[GRASS-SVN] r68510 - in grass/trunk: scripts/r.import temporal/t.register
svn_grass at osgeo.org
Wed May 25 09:49:46 PDT 2016
Author: neteler
Date: 2016-05-25 09:49:46 -0700 (Wed, 25 May 2016)
New Revision: 68510
grass/trunk/scripts/r.import/r.import.html
grass/trunk/temporal/t.register/t.register.html
r.import + t.register manuals: minor updates
Modified: grass/trunk/scripts/r.import/r.import.html
--- grass/trunk/scripts/r.import/r.import.html 2016-05-25 09:29:11 UTC (rev 68509)
+++ grass/trunk/scripts/r.import/r.import.html 2016-05-25 16:49:46 UTC (rev 68510)
@@ -86,7 +86,7 @@
<h3>Import of WorldClim data</h3>
-Import of a subset from WorldClim <a href="http://worldclim.org/current">Bioclim data set</a>,
+Import of a subset from WorldClim <a href="http://worldclim.org/bioclim">Bioclim data set</a>,
to be reprojected to current location projection (North Carolina sample dataset).
Different resolutions are available, in this example we use the 2.5 arc-minutes
resolution data. During import, we spatially subset the world data to the
@@ -94,9 +94,10 @@
<div class="code"><pre>
# download selected Bioclim data (2.5 arc-minutes resolution)
+# optionally tiles are available for the 30 arc-sec resolution
wget http://biogeo.ucdavis.edu/data/climate/worldclim/1_4/grid/cur/bio_2-5m_bil.zip
-# extract BIO1 from package:
+# extract BIO1 from package (BIO1 = Annual Mean Temperature):
unzip bio_2-5m_bil.zip bio1.bil bio1.hdr
# prior to import, fix broken WorldClim extent using GDAL tool
@@ -110,6 +111,7 @@
r.import input=bio1_fixed.tif output=bioclim01 resample=bilinear \
extent=region resolution=region -n
+# temperature data are in °C * 10
r.info bioclim01
r.univar -e bioclim01
</pre></div>
Modified: grass/trunk/temporal/t.register/t.register.html
--- grass/trunk/temporal/t.register/t.register.html 2016-05-25 09:29:11 UTC (rev 68509)
+++ grass/trunk/temporal/t.register/t.register.html 2016-05-25 16:49:46 UTC (rev 68510)
@@ -233,9 +233,11 @@
<em>
<a href="t.create.html">t.create</a>,
<a href="t.info.html">t.info</a>
-<a href="https://grasswiki.osgeo.org/wiki/Temporal_data_processing/maps_registration">Maps registration examples in Temporal data processing Wiki</a>
</em>
+<p>
+<a href="https://grasswiki.osgeo.org/wiki/Temporal_data_processing/maps_registration">Maps registration examples in Temporal data processing Wiki</a>
<h2>AUTHOR</h2>
Sören Gebbert, Thünen Institute of Climate-Smart Agriculture
