[GRASS-SVN] r69855 - in grass-addons/grass7/raster3d: . r3.forestfrag r3.forestfrag/testsuite
svn_grass at osgeo.org
Sun Nov 20 14:11:34 PST 2016
Author: wenzeslaus
Date: 2016-11-20 14:11:34 -0800 (Sun, 20 Nov 2016)
New Revision: 69855
Added:
grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r3_forestfrag_trivial.py
Removed:
grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_ncspm.py
grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_trivial.py
grass-addons/grass7/raster3d/Makefile
grass-addons/grass7/raster3d/r3.forestfrag/Makefile
grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html
grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py
grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_xy.py
r3.forestfrag: 3D version of Riitters et al. 2000 forest fragmentation index
Modified: grass-addons/grass7/raster3d/Makefile
--- grass-addons/grass7/raster3d/Makefile 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/Makefile 2016-11-20 22:11:34 UTC (rev 69855)
@@ -2,6 +2,7 @@
SUBDIRS = \
r3.count.categories \
+ r3.r3.forestfrag \
r3.profile \
r3.scatterplot \
r3.what
Modified: grass-addons/grass7/raster3d/r3.forestfrag/Makefile
--- grass-addons/grass7/raster3d/r3.forestfrag/Makefile 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/r3.forestfrag/Makefile 2016-11-20 22:11:34 UTC (rev 69855)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.forestfrag
+PGM = r3.forestfrag
include $(MODULE_TOPDIR)/include/Make/Script.make
Modified: grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html
--- grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.html 2016-11-20 22:11:34 UTC (rev 69855)
@@ -1,7 +1,9 @@
<h2>DESCRIPTION</h2>
+TODO: Create a description specific for 3D version
<em>r.forestfrag</em> Computes the forest fragmentation following
-the methodology proposed by Riitters et al. (2000). See
+the methodology proposed by Riitters et. al (2000). See
<a href="http://www.consecol.org/vol4/iss2/art3/">this article</a> for a
detailed explanation.
@@ -30,10 +32,10 @@
<div class="code"><pre>
interior: Pf = 1.0
-patch: Pf < 0.4
-transitional: 0.4 ≤ Pf < 0.6
-edge: Pf ≥ 0.6 and Pf - Pff < 0
-perforated: Pf ≥ 0.6 and Pf - Pff > 0
+patch: Pf < 0.4
+transitional: 0.4 ≤ Pf < 0.6
+edge: Pf ≥ 0.6 and Pf - Pff < 0
+perforated: Pf ≥ 0.6 and Pf - Pff > 0
undetermined: Pf ≥ 0.6 and Pf = Pff
</pre></div>
@@ -52,61 +54,19 @@
to set the region to match the input layer.
</ul>
-<h2>EXAMPLE</h2>
-In the North Carolina sample Location, set the computational region
-to match the land classification raster map:
-<div class="code"><pre>
-g.region raster=landclass96
-</pre></div>
-Then mark all cells which are forest as 1 and everything else as zero:
-r.mapcalc "forest = if(landclass96 == 5, 1, 0)"
-</pre></div>
-Use the new forest presence raster map to compute the forest
-fragmentation index with window size 7:
-r.forestfrag input=forest output=fragmentation window=7
-</pre></div>
-<center>
-<img src="r_forestfrag_window_7.png" alt="r.forestfrag output with window size 7">
-<img src="r_forestfrag_window_11.png" alt="r.forestfrag output with window size 11">
-<p><em>
-Two forest fragmentation indices with window size 7 (left) and
-11 (right) show how increasing window size increases the amount of
-edges.
-</em></p>
-</center>
<h2>SEE ALSO</h2>
-<em>
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.li.html">r.li</a>
-</em>
-<p>
The addon is based on the
-<a href="https://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.forestfrag">
+<a href="http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.forestfrag>">
r.forestfrag.sh</a> script, with as extra options user-defined
moving window size, option to trim the region (by default it
respects the region) and a better handling of no-data cells.
