[GRASS-SVN] r68383 - in grass-addons/grass7/vector: v.sort.points v.stream.order v.stream.order/testsuite
svn_grass at osgeo.org
Fri May 6 08:04:06 PDT 2016
Author: neteler
Date: 2016-05-06 08:04:06 -0700 (Fri, 06 May 2016)
New Revision: 68383
grass-addons/grass7/vector/v.sort.points/Makefile
grass-addons/grass7/vector/v.sort.points/v.sort.points.html
grass-addons/grass7/vector/v.sort.points/v.sort.points.py
grass-addons/grass7/vector/v.stream.order/Makefile
grass-addons/grass7/vector/v.stream.order/stream_network.png
grass-addons/grass7/vector/v.stream.order/stream_network_order_drwal.png
grass-addons/grass7/vector/v.stream.order/stream_network_order_scheidegger.png
grass-addons/grass7/vector/v.stream.order/stream_network_order_shreve.png
grass-addons/grass7/vector/v.stream.order/stream_network_order_strahler.png
grass-addons/grass7/vector/v.stream.order/testsuite/generate_manpage_images.sh
grass-addons/grass7/vector/v.stream.order/testsuite/generate_stream_outflow_points.sh
grass-addons/grass7/vector/v.stream.order/testsuite/test_stream_order.py
grass-addons/grass7/vector/v.stream.order/v.stream.order.html
grass-addons/grass7/vector/v.stream.order/v.stream.order.py
addons: svn propset
Property changes on: grass-addons/grass7/vector/v.sort.points/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Modified: grass-addons/grass7/vector/v.sort.points/v.sort.points.html
--- grass-addons/grass7/vector/v.sort.points/v.sort.points.html 2016-05-06 14:49:38 UTC (rev 68382)
+++ grass-addons/grass7/vector/v.sort.points/v.sort.points.html 2016-05-06 15:04:06 UTC (rev 68383)
@@ -21,4 +21,4 @@
<h2>AUTHOR</h2>
Moritz Lennert
-<p><i>Last changed: $Date: 2016-05-04 19:42:00 +0100 (mer 04 avr 2016) $</i>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.sort.points/v.sort.points.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass-addons/grass7/vector/v.sort.points/v.sort.points.py
+ text/x-python
+ native
Property changes on: grass-addons/grass7/vector/v.stream.order/Makefile
+ text/x-makefile
+ native
Property changes on: grass-addons/grass7/vector/v.stream.order/stream_network.png
Modified: svn:mime-type
- application/octet-stream
+ image/png
Property changes on: grass-addons/grass7/vector/v.stream.order/stream_network_order_drwal.png
+ image/png
Property changes on: grass-addons/grass7/vector/v.stream.order/stream_network_order_scheidegger.png
+ image/png
Property changes on: grass-addons/grass7/vector/v.stream.order/stream_network_order_shreve.png
+ image/png
Property changes on: grass-addons/grass7/vector/v.stream.order/stream_network_order_strahler.png
+ image/png
Property changes on: grass-addons/grass7/vector/v.stream.order/testsuite/generate_manpage_images.sh
Added: svn:executable
+ text/x-sh
+ native
Property changes on: grass-addons/grass7/vector/v.stream.order/testsuite/generate_stream_outflow_points.sh
+ text/x-sh
+ native
Property changes on: grass-addons/grass7/vector/v.stream.order/testsuite/test_stream_order.py
+ text/x-python
+ native
Modified: grass-addons/grass7/vector/v.stream.order/v.stream.order.html
--- grass-addons/grass7/vector/v.stream.order/v.stream.order.html 2016-05-06 14:49:38 UTC (rev 68382)
+++ grass-addons/grass7/vector/v.stream.order/v.stream.order.html 2016-05-06 15:04:06 UTC (rev 68383)
@@ -194,5 +194,5 @@
<p>Documentation of the implemented algorithms are in most parts copied from
r.stream.order implemented by: Jarek Jasiewicz and Markus Metz</p>
-<p><i>Last changed: $Date: 2013-03-27 10:11:17 +0100 (Mi, 27. Mär 2013) $</i>
Property changes on: grass-addons/grass7/vector/v.stream.order/v.stream.order.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass-addons/grass7/vector/v.stream.order/v.stream.order.py
+ text/x-python
+ native
