[GRASS-SVN] r69884 - grass-addons/grass7/raster/r.resamp.tps
    svn_grass at osgeo.org
    Wed Nov 23 13:42:34 PST 2016
Author: mmetz
Date: 2016-11-23 13:42:34 -0800 (Wed, 23 Nov 2016)
New Revision: 69884
Added:
   grass-addons/grass7/raster/r.resamp.tps/pavl.c
   grass-addons/grass7/raster/r.resamp.tps/pavl.h
   grass-addons/grass7/raster/r.resamp.tps/Makefile
   grass-addons/grass7/raster/r.resamp.tps/tps.c
r.resamp.tps: Red-Black -> AVL
Modified: grass-addons/grass7/raster/r.resamp.tps/Makefile
--- grass-addons/grass7/raster/r.resamp.tps/Makefile	2016-11-23 21:41:25 UTC (rev 69883)
+++ grass-addons/grass7/raster/r.resamp.tps/Makefile	2016-11-23 21:42:34 UTC (rev 69884)
@@ -2,8 +2,8 @@
 PGM = r.resamp.tps
-LIBES = $(RASTERLIB) $(BTREE2LIB) $(SEGMENTLIB) $(GISLIB) $(MATHLIB)
-DEPENDENCIES = $(RASTERDEP) $(BTREE2DEP) $(SEGMENTDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(SEGMENTLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(SEGMENTDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Added: grass-addons/grass7/raster/r.resamp.tps/pavl.c
--- grass-addons/grass7/raster/r.resamp.tps/pavl.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.resamp.tps/pavl.c	2016-11-23 21:42:34 UTC (rev 69884)
@@ -0,0 +1,843 @@
+/* Produced by texiweb from libavl.w. */
+/* libavl - library for manipulation of binary trees.
+   Copyright (C) 1998, 1999, 2000, 2001, 2002, 2004 Free Software
+   Foundation, Inc.
+   This library is free software; you can redistribute it and/or
+   modify it under the terms of the GNU Lesser General Public
+   License as published by the Free Software Foundation; either
+   version 3 of the License, or (at your option) any later version.
+   This library is distributed in the hope that it will be useful,
+   but WITHOUT ANY WARRANTY; without even the implied warranty of
+   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+   Lesser General Public License for more details.
+   You should have received a copy of the GNU Lesser General Public
+   License along with this library; if not, write to the Free Software
+   Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
+   02110-1301 USA.
+/* from libavl-2.0.3
+   some speed optimizations by Markus Metz
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include "pavl.h"
+/* Creates and returns a new table
+   with comparison function |compare| using parameter |param|
+   and memory allocator |allocator|.
+   Returns |NULL| if memory allocation failed. */
+struct pavl_table *pavl_create(pavl_comparison_func * compare, void *param,
+			       struct libavl_allocator *allocator)
+    struct pavl_table *tree;
+    assert(compare != NULL);
+    if (allocator == NULL)
+	allocator = &pavl_allocator_default;
+    tree = allocator->libavl_malloc(allocator, sizeof *tree);
+    if (tree == NULL)
+	return NULL;
+    tree->pavl_root = NULL;
+    tree->pavl_compare = compare;
+    tree->pavl_param = param;
+    tree->pavl_alloc = allocator;
+    tree->pavl_count = 0;
+    return tree;
+/* Search |tree| for an item matching |item|, and return it if found.
+   Otherwise return |NULL|. */
+void *pavl_find(const struct pavl_table *tree, const void *item)
+    const struct pavl_node *p;
+    assert(tree != NULL && item != NULL);
+    p = tree->pavl_root;
+    while (p != NULL) {
+	int cmp = tree->pavl_compare(item, p->pavl_data, tree->pavl_param);
+	if (cmp == 0)
+	    return p->pavl_data;
+	p = p->pavl_link[cmp > 0];
+    return NULL;
+/* Inserts |item| into |tree| and returns a pointer to |item|'s address.
+   If a duplicate item is found in the tree,
+   returns a pointer to the duplicate without inserting |item|.
