[GRASS-SVN] r69853 - in grass-addons/grass7/raster3d: . r3.forestfrag
Sat Nov 19 19:56:15 PST 2016
Author: wenzeslaus
Date: 2016-11-19 19:56:15 -0800 (Sat, 19 Nov 2016)
New Revision: 69853
Added:
   grass-addons/grass7/raster3d/r3.forestfrag/
   grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html
   grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py
Removed:
   grass-addons/grass7/raster3d/r3.forestfrag/r.forestfrag.html
   grass-addons/grass7/raster3d/r3.forestfrag/r.forestfrag.py
   grass-addons/grass7/raster3d/r3.forestfrag/r_forestfrag_window_11.png
   grass-addons/grass7/raster3d/r3.forestfrag/r_forestfrag_window_7.png
r3.forestfrag: copy r.forestfrag
Deleted: grass-addons/grass7/raster3d/r3.forestfrag/r.forestfrag.html
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.html	2016-09-28 23:55:37 UTC (rev 69601)
+++ grass-addons/grass7/raster3d/r3.forestfrag/r.forestfrag.html	2016-11-20 03:56:15 UTC (rev 69853)
@@ -1,117 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.forestfrag</em> Computes the forest fragmentation following
-the methodology proposed by Riitters et al. (2000). See
-<a href="http://www.consecol.org/vol4/iss2/art3/">this article</a> for a
-detailed explanation.
-<p>It follows a "sliding window" algorithm with overlapping windows.
-The amount of forest and its occurence as adjacent forest pixels
-within fixed- area "moving-windows" surrounding each forest pixel is
-measured. The window size is user-defined. The result is stored at
-the location of the center pixel. Thus, a pixel value in the derived
-map refers to "between-pixel" fragmentation around the corresponding
-forest location.
-<p>As input it requires a binary map with (1) forest and (0)
-non-forest. Obviously, one can replace forest any other land cover
-type. If one wants to exclude the influence of a specific land cover
-type, e.g., water bodies, it should be classified as no-data (NA) in
-the input map. See e.g.,
-<a href="https://pvanb.wordpress.com/2016/03/25/update-of-r-forestfrag-addon/">blog post</a>.
-<p>Let <em>Pf</em> be the proportion of pixels in the window that
-are forested. Define <em>Pff</em> (strictly) as the proportion of
-all adjacent (cardinal directions only) pixel pairs that include at
-least one forest pixel, for which both pixels are forested. <em>Pff</em>
- thus (roughly) estimates the conditional probability that,
-given a pixel of forest, its neighbor is also forest. The
-classification model then identifies six fragmentation categories as:
-<div class="code"><pre>
-interior:       Pf = 1.0
-patch:          Pf < 0.4
-transitional:   0.4 ≤ Pf < 0.6
-edge:           Pf ≥ 0.6 and Pf - Pff < 0
-perforated:     Pf ≥ 0.6 and Pf - Pff > 0
-undetermined:   Pf ≥ 0.6 and Pf = Pff
-</pre></div>
-<h2>NOTES</h2>
-<ul>
-<li>The moving window size is user-defined (default=3)
-and must be an odd number. If an even number is given the function
-will stop with an error message.
-<li>No-data cells are ignored. This means that statistics at the
-raster edges are based on fewer cells (smaller) moving windows. If this
-is a problem, the user can choose to have the output raster trimmed
-with a number of raster cells equal to 1/2 * the size of the moving
-window.
-<li>The function respects the region. The user has however the option
-to set the region to match the input layer.
-</ul>
-<h2>EXAMPLE</h2>
-In the North Carolina sample Location, set the computational region
-to match the land classification raster map:
-g.region raster=landclass96
-</pre></div>
-Then mark all cells which are forest as 1 and everything else as zero:
-r.mapcalc "forest = if(landclass96 == 5, 1, 0)"
-</pre></div>
-Use the new forest presence raster map to compute the forest
-fragmentation index with window size 7:
-r.forestfrag input=forest output=fragmentation window=7
-</pre></div>
-<center>
-<img src="r_forestfrag_window_7.png" alt="r.forestfrag output with window size 7">
-<img src="r_forestfrag_window_11.png" alt="r.forestfrag output with window size 11">
-<p><em>
-Two forest fragmentation indices with window size 7 (left) and
-11 (right) show how increasing window size increases the amount of
-edges.
-</em></p>
-</center>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.li.html">r.li</a>
-</em>
-<p>
-The addon is based on the
-<a href="https://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.forestfrag">
-r.forestfrag.sh</a> script, with as extra options user-defined
-moving window size, option to trim the region (by default it
-respects the region) and a better handling of no-data cells.
-<h2>AUTHORS</h2>
-<em>Paulo van Breugel</em>: Rewritten in Python, added option to set
-moving window size, and improved handling no-data cells<br>
-<em>Stefan Sylla</em>: Revised / updated the r.forestfrag.sh for
-GRASS GIS 6<br>
-<em>Emmanuel Sambale</em>: Author original shell script
-<h2>REFERENCES</h2>
-Riitters, K., J. Wickham, R. O'Neill, B. Jones,
-and E. Smith. 2000. Global-scale patterns of forest fragmentation.
