[GRASS-SVN] r68419 - grass/trunk/raster/r.watershed/front
Wed May 11 00:04:39 PDT 2016
Author: mmetz
Date: 2016-05-11 00:04:39 -0700 (Wed, 11 May 2016)
New Revision: 68419
   grass/trunk/raster/r.watershed/front/r.watershed.html
r.watershed: update manual
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html	2016-05-10 18:03:54 UTC (rev 68418)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html	2016-05-11 07:04:39 UTC (rev 68419)
@@ -80,10 +80,10 @@
 used for the RUSLE calculations.
 <p>
-Option <b>blocking</b> specifies terrain that will block overland
-surface flow.  errain that will block overland surface flow and
-restart the slope length for the RUSLE.  All cells that are not NULL
-and not zero indicate blocking terrain.
+Option <b>blocking</b> specifies terrain that will block overland
+surface flow. Blocking cells and streams stop the slope length for the
+RUSLE.  All cells that are not NULL and not zero indicate blocking
+terrain.
 <p>
 Option <b>threshold</b> specifies the minimum size of an exterior
@@ -144,7 +144,7 @@
 depression input map).  Negative values indicate that surface runoff
 is leaving the boundaries of the current geographic region.  The
 absolute value of these negative cells indicates the direction of
-flow.
+flow. For MFD, drainage indicates the direction of maximum flow.
 <p>
 The output <b>basin</b> map contains unique label for each watershed
