[GRASS-SVN] r68472 - in grass/trunk/vector: v.in.lidar v.in.pdal v.out.lidar
Thu May 19 15:51:52 PDT 2016
Author: wenzeslaus
Date: 2016-05-19 15:51:51 -0700 (Thu, 19 May 2016)
New Revision: 68472
   grass/trunk/vector/v.in.lidar/main.c
   grass/trunk/vector/v.in.pdal/main.cpp
   grass/trunk/vector/v.out.lidar/main.c
v.in.lidar, v.out.lidar, v.in.pdal: do not use category 0
Merge class 0 into class 1
and add 1 to the RGB number before saving
(and subtract 1 before reading).
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c	2016-05-19 22:36:56 UTC (rev 68471)
+++ grass/trunk/vector/v.in.lidar/main.c	2016-05-19 22:51:51 UTC (rev 68472)
@@ -595,8 +595,14 @@
             int return_c = return_to_cat(return_n, n_returns);
             Vect_cat_set(Cats, return_layer, return_c);
-        if (class_layer)
-            Vect_cat_set(Cats, class_layer, point_class);
+        if (class_layer) {
+            /* 0 is not a valid category and
+             * classes 0 and 1 as practically the same */
+            if (point_class == 0)
+                Vect_cat_set(Cats, class_layer, 1);
+            else
+                Vect_cat_set(Cats, class_layer, point_class);
         if (have_color && rgb_layer) {
             /* TODO: if attr table, acquired again, performance difference? */
             LASColorH LAS_color = LASPoint_GetColor(LAS_point);
@@ -607,6 +613,7 @@
                 int rgb = red;
                 rgb = (rgb << 8) + green;
                 rgb = (rgb << 8) + blue;
+                rgb++;  /* cat 0 is not valid, add one */
                 Vect_cat_set(Cats, rgb_layer, rgb);
Modified: grass/trunk/vector/v.in.pdal/main.cpp
--- grass/trunk/vector/v.in.pdal/main.cpp	2016-05-19 22:36:56 UTC (rev 68471)
+++ grass/trunk/vector/v.in.pdal/main.cpp	2016-05-19 22:51:51 UTC (rev 68472)
@@ -64,6 +64,7 @@
         int rgb = red;
         Vect_cat_set(cats, layers->rgb_layer, rgb);
Modified: grass/trunk/vector/v.out.lidar/main.c
--- grass/trunk/vector/v.out.lidar/main.c	2016-05-19 22:36:56 UTC (rev 68471)
+++ grass/trunk/vector/v.out.lidar/main.c	2016-05-19 22:51:51 UTC (rev 68472)
@@ -416,9 +416,12 @@
         if (context->rgb_layer) {
             if (!Vect_cat_get(cats, context->rgb_layer, &cat))
                 return;         /* TODO: is this an error? */
-            int red = (cat >> 16) & 0xFF;
-            int green = (cat >> 8) & 0xFF;
-            int blue = cat & 0xFF;
+            /* cat 0 is not valid, so we are adding 1 when storing
+             * now we need to subtract 1 */
+            int rgb = cat - 1;
+            int red = (rgb >> 16) & 0xFF;
+            int green = (rgb >> 8) & 0xFF;
+            int blue = rgb & 0xFF;
             LASColor_SetRed(las_color, red);
             LASColor_SetGreen(las_color, green);
