[GRASS-SVN] r69779 - grass/branches/releasebranch_7_0/scripts/r.mask
svn_grass at osgeo.org
Sat Nov 5 20:11:39 PDT 2016
Author: annakrat
Date: 2016-11-05 20:11:39 -0700 (Sat, 05 Nov 2016)
New Revision: 69779
grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py
r.mask: ignore case when removing mask for Windows (merged from trunk, r69607)
Modified: grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py
--- grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py 2016-11-06 03:09:16 UTC (rev 69778)
+++ grass/branches/releasebranch_7_0/scripts/r.mask/r.mask.py 2016-11-06 03:11:39 UTC (rev 69779)
@@ -67,6 +67,7 @@
#%end
import os
+import sys
import atexit
import grass.script as grass
@@ -100,8 +101,12 @@
if remove:
# -> remove
if exists:
- grass.run_command('g.remove', flags = 'f', quiet = True,
- type = 'raster', name = 'MASK')
+ if sys.platform == 'win32':
+ grass.run_command('g.remove', flags='if', quiet=True,
+ type='raster', name='MASK')
+ else:
+ grass.run_command('g.remove', flags='f', quiet=True,
grass.message(_("Raster MASK removed"))
else:
grass.fatal(_("No existing MASK to remove"))
