens must be a list or tuple.")
         # Check to see if a requires dictionary is defined.
         requires = ldict.get("require", None)
         if requires:
-            if not (isinstance(requires, types.DictType)):
-                raise YaccError, "require must be a dictionary."
+            if not (isinstance(requires, dict)):
+                raise YaccError("require must be a dictionary.")
             for r, v in requires.items():
                 try:
-                    if not (isinstance(v, types.ListType)):
+                    if not (isinstance(v, list)):
                         raise TypeError
                     v1 = [x.split(".") for x in v]
                     Requires[r] = v1
                 except Exception:
-                    print "Invalid specification for rule '%s' in require. Expected a list of strings" % r
+                    print("Invalid specification for rule '%s' in require. Expected a list of strings" % r)
         # Build the dictionary of terminals.  We a record a 0 in the
         # dictionary to track whether or not a terminal is actually
         # used in the grammar
         if 'error' in tokens:
-            print "yacc: Illegal token 'error'.  Is a reserved word."
-            raise YaccError, "Illegal token name"
+            print("yacc: Illegal token 'error'.  Is a reserved word.")
+            raise YaccError("Illegal token name")
         for n in tokens:
             if n in Terminals:
-                print "yacc: Warning. Token '%s' multiply defined." % n
+                print("yacc: Warning. Token '%s' multiply defined." % n)
             Terminals[n] = []
         Terminals['error'] = []
@@ -2228,8 +2233,8 @@
         # Get the precedence map (if any)
         prec = ldict.get("precedence", None)
         if prec:
-            if not (isinstance(prec, types.ListType) or isinstance(prec, types.TupleType)):
-                raise YaccError, "precedence must be a list or tuple."
+            if not (isinstance(prec, list) or isinstance(prec, tuple)):
+                raise YaccError("precedence must be a list or tuple.")
             add_precedence(prec)
             Signature.update(repr(prec))
@@ -2245,17 +2250,17 @@
             elif isinstance(ef, types.MethodType):
                 ismethod = 1
             else:
-                raise YaccError, "'p_error' defined, but is not a function or method."
-            eline = ef.func_code.co_firstlineno
-            efile = ef.func_code.co_filename
+                raise YaccError("'p_error' defined, but is not a function or method.")
+            eline = get_func_code(ef).co_firstlineno
+            efile = get_func_code(ef).co_filename
             files[efile] = None
-            if (ef.func_code.co_argcount != 1 + ismethod):
-                raise YaccError, "%s:%d: p_error() requires 1 argument." % (efile, eline)
+            if (get_func_code(ef).co_argcount != 1 + ismethod):
+                raise YaccError("%s:%d: p_error() requires 1 argument." % (efile, eline))
             global Errorfunc
             Errorfunc = ef
         else:
-            print "yacc: Warning. no p_error() function is defined."
+            print("yacc: Warning. no p_error() function is defined.")
         # Get the list of built-in functions with p_ prefix
         symbols = [
@@ -2268,17 +2273,17 @@
         # Check for non-empty symbols
         if len(symbols) == 0:
-            raise YaccError, "no rules of the form p_rulename are defined."
+            raise YaccError("no rules of the form p_rulename are defined.")
         # Sort the symbols by line number
-        symbols.sort(lambda x, y: cmp(x.func_code.co_firstlineno, y.func_code.co_firstlineno))
+        symbols.sort(lambda x, y: cmp(get_func_code(x).co_firstlineno, get_func_code(y).co_firstlineno))
         # Add all of the symbols to the grammar
         for f in symbols:
             if (add_function(f)) < 0:
                 error += 1
             else:
-                files[f.func_code.co_filename] = None
+                files[get_func_code(f).co_filename] = None
         # Make a signature of the docstrings
         for f in symbols:
@@ -2288,7 +2293,7 @@
         lr_init_vars()
         if error:
-            raise YaccError, "Unable to construct parser."