-Conservation Ecology 4(2): 3. [online] URL:
-<a href="http://www.consecol.org/vol4/iss2/art3/">http://www.consecol.org/vol4/iss2/art3/</a>
-<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster3d/r3.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-09-28 23:55:37 UTC (rev 69601)
+++ grass-addons/grass7/raster3d/r3.forestfrag/r.forestfrag.py	2016-11-20 03:56:15 UTC (rev 69853)
@@ -1,417 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE:    r.forestfrag
-# AUTHOR(S): Emmanuel Sambale, Stefan Sylla,
-#            Paulo van Breugel (Python version, paulo at ecodiv.org)
-# PURPOSE:   Creates forest fragmentation index map from a
-#            forest-non-forest raster; The index map is based on
-#            Riitters, K., J. Wickham, R. O'Neill, B. Jones, and
-#            E. Smith. 2000. in: Global-scalepatterns of forest
-#            fragmentation. Conservation Ecology 4(2): 3. [online]
-#            URL: http://www.consecol.org/vol4/iss2/art3/
-# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
-#            This program is free software under the GNU General Public
-#            License (>=v2). Read the file COPYING that comes with GRASS
-#            for details.
-#%module
-#% description: Computes the forest fragmentation index (Riitters et al. 2000)
-#% keyword: raster
-#% keyword: landscape structure analysis
-#% keyword: forest
-#% keyword: fragmentation index
-#% keyword: Riitters
-#%end
-#%option G_OPT_R_INPUT
-#% description: Name of forest raster map (where forest=1, non-forest=0)
-#% required: yes
-#%end
-#%option G_OPT_R_OUTPUT
-#% required: yes
-#%end
-#%option
-#% key: size
-#% type: integer
-#% description: Moving window size (odd number)
-#% key_desc: number
-#% options: 3-
-#% answer : 3
-#% required: no
-#%end
-#% key: pf
-#% label: Name for output Pf (forest area density) raster map
-#% description: Proportion of area which is forested (amount of forest)
-#% required: no
-#%end
-#% key: pff
-#% label: Name for output Pff (forest connectivity) raster map
-#% description: Conditional probability that neighboring cell is forest
-#% required: no
-#%end
-#%flag
-#% key: r
-#% description: Set computational region to input raster map
-#%end
-#%flag
-#% key: t
-#% description: Keep Pf and Pff maps
-#%end
-#%flag
-#% key: s
-#% description: Run r.report on output map
-#%end
-#%flag
-#% key: a
-#% description: Trim the output map to avoid border effects
-#%end
-#%option
-#% key: window
-#% type: integer
-#% label: This option is deprecated, use the option size instead
-#% options: 3-
-#% required: no
-#%end
-# import libraries
-import os
-import sys
-import uuid
-import atexit
-import tempfile
-import string
-import grass.script as gs
-LABELS = """\
-0 nonforest
-1 patch
-2 transitional
-3 edge
-4 perforated
-5 interior
-6 undetermined
-COLORS_SAMBALE = """\
-0 255:255:0
-1 215:48:39
-2 252:141:89
-3 254:224:139
-4 217:239:139
-5 26:152:80
-6 145:207:96
-# create set to store names of temporary maps to be deleted upon exit
-CLEAN_RAST = []
-def cleanup():
-    """Remove temporary maps specified in the global list"""
-    cleanrast = list(reversed(CLEAN_RAST))
-    for rast in cleanrast:
-        gs.run_command("g.remove", flags="f", type="raster", name=rast,
-                       quiet=True)
-def raster_exists(name):
-    """Check if the raster map exists, call GRASS fatal otherwise"""
-    ffile = gs.find_file(name, element='cell')
-    if not ffile['fullname']:
-        gs.fatal(_("Raster map <%s> not found") % name)
-def tmpname(prefix):
-    """Generate a tmp name which conatins prefix
-    Store the name in the global list.
-    Use only for raster maps.