+   Returns |NULL| in case of memory allocation failure. */
+void **pavl_probe(struct pavl_table *tree, void *item)
+    struct pavl_node *y;	/* Top node to update balance factor, and parent. */
+    struct pavl_node *p, *q;	/* Iterator, and parent. */
+    struct pavl_node *n;	/* Newly inserted node. */
+    struct pavl_node *w;	/* New root of rebalanced subtree. */
+    int dir;			/* Direction to descend. */
+    y = p = tree->pavl_root;
+    q = NULL;
+    dir = 0;
+	if (cmp == 0)
+	    return &p->pavl_data;
+	dir = cmp > 0;
+	if (p->pavl_balance != 0)
+	    y = p;
+	q = p, p = p->pavl_link[dir];
+    n = tree->pavl_alloc->libavl_malloc(tree->pavl_alloc, sizeof *p);
+    if (n == NULL)
+	return NULL;
+    tree->pavl_count++;
+    n->pavl_link[0] = n->pavl_link[1] = NULL;
+    n->pavl_parent = q;
+    n->pavl_data = item;
+    n->pavl_balance = 0;
+    if (q != NULL)
+	q->pavl_link[dir] = n;
+    else {
+	tree->pavl_root = n;
+	return &n->pavl_data;
+    p = n;
+    while (p != y) {
+	q = p->pavl_parent;
+	   dir = q->pavl_link[0] != p;
+	   if (dir == 0)
+	   q->pavl_balance--;
+	   else
+	   q->pavl_balance++;
+	if (q->pavl_link[0] != p)
+	else
+	p = q;
+    if (y->pavl_balance == -2) {
+	struct pavl_node *x = y->pavl_link[0];
+	if (x->pavl_balance == -1) {
+	    w = x;
+	    y->pavl_link[0] = x->pavl_link[1];
+	    x->pavl_link[1] = y;
+	    x->pavl_balance = y->pavl_balance = 0;
+	    x->pavl_parent = y->pavl_parent;
+	    y->pavl_parent = x;
+	    if (y->pavl_link[0] != NULL)
+		y->pavl_link[0]->pavl_parent = y;
+	else {
+	    assert(x->pavl_balance == +1);
+	    w = x->pavl_link[1];
+	    x->pavl_link[1] = w->pavl_link[0];
+	    w->pavl_link[0] = x;
+	    y->pavl_link[0] = w->pavl_link[1];
+	    w->pavl_link[1] = y;
+	    if (w->pavl_balance == -1)
+		x->pavl_balance = 0, y->pavl_balance = +1;
+	    else if (w->pavl_balance == 0)
+	    else		/* |w->pavl_balance == +1| */
+		x->pavl_balance = -1, y->pavl_balance = 0;
+	    w->pavl_balance = 0;
+	    w->pavl_parent = y->pavl_parent;
+	    x->pavl_parent = y->pavl_parent = w;
+	    if (x->pavl_link[1] != NULL)
+		x->pavl_link[1]->pavl_parent = x;
+    else if (y->pavl_balance == +2) {
+	struct pavl_node *x = y->pavl_link[1];
+	if (x->pavl_balance == +1) {
+	    w = x;
+	    y->pavl_link[1] = x->pavl_link[0];
+	    x->pavl_link[0] = y;
+	    if (y->pavl_link[1] != NULL)
+		y->pavl_link[1]->pavl_parent = y;
+	else {
+	    assert(x->pavl_balance == -1);
+	    w = x->pavl_link[0];
+	    x->pavl_link[0] = w->pavl_link[1];
+	    w->pavl_link[1] = x;
+	    y->pavl_link[1] = w->pavl_link[0];
+	    w->pavl_link[0] = y;
+	    if (w->pavl_balance == +1)
+		x->pavl_balance = 0, y->pavl_balance = -1;
+	    else		/* |w->pavl_balance == -1| */
+		x->pavl_balance = +1, y->pavl_balance = 0;
+	    if (x->pavl_link[0] != NULL)
+		x->pavl_link[0]->pavl_parent = x;
+    else
+    if (w->pavl_parent != NULL)
+	w->pavl_parent->pavl_link[y != w->pavl_parent->pavl_link[0]] = w;
+    else
+	tree->pavl_root = w;
+/* Inserts |item| into |table|.
+   Returns |NULL| if |item| was successfully inserted
+   or if a memory allocation error occurred.
+   Otherwise, returns the duplicate item. */
+void *pavl_insert(struct pavl_table *table, void *item)
+    void **p = pavl_probe(table, item);
+    return p == NULL || *p == item ? NULL : *p;
+/* Inserts |item| into |table|, replacing any duplicate item.