+            raise YaccError("Unable to construct parser.")
         if not lr_read_tables(tabmodule):
@@ -2301,7 +2306,7 @@
             validate_dict(ldict)
             if start and start not in Prodnames:
-                raise YaccError, "Bad starting symbol '%s'" % start
+                raise YaccError("Bad starting symbol '%s'" % start)
             augment_grammar(start)
             error = verify_productions(cycle_check=check_recursion)
@@ -2313,7 +2318,7 @@
                         :2] != 'p_')]
             if error:
             build_lritems()
             compute_first1()
@@ -2322,7 +2327,7 @@
             if method in ['SLR', 'LALR']:
                 lr_parse_table(method)
             else:
-                raise YaccError, "Unknown parsing method '%s'" % method
+                raise YaccError("Unknown parsing method '%s'" % method)
             if write_tables:
                 lr_write_tables(tabmodule, outputdir)
@@ -2335,7 +2340,7 @@
                     f.write(_vf.getvalue())
                     f.close()
-                    print "yacc: can't create '%s'" % debugfile, e
+                    print("yacc: can't create '%s'" % debugfile, e)
     # Made it here.   Create a parser object and set up its internal state.
     # Set global parse() method to bound method of parser object.
@@ -2366,7 +2371,7 @@
     def __init__(self, magic=None):
         if magic != "xyzzy":
-            raise YaccError, 'Use yacc()'
+            raise YaccError('Use yacc()')
     def init_parser(self, parser=None):
         if not parser:
@@ -2401,4 +2406,4 @@
 # Stub that raises an error if parsing is attempted without first calling yacc()
 def parse(*args, **kwargs):
-    raise YaccError, "yacc: No parser built with yacc()"
+    raise YaccError("yacc: No parser built with yacc()")
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/printer/__init__.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/printer/__init__.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/printer/__init__.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -5,6 +5,6 @@
 produce the final .py output files.
-from printer import WrapperPrinter
+from .printer import WrapperPrinter
 __all__ = ["WrapperPrinter"]
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/printer/preamble.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -1,3 +1,8 @@
+try:
+    long = int
 import os
 import sys
@@ -43,7 +48,7 @@
 class UserString:
     def __init__(self, seq):
-        if isinstance(seq, basestring):
+        if isinstance(seq, str):
             self.data = seq
         elif isinstance(seq, UserString):
             self.data = seq.data[:]
@@ -85,13 +90,13 @@
     def __add__(self, other):
         if isinstance(other, UserString):
             return self.__class__(self.data + other.data)
-        elif isinstance(other, basestring):
+        elif isinstance(other, str):
             return self.__class__(self.data + other)
         else:
             return self.__class__(self.data + str(other))
     def __radd__(self, other):
-        if isinstance(other, basestring):
+        if isinstance(other, str):
             return self.__class__(other + self.data)
         else:
             return self.__class__(str(other) + self.data)
@@ -255,7 +260,7 @@
         end = max(end, 0)
         if isinstance(sub, UserString):
             self.data = self.data[:start] + sub.data + self.data[end:]
-        elif isinstance(sub, basestring):
+        elif isinstance(sub, str):
             self.data = self.data[:start] + sub + self.data[end:]
         else:
             self.data = self.data[:start] + str(sub) + self.data[end:]
@@ -271,7 +276,7 @@
     def __iadd__(self, other):
             self.data += other.data
             self.data += other
         else:
             self.data += str(other)
@@ -288,7 +293,7 @@
                 ('data', c_char_p)]
     def __init__(self, obj=""):
-        if isinstance(obj, (str, unicode, UserString)):
+        if isinstance(obj, (str, UserString)):
             self.data = str(obj)
         else:
             self.raw = obj
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/printer/printer.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -1,8 +1,10 @@
 #!/usr/bin/env python
 import os
 import sys
-import test  # So we can find the path to local files in the printer package