-    tmpf = prefix + str(uuid.uuid4())
-    tmpf = string.replace(tmpf, '-', '_')
-    CLEAN_RAST.append(tmpf)
-    return tmpf
-def pairs_expression(map_name, max_index, combine_op, aggregate_op="+"):
-    """Generate window (matrix) expression
-    :param map_name: name of the map to index
-    :param max_index: the maximum positive index to use
-                      usually (window_size - 1) / 2
-    :param combine_op: operator used to combine values in the pair
-    :param aggregate_op: operator used to combine all pairs together
-    s = max_index  # just to be brief
-    base_expr = "({m}[{a},{b}] {o} {m}[{c},{d}])"
-    expr = []
-    for j in range(-s, s + 1):
-        for i in range(-s, s):
-            expr.append(base_expr.format(
-                m=map_name, o=combine_op, a=i, b=j, c=i + 1, d=j))
-    for i in range(-s, s + 1):
-        for j in range(-s, s):
-                m=map_name, o=combine_op, a=i, b=j, c=i, d=j + 1))
-    return aggregate_op.join(expr)
-def main(options, flags):
-    # options and flags into variables
-    ipl = options['input']
-    raster_exists(ipl)
-    opl = options['output']
-    # size option backwards compatibility with window
-    if not options['size'] and not options['window']:
-        gs.fatal(_("Required parameter <%s> not set") % 'size')
-    if options['size']:
-        wz = int(options['size'])
-    if options['window']:
-        gs.warning(_("The window option is deprecated, use the option"
-                     " size instead"))
-        wz = int(options['window'])
-    if options['size'] and options['size'] != '3' and options['window']:
-        gs.warning(_("When the obsolete window option is used, the"
-                     " new size option is ignored"))
-    if wz % 2 == 0:
-        gs.fatal(_("Please provide an odd number for the moving"
-                   " window size, not %d") % wz)
-    # user wants pf or pff
-    user_pf = options['pf']
-    user_pff = options['pff']
-    # backwards compatibility
-    if flags['t']:
-        gs.warning(_("The -t flag is deprecated, use pf and pff options"
-                     " instead"))
-    if not user_pf and not user_pff and flags['t']:
-        user_pf = opl + '_pf'
-        user_pff = opl + '_pff'
-    elif flags['t']:
-        gs.warning(_("When pf or pff option is used, the -t flag"
-                     " is ignored"))
-    flag_r = flags['r']
-    flag_s = flags['s']
-    clip_output = flags['a']
-    # set to current input map region if requested by the user
-    # default is (and should be) the current region
-    # we could use tmp region for this but if the flag is there
-    # it makes sense to use it from now on
-    if flag_r:
-        gs.message(_("Setting region to input map..."))
-        gs.run_command('g.region', quiet=True, raster=ipl)
-    # check if map values are limited to 1 and 0
-    input_info = gs.raster_info(ipl)
-    # we know what we are doing only when input is integer
-    if input_info['datatype'] != 'CELL':
-        gs.fatal(_("The input raster map must have type CELL"
-                   " (integer)"))
-    # for integer, we just need to text min and max
-    if input_info['min'] != 0 or input_info['max'] != 1:
-        gs.fatal(_("The input raster map must be a binary raster,"
-                   " i.e. it should contain only values 0 and 1"
-                   " (now the minimum is %d and maximum is %d)")
-                 % (input_info['min'], input_info['max']))
-    # computing pf values
-    gs.info(_("Step 1: Computing Pf values..."))
-    # let forested pixels be x and number of all pixels in moving window
-    # be y, then pf=x/y"
-    # generate grid with pixel-value=number of forest-pixels in window
-    # generate grid with pixel-value=number of pixels in moving window:
-    tmpA2 = tmpname('tmpA01_')
-    tmpC3 = tmpname('tmpA02_')
-    gs.run_command("r.neighbors", quiet=True, input=ipl,
-                   output=[tmpA2, tmpC3], method=["sum", "count"], size=wz)
-    # create pf map
-    if user_pf:
-        pf = user_pf
-    else:
-        pf = tmpname('tmpA03_')
-    gs.mapcalc("$pf = if( $ipl >=0, float($tmpA2) / float($tmpC3))",
-               ipl=ipl, pf=pf, tmpA2=tmpA2, tmpC3=tmpC3)
-    # computing pff values
-    gs.info(_("Step 2: Computing Pff values..."))
-    # Considering pairs of pixels in cardinal directions in
-    # a 3x3 window, the total number of adjacent pixel pairs is 12.
-    # Assuming that x pairs include at least one forested pixel, and
-    # y of those pairs are forest-forest pairs, so pff equals y/x.
-    # create copy of forest map and convert NULL to 0 (if any)
-    tmpC4 = tmpname('tmpA04_')
-    gs.run_command("g.copy", raster=[ipl, tmpC4], quiet=True)
-    gs.run_command("r.null", map=tmpC4, null=0, quiet=True)
-    # window dimensions
-    max_index = int((wz - 1) / 2)
-    # number of 'forest-forest' pairs
-    expr1 = pairs_expression(map_name=tmpC4, max_index=max_index,
-                             combine_op='&')
-    # number of 'nonforest-forest' pairs
-    expr2 = pairs_expression(map_name=tmpC4, max_index=max_index,
-                             combine_op='|')
-    # create pff map
-    if user_pff:
-        pff = user_pff
-    else:
-        pff = tmpname('tmpA07_')
-    # potentially this can be split and parallelized
-    gs.mapcalc("$pff = if($ipl >= 0, float($tmpl4) / float($tmpl5))",
-               ipl=ipl, tmpl4=expr1, tmpl5=expr2, pff=pff)
-    # computing fragmentation index
-    # (a b) name, condition
-    # where a is a number used by Riitters et al. in ERRATUM (2)
-    # and b is a number used in the sh script by Sambale and Sylla
-    # b also defines 0 for non-forested which is consistent with input
-    # (1 1) edge, if Pf > 0.6 and Pf - Pff < 0
-    # (2 6) undetermined, if Pf > 0.6 and Pf = Pff
-    # (3 4) perforated, if Pf > 0.6 and Pf - Pff > 0
-    # (4 5) interior, if Pf = 1.0
-    # (5 1) patch, if Pf < 0.4
-    # (6 2) transitional, if 0.4 < Pf < 0.6
-    gs.info(_("Step 3: Computing fragmentation index..."))
