[GRASS-SVN] r68399 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Sat May 7 19:23:50 PDT 2016
Author: wenzeslaus
Date: 2016-05-07 19:23:50 -0700 (Sat, 07 May 2016)
New Revision: 68399
grass/trunk/gui/wxpython/gui_core/pyedit.py
pyedit: add toggle toolbar button for overwrite=True
Needs a better icon. Depends on r68398.
Modified: grass/trunk/gui/wxpython/gui_core/pyedit.py
--- grass/trunk/gui/wxpython/gui_core/pyedit.py 2016-05-08 02:13:17 UTC (rev 68398)
+++ grass/trunk/gui/wxpython/gui_core/pyedit.py 2016-05-08 02:23:50 UTC (rev 68399)
@@ -21,7 +21,7 @@
import grass.script as gscript
from grass.script.utils import try_remove
-# just for testing
+# needed just for testing
if __name__ == '__main__':
from grass.script.setup import set_gui_path
set_gui_path()
@@ -37,9 +37,8 @@
from icons.icon import MetaIcon
# TODO: add validation: call/import pep8 (error message if not available)
-# TODO: run with parameters
-# TODO: run with overwrite (in process env, not os.environ)
-# TODO: add more examples (separate file)
+# TODO: run with parameters (alternatively, just use console or GUI)
+# TODO: add more examples (better separate file)
# TODO: add test for templates and examples
# TODO: add pep8 test for templates and examples
# TODO: add snippets?
@@ -204,6 +203,7 @@
sys.exit(main())
def module_error_handling_example():
"""Example of a GRASS module"""
return r"""#!/usr/bin/env python
@@ -259,6 +259,7 @@
self.body = panel
self.filename = None
self.tempfile = None # bool, make them strings for better code
+ self.overwrite = False
def OnRun(self, event):
"""Run Python script"""
@@ -286,10 +287,16 @@
# (not sure if needed every time but useful for opened files)
os.chmod(self.filename, stat.S_IRWXU | stat.S_IWUSR)
- # TODO: add overwrite to toolbar, needs env in GConsole
# run in console as other modules, avoid Python shell which
# carries variables over to the next execution
- self.giface.RunCmd([fd.name])
+ env = os.environ.copy()
+ if not self.overwrite:
+ print "overwrite not active"
+ if self.overwrite:
+ print "overwrite active"
+ env['GRASS_OVERWRITE'] = '1'
+ print self.giface
+ self.giface.RunCmd([fd.name], env=env)
def SaveAs(self):
"""Save python script to file"""
@@ -471,6 +478,19 @@
def __init__(self, parent):
BaseToolbar.__init__(self, parent)
+ self.icons = {
+ 'open': MetaIcon(img='open',
+ label=_('Open (Ctrl+O)')),
+ 'save': MetaIcon(img='save',
+ label=_('Save (Ctrl+S)')),
+ 'run': MetaIcon(img='execute',
+ label=_('Run (Ctrl+R)')),
+ 'overwriteTrue': MetaIcon(img='locked',
+ label=_('Activate overwrite')),
+ 'overwriteFalse': MetaIcon(img='unlocked',
+ label=_('Deactive overwrite')),
# workaround for http://trac.wxwidgets.org/ticket/13888
if sys.platform == 'darwin':
parent.SetToolBar(self)
@@ -482,28 +502,37 @@
def _toolbarData(self):
"""Toolbar data"""
- icons = {
- 'open': MetaIcon(img='open',
- label=_('Open (Ctrl+O)')),
- 'save': MetaIcon(img='save',
- label=_('Save (Ctrl+S)')),
- 'run': MetaIcon(img='execute',
- label=_('Run (Ctrl+R)')),
- return self._getToolbarData((('open', icons['open'],
+ return self._getToolbarData((('open', self.icons['open'],
self.parent.OnOpen),
- ('save', icons['save'],
+ ('save', self.icons['save'],
self.parent.OnSave),
(None, ),
- ('run', icons['run'],
+ ('run', self.icons['run'],
self.parent.OnRun),
+ ('overwrite', self.icons['overwriteTrue'],
+ self.OnSetOverwrite, wx.ITEM_CHECK),
(None, ),
("help", BaseIcons['help'],
self.parent.OnHelp),
+ def OnSetOverwrite(self, event):
+ if self.GetToolState(self.overwrite):
+ self.SetToolNormalBitmap(self.overwrite,
+ self.icons['overwriteFalse'].GetBitmap())
+ self.SetToolShortHelp(self.overwrite,
+ self.icons['overwriteFalse'].GetLabel())
+ print "setting overwrite true"
+ self.parent.overwrite = True
+ else:
+ self.icons['overwriteTrue'].GetBitmap())
+ self.icons['overwriteTrue'].GetLabel())
+ print "setting overwrite false"
+ self.parent.overwrite = False
class PyEditFrame(wx.Frame):
# GUI class and a lot of trampoline methods
# pylint: disable=missing-docstring
@@ -594,7 +623,15 @@
def OnSupport(self, *args, **kwargs):
self.controller.OnSupport(*args, **kwargs)
+ def _get_overwrite(self):
+ return self.controller.overwrite
+ def _set_overwrite(self, overwrite):
+ self.controller.overwrite = overwrite
+ overwrite = property(_get_overwrite, _set_overwrite)
def main():
"""Test application (potentially useful as g.gui.pyedit)"""
app = wx.App()
