[GRASS-SVN] r69805 - grass/branches/releasebranch_7_2/gui/wxpython/lmgr
svn_grass at osgeo.org
Sun Nov 13 14:12:03 PST 2016
Author: annakrat
Date: 2016-11-13 14:12:03 -0800 (Sun, 13 Nov 2016)
New Revision: 69805
grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py
grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py
wxGUI: fix layer order when loading workspace, see #3196 (merge from trunk, r69775)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py 2016-11-13 22:00:24 UTC (rev 69804)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py 2016-11-13 22:12:03 UTC (rev 69805)
@@ -1458,7 +1458,6 @@
for layer in gxwXml.layers:
display = layer['display']
maptree = self.notebookLayers.GetPage(display).maptree
newItem = maptree.AddLayer(ltype=layer['type'],
lname=layer['name'],
lchecked=layer['checked'],
@@ -1466,7 +1465,8 @@
lcmd=layer['cmd'],
lgroup=layer['group'],
lnviz=layer['nviz'],
- lvdigit=layer['vdigit'])
+ lvdigit=layer['vdigit'],
+ loadWorkspace=True)
if 'selected' in layer:
selectList.append((maptree, newItem, layer['selected']))
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py 2016-11-13 22:00:24 UTC (rev 69804)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py 2016-11-13 22:12:03 UTC (rev 69805)
@@ -1275,7 +1275,8 @@
event.Skip()
def AddLayer(self, ltype, lname=None, lchecked=None, lopacity=1.0,
- lcmd=None, lgroup=None, lvdigit=None, lnviz=None, multiple=True):
+ lcmd=None, lgroup=None, lvdigit=None, lnviz=None,
+ multiple=True, loadWorkspace=False):
"""Add new item to the layer tree, create corresponding MapLayer instance.
Launch property dialog if needed (raster, vector, etc.)
@@ -1288,6 +1289,7 @@
:param lvdigit: vector digitizer settings (eg. geometry attributes)
:param lnviz: layer Nviz properties
:param bool multiple: True to allow multiple map layers in layer tree
+ :param bool loadWorkspace: True if called when loading workspace
if lname and not multiple:
# check for duplicates
@@ -1323,36 +1325,36 @@
ctrl.SetToolTipString(_("Click to edit layer settings"))
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, ctrl)
# add layer to the layer tree
- if selectedLayer and selectedLayer != self.GetRootItem():
- if self.GetLayerInfo(selectedLayer, key='type') == 'group' \
- and self.IsExpanded(selectedLayer):
- # add to group (first child of self.layer_selected) if group
- # expanded
- layer = self.PrependItem(parent=selectedLayer,
- text='', ct_type=1, wnd=ctrl)
- else:
- # prepend to individual layer or non-expanded group
- if lgroup == -1:
- # -> last child of root (loading from workspace)
- layer = self.AppendItem(parentId=self.root,
- elif lgroup > -1:
- # -> last child of group (loading from workspace)
- parent = self.FindItemByIndex(index=lgroup)
- if not parent:
- parent = self.root
- layer = self.AppendItem(parentId=parent,
- elif lgroup is None:
+ if loadWorkspace:
+ # when loading workspace, we always append
+ if lgroup == -1:
+ # -> last child of root (loading from workspace)
+ layer = self.AppendItem(parentId=self.root,
+ text='', ct_type=1, wnd=ctrl)
+ elif lgroup > -1:
+ # -> last child of group (loading from workspace)
+ parent = self.FindItemByIndex(index=lgroup)
+ if not parent:
+ parent = self.root
+ layer = self.AppendItem(parentId=parent,
+ else:
+ if selectedLayer and selectedLayer != self.GetRootItem():
+ if selectedLayer and self.GetLayerInfo(selectedLayer, key='type') == 'group' \
+ and self.IsExpanded(selectedLayer):
+ # add to group (first child of self.layer_selected) if group
+ # expanded
+ layer = self.PrependItem(parent=selectedLayer,
+ else:
# -> previous sibling of selected layer
parent = self.GetItemParent(selectedLayer)
layer = self.InsertItem(
- parentId=parent, input=self.GetPrevSibling(
- selectedLayer),
- else: # add first layer to the layer tree (first child of root)
- parent=self.root, text='', ct_type=1, wnd=ctrl)
+ parentId=parent, input=self.GetPrevSibling(selectedLayer),
+ else: # add first layer to the layer tree (first child of root)
+ parent=self.root, text='', ct_type=1, wnd=ctrl)
# layer is initially unchecked as inactive (beside 'command')
# use predefined value if given