-    if clip_output:
-        indexfin2 = tmpname('tmpA16_')
-    else:
-        indexfin2 = opl
-    gs.mapcalc(
-        "eval("
-        "dpf = $pf - $pff,"
-        # individual classes
-        "patch = if($pf < 0.4, 1, 0),"
-        "transitional = if($pf >= 0.4 && $pf < 0.6, 2, 0),"
-        "edge = if($pf >= 0.6 && dpf<0,3,0),"
-        "perforated = if($pf > 0.6 && $pf < 1 && dpf > 0, 4, 0),"
-        "interior = if($pf == 1, 5, 0),"
-        "undetermined = if($pf > 0.6 && $pf < 1 && dpf == 0, 6, 0),"
-        # null is considered as non-forest and we need to do it before +
-        "patch = if(isnull(patch), 0, patch),"
-        "transitional = if(isnull(transitional), 0, transitional),"
-        "edge = if(isnull(edge), 0, edge),"
-        "perforated = if(isnull(perforated), 0, perforated),"
-        "interior = if(isnull(interior), 0, interior),"
-        "undetermined = if(isnull(undetermined), 0, undetermined),"
-        # combine classes (they don't overlap)
-        # more readable than nested ifs from the ifs above
-        "all = patch + transitional + edge + perforated + interior"
-        " + undetermined"
-        ")\n"
-        # mask result by non-forest (according to the input)
-        # removes the nonsense data created in the non-forested areas
-        "$out = all * $binary_forest",
-        out=indexfin2, binary_forest=ipl, pf=pf, pff=pff)
-    # shrink the region
-    if clip_output:
-        gs.use_temp_region()
-        reginfo = gs.parse_command("g.region", flags="gp")
-        nscor = max_index * float(reginfo['nsres'])
-        ewcor = max_index * float(reginfo['ewres'])
-        gs.run_command("g.region",
-                       n=float(reginfo['n']) - nscor,
-                       s=float(reginfo['s']) + nscor,
-                       e=float(reginfo['e']) - ewcor,
-                       w=float(reginfo['w']) + ewcor,
-                       quiet=True)
-        gs.mapcalc("$opl = $if3", opl=opl, if3=indexfin2, quiet=True)
-    # create categories
-    # TODO: parametrize classes (also in r.mapcalc, r.colors and desc)?
-    # TODO: translatable labels?
-    labels = LABELS
-    gs.write_command("r.category", quiet=True, map=opl,
-                     rules='-', stdin=labels, separator='space')
-    # create color table
-    colors = COLORS_SAMBALE
-    gs.write_command("r.colors", map=opl, rules='-',
-                     stdin=colors, quiet=True)
-    # write metadata for main layer
-    gs.run_command("r.support", map=opl,
-                   title="Forest fragmentation",
-                   source1="Based on %s" % ipl,
-                   description="Forest fragmentation index (6 classes)")
-    gs.raster_history(opl)
-    # write metadata for intermediate layers
-    if user_pf:
-        # pf layer
-        gs.run_command("r.support", map=pf,
-                       title="Proportion forested",
-                       units="Proportion",
-                       description="Proportion of pixels in the moving"
-                                   " window that is forested")
-        gs.raster_history(pf)
-    if user_pff:
-        # pff layer
-        unused, tmphist = tempfile.mkstemp()
-        text_file = open(tmphist, "w")
-        long_description = """\
-Proportion of all adjacent (cardinal directions only) pixel pairs that
-include at least one forest pixel for which both pixels are forested.
-It thus (roughly) estimates the conditional probability that, given a
-pixel of forest, its neighbor is also forest.