<h2>AUTHORS</h2>
-<em>Paulo van Breugel</em>: Rewritten in Python, added option to set
-moving window size, and improved handling no-data cells<br>
+<em>Paulo van Breugel<em>: Rewritten in Python, added option to set
+moving window size, and improved handling no-data cells
<em>Stefan Sylla</em>: Revised / updated the r.forestfrag.sh for
GRASS GIS 6<br>
-<em>Emmanuel Sambale</em>: Author original shell script
+<em>Emmanuel Sambale</em>: Author original shell script<br>
<h2>REFERENCES</h2>
Riitters, K., J. Wickham, R. O'Neill, B. Jones,
Modified: grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py
--- grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/r3.forestfrag/r3.forestfrag.py 2016-11-20 22:11:34 UTC (rev 69855)
@@ -3,12 +3,12 @@
-# MODULE: r.forestfrag
+# MODULE: r3.forestfrag
-# AUTHOR(S): Emmanuel Sambale (original shell version)
+# AUTHOR(S): Vaclav Petras (based on r.forestfrag, wenzeslaus gmail com)
+# Emmanuel Sambale (original shell version)
# Stefan Sylla (original shell version)
# Paulo van Breugel (Python version, paulo at ecodiv.org)
-# Vaclav Petras (major code clean up, wenzeslaus gmail com)
# PURPOSE: Creates forest fragmentation index map from a
# forest-non-forest raster; The index map is based on
@@ -27,19 +27,20 @@
#%module
#% description: Computes the forest fragmentation index (Riitters et al. 2000)
-#% keyword: raster
+#% keyword: raster3d
#% keyword: landscape structure analysis
+#% keyword: vegetation structure analysis
#% keyword: forest
#% keyword: fragmentation index
#% keyword: Riitters
#%end
-#%option G_OPT_R_INPUT
+#%option G_OPT_R3_INPUT
#% description: Name of forest raster map (where forest=1, non-forest=0)
#% required: yes
#%end
-#%option G_OPT_R_OUTPUT
+#%option G_OPT_R3_OUTPUT
#% required: yes
#%end
@@ -50,7 +51,7 @@
#% key_desc: number
#% options: 3-
#% answer : 3
-#% required: no
+#% required: yes
#%end
@@ -67,6 +68,39 @@
#% required: no
#%end
+#%option
+#% key: transitional_limit
+#% type: double
+#% description: transitional_limit
+#% answer: 0.6
+#% required: yes
+#%end
+#%option
+#% key: patch_limit
+#% type: double
+#% description: patch_limit
+#% answer: 0.4
+#% required: yes
+#%end
+#%option
+#% key: interior_limit
+#% type: double
+#% description: interior_limit
+#%end
+#%option
+#% key: color
+#% type: string
+#% label: Source raster for colorization
+#% description: Input and color_input are taken from input and color_input options respectively. The rest is computed using r.slope.aspect
+#% required: no
+#% options: sambale,riitters,perceptual
+#% descriptions: sambale;Sambale, Stefan Sylla;riitters; Riitters et. al 2000;perceptual;Perceptually uniform
+#% answer: sambale
+#%end
#%flag
#% key: r
#% description: Set computational region to input raster map
@@ -87,13 +121,6 @@
#% description: Trim the output map to avoid border effects
#%end
-#%option
-#% key: window
-#% type: integer
-#% label: This option is deprecated, use the option size instead
-#% options: 3-
-#% required: no
-#%end
import os
import sys
@@ -102,20 +129,10 @@
import tempfile
import string
import grass.script as gs
-# neutral naming for better compatibility between 2D and 3D version
-from grass.script.raster import mapcalc
+# neutral naming for better compatibility with 2D version
+from grass.script.raster3d import mapcalc3d as mapcalc
-LABELS = """\
-0 exterior
-1 patch
-2 transitional
-3 edge
-4 perforated
-5 interior
-6 undetermined
COLORS_SAMBALE = """\
0 255:255:0
1 215:48:39
@@ -126,6 +143,37 @@
6 145:207:96
+COLORS_RIITTERS = """\
+0 255:255:255
+1 34:34:220
+2 153:204:255
+3 255:153:102
+4 255:255:102
+5 34:255:34
+6 230:255:0
+COLORS_PERCEPTUAL = """\
+0 245:244:68
+1 35:60:37
+2 172:92:80
+3 192:126:73
+4 157:182:90
+5 107:214:72
+6 195:233:82
