[GRASS-SVN] r68392 - grass-addons/grass7/raster/r.to.vect.lines
svn_grass at osgeo.org
Sat May 7 04:38:08 PDT 2016
Author: annakrat
Date: 2016-05-07 04:38:08 -0700 (Sat, 07 May 2016)
New Revision: 68392
grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py
r.to.vect.lines: port to GRASS 7 and pep8
Modified: grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py
--- grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py 2016-05-07 01:55:18 UTC (rev 68391)
+++ grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py 2016-05-07 11:38:08 UTC (rev 68392)
@@ -60,10 +60,11 @@
from grass.script import core as grass
from grass.lib.gis import *
from grass.lib.vector import *
+from grass.lib.raster import *
from ctypes import *
# check if GRASS is running or not
-if not os.environ.has_key("GISBASE"):
+if "GISBASE" not in os.environ:
sys.exit("You must be in GRASS GIS to run this program")
@@ -76,7 +77,7 @@
go_vert = flags['v']
if go_vert:
- sys.exit("Vertical lines are yet to do.")
+ sys.exit("Vertical lines are yet to do.")
##### Query the region
region = Cell_head()
@@ -88,12 +89,12 @@
if '@' in inmap:
inmap, mapset = inmap.split('@')
- gfile = grass.find_file(name = inmap, element = 'cell', mapset = mapset)
+ gfile = grass.find_file(name=inmap, element='cell', mapset=mapset)
if not gfile['name']:
grass.fatal(_("Raster map <%s> not found") % inmap)
# determine the inputmap type (CELL/FCELL/DCELL)
- data_type = Rast_get_map_type(inmap, mapset)
+ data_type = Rast_map_type(inmap, mapset)
if data_type == CELL_TYPE:
ptype = POINTER(c_int)
@@ -107,15 +108,14 @@
#print "Raster map <%s> contains data type %s." % (inmap, type_name)
- in_fd = G_open_cell_old(inmap, mapset)
- in_rast = G_allocate_raster_buf(data_type)
+ in_fd = Rast_open_old(inmap, mapset)
+ in_rast = Rast_allocate_buf(data_type)
in_rast = cast(c_void_p(in_rast), ptype)
- rows = G_window_rows()
- cols = G_window_cols()
+ rows = Rast_window_rows()
+ cols = Rast_window_cols()
#print "Current region is %d rows x %d columns" % (rows, cols)
#### Vector map setup
# define map structure
map_info = pointer(Map_info())
@@ -125,9 +125,9 @@
# open new 3D vector map
Vect_open_new(map_info, outmap, True)
+ print 'ddd'
+ Vect_hist_command(map_info)
- Vect_hist_command(outmap)
# Create and initialize structs to store points/lines and category numbers
Points = Vect_new_line_struct()
Cats = Vect_new_cats_struct()
@@ -138,37 +138,36 @@
yL = LineArrayType()
zL = LineArrayType()
#### iterate through map rows
for row in xrange(rows):
if row % skip != 0:
continue
# read a row of raster data into memory, then print it
- G_get_raster_row(in_fd, in_rast, row, data_type)
+ Rast_get_row(in_fd, in_rast, row, data_type)
#print row, in_rast[0:cols]
- #print row, in_rast[0:5]
+ #print row, in_rast[0:5]
# y-value
- coor_row_static = G_row_to_northing((row + 0.5), byref(region))
+ coor_row_static = Rast_row_to_northing((row + 0.5), byref(region))
# x-end nodes
#coor_col_min = G_col_to_easting((0 + 0.5), byref(region))
- #coor_col_max = G_col_to_easting((cols - 0.5), byref(region))
+ #coor_col_max = G_col_to_easting((cols - 0.5), byref(region))
#print ' ',coor_row_static,coor_col_min,coor_col_max
# reset
- n = 0
+ n = 0
for col in xrange(cols):
- xL[col] = yL[col] = zL[col] = 0
+ xL[col] = yL[col] = zL[col] = 0
# TODO check for NULL
# if not G_is_null_value(byref(in_rast[col]), data_type):
if in_rast[col] > -2e9:
- xL[n] = G_col_to_easting((col + 0.5), byref(region))
+ xL[n] = Rast_col_to_easting((col + 0.5), byref(region))
yL[n] = coor_row_static
zL[n] = in_rast[col]
- n = n + 1
+ n = n + 1
#print valid_cols,n
Vect_cat_del(Cats, 1)
@@ -178,11 +177,10 @@
Vect_copy_xyz_to_pnts(Points, xL, yL, zL, n)
Vect_write_line(map_info, fea_type, Points, Cats)
# Build topology for vector map and close them all
Vect_build(map_info)
Vect_close(map_info)
- G_close_cell(in_fd)
+ Rast_close(in_fd)
G_done_msg('')
