[GRASS-SVN] r68397 - grass-addons/grass7/imagery/i.landsat8.swlst
svn_grass at osgeo.org
Sat May 7 14:32:41 PDT 2016
Author: nikosa
Date: 2016-05-07 14:32:41 -0700 (Sat, 07 May 2016)
New Revision: 68397
grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html
grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py
Merged https://github.com/NikosAlexandris/i.landsat8.swlst/pull/1
Modified: grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html
--- grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html 2016-05-07 18:52:46 UTC (rev 68396)
+++ grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.html 2016-05-07 21:32:41 UTC (rev 68397)
@@ -1,5 +1,5 @@
<h2 id="description">DESCRIPTION</h2>
-<p><em>i.landsat8.swlst</em> is an implementation of a robust and practical Split-Window (SW) algorithm estimating land surface temperature (LST), from the Thermal Infra-Red Sensor (TIRS) aboard Landsat 8 with an accuracy of better than 1.0 K. [1]</p>
+<p><em>i.landsat8.swlst</em> is an implementation of a robust and practical Slit-Window (SW) algorithm estimating land surface temperature (LST), from the Thermal Infra-Red Sensor (TIRS) aboard Landsat 8 with an accuracy of better than 1.0 K. [1]</p>
<h3 id="overview">Overview</h3>
<p>The components of the algorithm estimating LST values are at-satellite brightness temperature (BT); land surface emissivity (LSE); and the coefficients of the main Split-Window equation (SWC).</p>
<p>LSEs are derived from an established look-up table linking the FROM-GLC classification scheme to average emissivities. The NDVI and the FVC are <em>not</em> computed each time an LST estimation is requested. Read [0] for details.</p>
@@ -252,7 +252,7 @@
</ul>
<h2 id="references">REFERENCES</h2>
<ul>
-<li><p>[0] Du, Chen; Ren, Huazhong; Qin, Qiming; Meng, Jinjie; Zhao, Shaohua. 2015. "A Practical Split-Window Algorithm for Estimating Land Surface Temperature from Landsat 8 Data." Remote Sens. 7, no. 1: 647-665. http://www.mdpi.com/2072-4292/7/1/647/htm#sthash.ba1pt9hj.dpuf</p></li>
+<li><p>[0] Du, Chen; Ren, Huazhong; Qin, Qiming; Meng, Jinjie; Zhao, Shaohua. 2015. "A Practical Split-Window Algorithm for Estimating Land Surface Temperature from Landsat 8 Data." Remote Sens. 7, no. 1: 647-665. http://www.mdpi.com/2072-4292/7/1/647/htm</p></li>
<li><p>[1] Huazhong Ren, Chen Du, Qiming Qin, Rongyuan Liu, Jinjie Meng, and Jing Li. "Atmospheric Water Vapor Retrieval from Landsat 8 and Its Validation." 3045--3048. IEEE, 2014.</p></li>
<li><p>[2] Ren, H., Du, C., Liu, R., Qin, Q., Yan, G., Li, Z. L., & Meng, J. (2015). Atmospheric water vapor retrieval from Landsat 8 thermal infrared images. Journal of Geophysical Research: Atmospheres, 120(5), 1723-1738.</p></li>
</ul>
Modified: grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py
--- grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py 2016-05-07 18:52:46 UTC (rev 68396)
+++ grass-addons/grass7/imagery/i.landsat8.swlst/i.landsat8.swlst.py 2016-05-07 21:32:41 UTC (rev 68397)
@@ -350,6 +350,9 @@
grass.run_command('g.remove', flags='f', type="rast",
pattern='tmp.{pid}*'.format(pid=os.getpid()), quiet=True)
+ if grass.find_file(name='MASK', element='cell')['file']:
+ r.mask(flags='r', verbose=True)
def tmp_map_name(name):
