[GRASS-SVN] r68353 - in grass/trunk/lib/python/pygrass: rpc vector vector/testsuite
svn_grass at osgeo.org
Mon May 2 09:07:29 PDT 2016
Author: zarch
Date: 2016-05-02 09:07:29 -0700 (Mon, 02 May 2016)
New Revision: 68353
grass/trunk/lib/python/pygrass/rpc/__init__.py
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/table.py
grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py
pygrass: fix python2 and python3 syntax
Modified: grass/trunk/lib/python/pygrass/rpc/__init__.py
--- grass/trunk/lib/python/pygrass/rpc/__init__.py 2016-05-02 16:07:20 UTC (rev 68352)
+++ grass/trunk/lib/python/pygrass/rpc/__init__.py 2016-05-02 16:07:29 UTC (rev 68353)
@@ -21,7 +21,7 @@
from grass.pygrass.vector import *
from grass.pygrass.raster import *
import grass.lib.gis as libgis
-from base import RPCServerBase
+from .base import RPCServerBase
from grass.pygrass.gis.region import Region
import grass.pygrass.utils as utils
import logging
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2016-05-02 16:07:20 UTC (rev 68352)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2016-05-02 16:07:29 UTC (rev 68353)
@@ -1,4 +1,6 @@
# -*- coding: utf-8 -*-
+from __future__ import print_function
from os.path import join, exists
libgis.G_gisinit('')
@@ -188,7 +190,7 @@
cur = self.table.conn.cursor()
cur.execute(self.table.columns.insert_str, attr)
cur.close()
if cat is not None:
cats = Cats(geo_obj.c_cats)
cats.reset()
@@ -246,7 +248,7 @@
>>> with VectorTopo(test_vector_name, mode='r') as test_vect:
... for feature in test_vect[:7]:
- ... print feature.attrs['name']
+ ... print(feature.attrs['name'])
point
point
@@ -396,7 +398,7 @@
>>> from operator import methodcaller as method
>>> areas.sort(key=method('area'), reverse=True) # sort the list
>>> for area in areas[:3]:
- ... print area, area.area()
+ ... print(area, area.area())
Area(1) 12.0
Area(2) 8.0
Area(4) 8.0
@@ -533,8 +535,8 @@
attr.extend(attrs)
self.table.update(key=line, values=attr)
elif self.table is None and attrs:
- print "Table for vector {name} does not exist, attributes not" \
- " loaded".format(name=self.name)
+ print("Table for vector {name} does not exist, attributes not"
+ " loaded".format(name=self.name))
libvect.Vect_cat_set(geo_obj.c_cats, self.layer, line)
result = libvect.Vect_rewrite_line(self.c_mapinfo,
line, geo_obj.gtype,
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2016-05-02 16:07:20 UTC (rev 68352)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2016-05-02 16:07:29 UTC (rev 68353)
@@ -194,7 +194,7 @@
return item in self.names()
def __repr__(self):
- return "Columns(%r)" % self.items()
+ return "Columns(%r)" % list(self.items())
def __getitem__(self, key):
return self.odict[key]
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py 2016-05-02 16:07:20 UTC (rev 68352)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py 2016-05-02 16:07:29 UTC (rev 68353)
@@ -4,6 +4,12 @@
@author: pietro
+try:
+ from builtins import long
+except ImportError:
+ # python3
+ long = int
import os
import sqlite3
import tempfile as tmp
