[GRASS-SVN] r69798 - in grass/branches/releasebranch_7_2/gui/wxpython: gui_core iclass wxplot
svn_grass at osgeo.org
Sun Nov 13 05:11:57 PST 2016
Author: annakrat
Date: 2016-11-13 05:11:56 -0800 (Sun, 13 Nov 2016)
New Revision: 69798
grass/branches/releasebranch_7_2/gui/wxpython/gui_core/wxlibplot.py
grass/branches/releasebranch_7_2/gui/wxpython/iclass/plots.py
grass/branches/releasebranch_7_2/gui/wxpython/wxplot/base.py
grass/branches/releasebranch_7_2/gui/wxpython/wxplot/histogram.py
grass/branches/releasebranch_7_2/gui/wxpython/wxplot/profile.py
grass/branches/releasebranch_7_2/gui/wxpython/wxplot/scatter.py
wxGUI/plot: use local wxlibplot for all wxPython versions, their old import of numpy does not work anymore (merge from trunk, r69797)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gui_core/wxlibplot.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gui_core/wxlibplot.py 2016-11-12 15:25:10 UTC (rev 69797)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gui_core/wxlibplot.py 2016-11-13 13:11:56 UTC (rev 69798)
@@ -118,17 +118,20 @@
import wx
# Needs NumPy
-try:
- import numpy as np
-except:
- msg = """
- This module requires the NumPy module, which could not be
- imported. It probably is not installed (it's not part of the
- standard Python distribution). See the Numeric Python site
- (http://numpy.scipy.org) for information on downloading source or
- binaries."""
- raise ImportError("NumPy not found.\n" + msg)
+import numpy as np
+from core.globalvar import CheckWxVersion
+if CheckWxVersion([3, 0, 0]):
+ from wx import PENSTYLE_SOLID
+ from wx import PENSTYLE_DOT_DASH
+ from wx import BRUSHSTYLE_SOLID
+ from wx import BRUSHSTYLE_TRANSPARENT
+else:
+ from wx import SOLID as PENSTYLE_SOLID
+ from wx import SOLID as BRUSHSTYLE_SOLID
+ from wx import DOT_DASH as PENSTYLE_DOT_DASH
+ from wx import TRANSPARENT as BRUSHSTYLE_TRANSPARENT
# Plotting classes...
@@ -230,7 +233,7 @@
_attributes = {'colour': 'black',
'width': 1,
- 'style': wx.PENSTYLE_SOLID,
+ 'style': PENSTYLE_SOLID,
'legend': ''}
def __init__(self, points, **attr):
@@ -280,7 +283,7 @@
'width': 1,
'legend': ''}
@@ -326,7 +329,7 @@
'width': 1,
'size': 2,
'fillcolour': None,
- 'fillstyle': wx.BRUSHSTYLE_SOLID,
+ 'fillstyle': BRUSHSTYLE_SOLID,
'marker': 'circle',
'legend': ''}
@@ -1179,7 +1182,7 @@
if dc is None:
# sets new dc and clears it
dc = wx.BufferedDC(wx.ClientDC(self.canvas), self._Buffer)
- bbr = wx.Brush(self.GetBackgroundColour(), wx.BRUSHSTYLE_SOLID)
+ bbr = wx.Brush(self.GetBackgroundColour(), BRUSHSTYLE_SOLID)
dc.SetBackground(bbr)
dc.SetBackgroundMode(wx.SOLID)
dc.Clear()
@@ -1696,7 +1699,7 @@
# draw rectangle
dc = wx.ClientDC(self.canvas)
dc.SetPen(wx.Pen(wx.BLACK))
- dc.SetBrush(wx.Brush(wx.WHITE, wx.BRUSHSTYLE_TRANSPARENT))
+ dc.SetBrush(wx.Brush(wx.WHITE, BRUSHSTYLE_TRANSPARENT))
dc.SetLogicalFunction(wx.INVERT)
dc.DrawRectangle(ptx, pty, rectWidth, rectHeight)
dc.SetLogicalFunction(wx.COPY)
@@ -2142,14 +2145,14 @@
data1.shape = (100, 2)
data1[:, 1] = np.sin(data1[:, 0])
line1 = PolySpline(
- data1, legend='Green Line', colour='green', width=6, style=wx.PENSTYLE_DOT)
+ data1, legend='Green Line', colour='green', width=6, style=PENSTYLE_DOT)
# 50 points cos function, plotted as red dot-dash
data1 = 2. * np.pi * np.arange(100) / 100.