@@ -552,8 +555,9 @@
# save Brightness Temperature map?
if brightness_temperature_prefix:
bt_output = brightness_temperature_prefix + band_number
- run('g.copy', raster=(tmp_brightness_temperature, bt_output))
- del(bt_output)
+ run('g.rename', raster=(tmp_brightness_temperature, bt_output))
+ tmp_brightness_temperature = bt_output
+ del(bt_output)
return tmp_brightness_temperature
@@ -575,21 +579,21 @@
'in the Quality Assessment band.'.format(qap=qa_pixel))
g.message(msg)
- tmp_cloudmask = tmp_map_name('cloudmask')
- qabits_expression = 'if({band} == {pixel}, 1, null())'.format(band=qa_band,
- pixel=qa_pixel)
+ #tmp_cloudmask = tmp_map_name('cloudmask')
+ #qabits_expression = 'if({band} == {pixel}, 1, null())'.format(band=qa_band,
+ # pixel=qa_pixel)
- cloud_masking_equation = equation.format(result=tmp_cloudmask,
- expression=qabits_expression)
- grass.mapcalc(cloud_masking_equation)
+ #cloud_masking_equation = equation.format(result=tmp_cloudmask,
+ # expression=qabits_expression)
+ #grass.mapcalc(cloud_masking_equation)
- r.mask(raster=tmp_cloudmask, flags='i', overwrite=True)
+ r.mask(raster=qa_band, maskcats=qa_pixel, flags='i', overwrite=True)
# save for debuging
#save_map(tmp_cloudmask)
- del(qabits_expression)
- del(cloud_masking_equation)
+ #del(qabits_expression)
+ #del(cloud_masking_equation)
def replace_dummies(string, *args, **kwargs):
@@ -714,7 +718,7 @@
# save land surface emissivity map?
if emissivity_output:
- run('g.copy', raster=(outname, emissivity_output))
+ run('g.rename', raster=(outname, emissivity_output))
def determine_delta_emissivity(outname, landcover_map, delta_lse_expression):
@@ -746,7 +750,7 @@
# save delta land surface emissivity map?
if delta_emissivity_output:
- run('g.copy', raster=(outname, delta_emissivity_output))
+ run('g.rename', raster=(outname, delta_emissivity_output))
def get_cwv_window_means(outname, t1x, t1x_mean_expression):
@@ -835,7 +839,7 @@
# save Column Water Vapor map?
if cwv_output:
- run('g.copy', raster=(outname, cwv_output))
+ run('g.rename', raster=(outname, cwv_output))
# save for debuging
#save_map(outname)
@@ -884,7 +888,7 @@
source1=source1_cwv, source2=source2_cwv,
history=history_cwv)
del(cwv_expression)
del(cwv_equation)
@@ -933,9 +937,14 @@
out_ti=t10,
in_tj=DUMMY_MAPCALC_STRING_T11,
out_tj=t11)
- split_window_equation = equation.format(result=outname,
+ # Convert to Celsius?
+ if celsius:
+ split_window_expression = '({swe}) - 273.15'.format(swe=split_window_expression)
+ split_window_equation = equation.format(result=outname,
expression=split_window_expression)
+ else:
+ expression=split_window_expression)
grass.mapcalc(split_window_equation, overwrite=True)
@@ -945,26 +954,6 @@
del(split_window_expression)
del(split_window_equation)
-def kelvin_to_celsius(outname, lst_map):
- Convert Kelvin to Celsius
- msg = '\n|i Converting LST output from Kelvin to Celsius degrees'
- #g.message(msg)
- kelvin_to_celsius_expression = '{lst} - 273.15'.format(lst=lst_map)
- kelvin_to_celsius_equation = equation.format(result=lst_map,
- expression=kelvin_to_celsius_expression)
- grass.mapcalc(kelvin_to_celsius_equation, overwrite=True)
- msg += '\n|i Applying the "Celsius" color table'
- g.message(msg)
- run('r.colors', map=lst_map, color='celsius')
- del(kelvin_to_celsius_expression)
- del(kelvin_to_celsius_equation)
def main():
Main program
@@ -982,7 +971,7 @@
tmp_avg_lse = tmp_map_name('avg_lse')
tmp_delta_lse = tmp_map_name('delta_lse')
tmp_cwv = tmp_map_name('cwv')
- tmp_lst = tmp_map_name('lst')
+ #tmp_lst = tmp_map_name('lst')