+COLORS_PERCEPTUAL_WHITE = """\
+0 255:255:255
+1 172:92:80
+2 192:126:73
+3 157:182:90
+4 245:244:68
+5 107:214:72
+6 195:233:82
# create set to store names of temporary maps to be deleted upon exit
CLEAN_RAST = []
@@ -134,13 +182,13 @@
"""Remove temporary maps specified in the global list"""
cleanrast = list(reversed(CLEAN_RAST))
for rast in cleanrast:
- gs.run_command("g.remove", flags="f", type="raster", name=rast,
+ gs.run_command("g.remove", flags="f", type="raster3d", name=rast,
quiet=True)
def raster_exists(name):
"""Check if the raster map exists, call GRASS fatal otherwise"""
- ffile = gs.find_file(name, element='cell')
+ ffile = gs.find_file(name, element='grid3')
if not ffile['fullname']:
gs.fatal(_("Raster map <%s> not found") % name)
@@ -167,16 +215,23 @@
:param aggregate_op: operator used to combine all pairs together
s = max_index # just to be brief
- base_expr = "({m}[{a},{b}] {o} {m}[{c},{d}])"
+ base_expr = "(int({m}[{a},{b},{c}]) {o} int({m}[{d},{e},{f}]))"
expr = []
for j in range(-s, s + 1):
- for i in range(-s, s):
- expr.append(base_expr.format(
- m=map_name, o=combine_op, a=i, b=j, c=i + 1, d=j))
+ for k in range(-s, s + 1):
+ for i in range(-s, s):
+ expr.append(base_expr.format(
+ m=map_name, o=combine_op, a=i, b=j, c=k, d=i + 1, e=j, f=k))
+ for i in range(-s, s + 1):
+ for j in range(-s, s):
+ m=map_name, o=combine_op, a=i, b=j, c=k, d=i, e=j + 1, f=k))
- for j in range(-s, s):
- m=map_name, o=combine_op, a=i, b=j, c=i, d=j + 1))
+ for j in range(-s, s + 1):
+ for k in range(-s, s):
+ m=map_name, o=combine_op, a=i, b=j, c=k, d=i, e=j, f=k + 1))
return aggregate_op.join(expr)
@@ -185,34 +240,29 @@
ipl = options['input']
raster_exists(ipl)
opl = options['output']
- # size option backwards compatibility with window
- if not options['size'] and not options['window']:
- gs.fatal(_("Required parameter <%s> not set") % 'size')
- if options['size']:
- wz = int(options['size'])
- if options['window']:
- gs.warning(_("The window option is deprecated, use the option"
- " size instead"))
- wz = int(options['window'])
- if options['size'] and options['size'] != '3' and options['window']:
- gs.warning(_("When the obsolete window option is used, the"
- " new size option is ignored"))
- if wz % 2 == 0:
- gs.fatal(_("Please provide an odd number for the moving"
- " window size, not %d") % wz)
+ size = int(options['size'])
+ if size % 2 == 0:
+ gs.fatal("Please provide an odd number for the moving window")
+ transitional_limit = float(options['transitional_limit'])
+ patch_limit = float(options['patch_limit'])
+ if patch_limit >= transitional_limit:
+ gs.fatal("Patch limit must be lower than transitional limit")
+ if options['interior_limit']:
+ interior_limit = float(options['interior_limit'])
+ else:
+ # we choose high value just to be sure
+ float_epsilon = 2.0e-06
+ interior_limit = float_epsilon
+ if 1 - transitional_limit <= interior_limit:
+ gs.fatal("Interior tolerance is too high or transitional limit is too high")
+ # TODO: set those using flags
+ interior_upper_test = False
+ interior_circle_test = True
+ interior_limit = "{:.7f}".format(interior_limit)
# user wants pf or pff
user_pf = options['pf']
user_pff = options['pff']
- # backwards compatibility
- if flags['t']:
- gs.warning(_("The -t flag is deprecated, use pf and pff options"
- " instead"))
- if not user_pf and not user_pff and flags['t']:
- user_pf = opl + '_pf'
- user_pff = opl + '_pff'
- elif flags['t']:
- gs.warning(_("When pf or pff option is used, the -t flag"
- " is ignored"))
flag_r = flags['r']
flag_s = flags['s']
clip_output = flags['a']
@@ -223,20 +273,9 @@
# it makes sense to use it from now on (but we should reconsider)
if flag_r:
gs.message(_("Setting region to input map..."))
