[GRASS-SVN] r69763 - grass-addons/grass7/raster/r.series.lwr
Wed Nov 2 14:50:43 PDT 2016
Author: mmetz
Date: 2016-11-02 14:50:43 -0700 (Wed, 02 Nov 2016)
New Revision: 69763
Added:
   grass-addons/grass7/raster/r.series.lwr/r.series.lwr.html
Removed:
   grass-addons/grass7/raster/r.series.lwr/r.hants.html
   grass-addons/grass7/raster/r.series.lwr/Makefile
   grass-addons/grass7/raster/r.series.lwr/main.c
new grass addon r.series.lwr
Modified: grass-addons/grass7/raster/r.series.lwr/Makefile
--- grass-addons/grass7/raster/r.series.lwr/Makefile	2016-11-02 21:47:26 UTC (rev 69762)
+++ grass-addons/grass7/raster/r.series.lwr/Makefile	2016-11-02 21:50:43 UTC (rev 69763)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.hants
+PGM = r.series.lwr
 LIBES = $(GMATHLIB) $(RASTERLIB) $(GISLIB)
 DEPENDENCIES = $(GMATHDEP) $(RASTERDEP) $(GISDEP)
Modified: grass-addons/grass7/raster/r.series.lwr/main.c
--- grass-addons/grass7/raster/r.series.lwr/main.c	2016-11-02 21:47:26 UTC (rev 69762)
+++ grass-addons/grass7/raster/r.series.lwr/main.c	2016-11-02 21:50:43 UTC (rev 69763)
@@ -1,13 +1,11 @@
- * MODULE:       r.hants
- * AUTHOR(S):    Wout Verhoef, NLR, Remote Sensing Dept., June 1998
- *               Mohammad Abouali, converted to MATLAB, 2011
- *               Markus Metz, converted to C, 2013
- *               based on r.series
+ * MODULE:       r.series.lwr
+ * AUTHOR(S):    Markus Metz
+ *               based on r.hants
  * PURPOSE:      time series correction
- * COPYRIGHT:    (C) 2013 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2016 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -26,8 +24,6 @@
 #include <grass/glocale.h>
 #include <grass/gmath.h>
-/* TODO: add option for amplitude and phase output */
 struct input
     const char *name;
@@ -42,6 +38,87 @@
     DCELL *buf;
+static double uniform(double ref, double x, double max)
+    double dist = fabs(x - ref) / max;
+    if (dist < 1)
+	return 1;
+    return 0;
+static double triangular(double ref, double x, double max)
+    if (dist == 0)
+	return 1;
+    if (dist >= 1)
+	return 0;
+    return (1.0 - dist);
+static double epanechnikov(double ref, double x, double max)
+    if (dist == 0)
+	return 1;
+    if (dist >= 1)
+	return 0;
+    return (1.0 - dist * dist);
+static double quartic(double ref, double x, double max)
+    double tmp;
+    if (dist == 0)
+	return 1;
+    if (dist >= 1)
+	return 0;
+    tmp = 1.0 - dist * dist;
+    return (tmp * tmp);
+static double tricube(double ref, double x, double max)
+    double tmp;
+    if (dist == 0)
+	return 1;
+    if (dist >= 1)
+	return 0;
+    tmp = 1.0 - dist * dist * dist;
+    return (tmp * tmp * tmp);
+static double cosine(double ref, double x, double max)
+    if (dist == 0)
+	return 1;
+    if (dist >= 1)
+	return 0;
+    return (cos(M_PI_2 * dist));
 static int solvemat(double **m, double a[], double B[], int n)
     int i, j, i2, j2, imark;
@@ -68,7 +145,7 @@
 	/* co-linear points results in a solution with rounding error */
 	if (pivot == 0.0) {
-	    G_warning(_("Matrix is unsolvable"));
+	    G_debug(4, "Matrix is unsolvable");
 	    return 0;
@@ -115,46 +192,65 @@
     return 1;
+static double term(int term, double x)
+    switch (term) {
+    case 0:
+	return 1.0;
+    case 1:
+	return x;
+    case 2:
+	return x * x;
+    case 3:
+	return x * x * x;
+    return 0.0;
 int main(int argc, char *argv[])
     struct GModule *module;
     struct
 	struct Option *input, *file, *suffix,
-	              *amp,	/* prefix for amplitude output */
-	              *phase,	/* prefix for phase output */
-	              *nf,	/* number of harmonics */
+	              *order,	/* polynomial order */
+		      *weight,	/* weighing function */