+   Returns |NULL| if |item| was inserted without replacing a duplicate,
+   Otherwise, returns the item that was replaced. */
+void *pavl_replace(struct pavl_table *table, void *item)
+    if (p == NULL || *p == item)
+	return NULL;
+    else {
+	void *r = *p;
+	*p = item;
+	return r;
+/* Deletes from |tree| and returns an item matching |item|.
+   Returns a null pointer if no matching item found. */
+void *pavl_delete(struct pavl_table *tree, const void *item)
+    struct pavl_node *p;	/* Traverses tree to find node to delete. */
+    struct pavl_node *q;	/* Parent of |p|. */
+    int dir;			/* Side of |q| on which |p| is linked. */
+    int cmp;			/* Result of comparison between |item| and |p|. */
+    if (tree->pavl_root == NULL)
+	return NULL;
+    dir = 0;
+    cmp = tree->pavl_compare(item, p->pavl_data, tree->pavl_param);
+    while (cmp != 0) {
+	dir = cmp > 0;
+	p = p->pavl_link[dir];
+	if (p == NULL)
+	    return NULL;
+    item = p->pavl_data;
+    if (q == NULL) {
+	q = (struct pavl_node *)&tree->pavl_root;
+	dir = 0;
+    if (p->pavl_link[1] == NULL) {
+	q->pavl_link[dir] = p->pavl_link[0];
+	if (q->pavl_link[dir] != NULL)
+	    q->pavl_link[dir]->pavl_parent = p->pavl_parent;
+    else {
+	struct pavl_node *r = p->pavl_link[1];
+	if (r->pavl_link[0] == NULL) {
+	    r->pavl_link[0] = p->pavl_link[0];
+	    q->pavl_link[dir] = r;
+	    r->pavl_parent = p->pavl_parent;
+	    if (r->pavl_link[0] != NULL)
+		r->pavl_link[0]->pavl_parent = r;
+	    r->pavl_balance = p->pavl_balance;
+	    q = r;
+	    dir = 1;
+	else {
+	    struct pavl_node *s = r->pavl_link[0];
+	    while (s->pavl_link[0] != NULL)
+		s = s->pavl_link[0];
+	    r = s->pavl_parent;
+	    r->pavl_link[0] = s->pavl_link[1];
+	    s->pavl_link[0] = p->pavl_link[0];
+	    s->pavl_link[1] = p->pavl_link[1];
+	    q->pavl_link[dir] = s;
+	    if (s->pavl_link[0] != NULL)
+		s->pavl_link[0]->pavl_parent = s;
+	    s->pavl_link[1]->pavl_parent = s;
+	    s->pavl_parent = p->pavl_parent;
+	    s->pavl_balance = p->pavl_balance;
+	    q = r;
+	    dir = 0;
+    tree->pavl_alloc->libavl_free(tree->pavl_alloc, p);
+    while (q != (struct pavl_node *)&tree->pavl_root) {
+	struct pavl_node *y = q;
+	if (y->pavl_parent != NULL)
+	    q = y->pavl_parent;
+	else
+	if (dir == 0) {
+	    dir = q->pavl_link[0] != y;
+	    y->pavl_balance++;
+	    if (y->pavl_balance == +1)
+		break;
+		    q->pavl_link[dir] = w;
+		else {
+		    q->pavl_link[dir] = x;
+		    if (x->pavl_balance == 0) {
+			x->pavl_balance = -1;
+			y->pavl_balance = +1;
+			break;
+		    else {
+			y = x;
+	else {
+	    y->pavl_balance--;
+	    if (y->pavl_balance == -1)
+		break;
+	    else if (y->pavl_balance == -2) {
+		else {
+			x->pavl_balance = +1;
+			y->pavl_balance = -1;
+			break;
+		    else {
+			y = x;
+    tree->pavl_count--;
+    return (void *)item;
+/* Initializes |trav| for use with |tree|
+   and selects the null node. */
+void pavl_t_init(struct pavl_traverser *trav, struct pavl_table *tree)
+    trav->pavl_table = tree;
+    trav->pavl_node = NULL;
+/* Initializes |trav| for |tree|.
