[GRASS-SVN] r69896 - grass/trunk/raster/r.texture
svn_grass at osgeo.org
Thu Nov 24 06:45:52 PST 2016
Author: mlennert
Date: 2016-11-24 06:45:51 -0800 (Thu, 24 Nov 2016)
New Revision: 69896
Added:
grass/trunk/raster/r.texture/r_texture_directions_example.png
grass/trunk/raster/r.texture/r.texture.html
r.texture: further improvement of man page, including image example
Modified: grass/trunk/raster/r.texture/r.texture.html
--- grass/trunk/raster/r.texture/r.texture.html 2016-11-24 14:25:17 UTC (rev 69895)
+++ grass/trunk/raster/r.texture/r.texture.html 2016-11-24 14:45:51 UTC (rev 69896)
@@ -11,7 +11,7 @@
of <em>r.texture</em> can thus be used as input to supervised classification
algorithms such as <a href="i.maxlik.html">i.maxlik</a> or
<a href="i.smap.html">i.smap</a>, or for characterizing objects resulting
-from a href="i.segment.html">i.segment</a>, for example as one of the
+from <a href="i.segment.html">i.segment</a>, for example as one of the
raster inputs of the
<a href="https://grass.osgeo.org/grass70/manuals/addons/i.segment.stats.html">
i.segment.stats</a> addon.
@@ -120,6 +120,12 @@
should be analyzed.
<p>
+Note that the output of <em>r.texture</em> will always be smaller than
+the current region as only cells for which there are no null cells and
+for which all cells of the moving window are within the current region
+will contain a value. The output will thus appear cropped at the margins.
+<p>
Importantly, the input raster map cannot have more than 255 categories.
<h2>EXAMPLE</h2>
@@ -151,6 +157,52 @@
The recoded raster map can then be used as input for r.texture as before.
+<p>
+Second example: analysis of IDM (homogeneity) on a simple raster with
+North-South line pattern.
+<div class="code"><pre>
+# import raster
+r.in.ascii in=- output=lines << EOF
+> north: 9
+> south: 0
+> east: 9
+> west: 0
+> rows: 9
+> cols: 9
+> 0 0 0 1 0 0 0 1 0
+> EOF
+# adjust region to raster
+g.region rast=lines
+# calculate IDM (homogeneity) in all directions
+r.texture -s lines method=idm out=text_lines
+</pre></div>
+<p>
+The following image shows the original map, the result in East-West direction
+and the result in North-South direction, showing how texture can depend on
+direction, with texture perfectly homogeneous (value=1) in the North-South
+direction, but quite heterogeneous in East-West direction, except for those
+areas where there are three columns of equal values (as size=3).
+The overlayed grid highlights that the texture measures output maps
+are cropped at the margins.
+<center>
+ <img src="r_texture_directions_example.png" border=1><br>
+ <i>IDM textures according to direction</i>
+</center>
<h2>KNOWN ISSUES</h2>
The program can run incredibly slow for large raster maps.
@@ -181,8 +233,12 @@
<h2>SEE ALSO</h2>
<em>
+<a href="i.maxlik.html">i.maxlik</a>,
+<a href="i.gensig.html">i.gensig</a>,
<a href="i.gensigset.html">i.gensigset</a>,
+<a href="https://grass.osgeo.org/grass70/manuals/addons/i.segment.stats.html">
+ i.segment.stats</a>,
<a href="i.pca.html">i.pca</a>,
<a href="r.neighbors.html">r.neighbors</a>,
<a href="r.rescale.html">r.rescale</a>
Added: grass/trunk/raster/r.texture/r_texture_directions_example.png
(Binary files differ)
Property changes on: grass/trunk/raster/r.texture/r_texture_directions_example.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