 		      *fet,	/* fit error tolerance */
+		      *ts,	/* time steps */
 		      *dod,	/* degree of over-determination */
-	              *range,	/* low/high threshold */
-		      *ts,	/* time steps*/
-		      *bl,	/* length of base period */
+		      *range,	/* range of valid values */
 		      *delta;	/* threshold for high amplitudes */
     } parm;
     struct
 	struct Flag *lo, *hi, *lazy;
     } flag;
-    int i, j, k;
-    int num_inputs;
+    int i, j, k, n;
+    int num_inputs, in_lo, in_hi;
     struct input *inputs = NULL;
     int num_outputs;
     struct output *outputs = NULL;
-    struct output *out_amp = NULL;
-    struct output *out_phase = NULL;
     char *suffix;
     struct History history;
-    DCELL *values = NULL, *rc = NULL;
+    struct Colors colors;
+    DCELL *values = NULL, *values2 = NULL;
     int nrows, ncols;
     int row, col;
-    double lo, hi, fet, *cs, *sn, *ts, delta;
-    int bl;
-    double **mat, **mat_t, **A, *Av, *Azero, *za, *zr, maxerrlo, maxerrhi;
-    int asize;
-    int dod, nf, nr, nout, noutmax;
-    int rejlo, rejhi, *useval;
-    int do_amp, do_phase;
+    int order;
+    double fet, maxerrlo, maxerrhi, lo, hi;
+    DCELL *resultn;
+    int msize;
+    double **m, **m2, *a, *a2, *B;
+    double *ts, weight;
+    double (*weight_func)(double, double, double);
+    int dod;
+    int *isnull, n_nulls;
+    int min_points, n_points;
+    int this_margin;
+    double max_ts, tsdiff1, tsdiff2;
+    double delta;
+    int rejlo, rejhi;
     G_gisinit(argv[0]);
@@ -178,28 +274,25 @@
     parm.suffix->key = "suffix";
     parm.suffix->type = TYPE_STRING;
     parm.suffix->required = NO;
-    parm.suffix->answer = "_hants";
+    parm.suffix->answer = "lwr";
     parm.suffix->label = _("Suffix for output maps");
     parm.suffix->description = _("The suffix will be appended to input map names");
-    parm.amp = G_define_option();
-    parm.amp->key = "amplitude";
-    parm.amp->type = TYPE_STRING;
-    parm.amp->required = NO;
-    parm.amp->label = _("Prefix for output amplitude maps");
+    parm.order = G_define_option();
+    parm.order->key = "order";
+    parm.order->type = TYPE_INTEGER;
+    parm.order->required = NO;
+    parm.order->options = "1,2,3";
+    parm.order->answer = "2";
+    parm.order->description = _("order number");
-    parm.phase = G_define_option();
-    parm.phase->key = "phase";
-    parm.phase->type = TYPE_STRING;
-    parm.phase->required = NO;
-    parm.phase->label = _("Prefix for output phase maps");
+    parm.weight = G_define_option();
+    parm.weight->key = "weight";
+    parm.weight->type = TYPE_STRING;
+    parm.weight->required = NO;
+    parm.weight->options = "uniform,triangular,epanechnikov,quartic,tricube,cosine";
+    parm.weight->answer = "tricube";
-    parm.nf = G_define_option();
-    parm.nf->key = "nf";
-    parm.nf->type = TYPE_INTEGER;
-    parm.nf->required = YES;
-    parm.nf->description = _("Number of frequencies");
     parm.fet = G_define_option();
     parm.fet->key = "fet";
     parm.fet->type = TYPE_DOUBLE;
@@ -211,7 +304,7 @@
     parm.dod->key = "dod";
     parm.dod->type = TYPE_INTEGER;
     parm.dod->required = NO;
-    parm.dod->answer = "0";
+    parm.dod->answer = "1";
     parm.dod->description = _("Degree of over-determination");
     parm.range = G_define_option();
@@ -226,11 +319,6 @@
     parm.ts->multiple = YES;
     parm.ts->description = _("Time steps of the input maps");
-    parm.bl = G_define_option();
-    parm.bl->key = "base_period";
-    parm.bl->type = TYPE_INTEGER;
-    parm.bl->description = _("Length of the base period");
     parm.delta = G_define_option();
     parm.delta->key = "delta";
     parm.delta->type = TYPE_DOUBLE;