+from . import test  # So we can find the path to local files in the printer package
 import time
 import ctypesgencore.libraryloader  # So we can get the path to it
@@ -29,13 +31,13 @@
             self.options.strip_build_path += os.path.sep
         self.print_header()
-        print >>self.file
+        print(file=self.file)
         self.print_preamble()
-        print >>self.file
         self.print_loader()
-        print >>self.file
         self.print_group(self.options.libraries, "libraries", self.print_library)
         self.print_group(self.options.modules, "modules", self.print_module)
@@ -54,36 +56,36 @@
         for kind, desc in data.output_order:
             if desc.included:
                 method_table[kind](desc)
-                print >>self.file
         self.print_group(self.options.inserted_files, "inserted files",
                          self.insert_file)
     def print_group(self, list, name, function):
         if list:
-            print >>self.file, "# Begin %s" % name
-            print >>self.file
+            print("# Begin %s" % name, file=self.file)
             for obj in list:
                 function(obj)
-            print >>self.file
-            print >>self.file, "# %d %s" % (len(list), name)
-            print >>self.file, "# End %s" % name
+            print("# %d %s" % (len(list), name), file=self.file)
+            print("# End %s" % name, file=self.file)
         else:
-            print >>self.file, "# No %s" % name
-        print >>self.file
+            print("# No %s" % name, file=self.file)
     def srcinfo(self, src):
         if src is None:
-            print >>self.file
         else:
             filename, lineno = src
             if filename in ("<built-in>", "<command line>"):
-                print >>self.file, "# %s" % filename
+                print("# %s" % filename, file=self.file)
             else:
                 if self.options.strip_build_path and \
                         filename.startswith(self.options.strip_build_path):
                     filename = filename[len(self.options.strip_build_path):]
-                print >>self.file, "# %s: %s" % (filename, lineno)
+                print("# %s: %s" % (filename, lineno), file=self.file)
     def template_subs(self):
         template_subs = {
@@ -92,7 +94,7 @@
             'name': os.path.basename(self.options.headers[0])
-        for opt, value in self.options.__dict__.iteritems():
+        for opt, value in self.options.__dict__.items():
             if isinstance(value, str):
                 template_subs[opt] = value
             elif isinstance(value, (list, tuple)):
@@ -125,72 +127,72 @@
     def print_preamble(self):
         path = path_to_local_file("preamble.py")
-        print >>self.file, "# Begin preamble"
-        print >>self.file
+        print("# Begin preamble", file=self.file)
         preamble_file = file(path, "r")
         self.file.write(preamble_file.read())
         preamble_file.close()
-        print >>self.file
-        print >>self.file, "# End preamble"
+        print("# End preamble", file=self.file)
     def print_loader(self):
-        print >>self.file, "_libs = {}"
-        print >>self.file, "_libdirs = %s" % self.options.compile_libdirs
-        print >>self.file
-        print >>self.file, "# Begin loader"
-        print >>self.file
+        print("_libs = {}", file=self.file)
+        print("_libdirs = %s" % self.options.compile_libdirs, file=self.file)
+        print("# Begin loader", file=self.file)
         path = path_to_local_file("libraryloader.py",
                                   ctypesgencore.libraryloader)
         loader_file = file(path, "r")
         self.file.write(loader_file.read())
         loader_file.close()
-        print >>self.file
-        print >>self.file, "# End loader"
-        print >>self.file
-        print >>self.file, "add_library_search_dirs([%s])" % \
-            ", ".join([repr(d) for d in self.options.runtime_libdirs])
+        print("# End loader", file=self.file)
+        print("add_library_search_dirs([%s])" % \
+            ", ".join([repr(d) for d in self.options.runtime_libdirs]), file=self.file)
     def print_library(self, library):
-        print >>self.file, '_libs["%s"] = load_library("%s")' % (library, library)
+        print('_libs["%s"] = load_library("%s")' % (library, library), file=self.file)
