[GRASS-SVN] r68499 - grass-addons/grass7/raster/r.out.ntv2
Tue May 24 09:02:28 PDT 2016
Author: msieczka
Date: 2016-05-24 09:02:27 -0700 (Tue, 24 May 2016)
New Revision: 68499
   grass-addons/grass7/raster/r.out.ntv2/Makefile
   grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
   grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py
Manual update and svn props set.
Property changes on: grass-addons/grass7/raster/r.out.ntv2/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Modified: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
--- grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html	2016-05-24 15:56:09 UTC (rev 68498)
+++ grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html	2016-05-24 16:02:27 UTC (rev 68499)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<em>r.out.ntv2</em> converts a pair of GRASS raster maps containing longitude and lattitude coordinate offsets into an <a href="http://trac.osgeo.org/proj/wiki/GenParms#nadgrids-GridBasedDatumAdjustments">g NTv2 datum shift</a> file.
+<em>r.out.ntv2</em> converts a pair of GRASS raster maps containing longitude and lattitude coordinate offsets into an <a href="http://trac.osgeo.org/proj/wiki/GenParms#nadgrids-GridBasedDatumAdjustments">NTv2 grid datum shift</a> file (if this document dissapeared it might have been moved to the <a href="https://github.com/OSGeo/proj.4/wiki">new PROJ.4 wiki</a>.
 <p>NTv2 format supports only single-precission floating point data. GRASS double-precision DCELL data need to be reduced to FCELL before export, eg. using <a href="r.mapcalc.html">r.mapcalc</a> <code>float()</code> function.
Property changes on: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/raster/r.out.ntv2/r.out.ntv2.py
   + text/x-python
   + native