@@ -260,18 +348,12 @@
     if (!parm.input->answer && !parm.file->answer)
         G_fatal_error(_("Please specify input= or file="));
-    if (parm.amp->answer && parm.phase->answer) {
-	if (strcmp(parm.amp->answer, parm.phase->answer) == 0)
-	    G_fatal_error(_("'%s' and '%s' options must be different"),
-			  parm.amp->key, parm.phase->key);
-    do_amp = parm.amp->answer != NULL;
-    do_phase = parm.phase->answer != NULL;
+    order = atoi(parm.order->answer);
+    if (order < 1)
+	G_fatal_error(_("The order number must be > 0"));
+    if (order > 3)
+	G_fatal_error(_("The order number must be <= 3"));
-    nf = atoi(parm.nf->answer);
-    if (nf < 1)
-	G_fatal_error(_("The number of frequencies must be > 0"));
     fet = DBL_MAX;
     if (parm.fet->answer) {
 	fet = atof(parm.fet->answer);
@@ -302,6 +384,23 @@
     if ((rejlo || rejhi) && !parm.fet->answer)
 	G_fatal_error(_("Fit error tolerance is required when outliers should be rejected"));
+    weight_func = tricube;
+    if (strcmp(parm.weight->answer, "uniform") == 0)
+	weight_func = uniform;
+    else if (strcmp(parm.weight->answer, "triangular") == 0)
+	weight_func = triangular;
+    else if (strcmp(parm.weight->answer, "epanechnikov") == 0)
+	weight_func = epanechnikov;
+    else if (strcmp(parm.weight->answer, "quartic") == 0)
+	weight_func = quartic;
+    else if (strcmp(parm.weight->answer, "tricube") == 0)
+    else if (strcmp(parm.weight->answer, "cosine") == 0)
+	weight_func = cosine;
+    else
+	G_fatal_error(_("Unknown weighing function '%s'"),
+	              parm.weight->answer);
     /* process the input maps from the file */
     if (parm.file->answer) {
 	FILE *in;
@@ -369,12 +468,24 @@
     if (num_inputs < 3)
 	G_fatal_error(_("At least 3 input maps are required"));
-    /* length of base period */
-    if (parm.bl->answer)
-	bl = atoi(parm.bl->answer);
-    else
-	bl = num_inputs;
+    ts = G_malloc(num_inputs * sizeof(double));
+    if (parm.ts->answer) {
+    	for (i = 0; parm.ts->answers[i]; i++);
+	if (i != num_inputs)
+	    G_fatal_error(_("Number of time steps does not match number of input maps"));
+    	for (i = 0; parm.ts->answers[i]; i++) {
+	    ts[i] = atof(parm.ts->answers[i]);
+	    if (i > 0 && ts[i - 1] >= ts[i])
+		G_fatal_error(_("Time steps must increase"));
+    else {
+	for (i = 0; i < num_inputs; i++) {
+	    ts[i] = i;
     /* open output maps */
     num_outputs = num_inputs;
@@ -382,7 +493,7 @@
     suffix = parm.suffix->answer;
     if (!suffix)
-	suffix = "_hants";
+	suffix = "_lwr";
     for (i = 0; i < num_outputs; i++) {
 	struct output *out = &outputs[i];
@@ -395,128 +506,35 @@
 	out->fd = Rast_open_new(output_name, DCELL_TYPE);
-    nr = 2 * nf + 1;
+    min_points = 1 + order + dod;
-    if (nr > num_inputs)
-	G_fatal_error(_("The maximum number of frequencies for %d input maps is %d."),
-	                num_inputs, (num_inputs - 1) / 2);
+    if (min_points > num_inputs)
+	G_fatal_error(_("At least %d input maps are required for "
+			"order number %d and "
+	                "degree of over-determination %d."),
+	                min_points, order, dod);
-    noutmax = num_inputs - nr - dod;
-    if (noutmax < 0)
-	G_fatal_error(_("The degree of overdetermination can not be larger than %d "
-			"for %d input maps and %d frequencies."),
-			dod + noutmax, num_inputs, nf);
-    if (noutmax == 0)
-	G_warning(_("Missing values can not be reconstructed, "
-	            "please reduce either '%s' or '%s'"),
-		    parm.nf->key, parm.dod->key);
-    if (do_amp) {
-	/* open output amplitude */
-	out_amp = G_calloc(nf, sizeof(struct output));
-	for (i = 0; i < nf; i++) {
-	    struct output *out = &out_amp[i];