+   Returns data item in |tree| with the least value,
+   or |NULL| if |tree| is empty. */
+void *pavl_t_first(struct pavl_traverser *trav, struct pavl_table *tree)
+    assert(tree != NULL && trav != NULL);
+    trav->pavl_node = tree->pavl_root;
+    if (trav->pavl_node != NULL) {
+	while (trav->pavl_node->pavl_link[0] != NULL)
+	    trav->pavl_node = trav->pavl_node->pavl_link[0];
+	return trav->pavl_node->pavl_data;
+    else
+	return NULL;
+   Returns data item in |tree| with the greatest value,
+void *pavl_t_last(struct pavl_traverser *trav, struct pavl_table *tree)
+	while (trav->pavl_node->pavl_link[1] != NULL)
+	    trav->pavl_node = trav->pavl_node->pavl_link[1];
+    else
+	return NULL;
+/* Searches for |item| in |tree|.
+   If found, initializes |trav| to the item found and returns the item
+   as well.
+   If there is no matching item, initializes |trav| to the null item
+   and returns |NULL|. */
+void *pavl_t_find(struct pavl_traverser *trav, struct pavl_table *tree,
+		  void *item)
+    int dir;
+    assert(trav != NULL && tree != NULL && item != NULL);
+    for (p = tree->pavl_root; p != NULL; p = p->pavl_link[dir]) {
+	if (cmp == 0) {
+	    trav->pavl_node = p;
+	dir = cmp > 0;
+    return NULL;
+/* Attempts to insert |item| into |tree|.
+   If |item| is inserted successfully, it is returned and |trav| is
+   initialized to its location.
+   If a duplicate is found, it is returned and |trav| is initialized to
+   its location.  No replacement of the item occurs.
+   If a memory allocation failure occurs, |NULL| is returned and |trav|
+   is initialized to the null item. */
+void *pavl_t_insert(struct pavl_traverser *trav,
+		    struct pavl_table *tree, void *item)
+    void **p;
+    p = pavl_probe(tree, item);
+    if (p != NULL) {
+	trav->pavl_node = ((struct pavl_node *) ((char *)p -
+			   offsetof(struct pavl_node, pavl_data)));
+	return *p;
+    else {
+	pavl_t_init(trav, tree);
+	return NULL;
+/* Initializes |trav| to have the same current node as |src|. */
+void *pavl_t_copy(struct pavl_traverser *trav,
+		  const struct pavl_traverser *src)
+    assert(trav != NULL && src != NULL);
+    trav->pavl_table = src->pavl_table;
+    trav->pavl_node = src->pavl_node;
+    return trav->pavl_node != NULL ? trav->pavl_node->pavl_data : NULL;
+/* Returns the next data item in inorder
+   within the tree being traversed with |trav|,
+   or if there are no more data items returns |NULL|. */
+void *pavl_t_next(struct pavl_traverser *trav)
+    assert(trav != NULL);
+    if (trav->pavl_node == NULL)
+	return pavl_t_first(trav, trav->pavl_table);
+    else if (trav->pavl_node->pavl_link[1] == NULL) {
+	struct pavl_node *q, *p;	/* Current node and its child. */
+	for (p = trav->pavl_node, q = p->pavl_parent;;
+	     p = q, q = q->pavl_parent)
+	    if (q == NULL || p == q->pavl_link[0]) {
+		trav->pavl_node = q;
+		       trav->pavl_node->pavl_data : NULL;
+    else {
+/* Returns the previous data item in inorder
+void *pavl_t_prev(struct pavl_traverser *trav)
+	return pavl_t_last(trav, trav->pavl_table);
+    else if (trav->pavl_node->pavl_link[0] == NULL) {
+	    if (q == NULL || p == q->pavl_link[1]) {
+    else {
+/* Returns |trav|'s current item. */
+void *pavl_t_cur(struct pavl_traverser *trav)
+/* Replaces the current item in |trav| by |new| and returns the item replaced.
+   |trav| must not have the null item selected.
+   The new item must not upset the ordering of the tree. */
+void *pavl_t_replace(struct pavl_traverser *trav, void *new)
+    void *old;
+    assert(trav != NULL && trav->pavl_node != NULL && new != NULL);
+    old = trav->pavl_node->pavl_data;
+    trav->pavl_node->pavl_data = new;
+    return old;
+/* Destroys |new| with |pavl_destroy (new, destroy)|,
+   first initializing right links in |new| that have
+   not yet been initialized at time of call. */
+static void
+copy_error_recovery(struct pavl_node *q,
+		    struct pavl_table *new, pavl_item_func * destroy)
+    assert(q != NULL && new != NULL);
+    for (;;) {
+	struct pavl_node *p = q;
+	q = q->pavl_parent;
+	if (q == NULL)
+	    break;
+	if (p == q->pavl_link[0])
+	    q->pavl_link[1] = NULL;
+    pavl_destroy(new, destroy);
+/* Copies |org| to a newly created tree, which is returned.