-        text_file.write(long_description)
-        text_file.close()
-        gs.run_command("r.support", map=pff,
-                       title="Conditional probability neighboring cell"
-                             " is forest",
-                       description="Probability neighbor of forest cell"
-                                   " is forest",
-                       loadhistory=tmphist)
-        gs.raster_history(pff)
-        os.remove(tmphist)
-    # report fragmentation index and names of layers created
-    if flag_s:
-        gs.run_command("r.report", map=opl, units=["h", "p"],
-                       flags="n", page_width=50, quiet=True)
-    gs.info(_("The following layers were created"))
-    gs.info(_("The fragmentation index: %s") % opl)
-    if user_pf:
-        gs.info(_("The proportion forested (pf): %s") % pf)
-    if user_pff:
-        gs.info(_("The proportion forested pixel pairs (pff): %s") % pff)
-if __name__ == "__main__":
-    atexit.register(cleanup)
-    sys.exit(main(*gs.parser()))
Copied: grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html (from rev 69601, grass-addons/grass7/raster/r.forestfrag/r.forestfrag.html)
--- grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html	2016-11-20 03:56:15 UTC (rev 69853)
@@ -0,0 +1,117 @@
+<h2>DESCRIPTION</h2>
+<em>r.forestfrag</em> Computes the forest fragmentation following
+the methodology proposed by Riitters et al. (2000). See
+<a href="http://www.consecol.org/vol4/iss2/art3/">this article</a> for a
+detailed explanation.
+<p>It follows a "sliding window" algorithm with overlapping windows.
+The amount of forest and its occurence as adjacent forest pixels
+within fixed- area "moving-windows" surrounding each forest pixel is
+measured. The window size is user-defined. The result is stored at
+the location of the center pixel. Thus, a pixel value in the derived
+map refers to "between-pixel" fragmentation around the corresponding
+forest location.
+<p>As input it requires a binary map with (1) forest and (0)
+non-forest. Obviously, one can replace forest any other land cover
+type. If one wants to exclude the influence of a specific land cover
+type, e.g., water bodies, it should be classified as no-data (NA) in
+the input map. See e.g.,
+<a href="https://pvanb.wordpress.com/2016/03/25/update-of-r-forestfrag-addon/">blog post</a>.
+<p>Let <em>Pf</em> be the proportion of pixels in the window that
+are forested. Define <em>Pff</em> (strictly) as the proportion of
+all adjacent (cardinal directions only) pixel pairs that include at
+least one forest pixel, for which both pixels are forested. <em>Pff</em>
+ thus (roughly) estimates the conditional probability that,
+given a pixel of forest, its neighbor is also forest. The
+classification model then identifies six fragmentation categories as:
+<div class="code"><pre>
+interior:       Pf = 1.0
+patch:          Pf < 0.4
+transitional:   0.4 ≤ Pf < 0.6
+edge:           Pf ≥ 0.6 and Pf - Pff < 0
+perforated:     Pf ≥ 0.6 and Pf - Pff > 0
+undetermined:   Pf ≥ 0.6 and Pf = Pff
+</pre></div>
+<h2>NOTES</h2>
+<ul>
+<li>The moving window size is user-defined (default=3)
+and must be an odd number. If an even number is given the function
+will stop with an error message.
+<li>No-data cells are ignored. This means that statistics at the
+raster edges are based on fewer cells (smaller) moving windows. If this
+is a problem, the user can choose to have the output raster trimmed
+with a number of raster cells equal to 1/2 * the size of the moving
+window.
+<li>The function respects the region. The user has however the option
+to set the region to match the input layer.
+</ul>
+<h2>EXAMPLE</h2>
+In the North Carolina sample Location, set the computational region
+to match the land classification raster map:
+g.region raster=landclass96
+</pre></div>
+Then mark all cells which are forest as 1 and everything else as zero:
+r.mapcalc "forest = if(landclass96 == 5, 1, 0)"
+</pre></div>
+Use the new forest presence raster map to compute the forest
+fragmentation index with window size 7:
+r.forestfrag input=forest output=fragmentation window=7
+</pre></div>
+<center>
+<img src="r_forestfrag_window_7.png" alt="r.forestfrag output with window size 7">
+<img src="r_forestfrag_window_11.png" alt="r.forestfrag output with window size 11">
+<p><em>
+Two forest fragmentation indices with window size 7 (left) and
+11 (right) show how increasing window size increases the amount of
+edges.
+</em></p>
+</center>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.li.html">r.li</a>
+</em>
+<p>
+The addon is based on the
+<a href="https://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.forestfrag">
+r.forestfrag.sh</a> script, with as extra options user-defined
+moving window size, option to trim the region (by default it
+respects the region) and a better handling of no-data cells.
+<h2>AUTHORS</h2>
+<em>Paulo van Breugel</em>: Rewritten in Python, added option to set
+moving window size, and improved handling no-data cells<br>
+<em>Stefan Sylla</em>: Revised / updated the r.forestfrag.sh for
+GRASS GIS 6<br>
+<em>Emmanuel Sambale</em>: Author original shell script
+<h2>REFERENCES</h2>
+Riitters, K., J. Wickham, R. O'Neill, B. Jones,
+and E. Smith. 2000. Global-scale patterns of forest fragmentation.