-	    char output_name[GNAME_MAX];
-	    sprintf(output_name, "%s.%d", parm.amp->answer, i);
-	    out->name = G_store(output_name);
-	    out->buf = Rast_allocate_d_buf();
-	    out->fd = Rast_open_new(output_name, DCELL_TYPE);
-    if (do_phase) {
-	/* open output phase */
-	out_phase = G_calloc(nf, sizeof(struct output));
-	    struct output *out = &out_phase[i];
-	    sprintf(output_name, "%s.%d", parm.phase->answer, i);
     /* initialise variables */
     values = G_malloc(num_inputs * sizeof(DCELL));
+    values2 = G_malloc(num_inputs * sizeof(DCELL));
+    resultn = G_malloc(num_inputs * sizeof(DCELL));
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
-    cs = G_alloc_vector(bl);
-    sn = G_alloc_vector(bl);
-    ts = G_alloc_vector(num_inputs);
-    rc = G_malloc(num_inputs * sizeof(DCELL));
-    useval = G_malloc(num_inputs * sizeof(int));
+    isnull = G_malloc(num_inputs * sizeof(int));
-    if (parm.ts->answer) {
-    	for (i = 0; parm.ts->answers[i]; i++);
-	if (i != num_inputs)
-	    G_fatal_error(_("Number of time steps does not match number of input maps"));
-	    ts[i] = atof(parm.ts->answers[i]);
-    else {
-	for (i = 0; i < num_inputs; i++) {
-	    ts[i] = i;
+    msize = 1 + order;
+    m = G_alloc_matrix(msize, msize);
+    m2 = G_alloc_matrix(msize, msize);
+    a = G_alloc_vector(msize);
+    a2 = G_alloc_vector(msize);
+    B = G_alloc_vector(msize);
-    mat = G_alloc_matrix(nr, num_inputs);
-    mat_t = G_alloc_matrix(num_inputs, nr);
-    A = G_alloc_matrix(nr, nr);
-    Av = *A;
-    Azero = G_alloc_vector(nr * nr);
-    asize = nr * nr * sizeof(double);
-    za = G_alloc_vector(nr);
-    zr = G_alloc_vector(nr);
-    rc = G_alloc_vector(num_inputs);
+    /* calculate weights for different margins */
-    for (i = 0; i < nr * nr; i++)
-	Azero[i] = 0;
-    for (i = 0; i < bl; i++) {
-	double ang = 2.0 * M_PI * i / bl;
-	cs[i] = cos(ang);
-	sn[i] = sin(ang);
-    for (j = 0; j < num_inputs; j++) {
-	mat[0][j] = 1.;
-	mat_t[j][0] = 1.;
-    for (i = 0; i < nr / 2; i++) {
-	int i1 = 2 * i + 1;
-	int i2 = 2 * i + 2;
-	    int idx = (int) ((i + 1) * (ts[j])) % bl;
-	    if (idx >= bl)
-		G_fatal_error("cs/sn index out of range: %d, %d", idx, bl);
-	    if (i2 >= nr)
-		G_fatal_error("mat index out of range: %d, %d", 2 * i + 2, nr);
-	    mat[i1][j] = cs[idx];
-	    mat[i2][j] = sn[idx];
-	    mat_t[j][i1] = mat[i1][j];
-	    mat_t[j][i2] = mat[i2][j];
     /* process the data */
-    G_message(_("Harmonic analysis of %d input maps..."), num_inputs);
+    G_message(_("Local weighted regression of %d input maps..."), num_inputs);
     for (row = 0; row < nrows; row++) {
 	G_percent(row, nrows, 4);
@@ -535,146 +553,205 @@
 	for (col = 0; col < ncols; col++) {
-	    int null = 0, non_null = 0;
+	    n_nulls = 0;
 		DCELL v = inputs[i].buf[col];
-		useval[i] = 0;
+		isnull[i] = 0;
 		if (Rast_is_d_null_value(&v)) {
-		    null++;
+		    isnull[i] = 1;
+		    n_nulls++;
 		else if (parm.range->answer && (v < lo || v > hi)) {
 		    Rast_set_d_null_value(&v, 1);
-		    null++;
+		    isnull[i] = 1;
+		    n_nulls++;
-		else {
-		    non_null++;
-		    useval[i] = 1;
 		values[i] = v;
-	    nout = null;
-	    /* HANTS */
-	    if (nout <= noutmax) {
-		int n = 0, done = 0;
+	    /* LWR */
+	    if (num_inputs - n_nulls >= min_points) {
-		while (!done) {
+		    DCELL result;
+		    /* margin around i */
+		    n_points = 0;
+		    in_lo = in_hi = i;
+		    this_margin = 0;
+		    if (!isnull[i])
+			n_points++;
+		    for (j = 1; j < num_inputs; j++) {
+			if (i - j >= 0) {
+			    if (!isnull[i - j]) {
+				n_points++;
+				in_lo = i - j;
+			if (i + j < num_inputs) {
+			    if (!isnull[i + j]) {
+				n_points++;
+				in_hi = i + j;
+			if (n_points >= min_points) {
+			    this_margin = j;
+			    break;
+		    tsdiff1 = ts[i] - ts[in_lo];
+		    tsdiff2 = ts[in_hi] - ts[i];
+		    max_ts = tsdiff1;
+		    if (max_ts < tsdiff2)
+			max_ts = tsdiff2;
-		    /* za = mat * y */
+		    max_ts *= (1.0 + 1.0 / this_margin);
-		    /* A = mat * diag(p) * mat' */
+		    /* initialize matrix and vectors */
+		    for (j = 0; j <= order; j++) {
+			a[j] = 0;
+			B[j] = 0;
+			m[j][j] = 0;
+			for (k = 0; k < j; k++) {
+			    m[j][k] = m[k][j] = 0;
+		    /* load points */
+		    for (n = in_lo; n <= in_hi; n++) {
+			if (isnull[n])
+			    continue;
-		    /* mat: nr, num_inputs
-		     * diag(p): num_inputs, num_inputs
-		     * mat_t: num_inputs, nr
-		     * A temp: nr, num_inputs
-		     * A: nr, nr */
+			weight = weight_func(ts[i], ts[n], max_ts);
+			    double val1 = term(j, ts[n]);
-		    memcpy(Av, Azero, asize);
-		    for (i = 0; i < nr; i++) {
-			za[i] = 0;
-			    if (useval[j]) {
-				za[i] += mat[i][j] * values[j];
+			    for (k = j; k <= order; k++) {
+				double val2 = term(k, ts[n]);
-				for (k = 0; k < nr; k++)
-				    A[i][k] += mat[i][j] * mat_t[j][k];
+				m[j][k] += val1 * val2 * weight;
+			    a[j] += values[n] * val1 * weight;
-			if (i > 0) {
-			    A[i][i] += delta;
+		    /* TRANSPOSE VALUES IN UPPER HALF OF M TO OTHER HALF */
+		    m2[0][0] = m[0][0];
+		    a2[0] = a[0];
+		    for (j = 1; j <= order; j++) {
+			    m[j][k] = m[k][j];
+			    m2[j][k] = m2[k][j] = m[k][j];
+			m[j][j] *= (1 + delta);
+			m2[j][j] = m[j][j];
+			a2[j] = a[j];
-		    /* zr = A \ za
-		     * solve A * zr = za */
-		    if (!solvemat(A, za, zr, nr)) {
-			done = -1;
-			Rast_set_d_null_value(rc, num_outputs);
-			break;
-		    /* G_math_solver_gauss(A, zr, za, nr) is much slower */
-		    /* rc = mat' * zr */
-		    maxerrlo = maxerrhi = 0;
-			rc[i] = 0;
-			for (j = 0; j < nr; j++) {
-			    rc[i] += mat_t[i][j] * zr[j];
+		    if (solvemat(m2, a2, B, order + 1) != 0) {
+			/* get estimate */
+			result = 0.0;
+			    result += B[j] * term(j, ts[i]);
-			if (useval[i]) {
-			    if (maxerrlo < rc[i] - values[i])
-				maxerrlo = rc[i] - values[i];
-			    if (maxerrhi < values[i] - rc[i])
-				maxerrhi = values[i] - rc[i];
-		    if (rejlo || rejhi) {
-			done = 1;
-			if (rejlo && maxerrlo > fet)
-			    done = 0;
-			if (rejhi && maxerrhi > fet)
-			    done = 0;
-			if (!done) {
-			    /* filter outliers */
+			if (rejlo || rejhi) {
+			    int done = 0;
-				if (useval[i]) {
-				    if (rejlo && rc[i] - values[i] > maxerrlo * 0.5) {
-					useval[i] = 0;
-					nout++;
+				if (isnull[n])
+				    continue;
+				values2[n] = values[n];
+			    while (!done) {
+				done = 1;
+				maxerrlo = maxerrhi = 0;
+				    if (isnull[n])
+					continue;
+				    resultn[n] = 0.0;
+					resultn[n] += B[j] * term(j, ts[n]);
-				    if (rejhi && values[i] - rc[i] > maxerrhi * 0.5) {
-					useval[i] = 0;
-					nout++;
+				    if (maxerrlo < resultn[n] - values2[n])
+					maxerrlo = resultn[n] - values2[n];
+				    if (maxerrhi < values2[n] - resultn[n])
+					maxerrhi = values2[n] - resultn[n];
-		    n++;
-		    if (n >= num_inputs)
-			done = 1;
-		    if (nout > noutmax)
-			done = 1;
+				if (rejlo && maxerrlo > fet)
+				    done = 0;
+				if (rejhi && maxerrhi > fet)
+				    done = 0;
-		for (i = 0; i < num_outputs; i++) {
-		    struct output *out = &outputs[i];
+				if (!done) {
-		    out->buf[col] = rc[i];
-		    if (rc[i] < lo)
-			out->buf[col] = lo;
-		    else if (rc[i] > hi)
-			out->buf[col] = hi;
+				    a2[0] = 0;
+					a2[j] = 0;
-		if (do_amp || do_phase) {
-		    /* amplitude and phase */
-		    /* skip constant */
+				    /* replace outliers */