+   If |copy != NULL|, each data item in |org| is first passed to |copy|,
+   and the return values are inserted into the tree;
+   |NULL| return values are taken as indications of failure.
+   On failure, destroys the partially created new tree,
+   applying |destroy|, if non-null, to each item in the new tree so far,
+   If |allocator != NULL|, it is used for allocation in the new tree.
+   Otherwise, the same allocator used for |org| is used. */
+struct pavl_table *pavl_copy(const struct pavl_table *org,
+			     pavl_copy_func * copy, pavl_item_func * destroy,
+    struct pavl_table *new;
+    const struct pavl_node *x;
+    assert(org != NULL);
+    new = pavl_create(org->pavl_compare, org->pavl_param,
+		      allocator != NULL ? allocator : org->pavl_alloc);
+    if (new == NULL)
+	return NULL;
+    new->pavl_count = org->pavl_count;
+    if (new->pavl_count == 0)
+	return new;
+    x = (const struct pavl_node *)&org->pavl_root;
+    y = (struct pavl_node *)&new->pavl_root;
+    for (;;) {
+	while (x->pavl_link[0] != NULL) {
+	    y->pavl_link[0] =
+		new->pavl_alloc->libavl_malloc(new->pavl_alloc,
+					       sizeof *y->pavl_link[0]);
+	    if (y->pavl_link[0] == NULL) {
+		if (y != (struct pavl_node *)&new->pavl_root) {
+		    y->pavl_data = NULL;
+		    y->pavl_link[1] = NULL;
+		copy_error_recovery(y, new, destroy);
+		return NULL;
+	    x = x->pavl_link[0];
+	    y = y->pavl_link[0];
+	y->pavl_link[0] = NULL;
+	for (;;) {
+	    y->pavl_balance = x->pavl_balance;
+	    if (copy == NULL)
+		y->pavl_data = x->pavl_data;
+	    else {
+		y->pavl_data = copy(x->pavl_data, org->pavl_param);
+		if (y->pavl_data == NULL) {
+		    return NULL;
+	    if (x->pavl_link[1] != NULL) {
+		y->pavl_link[1] =
+						   sizeof *y->pavl_link[1]);
+		if (y->pavl_link[1] == NULL) {
+		    return NULL;
+		x = x->pavl_link[1];
+		y = y->pavl_link[1];
+		break;
+	    else
+	    for (;;) {
+		const struct pavl_node *w = x;
+		x = x->pavl_parent;
+		if (x == NULL) {
+		    new->pavl_root->pavl_parent = NULL;
+		    return new;
+		y = y->pavl_parent;
+		if (w == x->pavl_link[0])
+		    break;
+    return new;
+/* Frees storage allocated for |tree|.
+   If |destroy != NULL|, applies it to each data item in inorder. */
+void pavl_destroy(struct pavl_table *tree, pavl_item_func * destroy)
+    assert(tree != NULL);
+	if (p->pavl_link[0] == NULL) {
+	    q = p->pavl_link[1];
+	    if (destroy != NULL && p->pavl_data != NULL)
+		destroy(p->pavl_data, tree->pavl_param);
+	else {
+	    q = p->pavl_link[0];
+	    p->pavl_link[0] = q->pavl_link[1];
+	    q->pavl_link[1] = p;
+	p = q;
+    tree->pavl_alloc->libavl_free(tree->pavl_alloc, tree);
+/* Allocates |size| bytes of space using |malloc()|.