- gs.run_command('g.region', raster=ipl, quiet=True)
+ gs.run_command('g.region', raster3d=ipl, quiet=True)
- # check if map values are limited to 1 and 0
- input_info = gs.raster_info(ipl)
- # we know what we are doing only when input is integer
- if input_info['datatype'] != 'CELL':
- gs.fatal(_("The input raster map must have type CELL"
- " (integer)"))
- # for integer, we just need to text min and max
- if input_info['min'] != 0 or input_info['max'] != 1:
- gs.fatal(_("The input raster map must be a binary raster,"
- " i.e. it should contain only values 0 and 1"
- " (now the minimum is %d and maximum is %d)")
- % (input_info['min'], input_info['max']))
+ # TODO: check if map values are limited to 1 and 0
# computing pf values
# let forested pixels be x and number of all pixels in moving window
@@ -244,20 +283,13 @@
gs.info(_("Step 1: Computing Pf values..."))
- # generate grid with pixel-value=number of forest-pixels in window
- # generate grid with pixel-value=number of pixels in moving window:
- tmpA2 = tmpname('tmpA01_')
- tmpC3 = tmpname('tmpA02_')
- gs.run_command("r.neighbors", quiet=True, input=ipl,
- output=[tmpA2, tmpC3], method=["sum", "count"], size=wz)
# create pf map
if user_pf:
pf = user_pf
else:
pf = tmpname('tmpA03_')
- mapcalc("$pf = if( $ipl >=0, float($tmpA2) / float($tmpC3))",
- ipl=ipl, pf=pf, tmpA2=tmpA2, tmpC3=tmpC3)
+ gs.run_command("r3.neighbors", input=ipl, output=pf,
+ method="average", window=(size, size, size))
# computing pff values
# Considering pairs of pixels in cardinal directions in
@@ -269,11 +301,11 @@
# create copy of forest map and convert NULL to 0 (if any)
tmpC4 = tmpname('tmpA04_')
- gs.run_command("g.copy", raster=[ipl, tmpC4], quiet=True)
- gs.run_command("r.null", map=tmpC4, null=0, quiet=True)
+ gs.run_command("g.copy", raster3d=[ipl, tmpC4], quiet=True)
+ gs.run_command("r3.null", map=tmpC4, null=0, quiet=True)
# window dimensions
- max_index = int((wz - 1) / 2)
+ max_index = int((size - 1) / 2)
# number of 'forest-forest' pairs
expr1 = pairs_expression(map_name=tmpC4, max_index=max_index,
combine_op='&')
@@ -285,9 +317,8 @@
pff = user_pff
else:
pff = tmpname('tmpA07_')
- # potentially this can be split and parallelized
- mapcalc("$pff = if($ipl >= 0, float($tmpl4) / float($tmpl5))",
- ipl=ipl, tmpl4=expr1, tmpl5=expr2, pff=pff)
+ mapcalc("$pff = float($e1) / float($e2)",
+ pff=pff, e1=expr1, e2=expr2)
# computing fragmentation index
# (a b) name, condition
@@ -303,20 +334,30 @@
gs.info(_("Step 3: Computing fragmentation index..."))
