[GRASS-SVN] r69823 - grass/trunk/locale/po
svn_grass at osgeo.org
Mon Nov 14 05:09:02 PST 2016
Author: marisn
Date: 2016-11-14 05:09:02 -0800 (Mon, 14 Nov 2016)
New Revision: 69823
grass/trunk/locale/po/grasslibs_ar.po
grass/trunk/locale/po/grasslibs_cs.po
grass/trunk/locale/po/grasslibs_de.po
grass/trunk/locale/po/grasslibs_el.po
grass/trunk/locale/po/grasslibs_es.po
grass/trunk/locale/po/grasslibs_fi.po
grass/trunk/locale/po/grasslibs_fr.po
grass/trunk/locale/po/grasslibs_it.po
grass/trunk/locale/po/grasslibs_ja.po
grass/trunk/locale/po/grasslibs_ko.po
grass/trunk/locale/po/grasslibs_lv.po
grass/trunk/locale/po/grasslibs_ml.po
grass/trunk/locale/po/grasslibs_pl.po
grass/trunk/locale/po/grasslibs_pt.po
grass/trunk/locale/po/grasslibs_pt_br.po
grass/trunk/locale/po/grasslibs_ro.po
grass/trunk/locale/po/grasslibs_ru.po
grass/trunk/locale/po/grasslibs_sl.po
grass/trunk/locale/po/grasslibs_th.po
grass/trunk/locale/po/grasslibs_tr.po
grass/trunk/locale/po/grasslibs_vi.po
grass/trunk/locale/po/grasslibs_zh.po
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fi.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
Revert r69811 for PO files
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_ar.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4491,7 +4491,7 @@
#: ../lib/python/temporal/aggregation.py:316
#, python-format
msgid ""
-"The limit of open files (%i) was reached (%i). The module r.series will be "
+"The limit of open fiels (%i) was reached (%i). The module r.series will be "
"run with flag z, to avoid open files limit exceeding."
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_cs.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4544,7 +4544,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_de.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4538,7 +4538,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_el.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4539,7 +4539,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_es.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4324,7 +4324,7 @@
#, python-format
-msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
+msgid "The limit of open fiels (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
msgstr ""
#: ../lib/python/temporal/register.py:76 ../lib/python/temporal/register.py:79
Modified: grass/trunk/locale/po/grasslibs_fi.po
--- grass/trunk/locale/po/grasslibs_fi.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_fi.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4341,7 +4341,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_fr.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4675,7 +4675,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_it.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4588,7 +4588,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_ja.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4537,7 +4537,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_ko.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4450,7 +4450,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_lv.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4486,7 +4486,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_ml.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4416,7 +4416,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_pl.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4508,7 +4508,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_pt.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4530,7 +4530,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_pt_br.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4515,7 +4515,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ro.po
--- grass/trunk/locale/po/grasslibs_ro.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_ro.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4414,7 +4414,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_ru.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4546,7 +4546,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_sl.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4514,7 +4514,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_th.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4534,7 +4534,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_tr.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4482,7 +4482,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_vi.po 2016-11-14 13:09:02 UTC (rev 69823)
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grasslibs_zh.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -4532,7 +4532,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_ar.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10711,7 +10711,7 @@
#: ../vector/v.lidar.edgedetection/main.c:204 ../vector/v.outlier/main.c:193
#: ../vector/v.lidar.correction/main.c:172
#, fuzzy
-msgid "Old auxiliary table could not be dropped"
+msgid "Old auxiliar table could not be dropped"
msgstr "غير موجود <%s> الراستر"
#: ../vector/v.lidar.edgedetection/main.c:223 ../vector/v.outlier/main.c:205
@@ -10784,7 +10784,7 @@
#: ../vector/v.lidar.edgedetection/main.c:467
#: ../vector/v.lidar.correction/main.c:439
#, fuzzy
-msgid "Auxiliary table could not be dropped"
+msgid "Auxiliar table could not be dropped"
#: ../vector/v.lidar.edgedetection/edgedetection.c:228
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_cs.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10721,7 +10721,7 @@
#: ../vector/v.lidar.edgedetection/main.c:192
msgstr "Nemohla být odstraněna pomocná tabulka"
@@ -10789,7 +10789,7 @@
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_de.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10624,7 +10624,7 @@
msgstr "Alte Hilfstabelle konnte nicht gelöscht werden."