+					if (isnull[n])
+					    continue;
-		    for (i = 1; i < nr; i += 2) {
-			int ifr = i >> 1;
+					if (rejlo && resultn[n] - values2[n] > maxerrlo * 0.5) {
+					    values2[n] = (resultn[n] + values2[n]) * 0.5;
+					if (rejhi && values2[n] - resultn[n] > maxerrhi * 0.5) {
+					    values2[n] = (values2[n] + resultn[n]) * 0.5;
-			if (do_amp) {
-			    out_amp[ifr].buf[col] = sqrt(zr[i] * zr[i] +
-						    zr[i + 1] * zr[i + 1]);
+					    a2[j] += values2[n] * val1 * weight;
+				    done = 1;
+					/* update estimate */
+					result = 0.0;
+					done = 0;
+		    else {
+			double wsum = 0.0;
-			if (do_phase) {
-			    double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
+			G_warning(_("Points are (nearly) co-linear, using weighted average"));
-			    if (angle < 0)
-				angle += 360;
-			    out_phase[ifr].buf[col] = angle;
+			result = 0.0;
+			    if (isnull[n])
+				continue;
+			    result += values[n] * weight;
+			    wsum += weight;
+			result /= wsum;
+		    outputs[i].buf[col] = result;
 	    else {
@@ -683,74 +760,32 @@
 		    Rast_set_d_null_value(&out->buf[col], 1);
-			if (do_amp)
-			    Rast_set_d_null_value(&out_amp[i].buf[col], 1);
-			if (do_phase)
-			    Rast_set_d_null_value(&out_phase[i].buf[col], 1);
 	    Rast_put_d_row(outputs[i].fd, outputs[i].buf);
-		if (do_amp)
-		    Rast_put_d_row(out_amp[i].fd, out_amp[i].buf);
-		if (do_phase)
-		    Rast_put_d_row(out_phase[i].fd, out_phase[i].buf);
     G_percent(row, nrows, 2);
-    /* Close input maps */
-    if (!flag.lazy->answer) {
-	    Rast_close(inputs[i].fd);
-    /* close output maps */
+    /* close input and output maps */
+	struct input *in = &inputs[i];
+	if (!flag.lazy->answer)
+	    Rast_close(in->fd);
 	Rast_close(out->fd);
 	Rast_short_history(out->name, "raster", &history);
 	Rast_command_history(&history);
 	Rast_write_history(out->name, &history);
-    if (do_amp) {
-	/* close output amplitudes */
-	    Rast_close(out->fd);
-	    Rast_short_history(out->name, "raster", &history);
-	    Rast_command_history(&history);
-	    Rast_write_history(out->name, &history);
+	if (Rast_read_colors(in->name, "", &colors) == 1)
+	    Rast_write_colors(out->name, G_mapset(), &colors);
-    if (do_phase) {
-	/* close output phases */
     exit(EXIT_SUCCESS);
Deleted: grass-addons/grass7/raster/r.series.lwr/r.hants.html
--- grass-addons/grass7/raster/r.series.lwr/r.hants.html	2016-11-02 21:47:26 UTC (rev 69762)
+++ grass-addons/grass7/raster/r.series.lwr/r.hants.html	2016-11-02 21:50:43 UTC (rev 69763)
@@ -1,204 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.hants</em> performs a harmonic analysis of time series in order to
-estimate missing values and identify outliers. For each input map, an
-output map with the suffix <em>suffix</em> (default: _hants) is created.
-<p>
-The option <b>nf</b>, number of frequencies, should be carefully chosen.
-Different numbers of frequencies should be tested first on a small test
-region before running the module on the full region. As a rule of thumb,
-the number of frequencies should be at least
-<em>estimated periodicity + 3</em>, e.g. for NDVI with an annual cycle
-(one peak per year), the number of frequencies should be at least 4 when
-analysing one year. If two peaks are assumed per year, the number of
-frequencies should be at least 5 when analysing one year.
-<p>The number of frequencies should also not be too large. With a large
-number of frequencies, outliers can no longer be identified because the
-fit is "too good", outliers can be represented by the estimate.
-The number of frequencies should also be smaller than <em>n input maps / 2</em>
-if missing values should be reconstructed.
-<h2>NOTES</h2>
-The optional <em>amplitude</em> and <em>phase</em> output maps contain
-the amplitude and phase for each frequency. The amplitude maps can be
-used to identify the dominant frequency with <em>r.series
-method=max_raster</em>. The baseline frequeny (base period) has the
-suffix <em>.0</em>, its first harmonic has the suffix <em>.1</em>, its
-second harmonic has the suffix <em>.2</em>, etc. The value of the
-output of <em>r.series method=max_raster</em> is identical to the
-number of the suffix. With the <em>amplitude</em> output maps for NDVI
-input, this can be used to determine the number of peaks in vegetation
-growth within the base period, where 0 (zero) means that the dominant
-frequency is the base period, i.e. one peak per base period.
-<p>
-If the <em>range</em> option is given, any values which fall outside
-that range will be treated as if they were NULL.
-The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
-values outside of this range are treated as NULL.
-<p>
-The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
-<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
-negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
-<p>
-The maximum number of raster maps that can be processed is given by the
-per-user limit of the operating system. For example, the soft limits
-for users are typically 1024. The soft limit can be changed with e.g.
-<tt>ulimit -n 4096</tt> (UNIX-based operating systems) but not higher
-than the hard limit. If it is too low, you can as superuser add an
-entry in
-<div class="code"><pre>
-/etc/security/limits.conf
-# <domain>      <type>  <item>         <value>
-your_username  hard    nofile          4096
-</pre></div>
-This would raise the hard limit to 4096 files. Also have a look at the
-overall limit of the operating system
-cat /proc/sys/fs/file-max
-</pre></div>
-which is on modern Linux systems several 100,000 files.
-<p>Use the <em>file</em> option to analyze large amount of raster maps
-without hitting open files limit and the size limit of command line
-arguments. The computation is slower than the <em>input</em> option
-method. For every single row in the output map(s) all input maps are
-opened and closed. The amount of RAM will rise linear with the number of
-specified input maps. The input and file options are mutually exclusive.
-Input is a text file with a new line separated list of raster map names.
-<p>For the usage of the option <b>fet</b> see Roerink et al. (2000). Its
-value is relative to the value range of the variable being considered.
-<h2>EXAMPLES</h2>
-<h3>Precipitation data example</h3>
-This small example is based on a climatic dataset for North Carolina which
-was from publicly available data (monthly temperature averages and monthly
-precipitation sums from 2000 to 2012, downloadable as
-<a href="http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip">GRASS GIS 7 location</a>):
-# set computational region to one of the maps
-g.region raster=2004_03_tempmean -p
-</pre></div>
-Visualize the time series as animation:
-# note: color table is different from standard "celsius"
-g.gui.animation rast=`g.list type=raster pattern="*tempmean" sep=comma`
-</pre></div>
-<p>
-Since HANTS is CPU intensive, we test for now at lower resolution:
-g.region -p res=5000
-# HANTS: Harmonic analysis of the 156 input maps...
-# just wildly guessing the parameters for a test run:
-# generate and check list of input maps (the order matters!)
-g.list type=raster pattern="20??_??_tempmean" output=tempmean.csv
-r.hants file=tempmean.csv \
-  nf=6 fet=0.1 dod=5 delta=0.1 base_period=12
-# assign reasonable color tables for temperature
-for map in `g.list type=raster pattern="*tempmean_hants"` ; do
-    r.colors $map color=celsius
-done
-# assign degree Celsius color table
-r.colors 2000_06_tempmean_hants color=celsius
-# verify with one of the 156 results (still at reduced resolution):
-r.mapcalc "2000_06_tempmean_diff = 2000_06_tempmean - 2000_06_tempmean_hants"
-r.colors 2000_06_tempmean_diff color=differences
-d.mon wx0
-d.rast 2000_06_tempmean_hants
-d.rast 2000_06_tempmean_diff
-r.univar 2000_06_tempmean_diff -g
-n=5066
-null_cells=5040
-cells=10106
-min=-0.0899336115228095
-max=0.359362050140941
-range=0.449295661663751
-mean=0.188579838052468
-# see HANTS time series as animation
-g.gui.animation rast=`g.list type=raster pattern="*tempmean_hants" sep=comma`
-# Check HANTS behaviour in a given point
-east=740830
-north=168832
-for map in `g.list rast pat="20??_??_tempmean"` ; do
-  r.what map=$map coordinates=$east,$north >> time_series_orig.csv
-done
-for map in `g.list rast pat="*tempmean_hants"` ; do
-  r.what map=$map coordinates=$east,$north >> time_series_hants.csv
-done
-# merge files:
-echo "east|north|temp_orig|temp_hants" > time_series_final.csv
-paste -d'|' time_series_orig.csv time_series_hants.csv | \
-      cut -d'|' -f1,2,4,8 >> time_series_final.csv
-# Resulting CSV file: 'time_series_final.csv'
-</pre></div>
-<h3>Using t.* modules to check for basic statistics</h3>
-The temporal framework (t.* modules) can be used to assess basic statistics:
-# create spatio temporal data set with hants output maps
-t.create type=strds temporaltype=absolute  output=tempmean_hants \
-  title="Mean Temperature HANTS" description="Mean Temperature reconstructed with HANTS"
-# register maps in the strds
-t.register -i type=raster input=tempmean_hants \
-  maps=`g.list raster pattern=*tempmean_hants sep=,` start="2000-01-01" \
-  increment="1 months"
-# getting general info of the strds (including max and min of the whole series)
-t.info type=strds input=tempmean_hants
-# getting statistics for each map in the series
-t.rast.univar -h tempmean_hants > stats_hants.txt
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="r.series.html">r.series</a></em>
-<h2>REFERENCES</h2>
-<p>
-Roerink, G. J., Menenti, M. and Verhoef, W., 2000. Reconstructing
-cloudfree NDVI composites using Fourier analysis of time series.
