[GRASS-SVN] r69861 - grass-addons/grass7/raster/r.series.lwr
svn_grass at osgeo.org
Mon Nov 21 12:38:08 PST 2016
Author: mmetz
Date: 2016-11-21 12:38:08 -0800 (Mon, 21 Nov 2016)
New Revision: 69861
grass-addons/grass7/raster/r.series.lwr/main.c
r.series.lwr: add flag to avoid extrapolation
Modified: grass-addons/grass7/raster/r.series.lwr/main.c
--- grass-addons/grass7/raster/r.series.lwr/main.c 2016-11-21 20:37:36 UTC (rev 69860)
+++ grass-addons/grass7/raster/r.series.lwr/main.c 2016-11-21 20:38:08 UTC (rev 69861)
@@ -144,7 +144,7 @@
/* co-linear points result in an undefined matrix, and nearly */
/* co-linear points results in a solution with rounding error */
- if (pivot == 0.0) {
+ if (fabs(pivot) < GRASS_EPSILON) {
G_debug(4, "Matrix is unsolvable");
return 0;
@@ -224,7 +224,7 @@
} parm;
struct
- struct Flag *lo, *hi, *lazy;
+ struct Flag *lo, *hi, *lazy, *int_only;
} flag;
int i, j, k, n;
int num_inputs, in_lo, in_hi;
@@ -247,6 +247,7 @@
int dod;
int *isnull, n_nulls;
int min_points, n_points;
+ int first, last, interp_only;
int this_margin;
double max_ts, tsdiff1, tsdiff2;
double delta;
@@ -338,6 +339,10 @@
flag.lazy->key = 'z';
flag.lazy->description = _("Don't keep files open");
+ flag.int_only = G_define_flag();
+ flag.int_only->key = 'i';
+ flag.int_only->description = _("Do not extrapolate, only interpolate");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -401,6 +406,8 @@
G_fatal_error(_("Unknown weighing function '%s'"),
parm.weight->answer);
+ interp_only = flag.int_only->answer;
/* process the input maps from the file */
if (parm.file->answer) {
FILE *in;
@@ -554,6 +561,7 @@
for (col = 0; col < ncols; col++) {
+ first = last = -1;
n_nulls = 0;
for (i = 0; i < num_inputs; i++) {
DCELL v = inputs[i].buf[col];
@@ -568,13 +576,22 @@
isnull[i] = 1;
n_nulls++;
+ else {
+ if (first == -1)
+ first = i;
+ last = i;
values[i] = v;
+ if (!interp_only) {
+ first = 0;
+ last = num_inputs - 1;
/* LWR */
if (num_inputs - n_nulls >= min_points) {
- for (i = 0; i < num_inputs; i++) {
+ for (i = first; i <= last; i++) {
DCELL result;
/* margin around i */
