[GRASS-SVN] r69782 - grass/trunk/raster/r.stats.quantile
svn_grass at osgeo.org
Sun Nov 6 06:58:10 PST 2016
Author: mmetz
Date: 2016-11-06 06:58:10 -0800 (Sun, 06 Nov 2016)
New Revision: 69782
grass/trunk/raster/r.stats.quantile/main.c
grass/trunk/raster/r.stats.quantile/r.stats.quantile.html
r.stats.quantile: enhance for #3203
Modified: grass/trunk/raster/r.stats.quantile/main.c
--- grass/trunk/raster/r.stats.quantile/main.c 2016-11-06 12:51:33 UTC (rev 69781)
+++ grass/trunk/raster/r.stats.quantile/main.c 2016-11-06 14:58:10 UTC (rev 69782)
@@ -307,22 +307,50 @@
G_percent(cat, num_cats, 2);
-static void print_quantiles(void)
+static void print_quantiles(char *fs, char *name, int table_frmt)
- int cat;
+ int cat, quant;
+ struct basecat *bc;
G_message(_("Printing quantiles"));
- for (cat = 0; cat < num_cats; cat++) {
- struct basecat *bc = &basecats[cat];
- int quant;
+ if (name != NULL && strcmp(name, "-") != 0) {
+ if (NULL == freopen(name, "w", stdout)) {
+ G_fatal_error(_("Unable to open file <%s> for writing"), name);
- if (bc->total == 0)
- continue;
+ if (!table_frmt) {
+ for (cat = 0; cat < num_cats; cat++) {
+ bc = &basecats[cat];
+ if (bc->total == 0)
+ continue;
+ for (quant = 0; quant < num_quants; quant++)
+ fprintf(stdout, "%d%s%d%s%f%s%f\n", cmin + cat, fs, quant, fs,
+ 100 * quants[quant], fs, bc->quants[quant]);
+ else {
+ fprintf(stdout, "cat");
- printf("%d:%d:%f:%f\n", cmin + cat, quant, 100 * quants[quant], bc->quants[quant]);
+ fprintf(stdout, "%s%f", fs, 100 * quants[quant]);
+ fprintf(stdout, "\n");
+ continue;
+ fprintf(stdout, "%d", cmin + cat);
+ fprintf(stdout, "%s%f", fs, bc->quants[quant]);
static void compute_quantiles(void)
@@ -468,13 +496,14 @@
struct GModule *module;
struct
- struct Option *quant, *perc, *slots, *basemap, *covermap, *output;
+ struct Option *quant, *perc, *slots, *basemap, *covermap,
+ *output, *file, *fs;
} opt;
struct {
- struct Flag *r, *p;
+ struct Flag *r, *p, *t;
} flag;
const char *basemap, *covermap;
- char **outputs;
+ char **outputs, *fs;
int reclass, print;
int cover_fd, base_fd;
struct Range range;
@@ -517,6 +546,16 @@
opt.output->required = NO;
opt.output->multiple = YES;
+ opt.file = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt.file->key = "file";
+ opt.file->required = NO;
+ opt.file->description =
+ _("Name for output file (if omitted or \"-\" output to stdout)");
+ opt.fs = G_define_standard_option(G_OPT_F_SEP);
+ opt.fs->answer = ":";
+ opt.fs->guisection = _("Formatting");
flag.r = G_define_flag();
flag.r->key = 'r';
flag.r->description =
@@ -527,6 +566,11 @@
flag.p->description =
_("Do not create output maps; just print statistics");
+ flag.t = G_define_flag();
+ flag.t->key = 't';
+ flag.t->description =
+ _("Print statistics in table format");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -534,7 +578,7 @@
covermap = opt.covermap->answer;
outputs = opt.output->answers;
reclass = flag.r->answer;
- print = flag.p->answer;
+ print = flag.p->answer || flag.t->answer;
if (!print && !opt.output->answers)
G_fatal_error(_("Either -%c or %s= must be given"),
@@ -599,8 +643,12 @@
sort_bins();
compute_quantiles();
- if (print)
- print_quantiles();
+ if (print) {
+ /* get field separator */
+ fs = G_option_to_separator(opt.fs);
+ print_quantiles(fs, opt.file->answer, flag.t->answer);
else if (reclass)
do_reclass(basemap, outputs);
else
Modified: grass/trunk/raster/r.stats.quantile/r.stats.quantile.html
--- grass/trunk/raster/r.stats.quantile/r.stats.quantile.html 2016-11-06 12:51:33 UTC (rev 69781)
+++ grass/trunk/raster/r.stats.quantile/r.stats.quantile.html 2016-11-06 14:58:10 UTC (rev 69782)
@@ -24,7 +24,8 @@
<h2>AUTHOR</h2>
-Glynn Clements
+Glynn Clements<br>
+Markus Metz
<p>
<i>Last changed: $Date$</i>