@@ -10696,7 +10696,7 @@
msgstr "Hilfstabelle konnte nicht gelöscht werden."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_el.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10279,7 +10279,7 @@
msgstr ""
@@ -10347,7 +10347,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_es.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -9800,7 +9800,7 @@
msgstr "La tabla auxiliar antigua no se pudo eliminar"
@@ -9868,7 +9868,7 @@
msgstr "La tabla auxiliar no se pudo eliminar"
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_fi.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -9863,7 +9863,7 @@
msgstr ""
@@ -9931,7 +9931,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_fr.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -11152,7 +11152,7 @@
#, fuzzy
msgstr "couche vecteur <%s> introuvable"
# c-format
@@ -11230,7 +11230,7 @@
#, fuzzy
# c-format
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_it.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10560,7 +10560,7 @@
msgstr ""
@@ -10628,7 +10628,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_ja.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10575,7 +10575,7 @@
msgstr "古いAuxiliarテーブルを削除できませんでした"
@@ -10645,7 +10645,7 @@
msgstr "Auxiliarテーブルはドロップできませんでした"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_ko.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10329,7 +10329,7 @@
msgstr ""
@@ -10398,7 +10398,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_lv.po 2016-11-14 13:09:02 UTC (rev 69823)
#, fuzzy
msgstr "rastrs <%s> nav atrasts"
@@ -10768,7 +10768,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_pl.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10598,7 +10598,7 @@
#, fuzzy
msgstr "Nie można otworzyć rastra <%s>"
@@ -10671,7 +10671,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_pt.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10831,7 +10831,7 @@
#, fuzzy
msgstr "mapa vetorial <%s> não encontrado"
@@ -10904,7 +10904,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10823,7 +10823,7 @@
#, fuzzy
@@ -10896,7 +10896,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_ro.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -9973,7 +9973,7 @@
msgstr ""
@@ -10041,7 +10041,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_ru.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10692,7 +10692,7 @@
#, fuzzy
msgstr "Дополнительная таблица не может быть удалена"
@@ -10763,7 +10763,7 @@
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_sl.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10745,7 +10745,7 @@
#, fuzzy
msgstr "Ne najdem rastrskega sloja <%s>"
@@ -10818,7 +10818,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_th.po 2016-11-14 13:09:02 UTC (rev 69823)
#, fuzzy
msgstr "ตาราง Auxiliar ไม่สามารถ dropped"
@@ -10742,7 +10742,7 @@
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_tr.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10535,7 +10535,7 @@
msgstr ""
@@ -10605,7 +10605,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_vi.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10072,7 +10072,7 @@
#: ../vector/v.surf.bspline/main.c:252
#, fuzzy
-msgstr "Không thể bỏ bảng phụ (auxiliary table)"
+msgstr "Không thể bỏ bảng phụ (auxiliar table)"
#: ../vector/v.surf.bspline/main.c:262 ../vector/v.surf.bspline/main.c:330
#: ../vector/v.outlier/main.c:200
@@ -10224,7 +10224,7 @@
#: ../vector/v.surf.bspline/main.c:942 ../vector/v.outlier/main.c:458
#, fuzzy
#: ../vector/v.surf.bspline/crosscorr.c:75
#, c-format
@@ -10683,8 +10683,8 @@
#: ../vector/v.lidar.correction/main.c:190
@@ -10752,8 +10752,8 @@
#: ../vector/v.lidar.edgedetection/edgedetection.c:274
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2016-11-14 04:30:55 UTC (rev 69822)
+++ grass/trunk/locale/po/grassmods_zh.po 2016-11-14 13:09:02 UTC (rev 69823)
@@ -10680,7 +10680,7 @@
#, fuzzy
msgstr "未发现矢量地图<%s>"
@@ -10753,7 +10753,7 @@
#, fuzzy
