[GRASS-SVN] r69767 - grass/branches/releasebranch_7_2/raster/r.univar
Thu Nov 3 04:46:42 PDT 2016
Author: neteler
Date: 2016-11-03 04:46:42 -0700 (Thu, 03 Nov 2016)
New Revision: 69767
   grass/branches/releasebranch_7_2/raster/r.univar/r.univar.html
r.univar manual: clearly mention r.stats.quantile
Modified: grass/branches/releasebranch_7_2/raster/r.univar/r.univar.html
--- grass/branches/releasebranch_7_2/raster/r.univar/r.univar.html	2016-11-03 11:44:22 UTC (rev 69766)
+++ grass/branches/releasebranch_7_2/raster/r.univar/r.univar.html	2016-11-03 11:46:42 UTC (rev 69767)
@@ -32,6 +32,9 @@
 extended statistics flag is used with a very large region setting. If the
 region is too large the module should exit gracefully with a memory allocation
 error. Basic statistics can be calculated using any size input region.
+Extended statistics can be calculated using
+<em><a href="r.stats.quantile.html">r.stats.quantile</a></em>.
 <p>
 Without a <b>zones</b> input raster, the <em>r.quantile</em> module will
 be significantly more efficient for calculating percentiles with large maps.