+ # equation for the interior
+ if interior_upper_test:
+ # using abs just be be sure in case floating pf goes little bit over 1
+ interior_eq = "abs($pf - 1) < $in_limit"
+ elif interior_circle_test:
+ interior_eq = "($pff - 1)^2 + ($pf - 1)^2 < $in_limit^2"
+ else:
+ interior_eq = "$pf == 1"
if clip_output:
indexfin2 = tmpname('tmpA16_')
else:
indexfin2 = opl
- mapcalc(
+ expression = (
"eval("
"dpf = $pf - $pff,"
+ "inter = " + interior_eq + "," # using plus to avoid formating twice
# individual classes
- "patch = if($pf < 0.4, 1, 0),"
- "transitional = if($pf >= 0.4 && $pf < 0.6, 2, 0),"
- "edge = if($pf >= 0.6 && dpf<0,3,0),"
- "perforated = if($pf > 0.6 && $pf < 1 && dpf > 0, 4, 0),"
- "interior = if($pf == 1, 5, 0),"
- "undetermined = if($pf > 0.6 && $pf < 1 && dpf == 0, 6, 0),"
+ "patch = if($pf < $pa_limit, 1, 0),"
+ "transitional = if($pf >= $pa_limit && $pf < $tr_limit, 2, 0),"
+ "edge = if($pf >= $tr_limit && not(inter) && dpf < 0, 3, 0),"
+ "perforated = if($pf > $tr_limit && not(inter) && dpf > 0, 4, 0),"
+ "interior = if(inter, 5, 0)," # TODO: we could skip this
+ "undetermined = if($pf > $tr_limit && not(inter) && dpf == 0, 6, 0),"
# null is considered as non-forest and we need to do it before +
"patch = if(isnull(patch), 0, patch),"
"transitional = if(isnull(transitional), 0, transitional),"
@@ -331,82 +372,25 @@
")\n"
# mask result by non-forest (according to the input)
# removes the nonsense data created in the non-forested areas
- "$out = all * $binary_forest",
- out=indexfin2, binary_forest=ipl, pf=pf, pff=pff)
+ "$out = all * $binary_forest")
+ gs.debug(expression)
+ mapcalc(expression,
+ out=indexfin2, binary_forest=ipl, pf=pf, pff=pff,
+ tr_limit=transitional_limit, pa_limit=patch_limit,
+ in_limit=interior_limit)
- # shrink the region
- if clip_output:
- gs.use_temp_region()
- reginfo = gs.parse_command("g.region", flags="gp")
- nscor = max_index * float(reginfo['nsres'])
- ewcor = max_index * float(reginfo['ewres'])
- gs.run_command("g.region",
- n=float(reginfo['n']) - nscor,
- s=float(reginfo['s']) + nscor,
- e=float(reginfo['e']) - ewcor,
- w=float(reginfo['w']) + ewcor,
- quiet=True)
- mapcalc("$opl = $if3", opl=opl, if3=indexfin2, quiet=True)
+ # TODO: create categories
- # create categories
- # TODO: parametrize classes (also in r.mapcalc, r.colors and desc)?
- # TODO: translatable labels?
- labels = LABELS
- gs.write_command("r.category", quiet=True, map=opl,
- rules='-', stdin=labels, separator='space')
# create color table
- colors = COLORS_SAMBALE
- gs.write_command("r.colors", map=opl, rules='-',
+ if options['color'] == 'riitters':
+ colors = COLORS_RIITTERS
+ if options['color'] == 'perceptual':
+ colors = COLORS_PERCEPTUAL
+ else:
+ colors = COLORS_SAMBALE
+ gs.write_command("r3.colors", map=opl, rules='-',
stdin=colors, quiet=True)
- # write metadata for main layer
- gs.run_command("r.support", map=opl,
- title="Forest fragmentation",
- source1="Based on %s" % ipl,
- description="Forest fragmentation index (6 classes)")
- gs.raster_history(opl)
- # write metadata for intermediate layers
- if user_pf:
- # pf layer
- gs.run_command("r.support", map=pf,
- title="Proportion forested",
- units="Proportion",
- description="Proportion of pixels in the moving"
- " window that is forested")
- gs.raster_history(pf)
- if user_pff:
- # pff layer
- unused, tmphist = tempfile.mkstemp()
- text_file = open(tmphist, "w")
- long_description = """\
-Proportion of all adjacent (cardinal directions only) pixel pairs that
-include at least one forest pixel for which both pixels are forested.
-It thus (roughly) estimates the conditional probability that, given a
-pixel of forest, its neighbor is also forest.