     def print_module(self, module):
-        print >>self.file, 'from %s import *' % name
+        print('from %s import *' % name, file=self.file)
     def print_constant(self, constant):
-        print >>self.file, '%s = %s' % \
-            (constant.name, constant.value.py_string(False)),
+        print('%s = %s' % \
+            (constant.name, constant.value.py_string(False)), end=' ', file=self.file)
         self.srcinfo(constant.src)
     def print_typedef(self, typedef):
-            (typedef.name, typedef.ctype.py_string()),
+            (typedef.name, typedef.ctype.py_string()), end=' ', file=self.file)
         self.srcinfo(typedef.src)
     def print_struct(self, struct):
         self.srcinfo(struct.src)
         base = {'union': 'Union', 'struct': 'Structure'}[struct.variety]
-        print >>self.file, 'class %s_%s(%s):' % \
-            (struct.variety, struct.tag, base)
-        print >>self.file, '    pass'
+        print('class %s_%s(%s):' % \
+            (struct.variety, struct.tag, base), file=self.file)
+        print('    pass', file=self.file)
     def print_struct_members(self, struct):
         if struct.opaque:
             return
-        print >>self.file, '%s_%s.__slots__ = [' % (struct.variety, struct.tag)
+        print('%s_%s.__slots__ = [' % (struct.variety, struct.tag), file=self.file)
         for name, ctype in struct.members:
-            print >>self.file, "    '%s'," % name
-        print >>self.file, ']'
-        print >>self.file, '%s_%s._fields_ = [' % (struct.variety, struct.tag)
+            print("    '%s'," % name, file=self.file)
+        print(']', file=self.file)
+        print('%s_%s._fields_ = [' % (struct.variety, struct.tag), file=self.file)
             if isinstance(ctype, CtypesBitfield):
-                print >>self.file, "    ('%s', %s, %s)," % \
-                    (name, ctype.py_string(), ctype.bitfield.py_string(False))
+                print("    ('%s', %s, %s)," % \
+                    (name, ctype.py_string(), ctype.bitfield.py_string(False)), file=self.file)
             else:
-                print >>self.file, "    ('%s', %s)," % (name, ctype.py_string())
+                print("    ('%s', %s)," % (name, ctype.py_string()), file=self.file)
     def print_enum(self, enum):
-        print >>self.file, 'enum_%s = c_int' % enum.tag,
+        print('enum_%s = c_int' % enum.tag, end=' ', file=self.file)
         self.srcinfo(enum.src)
         # Values of enumerator are output as constants.
@@ -203,69 +205,69 @@
     def print_fixed_function(self, function):
         self.srcinfo(function.src)
         if function.source_library:
-            print >>self.file, "if hasattr(_libs[%r], %r):" % \
-                (function.source_library, function.c_name())
-            print >>self.file, "    %s = _libs[%r].%s" % \
-                (function.py_name(), function.source_library, function.c_name())
-            print >>self.file, "    %s.restype = %s" % \
-                (function.py_name(), function.restype.py_string())
-            print >>self.file, "    %s.argtypes = [%s]" % (
+            print("if hasattr(_libs[%r], %r):" % \
+                (function.source_library, function.c_name()), file=self.file)
+            print("    %s = _libs[%r].%s" % \
+                (function.py_name(), function.source_library, function.c_name()), file=self.file)
+            print("    %s.restype = %s" % \
+                (function.py_name(), function.restype.py_string()), file=self.file)
+            print("    %s.argtypes = [%s]" % (
                 function.py_name(),
-                ', '.join([a.py_string() for a in function.argtypes]))
+                ', '.join([a.py_string() for a in function.argtypes])), file=self.file)
         else:
-            print >>self.file, "for _lib in _libs.values():"
-            print >>self.file, "    if hasattr(_lib, %r):" % function.c_name()
-            print >>self.file, "        %s = _lib.%s" % (function.py_name(), function.c_name())
-            print >>self.file, "        %s.restype = %s" % (
-                function.py_name(), function.restype.py_string())
-                function.py_name(), ', '.join([a.py_string() for a in function.argtypes]))
-            print >>self.file, "        break"
+            print("for _lib in _libs.values():", file=self.file)
