[GRASS-SVN] r69882 - grass/trunk/raster/r.texture
svn_grass at osgeo.org
Wed Nov 23 12:47:13 PST 2016
Author: mmetz
Date: 2016-11-23 12:47:12 -0800 (Wed, 23 Nov 2016)
New Revision: 69882
grass/trunk/raster/r.texture/r.texture.html
r.texture: update manual
Modified: grass/trunk/raster/r.texture/r.texture.html
--- grass/trunk/raster/r.texture/r.texture.html 2016-11-23 15:34:07 UTC (rev 69881)
+++ grass/trunk/raster/r.texture/r.texture.html 2016-11-23 20:47:12 UTC (rev 69882)
@@ -4,7 +4,12 @@
user-specified raster map layer. The module calculates textural features
based on spatial dependence matrices at 0, 45, 90, and 135
degrees for a <em>distance</em> (default = 1).
<p>
+The output of <em>r.texture</em> can be used as additional input for
+image classification or image segmentation (object recognition).
+<p>
<em>r.texture</em> assumes grey levels ranging from 0 to 255 as input.
The input is automatically rescaled to 0 to 255 if the input map range is outside
of this range.
@@ -31,9 +36,7 @@
consists of four images for each textural feature, one for every direction
(0, 45, 90, 135).
-<p>
-The user must carefully set the resolution (using <em>g.region</em>) before
-running this program, or the computer may run out of memory.
+<h2>NOTES</h2>
<p>
A commonly used texture model is based on the so-called grey level co-occurrence
@@ -104,9 +107,14 @@
<li> Maximal Correlation Coefficient (MCC)</li>
</ul>
-<h2>NOTES</h2>
+<p>
+The computational region should be set to the input map with
+<b>g.region rast=<input map></b>, or aligned to the input map
+with <b>g.region align=<input map></b> if only a subregion
+should be analyzed.
+<p>
Importantly, the input raster map cannot have more than 255 categories.
<h2>EXAMPLE</h2>