- text_file.write(long_description)
- text_file.close()
- gs.run_command("r.support", map=pff,
- title="Conditional probability neighboring cell"
- " is forest",
- description="Probability neighbor of forest cell"
- " is forest",
- loadhistory=tmphist)
- gs.raster_history(pff)
- os.remove(tmphist)
- # report fragmentation index and names of layers created
- if flag_s:
- gs.run_command("r.report", map=opl, units=["h", "p"],
- flags="n", page_width=50, quiet=True)
gs.info(_("The following layers were created"))
gs.info(_("The fragmentation index: %s") % opl)
if user_pf:
Copied: grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r3_forestfrag_trivial.py (from rev 69853, grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_trivial.py)
--- grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r3_forestfrag_trivial.py (rev 0)
+++ grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r3_forestfrag_trivial.py 2016-11-20 22:11:34 UTC (rev 69855)
@@ -0,0 +1,197 @@
+#!/usr/bin/env python
+# MODULE: r3_forestfrag_trivial
+# AUTHOR: Vaclav Petras
+# PURPOSE: Test using a small example computed by hand
+# COPYRIGHT: (C) 2016 by Vaclav Petras and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+FOREST = """\
+version: grass7
+order: nsbt
+north: 10
+south: 8
+east: 20
+west: 18
+top: 7
+bottom: 5
+rows: 3
+cols: 3
+levels: 3
+1 0 0
+1 0 0
+0 0 0
+1 1 0
+0 1 1
+1 0 1
+0 1 1
+0 0 0
+0 0 0
+# output contains all cells but we check just the middle one
+PF = """\
+version: grass7
+order: nsbt
+north: 10
+south: 8
+east: 20
+west: 18
+top: 7
+bottom: 5
+rows: 3
+cols: 3
+levels: 3
+N N N
+N N N
+N N N
+N N N
+N 0.370 N
+N N N
+N N N
+N N N
+N N N
+PFF = """\
+version: grass7
+order: nsbt
+north: 10
+south: 8
+east: 20
+west: 18
+top: 7
+bottom: 5
+rows: 3
+cols: 3
+levels: 3
+N N N
+N N N
+N N N
+N N N
+N 0.235 N
+N N N
+N N N
+N N N
+N N N
+FRAG = """\
+version: grass7
+order: nsbt
+north: 10
+south: 8
+east: 20
+west: 18
+top: 7
+bottom: 5
+rows: 3
+cols: 3
+levels: 3
+N N N
+N N N
+N N N
+N N N
+N 1 N
+N N N
+N N N
+N N N
+N N N
+class TestForestFragTrivial(TestCase):
+ # TODO: replace by unified handing of maps
+ to_remove = []
+ forest = 'r3ff_test_forest_trivial'
+ forest_frag = 'r3ff_test_forest_frag_trivial'
+ forest_frag_ref = 'r3ff_test_forest_frag_trivial_ref'
+ pf_ref = 'r3ff_test_forest_frag_trivial_ref_pf'
+ pff_ref = 'r3ff_test_forest_frag_trivial_ref_pff'
+ def setUp(self):
+ self.use_temp_region()
+ self.runModule('r3.in.ascii', input='-', stdin_=FOREST,
+ output=self.forest)
+ self.to_remove.append(self.forest)
+ self.runModule('g.region', raster_3d=self.forest)
+ self.runModule('r3.in.ascii', input='-', stdin_=PF,
+ output=self.pf_ref,
+ null_value='N')
+ self.to_remove.append(self.pf_ref)
+ self.runModule('r3.in.ascii', input='-', stdin_=PFF,
+ output=self.pff_ref,
+ null_value='N')
+ self.to_remove.append(self.pff_ref)
+ self.runModule('r3.in.ascii', input='-', stdin_=FRAG,
+ output=self.forest_frag_ref,
+ null_value='N')
+ self.to_remove.append(self.forest_frag_ref)
+ def tearDown(self):
+ self.del_temp_region()
+ if self.to_remove:
+ self.runModule('g.remove', flags='f', type='raster',
+ name=','.join(self.to_remove), verbose=True)
+ def test_simple_window(self):
+ pf = self.forest_frag + '_pf'
+ pff = self.forest_frag + '_pff'
+ self.assertModule('r3.forestfrag', input=self.forest,
+ output=self.forest_frag, size=3,
+ pf=pf, pff=pff, flags='t')
+ self.assertRaster3dExists(self.forest_frag)
+ self.to_remove.append(self.forest_frag)
+ self.assertRaster3dExists(pf)
+ self.to_remove.append(pf)
