[GRASS-SVN] r69809 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Sun Nov 13 14:51:53 PST 2016
Author: wenzeslaus
Date: 2016-11-13 14:51:53 -0800 (Sun, 13 Nov 2016)
New Revision: 69809
grass/trunk/lib/python/pygrass/vector/__init__.py
pygrass: 7.0 API now works even without using kwargs for Vector.write(), see #3010
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2016-11-13 22:37:58 UTC (rev 69808)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2016-11-13 22:51:53 UTC (rev 69809)
@@ -179,7 +179,18 @@
self.n_lines += 1
+ if not isinstance(cat, int) and not isinstance(cat, str):
+ # likely the case of using 7.0 API
+ import warnings
+ warnings.warn("Vector.write(geo_obj, attrs=(...)) is"
+ " depreciated, specify cat explicitly",
+ DeprecationWarning)
+ # try to accommodate
+ attrs = cat
+ cat = None
if attrs and cat is None:
+ # TODO: this does not work as expected when there are
+ # already features in the map when we opened it
cat = (self._cats[-1] if self._cats else 0) + 1
if cat is not None and cat not in self._cats:
