[GRASS-SVN] r68434 - in grass/trunk/imagery: i.cluster i.gensig i.gensigset
Sun May 15 05:43:14 PDT 2016
Author: marisn
Date: 2016-05-15 05:43:14 -0700 (Sun, 15 May 2016)
New Revision: 68434
   grass/trunk/imagery/i.cluster/main.c
   grass/trunk/imagery/i.cluster/open_files.c
   grass/trunk/imagery/i.gensig/parse.c
   grass/trunk/imagery/i.gensigset/parse.c
Imagery modules: Ask to overwrite signature files. Fixes #3000
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c	2016-05-15 12:37:40 UTC (rev 68433)
+++ grass/trunk/imagery/i.cluster/main.c	2016-05-15 12:43:14 UTC (rev 68434)
@@ -91,7 +91,7 @@
     parm.out_sig->type = TYPE_STRING;
     parm.out_sig->key_desc = "name";
     parm.out_sig->required = YES;
-    parm.out_sig->gisprompt = "old,sig,sigfile";
+    parm.out_sig->gisprompt = "new,sig,sigfile";
     parm.out_sig->description = _("Name for output file containing result signatures");
     parm.class = G_define_option();
@@ -160,6 +160,25 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    group = parm.group_name->answer;	/* a required parameter */
+    subgroup = parm.subgroup_name->answer;	/* required */
+    outsigfile = parm.out_sig->answer;
+    /* check all the inputs */
+    if (!I_find_group(group)) {
+        G_fatal_error(_("Group <%s> not found in current mapset"), group);
+    if (!I_find_subgroup(group, subgroup)) {
+        G_fatal_error(_("Subgroup <%s> in group <%s> not found"), subgroup, group);
+    /* GRASS parser fails to detect existing signature files as
+     * detection needs answers from other parameters as group and subgroup.
+     * Thus check is performed only now. */
+    if (!G_get_overwrite() && I_find_signature_file(group, subgroup, "sig", outsigfile)) {
+        G_fatal_error(_("option <%s>: <%s> exists. To overwrite, use the --overwrite flag"),
+                        parm.out_sig->key, parm.out_sig->answer);
     G_get_window(&window);
     nrows = Rast_window_rows();
@@ -167,11 +186,7 @@
     I_cluster_clear(&C);
-    group = parm.group_name->answer;	/* a required parameter */
-    subgroup = parm.subgroup_name->answer;	/* required */
-    outsigfile = parm.out_sig->answer;
     if (sscanf(parm.class->answer, "%d", &maxclass) != 1 || maxclass < 1
 	|| maxclass > 255) {
 	G_fatal_error(_("Illegal number of initial classes (%s)"),
Modified: grass/trunk/imagery/i.cluster/open_files.c
--- grass/trunk/imagery/i.cluster/open_files.c	2016-05-15 12:37:40 UTC (rev 68433)
+++ grass/trunk/imagery/i.cluster/open_files.c	2016-05-15 12:43:14 UTC (rev 68434)
@@ -12,16 +12,6 @@
     int n, missing;
     I_init_group_ref(&ref);
-    G_strip(group);
-    if (!I_find_group(group))
-	G_fatal_error(_("Group <%s> not found in current mapset"), group);
-    G_strip(subgroup);
-    if (!I_find_subgroup(group, subgroup))
-	G_fatal_error(_("Subgroup <%s> in group <%s> not found"),
-		      subgroup, group);
     I_free_group_ref(&ref);
     I_get_subgroup_ref(group, subgroup, &ref);
Modified: grass/trunk/imagery/i.gensig/parse.c
--- grass/trunk/imagery/i.gensig/parse.c	2016-05-15 12:37:40 UTC (rev 68433)
+++ grass/trunk/imagery/i.gensig/parse.c	2016-05-15 12:43:14 UTC (rev 68434)
@@ -22,7 +22,7 @@
     sigfile->type = TYPE_STRING;
     sigfile->key_desc = "name";
     sigfile->required = YES;
-    sigfile->gisprompt = "old,sig,sigfile";
+    sigfile->gisprompt = "new,sig,sigfile";
     sigfile->description = _("Name for output file containing result signatures");
@@ -42,6 +42,14 @@
     if (!I_find_subgroup(parms->group, parms->subgroup))
 	G_fatal_error(_("Subgroup <%s> in group <%s> not found"), parms->subgroup, parms->group);
+    if (!G_get_overwrite() && I_find_signature_file(parms->group, parms->subgroup, "sig", parms->sigfile)) {
+                        sigfile->key, sigfile->answer);
     return 0;
Modified: grass/trunk/imagery/i.gensigset/parse.c
--- grass/trunk/imagery/i.gensigset/parse.c	2016-05-15 12:37:40 UTC (rev 68433)
+++ grass/trunk/imagery/i.gensigset/parse.c	2016-05-15 12:43:14 UTC (rev 68434)
@@ -21,7 +21,7 @@
     maxsig = G_define_option();
@@ -49,6 +49,15 @@
     if (!I_find_subgroup(parms->group, parms->subgroup)) {
+    if (!G_get_overwrite() && I_find_signature_file(parms->group, parms->subgroup, "sigset", parms->sigfile)) {
     if (sscanf(maxsig->answer, "%d", &parms->maxsubclasses) != 1 ||
 	parms->maxsubclasses <= 0) {
 	G_fatal_error(_("Illegal number of sub-signatures (%s)"),