+ self.assertRaster3dExists(pff)
+ self.to_remove.append(pff)
+ # check the basic properties
+ ref_univar = dict(null_cells=0, cells=27)
+ self.assertRaster3dFitsUnivar(raster=self.forest_frag,
+ reference=ref_univar, precision=0)
+ # the null cells requirements for pf and pff are fuzzy
+ ref_univar = dict(cells=27)
+ self.assertRaster3dFitsUnivar(raster=pf,
+ self.assertRaster3dFitsUnivar(raster=pff,
+ self.assertRaster3dMinMax(pf, refmin=0, refmax=1)
+ self.assertRaster3dMinMax(pff, refmin=0, refmax=1)
+ self.assertRaster3dMinMax(self.forest_frag, refmin=0, refmax=6)
+ # to check just the middle cell
+ # the current implementation of assertRasters3dNoDifference
+ # ignores nulls, so it just works regardless of region
+ # there is no zoom for 3D
+ # self.runModule('g.region', zoom=self.pff_ref)
+ # check the values
+ self.assertRasters3dNoDifference(actual=pf,
+ reference=self.pf_ref,
+ precision=0.001)
+ self.assertRasters3dNoDifference(actual=pff,
+ reference=self.pff_ref,
+ precision=0.001)
+ self.assertRasters3dNoDifference(actual=self.forest_frag,
+ reference=self.forest_frag_ref,
+ precision=0) # it's CELL type
+if __name__ == '__main__':
+ test()
Deleted: grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_ncspm.py
--- grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_ncspm.py 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_ncspm.py 2016-11-20 22:11:34 UTC (rev 69855)
@@ -1,62 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r_forestfrag_ncspm
-# AUTHOR: Vaclav Petras
-# PURPOSE: Test using NC SPM data
-# COPYRIGHT: (C) 2016 by Vaclav Petras and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-from grass.gunittest.case import TestCase
-from grass.gunittest.main import test
-import grass.script.raster as gr
-class TestForestFrag(TestCase):
- # TODO: replace by unified handing of maps
- to_remove = []
- landclass = 'landclass96' # in full NC SPM
- forest = 'rff_test_forest'
- forest_frag = 'rff_test_forest_frag'
- def setUp(self):
- self.use_temp_region()
- self.runModule('g.region', raster=self.landclass)
- gr.mapcalc("{f} = if({c} == 5, 1, 0)".format(c=self.landclass,
- f=self.forest))
- self.to_remove.append(self.forest)
- def tearDown(self):
- self.del_temp_region()
- if self.to_remove:
- self.runModule('g.remove', flags='f', type='raster',
- name=','.join(self.to_remove), verbose=True)
- def test_3x3(self):
- self.assertModule('r.forestfrag', input=self.forest,
- output=self.forest_frag, window=3)
- self.assertRasterExists(self.forest_frag)
- self.to_remove.append(self.forest_frag)
- self.assertRasterMinMax(self.forest_frag, refmin=0, refmax=6)
- # we don't have a check sum test for raster, so we just test all
- ref = dict(north=228527.25, south=215018.25,
- east=644971, west=629980,
- nsres=28.5, ewres=28.5, rows=474, cols=526,
- cells=249324, datatype='CELL', ncats=6)
- self.assertRasterFitsInfo(raster=self.forest_frag,
- reference=ref, precision=0.0006)
- ref = dict(n=249323, null_cells=1, cells=249324, min=0, max=5,
- range=5, mean=2.2925, mean_of_abs=2.2925,
- stddev=2.3564, variance=5.5527, coeff_var=102.7879,
- sum=571572)
- self.assertRasterFitsUnivar(raster=self.forest_frag,
-if __name__ == '__main__':
- test()
Deleted: grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_trivial.py
--- grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_trivial.py 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_trivial.py 2016-11-20 22:11:34 UTC (rev 69855)
@@ -1,162 +0,0 @@
-# MODULE: r_forestfrag_trivial
-# PURPOSE: Test using example from the Riitters et al. 2000 paper
-# for details.
