[GRASS-SVN] r68438 - grass/trunk/scripts/v.what.strds
svn_grass at osgeo.org
Mon May 16 01:40:26 PDT 2016
Author: neteler
Date: 2016-05-16 01:40:26 -0700 (Mon, 16 May 2016)
New Revision: 68438
grass/trunk/scripts/v.what.strds/v.what.strds.py
v.what.strds: some msg standardization, see https://trac.osgeo.org/grass/wiki/MessageStandardization
Modified: grass/trunk/scripts/v.what.strds/v.what.strds.py
--- grass/trunk/scripts/v.what.strds/v.what.strds.py 2016-05-16 08:25:49 UTC (rev 68437)
+++ grass/trunk/scripts/v.what.strds/v.what.strds.py 2016-05-16 08:40:26 UTC (rev 68438)
@@ -201,14 +201,14 @@
pymap.open('r')
except:
dbif.close()
- grass.fatal(_("It is not possible to open the new map %s" % output))
+ grass.fatal(_("Unable to create vector map <%s>" % output))
if len(pymap.dblinks) == 0:
try:
grass.run_command("v.db.addtable", map=output)
except CalledModuleError:
dbif.close()
- grass.fatal(_("Impossible add table to vector %s" % output))
+ grass.fatal(_("Unable to add table <%s> to vector map <%s>" % output))
pymap.close()
for sample in samples:
raster_names = sample.raster_names