# basic equation for mapcalc
global equation, citation_lst
@@ -1023,7 +1012,10 @@
# save Brightness Temperature maps?
global brightness_temperature_prefix
- brightness_temperature_prefix = options['prefix_bt']
+ if options['prefix_bt']:
+ brightness_temperature_prefix = options['prefix_bt']
+ else:
+ brightness_temperature_prefix = None
global cwv_output
cwv_window_size = int(options['window'])
@@ -1050,9 +1042,11 @@
global info, null
info = flags['i']
keep_region = flags['k']
- celsius = flags['c']
timestamping = flags['t']
null = flags['n']
+ global celsius
+ celsius = flags['c']
# ToDo:
# shell = flags['g']
@@ -1070,11 +1064,11 @@
# Improve below!
if b10:
- run('g.region', rast=b10)
+ run('g.region', rast=b10, align=b10)
msg = msg.format(name=b10)
elif t10:
- run('g.region', rast=t10)
+ run('g.region', rast=t10, align=t10)
msg = msg.format(name=t10)
g.message(msg)
@@ -1155,12 +1149,17 @@
if not average_emissivity_map:
determine_average_emissivity(tmp_avg_lse, landcover_map,
split_window_lst.average_lse_mapcalc)
+ if options['emissivity_out']:
+ tmp_avg_lse = options['emissivity_out']
if delta_emissivity_map:
tmp_delta_lse = delta_emissivity_map
if not delta_emissivity_map:
determine_delta_emissivity(tmp_delta_lse, landcover_map,
split_window_lst.delta_lse_mapcalc)
+ if options['delta_emissivity_out']:
+ tmp_delta_lse = options['delta_emissivity_out']
# 4. Modified Split-Window Variance-Covariance Matrix > Column Water Vapor
@@ -1175,6 +1174,8 @@
cwv = Column_Water_Vapor(cwv_window_size, t10, t11)
citation_cwv = cwv.citation
estimate_cwv_big_expression(tmp_cwv, t10, t11, cwv._big_cwv_expression())
+ if cwv_output:
+ tmp_cwv = cwv_output
# 5. Estimate Land Surface Temperature
@@ -1184,7 +1185,7 @@
msg = '\n|* Will pick a random emissivity class!'
grass.verbose(msg)
- estimate_lst(tmp_lst, t10, t11,
+ estimate_lst(lst_output, t10, t11,
tmp_avg_lse, tmp_delta_lse, tmp_cwv,
split_window_lst.sw_lst_mapcalc)
@@ -1197,18 +1198,17 @@
# time-stamping
if timestamping:
- add_timestamp(mtl_file, tmp_lst)
+ add_timestamp(mtl_file, lst_output)
if cwv_output:
add_timestamp(mtl_file, cwv_output)
- # convert to celsius and apply color table?
+ # Apply color table
if celsius:
- kelvin_to_celsius(tmp_lst, tmp_lst)
+ run('r.colors', map=lst_output, color='celsius')
else:
# color table for kelvin
- run('r.colors', map=tmp_lst, color='kelvin')
+ run('r.colors', map=lst_output, color='kelvin')
# ToDo: helper function for r.support
# strings for metadata
@@ -1231,13 +1231,13 @@
source2_lst = landsat8_metadata.origin
# history entry
- run("r.support", map=tmp_lst, title=title_lst,
+ run("r.support", map=lst_output, title=title_lst,
units=units_lst, description=description_lst,
source1=source1_lst, source2=source2_lst,
history=history_lst)
# (re)name the LST product
- run("g.rename", rast=(tmp_lst, lst_output))
+ #run("g.rename", rast=(tmp_lst, lst_output))
# restore region
if not keep_region:
