Author: mmetz
Date: 2016-05-17 14:04:51 -0700 (Tue, 17 May 2016)
New Revision: 68454
grass/trunk/raster/r.resamp.stats/main.c
r.resamp.stats: do not use Rast_easting_to_col() because it does ll wrap
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c 2016-05-17 21:02:57 UTC (rev 68453)
+++ grass/trunk/raster/r.resamp.stats/main.c 2016-05-17 21:04:51 UTC (rev 68454)
@@ -40,7 +40,7 @@
{c_var, w_var, "variance", "variance value"},
{c_stddev, w_stddev, "stddev", "standard deviation"},
{c_quant, w_quant, "quantile", "arbitrary quantile"},
- {NULL, NULL, NULL}
+ {NULL, NULL, NULL, NULL}
static char *build_method_list(void)
@@ -100,7 +100,8 @@
for (col = 0; col <= dst_w.cols; col++) {
double x = Rast_col_to_easting(col, &dst_w);
- col_map[col] = (int)floor(Rast_easting_to_col(x, &src_w) + 0.5);
+ /* col_map[col] = (int)floor(Rast_easting_to_col(x, &src_w) + 0.5); */
+ col_map[col] = (int)floor((x - src_w.west) / src_w.ew_res + 0.5);
for (row = 0; row <= dst_w.rows; row++) {
@@ -115,7 +116,7 @@
int count = maprow1 - maprow0;
int i;
- G_percent(row, dst_w.rows, 2);
+ G_percent(row, dst_w.rows, 4);
for (i = 0; i < count; i++)
Rast_get_d_row(infile, bufs[i], maprow0 + i);
@@ -168,7 +169,8 @@
- col_map[col] = Rast_easting_to_col(x, &src_w);
+ /* col_map[col] = Rast_easting_to_col(x, &src_w); */
+ col_map[col] = (x - src_w.west) / src_w.ew_res;
@@ -185,7 +187,7 @@
int i;
@@ -302,15 +304,32 @@
G_get_set_window(&dst_w);
- /* set window to old map */
+ /* set source window to old map */
Rast_get_cellhd(parm.rastin->answer, "", &src_w);
- /* enlarge source window */
+ if (G_projection() == PROJECTION_LL) {
+ /* try to shift source window to overlap with destination window */
+ while (src_w.west >= dst_w.east && src_w.east - 360.0 > dst_w.west) {
+ src_w.east -= 360.0;
+ src_w.west -= 360.0;
+ while (src_w.east <= dst_w.west && src_w.west + 360.0 < dst_w.east) {
+ src_w.east += 360.0;
+ src_w.west += 360.0;
+ /* adjust source window to cover destination window */
int r0 = (int)floor(Rast_northing_to_row(dst_w.north, &src_w));
int r1 = (int)ceil(Rast_northing_to_row(dst_w.south, &src_w));
+ /* do not use Rast_easting_to_col() because it does ll wrap */
int c0 = (int)floor(Rast_easting_to_col(dst_w.west, &src_w));
int c1 = (int)ceil(Rast_easting_to_col(dst_w.east, &src_w));
+ int c0 = (int)floor((dst_w.west - src_w.west) / src_w.ew_res);
+ int c1 = src_w.cols + (int)ceil((dst_w.east - src_w.east) / src_w.ew_res);
src_w.south -= src_w.ns_res * (r1 - src_w.rows);
src_w.north += src_w.ns_res * (-r0);