+   Returns a null pointer if allocation fails. */
+void *pavl_malloc(struct libavl_allocator *allocator, size_t size)
+    assert(allocator != NULL && size > 0);
+    return malloc(size);
+/* Frees |block|. */
+void pavl_free(struct libavl_allocator *allocator, void *block)
+    assert(allocator != NULL && block != NULL);
+    free(block);
+/* Default memory allocator that uses |malloc()| and |free()|. */
+struct libavl_allocator pavl_allocator_default = {
+    pavl_malloc,
+    pavl_free
+#undef NDEBUG
+/* Asserts that |pavl_insert()| succeeds at inserting |item| into |table|. */
+void (pavl_assert_insert) (struct pavl_table * table, void *item)
+    assert(p != NULL && *p == item);
+/* Asserts that |pavl_delete()| really removes |item| from |table|,
+   and returns the removed item. */
+void *(pavl_assert_delete) (struct pavl_table * table, void *item)
+    void *p = pavl_delete(table, item);
+    assert(p != NULL);
+    return p;
Property changes on: grass-addons/grass7/raster/r.resamp.tps/pavl.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.resamp.tps/pavl.h
--- grass-addons/grass7/raster/r.resamp.tps/pavl.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.resamp.tps/pavl.h	2016-11-23 21:42:34 UTC (rev 69884)
@@ -0,0 +1,108 @@
+   Foundation, Inc.
+   02110-1301 USA.
+#ifndef PAVL_H
+#define PAVL_H 1
+#include <stddef.h>
+/* Function types. */
+typedef int pavl_comparison_func (const void *pavl_a, const void *pavl_b,
+                                 void *pavl_param);
+typedef void pavl_item_func (void *pavl_item, void *pavl_param);
+typedef void *pavl_copy_func (void *pavl_item, void *pavl_param);
+#ifndef LIBAVL_ALLOCATOR
+#define LIBAVL_ALLOCATOR
+/* Memory allocator. */
+    void *(*libavl_malloc) (struct libavl_allocator *, size_t libavl_size);
+    void (*libavl_free) (struct libavl_allocator *, void *libavl_block);
+#endif
+/* Default memory allocator. */
+extern struct libavl_allocator pavl_allocator_default;
+void *pavl_malloc (struct libavl_allocator *, size_t);
+void pavl_free (struct libavl_allocator *, void *);
+/* Maximum PAVL height, unused. */
+#ifndef PAVL_MAX_HEIGHT
+#define PAVL_MAX_HEIGHT 32
+#endif
+/* Tree data structure. */
+struct pavl_table
+    struct pavl_node *pavl_root;        /* Tree's root. */
+    pavl_comparison_func *pavl_compare; /* Comparison function. */
+    void *pavl_param;                   /* Extra argument to |pavl_compare|. */
+    struct libavl_allocator *pavl_alloc; /* Memory allocator. */
+    size_t pavl_count;                  /* Number of items in tree. */
+/* An PAVL tree node. */
+struct pavl_node
+    struct pavl_node *pavl_link[2]; /* Subtrees. */
+    struct pavl_node *pavl_parent;  /* Parent node. */
+    void *pavl_data;                /* Pointer to data. */
+    signed char pavl_balance;       /* Balance factor. */
+/* PAVL traverser structure. */
+struct pavl_traverser
+    struct pavl_table *pavl_table;        /* Tree being traversed. */
+    struct pavl_node *pavl_node;          /* Current node in tree. */
+/* Table functions. */
+struct pavl_table *pavl_create (pavl_comparison_func *, void *,
+                              struct libavl_allocator *);
+struct pavl_table *pavl_copy (const struct pavl_table *, pavl_copy_func *,
+                            pavl_item_func *, struct libavl_allocator *);
+void pavl_destroy (struct pavl_table *, pavl_item_func *);
+void **pavl_probe (struct pavl_table *, void *);
+void *pavl_insert (struct pavl_table *, void *);
+void *pavl_replace (struct pavl_table *, void *);
+void *pavl_delete (struct pavl_table *, const void *);
+void *pavl_find (const struct pavl_table *, const void *);
