[GRASS-SVN] r68424 - grass/branches/releasebranch_7_0/doc
svn_grass at osgeo.org
Thu May 12 01:31:56 PDT 2016
Author: neteler
Date: 2016-05-12 01:31:56 -0700 (Thu, 12 May 2016)
New Revision: 68424
grass/branches/releasebranch_7_0/doc/howto_release.txt
howto release docs: updated trac procedure
Modified: grass/branches/releasebranch_7_0/doc/howto_release.txt
--- grass/branches/releasebranch_7_0/doc/howto_release.txt 2016-05-12 08:29:26 UTC (rev 68423)
+++ grass/branches/releasebranch_7_0/doc/howto_release.txt 2016-05-12 08:31:56 UTC (rev 68424)
@@ -172,10 +172,16 @@
release tag for the differences
o Trac updates:
+ - Add new release to https://trac.osgeo.org/grass/admin/ticket/versions
- Set "complete" flag in https://trac.osgeo.org/grass/milestone/7.0.x --> Edit Milestone
- this batch-migrates assigned tickets to next milestone
- - Add release to https://trac.osgeo.org/grass/admin/ticket/versions
+ (this ideally batch-migrates assigned tickets to next milestone)
+ - batch modify tickets, set to next milestone (update this query accordingly)
+ https://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&milestone=7.0.4&milestone=7.0.5&group=status&col=id&col=summary&col=owner&col=type&col=priority&col=component&col=version&order=priority
+ - under "Comment" add Field "Milestone" and set to next version
+ - Select all shown tickets via Status: assigned/new/reopened
+ - then "Change ticket" button
o WinGRASS notes:
Update grass_packager_release.bat, eg.