-# This test led to discovery of #3067 (r68717) which was an r.mapcalc
-# row indexing bug.
-FOREST_RIITTERS = """\
-north: 10
-south: 8
-east: 20
-west: 18
-rows: 3
-cols: 3
-1 0 1
-1 1 0
-1 1 0
-FRAG_RIITTERS = """\
-north: 10
-south: 8
-east: 20
-west: 18
-rows: 3
-cols: 3
-null: N
-N N N
-N 4 N
-N N N
-PF_RIITTERS = """\
-north: 10
-south: 8
-east: 20
-west: 18
-rows: 3
-cols: 3
-null: N
-N N N
-N 0.67 N
-N N N
-PFF_RIITTERS = """\
-north: 10
-south: 8
-east: 20
-west: 18
-rows: 3
-cols: 3
-null: N
-N N N
-N 0.45 N
-N N N
-class TestForestFragTrivial(TestCase):
- to_remove = []
- forest = 'rff_test_forest_trivial'
- forest_frag = 'rff_test_forest_frag_trivial'
- forest_frag_ref = 'rff_test_forest_frag_trivial_ref'
- def setUp(self):
- if 0 and self.to_remove:
- def forest_frag_general(self, forest, window, reference):
- self.runModule('r.in.ascii', input='-', stdin_=forest,
- output=self.forest)
- self.runModule('g.region', raster=self.forest)
- self.assertRasterMinMax(self.forest,
- refmin=0, refmax=1)
- self.runModule('r.in.ascii', input='-', stdin_=reference,
- output=self.forest_frag_ref)
- self.to_remove.append(self.forest_frag_ref)
- pf_ref = self.forest_frag_ref + '_pf'
- self.runModule('r.in.ascii', input='-', stdin_=PF_RIITTERS,
- output=pf_ref)
- self.to_remove.append(pf_ref)
- pff_ref = self.forest_frag_ref + '_pff'
- self.runModule('r.in.ascii', input='-', stdin_=PFF_RIITTERS,
- output=pff_ref)
- self.to_remove.append(pff_ref)
- # just check if the reference is all right
- theoretical_min = 0
- theoretical_max = 6
- self.assertRasterMinMax(self.forest_frag_ref,
- refmin=theoretical_min,
- refmax=theoretical_max)
- ref_univar = dict(null_cells=8)
- self.assertRasterFitsUnivar(raster=self.forest_frag_ref,
- reference=ref_univar, precision=0)
- # actually run the module
- pf = self.forest_frag + '_pf'
- pff = self.forest_frag + '_pff'
- output=self.forest_frag, window=window,
- pf=pf, pff=pff)
- self.assertRasterExists(pf)
- self.to_remove.append(pf)
- self.assertRasterExists(pff)
- self.to_remove.append(pff)
- # check the basic properties
- ref_univar = dict(null_cells=0)
- self.runModule('g.region', zoom=pff_ref)
- # check cell by cell
- self.assertRastersNoDifference(actual=pf,
- reference=pf_ref,
- precision=0.01)
- self.assertRastersNoDifference(actual=pff,
- reference=pff_ref,
- precision=0.01)
- self.assertRastersNoDifference(actual=self.forest_frag,
- reference=self.forest_frag_ref,
- precision=0) # it's CELL type
- def test_riitters(self):
- self.forest_frag_general(FOREST_RIITTERS, 3, FRAG_RIITTERS)
- test()
Modified: grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_xy.py
--- grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_xy.py 2016-11-20 21:00:28 UTC (rev 69854)
+++ grass-addons/grass7/raster3d/r3.forestfrag/testsuite/r_forestfrag_xy.py 2016-11-20 22:11:34 UTC (rev 69855)
@@ -1,5 +1,7 @@
+# TODO: create a 3D version of this to test r3.forestfrag
# MODULE: r_forestfrag_xy