+void pavl_assert_insert (struct pavl_table *, void *);
+void *pavl_assert_delete (struct pavl_table *, void *);
+#define pavl_count(table) ((size_t) (table)->pavl_count)
+/* Table traverser functions. */
+void pavl_t_init (struct pavl_traverser *, struct pavl_table *);
+void *pavl_t_first (struct pavl_traverser *, struct pavl_table *);
+void *pavl_t_last (struct pavl_traverser *, struct pavl_table *);
+void *pavl_t_find (struct pavl_traverser *, struct pavl_table *, void *);
+void *pavl_t_insert (struct pavl_traverser *, struct pavl_table *, void *);
+void *pavl_t_copy (struct pavl_traverser *, const struct pavl_traverser *);
+void *pavl_t_next (struct pavl_traverser *);
+void *pavl_t_prev (struct pavl_traverser *);
+void *pavl_t_cur (struct pavl_traverser *);
+void *pavl_t_replace (struct pavl_traverser *, void *);
+#endif /* pavl.h */
Property changes on: grass-addons/grass7/raster/r.resamp.tps/pavl.h
   + text/x-chdr
   + native
Modified: grass-addons/grass7/raster/r.resamp.tps/tps.c
--- grass-addons/grass7/raster/r.resamp.tps/tps.c	2016-11-23 21:41:25 UTC (rev 69883)
+++ grass-addons/grass7/raster/r.resamp.tps/tps.c	2016-11-23 21:42:34 UTC (rev 69884)
@@ -5,11 +5,11 @@
 #include <grass/gis.h>
 #include <grass/raster.h>
 #include <grass/segment.h>
-#include <grass/rbtree.h>
 #include <grass/glocale.h>
 #include "tps.h"
 #include "flag.h"
 #include "rclist.h"
+#include "pavl.h"
 #ifdef USE_RC
 #undef USE_RC
@@ -93,21 +93,11 @@
     return (dst->north - src->north + (row + 0.5) * src->ns_res) / dst->ns_res;
-static int row_dst2src(int row, struct Cell_head *src, struct Cell_head *dst)
-    return (src->north - dst->north + (row + 0.5) * dst->ns_res) / src->ns_res;
 static int col_src2dst(int col, struct Cell_head *src, struct Cell_head *dst)
     return (src->west - dst->west + (col + 0.5) * src->ew_res) / dst->ew_res;
-static int col_dst2src(int col, struct Cell_head *src, struct Cell_head *dst)
-    return (dst->west - src->west + (col + 0.5) * dst->ew_res) / src->ew_res;
 static int cmp_pnts(const void *first, const void *second)
     struct tps_pnt *a = (struct tps_pnt *)first;
@@ -203,7 +193,7 @@
-static int cmp_rc(const void *first, const void *second)
+static int cmp_rc(const void *first, const void *second, void *avl_param)
     struct rc *a = (struct rc *)first, *b = (struct rc *)second;
@@ -213,6 +203,11 @@
     return (a->row - b->row);
+static void avl_free_item(void *avl_item, void *avl_param)
+    G_free(avl_item);
 static int bfs_search_nn(FLAG *pnt_flag, struct Cell_head *src,
                          struct tps_pnt *cur_pnts, int max_points,
                          int row, int col,
@@ -223,15 +218,19 @@
     int nextr[8] = {0, -1, 0, 1, -1, -1, 1, 1};
     int nextc[8] = {1, 0, -1, 0, 1, -1, -1, 1};
     int n, found;
-    struct rc next, ngbr_rc;
+    struct rc next, ngbr_rc, *pngbr_rc;
     struct rclist rilist;
-    struct RB_TREE *visited;
+    struct pavl_table *visited;
     double dx, dy, dist;
-    visited = rbtree_create(cmp_rc, sizeof(struct rc));
+    visited = pavl_create(cmp_rc, NULL, NULL);
     ngbr_rc.row = row;
     ngbr_rc.col = col;
-    rbtree_insert(visited, &ngbr_rc);
+    pngbr_rc = G_malloc(sizeof(struct rc));
+    *pngbr_rc = ngbr_rc;
+    pavl_insert(visited, pngbr_rc);
+    pngbr_rc = NULL;
     nrows = src->rows;
     ncols = src->cols;
@@ -271,10 +270,17 @@
 	    ngbr_rc.row = rown;
 	    ngbr_rc.col = coln;
-	    if (rbtree_find(visited, &ngbr_rc))
+	    if (pngbr_rc == NULL)
+	    if (pavl_insert(visited, pngbr_rc) != NULL) {
 		continue;
+	    pngbr_rc = NULL;
 	    rclist_add(&rilist, rown, coln);
 	    if (FLAG_GET(pnt_flag, rown, coln)) {
@@ -310,7 +316,9 @@
