[GRASS-SVN] r69858 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial
svn_grass at osgeo.org
Mon Nov 21 05:34:52 PST 2016
Author: Giulia
Date: 2016-11-21 05:34:52 -0800 (Mon, 21 Nov 2016)
New Revision: 69858
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
r.green: add excavation and compensation cost for the financial module
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py 2016-11-20 22:22:32 UTC (rev 69857)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py 2016-11-21 13:34:52 UTC (rev 69858)
@@ -349,10 +349,15 @@
#%end
#%option
#% key: electro_layer
-#% description: Name of the vector map layer of the grid
+#% description: Vector map layer of the grid
#% required: no
#% answer: 1
#%end
+#%option
+#% key: elines
+#% description: Output name of the vector map with power lines
+#% required: no
+#%end
# DEFINE POWER STATION COSTS
@@ -446,17 +451,10 @@
#% key: operative_hours
#% type: double
#% description: Number of operative hours per year [hours/year]
-#% answer: 6500.
+#% answer: 3650.
#% guisection: Revenues
#%end
#%option
-#% key: alpha_revenue
-#% type: double
-#% description: Coefficient to transform installed power to mean power
-#% answer: 1.0
-#% guisection: Revenues
-#%end
-#%option
#% key: const_revenue
#% type: double
#% description: Constant to assess the revenues
@@ -495,21 +493,25 @@
from __future__ import print_function
import os
+import sys
import atexit
import numpy as np
-from grass.script import core as gcore
from grass.exceptions import ParameterError
from grass.script.core import parser, overwrite, warning
from grass.pygrass.modules.shortcuts import raster as r
from grass.pygrass.modules.shortcuts import vector as v
from grass.pygrass.utils import set_path
-from grass.pygrass.raster import RasterRow
from grass.pygrass.vector import VectorTopo, sql
from grass.pygrass.vector.basic import Cats
+from grass.pygrass.vector import geometry as geo
+from grass.pygrass.gis.region import Region
from grass.pygrass.messages import get_msgr
+#from grass.script import mapcalc
+version = 70 # 71
try:
import numexpr as ne
except ImportError:
@@ -704,19 +706,41 @@
# open vector map with the existing electroline
ename = opts['electro']
ename, emapset = ename.split('@') if '@' in ename else (ename, '')
- with VectorTopo(ename, mapset=emapset, layer=int(opts['electro_layer']),
+ ltemp=[]
+ with VectorTopo(ename, mapset=emapset,
+ layer=int(opts['electro_layer']),
mode='r') as electro:
- for line in vect:
- if line.attrs[kcol] == ktype:
+ pid = os.getpid()
+ elines = (opts['elines'] if opts['elines']
+ else ('tmprgreen_%i_elines' % pid))
+ for cat, line in enumerate(vect):
+ if line.attrs[kcol] == ktype and line.attrs['side']=='option1':
# the turbine is the last point of the penstock
turbine = line[-1]
# find the closest electro line
eline = electro.find['by_point'].geo(turbine, maxdist=1e6)
dist = eline.distance(turbine)
- line.attrs['electro_length'] = dist.dist
+ # line.attrs['electro_length'] = dist.dist
+ ltemp.append([geo.Line([turbine, dist.point]),
+ (line.attrs['plant_id'], line.attrs['side'])])
else:
line.attrs['electro_length'] = 0.
vect.table.conn.commit()
+ new = VectorTopo(elines) # new vec with elines
+ new.layer = 1
+ cols = [(u'cat', 'INTEGER PRIMARY KEY'),
+ (u'plant_id', 'VARCHAR(10)'),
+ (u'side', 'VARCHAR(10)'), ]
+ new.open('w', tab_cols=cols)
+ reg = Region()
+ for cat, line in enumerate(ltemp):
+ if version == 70:
+ new.write(line[0], line[1])
+ else:
+ new.write(line[0], cat=cat, attrs=line[1])
+ new.table.conn.commit()
+ new.comment = (' '.join(sys.argv))
+ new.close()
def get_gamma_NPV(r=0.03, y=30):
@@ -847,6 +871,36 @@
print('Finish')
+def write2struct(elines, opts):
+ msgr = get_msgr()
+ ktype = opts['struct_kind_turbine']
+ kcol = opts['struct_column_kind']
+ pname = opts['struct']
+ pname, vmapset = pname.split('@') if '@' in pname else (pname, '')
+ with VectorTopo(pname, mapset=vmapset, layer=int(opts['struct_layer']),
+ mode='r') as vect:
+ if 'el_comp_exc' not in vect.table.columns:
+ vect.table.columns.add('el_comp_exc', 'double precision')
+ ename, emapset = elines.split('@') if '@' in elines else (elines, '')
+ mode='r') as electro:
+ for line in vect:
+ if line.attrs[kcol] == ktype:
+ plant_id = line.attrs['plant_id']
+ line.attrs['el_comp_exc'] = 0.
+ for eline in electro:
+ if plant_id == eline.attrs['plant_id']:
+ msgr.message(plant_id)
+ cost = ((eline.attrs['comp_cost_sum'] +
+ eline.attrs['exc_cost_sum'])
+ if eline.attrs['comp_cost_sum'] else 0)
+ line.attrs['el_comp_exc'] = cost
+ electro.rewind()
+ break
+ vect.table.conn.commit()
def main(opts, flgs):
pid = os.getpid()
pat = "tmprgreen_%i_*" % pid
@@ -920,6 +974,16 @@
alpha=float(opts['lc_electro']), length='electro_length',
vlayer=vlayer, ctype='double precision', overwrite=overw)
+ # add excavation cost and compensation cost for electroline
+ v.rast_stats(map=elines, layer=vlayer, flags='c',
+ raster=comp, column_prefix='comp_cost', method='sum')
+ # add excavation costs
+ raster=exc, column_prefix='exc_cost', method='sum')
+ write2struct(elines, opts)
xcost = "{cname} = {alpha} * {em}"
# add power station costs
vcolcalc(vname=struct, vlayer=vlayer,
@@ -933,7 +997,7 @@
alpha=opts['alpha_inlet']))
# add total inlet costs
# TODO: to be check to avoid to count cost more than one time I have moltiplied by 0.5
- tot = ('tot_cost = (comp_cost_sum + em_cost + '
+ tot = ('tot_cost = (comp_cost_sum + em_cost + el_comp_exc +'
'lin_pipe_cost + lin_electro_cost + '
'station_cost + inlet_cost + {grid}*0.5) * '
'(1 + {general} + {hindrances})')
@@ -983,7 +1047,7 @@
const=opts['const_maintenance']))
# compute yearly revenues
- rev = "{cname} = {eta} * {power} * {eprice} * {ophours} * {alpha} + {const}"
+ rev = "{cname} = {eta} * {power} * {eprice} * {ophours} + {const}"
vcolcalc(vname=opts['output_struct'], vlayer=vlayer,
ctype='double precision', notfinitesubstitute=0.,
expr=rev.format(cname='revenue',
@@ -991,7 +1055,6 @@
power=opts['struct_column_power'],
eprice=opts['energy_price'],
ophours=opts['operative_hours'],
- alpha=opts['alpha_revenue'],
const=opts['const_revenue']))
# compute the Net Present Value