data1.shape = (50, 2)
data1[:, 1] = np.cos(data1[:, 0])
line2 = PolySpline(
- data1, legend='Red Line', colour='red', width=3, style=wx.PENSTYLE_DOT_DASH)
+ data1, legend='Red Line', colour='red', width=3, style=PENSTYLE_DOT_DASH)
# A few more points...
pi = np.pi
@@ -2352,7 +2355,7 @@
- dc.SetBrush(wx.Brush(wx.BLACK, wx.BRUSHSTYLE_SOLID))
+ dc.SetBrush(wx.Brush(wx.BLACK, BRUSHSTYLE_SOLID))
sx, sy = mDataDict["scaledXY"] # scaled x,y of closest point
# 10by10 square centered on point
Modified: grass/branches/releasebranch_7_2/gui/wxpython/iclass/plots.py
--- grass/branches/releasebranch_7_2/gui/wxpython/iclass/plots.py 2016-11-12 15:25:10 UTC (rev 69797)
+++ grass/branches/releasebranch_7_2/gui/wxpython/iclass/plots.py 2016-11-13 13:11:56 UTC (rev 69798)
@@ -16,14 +16,8 @@
import wx
-from core.globalvar import CheckWxVersion
-try:
- if CheckWxVersion(version=[3, 0, 0]):
- import gui_core.wxlibplot as plot
- else:
- import wx.lib.plot as plot
-except ImportError as e:
- print >> sys.stderr, e
+import gui_core.wxlibplot as plot
import wx.lib.scrolledpanel as scrolled
from core.utils import _
from core.gcmd import GError
Modified: grass/branches/releasebranch_7_2/gui/wxpython/wxplot/base.py
--- grass/branches/releasebranch_7_2/gui/wxpython/wxplot/base.py 2016-11-12 15:25:10 UTC (rev 69797)
+++ grass/branches/releasebranch_7_2/gui/wxpython/wxplot/base.py 2016-11-13 13:11:56 UTC (rev 69798)
@@ -19,15 +19,8 @@
import sys
import wx
-try:
- else:
from core.globalvar import ICONDIR
from core.settings import UserSettings
from wxplot.dialogs import TextDialog, OptDialog
Modified: grass/branches/releasebranch_7_2/gui/wxpython/wxplot/histogram.py
--- grass/branches/releasebranch_7_2/gui/wxpython/wxplot/histogram.py 2016-11-12 15:25:10 UTC (rev 69797)
+++ grass/branches/releasebranch_7_2/gui/wxpython/wxplot/histogram.py 2016-11-13 13:11:56 UTC (rev 69798)
@@ -18,17 +18,9 @@
import sys
import wx
-try:
- else:
import grass.script as grass
from gui_core.toolbars import BaseToolbar, BaseIcons
from wxplot.base import BasePlotFrame, PlotIcons
from wxplot.dialogs import HistRasterDialog, PlotStatsFrame
Modified: grass/branches/releasebranch_7_2/gui/wxpython/wxplot/profile.py
--- grass/branches/releasebranch_7_2/gui/wxpython/wxplot/profile.py 2016-11-12 15:25:10 UTC (rev 69797)
+++ grass/branches/releasebranch_7_2/gui/wxpython/wxplot/profile.py 2016-11-13 13:11:56 UTC (rev 69798)
@@ -18,31 +18,13 @@
import os
import sys
import math
+import numpy
import wx
-try:
- else:
-try:
- import numpy
-except ImportError:
- msg = _(
- "This module requires the NumPy module, which could not be "
- "imported. It probably is not installed (it's not part of the "
- "standard Python distribution). See the Numeric Python site "
- "(http://numpy.scipy.org) for information on downloading source or "
- "binaries.")
- print >> sys.stderr, "wxplot.py: " + msg
from wxplot.dialogs import ProfileRasterDialog, PlotStatsFrame
Modified: grass/branches/releasebranch_7_2/gui/wxpython/wxplot/scatter.py
--- grass/branches/releasebranch_7_2/gui/wxpython/wxplot/scatter.py 2016-11-12 15:25:10 UTC (rev 69797)
+++ grass/branches/releasebranch_7_2/gui/wxpython/wxplot/scatter.py 2016-11-13 13:11:56 UTC (rev 69798)
@@ -18,17 +18,9 @@
import sys
import wx
-try:
- else:
from wxplot.dialogs import ScatterRasterDialog, PlotStatsFrame