     rclist_destroy(&rilist);
-    rbtree_destroy(visited);
+    if (pngbr_rc)
+	G_free(pngbr_rc);
+    pavl_destroy(visited, avl_free_item);
     return found;
@@ -325,16 +333,19 @@
     int n, found;
     ngbr_rc.row = row;
     ngbr_rc.col = col;
+    pngbr_rc = NULL;
     nrows = src->rows;
     ncols = src->cols;
@@ -359,11 +370,17 @@
 	    ngbr_rc.row = rown;
 	    ngbr_rc.col = coln;
 		continue;
+	    pngbr_rc = NULL;
 	    if (!(FLAG_GET(pnt_flag, rown, coln))) {
@@ -387,7 +404,9 @@
     } while (rclist_drop(&rilist, &next));   /* while there are cells to check */
+	G_free(pngbr_rc);
     return found;
@@ -398,7 +417,7 @@
 	      off_t n_points, int min_points,
 	      double regularization, double overlap, int clustered)
-    int ridx, cidx, row, col, nrows, ncols;
+    int ridx, cidx, row, col, nrows, ncols, src_row, src_col;
     double **m, *a, *B;
     int i, j;
     int kdalloc, palloc, n_cur_points;
@@ -408,8 +427,8 @@
     CELL *maskbuf;
     int solved;
     int kdfound, bfsfound, pfound;
-    double distmax;
+    double distmax, mindist;
+    int do_clustered;
     int mask_fd;
     FLAG *mask_flag, *pnt_flag;
     struct tps_out tps_out;
@@ -531,6 +550,8 @@
 	if (ridx & 1)
 	    row = nrows - 1 - row;
+	src_row = row_src2dst(row, dst, src);
 	for (cidx = 0; cidx < ncols; cidx++) {
 	    col = (cidx >> 1);
@@ -556,6 +577,7 @@
 	    solved = 0;
 	    n_cur_points = 0;
 	    kdfound = 0;
+	    src_col = col_src2dst(col, dst, src);
 	    while (!solved) {
@@ -587,16 +609,24 @@
 		cmax = 0;
 		kdfound = bfs_search_nn(pnt_flag, src, cur_pnts,
 		                        n_cur_points,
-					row_dst2src(row, src, dst),
-					col_dst2src(col, src, dst),
+					src_row, src_col,
 					&rmin, &rmax, &cmin, &cmax,
 					&distmax);
-		/* convert src min/max to dst min/max */
+		mindist = n_cur_points / M_PI * 1.5;
+		do_clustered = 0;
+		if (distmax > mindist ||
+		    rmin >= src_row || rmax <= src_row ||
+		    cmin >= src_col || cmax <= src_col) {
+		    do_clustered = 1;
 		pfound = kdfound;
-		if (clustered) {
+		if (clustered && do_clustered) {
 		    /* collect points with breadth-first search
 		     * min dist must be > max dist of nearest neighbors */
@@ -604,11 +634,10 @@
 		    if (rminp <= row && cmaxp > col) {
 			bfsfound = bfs_search(pnt_flag, src,
 			           cur_pnts + pfound,
+				   src_row, src_col,
 				   n_cur_points / 3, distmax,
-				   0, row_dst2src(row, src, dst),
-				   col_dst2src(col, src, dst) + 1, src->cols - 1);
+				   0, src_row,
+				   src_col + 1, src->cols - 1);
 			if (bfsfound == 0)
 			    G_debug(4, "No BFS points for NE quadrant");
@@ -620,11 +649,10 @@
 		    if (rminp < row && cminp <= col) {
 			           cur_pnts + pfound,
+				   src_row, src_col,
-				   0, row_dst2src(row, src, dst) - 1,
-				   0, col_dst2src(col, src, dst));
+				   0, src_row - 1,
+				   0, src_col);
 			if (bfsfound == 0)
 			    G_debug(4, "No BFS points for NW quadrant");
@@ -636,11 +664,10 @@
 		    if (rmaxp >= row && cminp < col) {
 			           cur_pnts + pfound,
+				   src_row, src_col,
-				   row_dst2src(row, src, dst), src->rows - 1,
-				   0, col_dst2src(col, src, dst) - 1);
+				   src_row, src->rows - 1,
+				   0, src_col - 1);
 			if (bfsfound == 0)
 			    G_debug(4, "No BFS points for SW quadrant");
@@ -652,11 +679,10 @@
 		    if (rmaxp > row && cmaxp >= col) {
 			           cur_pnts + pfound,
+				   src_row, src_col,
-				   row_dst2src(row, src, dst) + 1, src->rows - 1,
-				   col_dst2src(col, src, dst), src->cols - 1);
+				   src_row + 1, src->rows - 1,
+				   src_col, src->cols - 1);
 			if (bfsfound == 0)
 			    G_debug(4, "No BFS points for SE quadrant");
