[GRASS-SVN] r68403 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Sat May 7 19:54:36 PDT 2016
Author: wenzeslaus
Date: 2016-05-07 19:54:35 -0700 (Sat, 07 May 2016)
New Revision: 68403
grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar: file list generation to documenetation (author: Doug Newcomb, closes #3026)
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2016-05-08 02:49:11 UTC (rev 68402)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2016-05-08 02:54:35 UTC (rev 68403)
@@ -259,13 +259,45 @@
<div class="code"><pre>
g.region raster=elevation -p
-r.in.lidar input=points.las output=height_above_ground base_raster=elevation
+r.in.lidar input=points.las output=mean_height_above_ground base_raster=elevation method=mean
</pre></div>
In this type of computation, it might be advantageous to change the resolution
to match the precision of the points rather than deriving it from the base raster.
<!-- TODO: say how -->
+<h3>Multiple file input</h3>
+The file option requres a file that contains a list of file names with the full
+path. For example, a list of files in the directory /home/user/data:
+<div class="code"><pre>
+points1.laz
+points2.laz
+points3.laz
+</pre></div>
+would be lised in the file as:
+/home/user/data/points1.laz
+/home/user/data/points2.laz
+/home/user/data/points3.laz
+</pre></div>
+On Linux and OSX, this file can be automatically generated with the command:
+ls /home/user/data/*.laz > /home/user/data/filelist.txt
+</pre></div>
+On Windows:
+dir /b c:\users\user\data\*.laz > c:\users\user\data\filelist.txt
+</pre></div>
+The mean height above ground example above would then be:
+g.region raster=elevation -p
+r.in.lidar file=/home/user/data/filelist.txt output=mean_height_above_ground base_raster=elevation method=mean
+</pre></div>
<h2>TODO</h2>
<ul>