-International Journal of Remote Sensing, 21 (9), 1911-1917.
-DOI: <a href=http://dx.doi.org/10.1080/014311600209814>10.1080/014311600209814</a>
-<h2>AUTHOR</h2>
-Markus Metz
-<p><i>Last changed: $Date$</i>
Copied: grass-addons/grass7/raster/r.series.lwr/r.series.lwr.html (from rev 69762, grass-addons/grass7/raster/r.series.lwr/r.hants.html)
--- grass-addons/grass7/raster/r.series.lwr/r.series.lwr.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.series.lwr/r.series.lwr.html	2016-11-02 21:50:43 UTC (rev 69763)
@@ -0,0 +1,88 @@
+<h2>DESCRIPTION</h2>
+<em>r.series.lwr</em> performs a local weighted regression (LWR) of
+time series in order to estimate missing values and identify outliers.
+For each input map, an output map with the suffix <em>suffix</em>
+(default: _lwr) is created.
+<p>
+For each point in the time series, the (in time) neighboring points are
+considered to estimate a polynomial function that best fits the
+observations. The points are weighted according to their distance (in
+time) to the current point with points farther away getting a lower
+weight.
+<p>
+The option <b>order</b> determines the order of the polynomial function
+used to fit the observations. An order of 1 is a linear regression,
+recommended and default is <em>order=2</em>. An order of 3 might cause
+over-fitting, resulting in no smoothing, and should only be used with
+data that show high fluctuations.
+<p>
+The <em>delta</em> option is experimental. It smoothes the polynomial
+function: with a high <em>delta</em> value, a higher order polynomial
+function fitting becomes similar to a moving average.
+<p>
+Optionally, outliers can be removed with the <em>-l</em> and
+<em>-h</em> flags when fitting a polynomial. In this case, a fit error
+tolerance (option <em>fit</em>) must be provided. These flags are
+slowing down the module and are only needed when the time series
+contains many outliers. A few outliers are handled well with the
+default settings.
+<h2>NOTES</h2>
+If the <em>range</em> option is given, any values which fall outside
+that range will be treated as if they were NULL.
+The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
+values outside of this range are treated as NULL.
+<p>
+The <em>low,high</em> thresholds are floating point, so use
+<em>-inf</em> or <em>inf</em> for a single threshold (e.g.,
+<em>range=0,inf</em> to ignore negative values, or
+<em>range=-inf,-200.4</em> to ignore values above -200.4).
+<p>
+The maximum number of raster maps that can be processed is given by the
+per-user limit of the operating system. For example, the soft limits
+for users are typically 1024. The soft limit can be changed with e.g.
+<tt>ulimit -n 4096</tt> (UNIX-based operating systems) but not higher
+than the hard limit. If it is too low, you can as superuser add an
+entry in
+<div class="code"><pre>
+/etc/security/limits.conf
+# <domain>      <type>  <item>         <value>
+your_username  hard    nofile          4096
+</pre></div>
+This would raise the hard limit to 4096 files. Also have a look at the
+overall limit of the operating system
+cat /proc/sys/fs/file-max
+</pre></div>
+which is on modern Linux systems several 100,000 files.
+<p>Use the <em>-z</em> flag to analyze large amount of raster maps
+without hitting open files limit and the size limit of command line
+arguments. This will however increase the processing time. For every
+single row in the output map(s) all input maps are opened and closed.
+The amount of RAM will rise linear with the number of specified input
+maps.
+<p>
+The input and file options are mutually exclusive. Input is a
+text file with a new line separated list of raster map names.
+<h2>SEE ALSO</h2>
+<em><a href="r.series.html">r.series</a></em>,
+<em><a href="r.hants.html">r.hants</a></em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