+Conservation Ecology 4(2): 3. [online] URL:
+<a href="http://www.consecol.org/vol4/iss2/art3/">http://www.consecol.org/vol4/iss2/art3/</a>
+<p><i>Last changed: $Date$</i>
Copied: grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py (from rev 69852, grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py)
--- grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py	2016-11-20 03:56:15 UTC (rev 69853)
@@ -0,0 +1,420 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:    r.forestfrag
+# AUTHOR(S): Emmanuel Sambale (original shell version)
+#            Stefan Sylla (original shell version)
+#            Paulo van Breugel (Python version, paulo at ecodiv.org)
+#            Vaclav Petras (major code clean up, wenzeslaus gmail com)
+# PURPOSE:   Creates forest fragmentation index map from a
+#            forest-non-forest raster; The index map is based on
+#            Riitters, K., J. Wickham, R. O'Neill, B. Jones, and
+#            E. Smith. 2000. in: Global-scalepatterns of forest
+#            fragmentation. Conservation Ecology 4(2): 3. [online]
+#            URL: http://www.consecol.org/vol4/iss2/art3/
+# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
+#            This program is free software under the GNU General Public
+#            License (>=v2). Read the file COPYING that comes with GRASS
+#            for details.
+#%module
+#% description: Computes the forest fragmentation index (Riitters et al. 2000)
+#% keyword: raster
+#% keyword: landscape structure analysis
+#% keyword: forest
+#% keyword: fragmentation index
+#% keyword: Riitters
+#%end
+#%option G_OPT_R_INPUT
+#% description: Name of forest raster map (where forest=1, non-forest=0)
+#% required: yes
+#%end
+#%option G_OPT_R_OUTPUT
+#% required: yes
+#%end
+#%option
+#% key: size
+#% type: integer
+#% description: Moving window size (odd number)
+#% key_desc: number
+#% options: 3-
+#% answer : 3
+#% required: no
+#%end
+#% key: pf
+#% label: Name for output Pf (forest area density) raster map
+#% description: Proportion of area which is forested (amount of forest)
+#% required: no
+#%end
+#% key: pff
+#% label: Name for output Pff (forest connectivity) raster map
+#% description: Conditional probability that neighboring cell is forest
+#% required: no
+#%end
+#%flag
+#% key: r
+#% description: Set computational region to input raster map
+#%end
+#%flag
+#% key: t
+#% description: Keep Pf and Pff maps
+#%end
+#%flag
+#% key: s
+#% description: Run r.report on output map
+#%end
+#%flag
+#% key: a
+#% description: Trim the output map to avoid border effects
+#%end
+#%option
+#% key: window
+#% type: integer
+#% label: This option is deprecated, use the option size instead
+#% options: 3-
+#% required: no
+#%end
+import os
+import sys
+import uuid
+import atexit
+import tempfile
+import string
+import grass.script as gs
+# neutral naming for better compatibility between 2D and 3D version
+from grass.script.raster import mapcalc
+LABELS = """\
+0 exterior
+1 patch
+2 transitional
+3 edge
+4 perforated
+5 interior
+6 undetermined
+COLORS_SAMBALE = """\
+0 255:255:0
+1 215:48:39
+2 252:141:89
+3 254:224:139
+4 217:239:139
+5 26:152:80
+6 145:207:96
+# create set to store names of temporary maps to be deleted upon exit
+CLEAN_RAST = []
+def cleanup():
+    """Remove temporary maps specified in the global list"""
+    cleanrast = list(reversed(CLEAN_RAST))
+    for rast in cleanrast:
+        gs.run_command("g.remove", flags="f", type="raster", name=rast,
+                       quiet=True)
+def raster_exists(name):
+    """Check if the raster map exists, call GRASS fatal otherwise"""
+    ffile = gs.find_file(name, element='cell')
+    if not ffile['fullname']:
+        gs.fatal(_("Raster map <%s> not found") % name)
+def tmpname(prefix):
+    """Generate a tmp name which conatins prefix
+    Store the name in the global list.
+    Use only for raster maps.