+            print("    if hasattr(_lib, %r):" % function.c_name(), file=self.file)
+            print("        %s = _lib.%s" % (function.py_name(), function.c_name()), file=self.file)
+            print("        %s.restype = %s" % (
+                function.py_name(), function.restype.py_string()), file=self.file)
+                function.py_name(), ', '.join([a.py_string() for a in function.argtypes])), file=self.file)
+            print("        break", file=self.file)
     def print_variadic_function(self, function):
-            print >>self.file, "    _func = _libs[%r].%s" % \
-            print >>self.file, "    _restype = %s" % function.restype.py_string()
-            print >>self.file, "    _argtypes = [%s]" % \
-            print >>self.file, "    %s = _variadic_function(_func,_restype,_argtypes)" % \
+            print("    _func = _libs[%r].%s" % \
+            print("    _restype = %s" % function.restype.py_string(), file=self.file)
+            print("    _argtypes = [%s]" % \
+                ', '.join([a.py_string() for a in function.argtypes]), file=self.file)
+            print("    %s = _variadic_function(_func,_restype,_argtypes)" % \
+                function.py_name(), file=self.file)
         else:
-            print >>self.file, "        _func = _lib.%s" % \
-                (function.c_name())
+            print("        _func = _lib.%s" % \
+                (function.c_name()), file=self.file)
     def print_variable(self, variable):
         self.srcinfo(variable.src)
         if variable.source_library:
-            print >>self.file, 'try:'
-            print >>self.file, '    %s = (%s).in_dll(_libs[%r], %r)' % \
+            print('try:', file=self.file)
+            print('    %s = (%s).in_dll(_libs[%r], %r)' % \
                 (variable.py_name(),
                  variable.ctype.py_string(),
                  variable.source_library,
-                 variable.c_name())
-            print >>self.file, 'except:'
+                 variable.c_name()), file=self.file)
+            print('except:', file=self.file)
         else:
-            print >>self.file, '    try:'
-            print >>self.file, '        %s = (%s).in_dll(_lib, %r)' % \
+            print('    try:', file=self.file)
+            print('        %s = (%s).in_dll(_lib, %r)' % \
-            print >>self.file, '    except:'
+            print('    except:', file=self.file)
     def print_macro(self, macro):
         if macro.params:
@@ -278,16 +280,16 @@
         # We want to contain the failures as much as possible.
         # Hence the try statement.
         self.srcinfo(macro.src)
-        print >>self.file, "try:"
-        print >>self.file, "    %s = %s" % (macro.name, macro.expr.py_string(True))
-        print >>self.file, "except:"
-        print >>self.file, "    pass"
+        print("try:", file=self.file)
+        print("    %s = %s" % (macro.name, macro.expr.py_string(True)), file=self.file)
+        print("except:", file=self.file)
+        print("    pass", file=self.file)
     def print_func_macro(self, macro):
-        print >>self.file, "def %s(%s):" % \
-            (macro.name, ", ".join(macro.params))
-        print >>self.file, "    return %s" % macro.expr.py_string(True)
+        print("def %s(%s):" % \
+            (macro.name, ", ".join(macro.params)), file=self.file)
+        print("    return %s" % macro.expr.py_string(True), file=self.file)
     def insert_file(self, filename):
         try:
@@ -296,10 +298,10 @@
             error_message("Cannot open file \"%s\". Skipped it." % filename,
                           cls='missing-file')
-        print >>self.file, "# Begin \"%s\"" % filename
-        print >>self.file
+        print("# Begin \"%s\"" % filename, file=self.file)
         self.file.write(inserted_file.read())
-        print >>self.file
-        print >>self.file, "# End \"%s\"" % filename
+        print("# End \"%s\"" % filename, file=self.file)
         inserted_file.close()
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/processor/__init__.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/processor/__init__.py	2016-05-02 16:06:52 UTC (rev 68350)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/processor/__init__.py	2016-05-02 16:07:13 UTC (rev 68351)
@@ -9,4 +9,4 @@
 __all__ = ["process"]
-from pipeline import process
+from .pipeline import process