+    tmpf = prefix + str(uuid.uuid4())
+    tmpf = string.replace(tmpf, '-', '_')
+    CLEAN_RAST.append(tmpf)
+    return tmpf
+def pairs_expression(map_name, max_index, combine_op, aggregate_op="+"):
+    """Generate window (matrix) expression
+    :param map_name: name of the map to index
+    :param max_index: the maximum positive index to use;
+                      usually (window_size - 1) / 2
+    :param combine_op: operator used to combine values in the pair
+    :param aggregate_op: operator used to combine all pairs together
+    s = max_index  # just to be brief
+    base_expr = "({m}[{a},{b}] {o} {m}[{c},{d}])"
+    expr = []
+    for j in range(-s, s + 1):
+        for i in range(-s, s):
+            expr.append(base_expr.format(
+                m=map_name, o=combine_op, a=i, b=j, c=i + 1, d=j))
+    for i in range(-s, s + 1):
+        for j in range(-s, s):
+                m=map_name, o=combine_op, a=i, b=j, c=i, d=j + 1))
+    return aggregate_op.join(expr)
+def main(options, flags):
+    # options and flags into variables
+    ipl = options['input']
+    raster_exists(ipl)
+    opl = options['output']
+    # size option backwards compatibility with window
+    if not options['size'] and not options['window']:
+        gs.fatal(_("Required parameter <%s> not set") % 'size')
+    if options['size']:
+        wz = int(options['size'])
+    if options['window']:
+        gs.warning(_("The window option is deprecated, use the option"
+                     " size instead"))
+        wz = int(options['window'])
+    if options['size'] and options['size'] != '3' and options['window']:
+        gs.warning(_("When the obsolete window option is used, the"
+                     " new size option is ignored"))
+    if wz % 2 == 0:
+        gs.fatal(_("Please provide an odd number for the moving"
+                   " window size, not %d") % wz)
+    # user wants pf or pff
+    user_pf = options['pf']
+    user_pff = options['pff']
+    # backwards compatibility
+    if flags['t']:
+        gs.warning(_("The -t flag is deprecated, use pf and pff options"
+                     " instead"))
+    if not user_pf and not user_pff and flags['t']:
+        user_pf = opl + '_pf'
+        user_pff = opl + '_pff'
+    elif flags['t']:
+        gs.warning(_("When pf or pff option is used, the -t flag"
+                     " is ignored"))
+    flag_r = flags['r']
+    flag_s = flags['s']
+    clip_output = flags['a']
+    # set to current input map region if requested by the user
+    # default is (and should be) the current region
+    # we could use tmp region for this but if the flag is there
+    # it makes sense to use it from now on (but we should reconsider)
+    if flag_r:
+        gs.message(_("Setting region to input map..."))
+        gs.run_command('g.region', raster=ipl, quiet=True)
+    # check if map values are limited to 1 and 0
+    input_info = gs.raster_info(ipl)
+    # we know what we are doing only when input is integer
+    if input_info['datatype'] != 'CELL':
+        gs.fatal(_("The input raster map must have type CELL"
+                   " (integer)"))
+    # for integer, we just need to text min and max
+    if input_info['min'] != 0 or input_info['max'] != 1:
+        gs.fatal(_("The input raster map must be a binary raster,"
+                   " i.e. it should contain only values 0 and 1"
+                   " (now the minimum is %d and maximum is %d)")
+                 % (input_info['min'], input_info['max']))
+    # computing pf values
+    # let forested pixels be x and number of all pixels in moving window
+    # be y, then pf=x/y"
+    gs.info(_("Step 1: Computing Pf values..."))
+    # generate grid with pixel-value=number of forest-pixels in window
+    # generate grid with pixel-value=number of pixels in moving window:
+    tmpA2 = tmpname('tmpA01_')
+    tmpC3 = tmpname('tmpA02_')
+    gs.run_command("r.neighbors", quiet=True, input=ipl,
+                   output=[tmpA2, tmpC3], method=["sum", "count"], size=wz)
+    # create pf map
+    if user_pf:
+        pf = user_pf
+    else:
+        pf = tmpname('tmpA03_')
+    mapcalc("$pf = if( $ipl >=0, float($tmpA2) / float($tmpC3))",
+            ipl=ipl, pf=pf, tmpA2=tmpA2, tmpC3=tmpC3)
+    # computing pff values
+    # Considering pairs of pixels in cardinal directions in
+    # a 3x3 window, the total number of adjacent pixel pairs is 12.
+    # Assuming that x pairs include at least one forested pixel, and
+    # y of those pairs are forest-forest pairs, so pff equals y/x.
+    gs.info(_("Step 2: Computing Pff values..."))
+    # create copy of forest map and convert NULL to 0 (if any)
+    tmpC4 = tmpname('tmpA04_')
+    gs.run_command("g.copy", raster=[ipl, tmpC4], quiet=True)
+    gs.run_command("r.null", map=tmpC4, null=0, quiet=True)
+    # window dimensions
+    max_index = int((wz - 1) / 2)
+    # number of 'forest-forest' pairs
+    expr1 = pairs_expression(map_name=tmpC4, max_index=max_index,
+                             combine_op='&')
+    # number of 'nonforest-forest' pairs
+    expr2 = pairs_expression(map_name=tmpC4, max_index=max_index,
+                             combine_op='|')
+    # create pff map
+    if user_pff:
+        pff = user_pff
+    else:
+        pff = tmpname('tmpA07_')
+    # potentially this can be split and parallelized
+    mapcalc("$pff = if($ipl >= 0, float($tmpl4) / float($tmpl5))",
+            ipl=ipl, tmpl4=expr1, tmpl5=expr2, pff=pff)
+    # computing fragmentation index
+    # (a b) name, condition
+    # where a is a number used by Riitters et al. in ERRATUM (2)
+    # and b is a number used in the sh script by Sambale and Sylla
+    # b also defines 0 for non-forested which is consistent with input
+    # (1 3) edge, if Pf > 0.6 and Pf - Pff < 0
+    # (2 6) undetermined, if Pf > 0.6 and Pf = Pff
+    # (3 4) perforated, if Pf > 0.6 and Pf - Pff > 0
+    # (4 5) interior, if Pf = 1.0
+    # (5 1) patch, if Pf < 0.4
+    # (6 2) transitional, if 0.4 < Pf < 0.6
+    gs.info(_("Step 3: Computing fragmentation index..."))
+    if clip_output:
+        indexfin2 = tmpname('tmpA16_')
+    else:
+        indexfin2 = opl
+    mapcalc(
+        "eval("
+        "dpf = $pf - $pff,"
+        # individual classes
+        "patch = if($pf < 0.4, 1, 0),"
+        "transitional = if($pf >= 0.4 && $pf < 0.6, 2, 0),"
+        "edge = if($pf >= 0.6 && dpf<0,3,0),"
+        "perforated = if($pf > 0.6 && $pf < 1 && dpf > 0, 4, 0),"
+        "interior = if($pf == 1, 5, 0),"
+        "undetermined = if($pf > 0.6 && $pf < 1 && dpf == 0, 6, 0),"
+        # null is considered as non-forest and we need to do it before +
+        "patch = if(isnull(patch), 0, patch),"
+        "transitional = if(isnull(transitional), 0, transitional),"
+        "edge = if(isnull(edge), 0, edge),"
+        "perforated = if(isnull(perforated), 0, perforated),"
+        "interior = if(isnull(interior), 0, interior),"
+        "undetermined = if(isnull(undetermined), 0, undetermined),"
+        # combine classes (they don't overlap)
+        # more readable than nested ifs from the ifs above
+        "all = patch + transitional + edge + perforated + interior"
+        " + undetermined"
+        ")\n"
+        # mask result by non-forest (according to the input)
+        # removes the nonsense data created in the non-forested areas
+        "$out = all * $binary_forest",
+        out=indexfin2, binary_forest=ipl, pf=pf, pff=pff)
+    # shrink the region
+    if clip_output:
+        gs.use_temp_region()
+        reginfo = gs.parse_command("g.region", flags="gp")
+        nscor = max_index * float(reginfo['nsres'])
+        ewcor = max_index * float(reginfo['ewres'])
+        gs.run_command("g.region",
+                       n=float(reginfo['n']) - nscor,
+                       s=float(reginfo['s']) + nscor,
+                       e=float(reginfo['e']) - ewcor,
+                       w=float(reginfo['w']) + ewcor,
+                       quiet=True)
+        mapcalc("$opl = $if3", opl=opl, if3=indexfin2, quiet=True)
+    # create categories
+    # TODO: parametrize classes (also in r.mapcalc, r.colors and desc)?
+    # TODO: translatable labels?
+    labels = LABELS
+    gs.write_command("r.category", quiet=True, map=opl,
+                     rules='-', stdin=labels, separator='space')
+    # create color table
+    colors = COLORS_SAMBALE
+    gs.write_command("r.colors", map=opl, rules='-',
+                     stdin=colors, quiet=True)
+    # write metadata for main layer
+    gs.run_command("r.support", map=opl,
+                   title="Forest fragmentation",
+                   source1="Based on %s" % ipl,
+                   description="Forest fragmentation index (6 classes)")
+    gs.raster_history(opl)
+    # write metadata for intermediate layers
+    if user_pf:
+        # pf layer
+        gs.run_command("r.support", map=pf,
+                       title="Proportion forested",
+                       units="Proportion",
+                       description="Proportion of pixels in the moving"
+                                   " window that is forested")
+        gs.raster_history(pf)
+    if user_pff:
+        # pff layer
+        unused, tmphist = tempfile.mkstemp()
+        text_file = open(tmphist, "w")
+        long_description = """\
+Proportion of all adjacent (cardinal directions only) pixel pairs that
+include at least one forest pixel for which both pixels are forested.
+It thus (roughly) estimates the conditional probability that, given a
+pixel of forest, its neighbor is also forest.
+        text_file.write(long_description)
+        text_file.close()
+        gs.run_command("r.support", map=pff,
+                       title="Conditional probability neighboring cell"
+                             " is forest",
+                       description="Probability neighbor of forest cell"
+                                   " is forest",
+                       loadhistory=tmphist)
+        gs.raster_history(pff)
+        os.remove(tmphist)
+    # report fragmentation index and names of layers created
+    if flag_s:
+        gs.run_command("r.report", map=opl, units=["h", "p"],
+                       flags="n", page_width=50, quiet=True)
+    gs.info(_("The following layers were created"))
+    gs.info(_("The fragmentation index: %s") % opl)
+    if user_pf:
+        gs.info(_("The proportion forested (Pf): %s") % pf)
+    if user_pff:
+        gs.info(_("The proportion forested pixel pairs (Pff): %s") % pff)
+if __name__ == "__main__":
+    atexit.register(cleanup)
+    sys.exit(main(*gs.parser()))
Deleted: grass-addons/grass7/raster3d/r3.forestfrag/r_forestfrag_window_11.png
(Binary files differ)
Deleted: grass-addons/grass7/raster3d/r3.forestfrag/r_forestfrag_window_7.png
