[GRASS-SVN] r69906 - grass-addons/grass7/raster/r.green/r.green.hydro/libhydro
svn_grass at osgeo.org
Thu Nov 24 22:52:10 PST 2016
Author: Giulia
Date: 2016-11-24 22:52:10 -0800 (Thu, 24 Nov 2016)
New Revision: 69906
grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py
r.green: fig bug on the length of the river segments
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py 2016-11-25 06:50:44 UTC (rev 69905)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py 2016-11-25 06:52:10 UTC (rev 69906)
@@ -10,6 +10,7 @@
import sys
import numpy as np
+import math
#from grass.script import mapcalc
version = 70 # 71
@@ -57,6 +58,50 @@
return -dh*fun_q(x[0])
+def find_s_z(s, *params):
+ #msgr = get_msgr()
+ x0, prog, h, l_max = params
+ fun_h = interpolate.interp1d(prog, h, bounds_error=False, fill_value=0)
+ delta_h = abs(fun_h(x0+s) - fun_h(x0))
+ theta = math.atan(delta_h/s)
+ return l_max-abs(s/math.cos(theta))
+def min_len_plant_z(prog, h, l_max, range_plant, range_line, tol=10.):
+ start, end = range_line
+ len_plant = []
+ if end - start > tol:
+ num = int((end-start-tol)/tol)
+ for x0 in np.linspace(start, end-1, num=num):
+ sol, infodict, ier, mesg = fsolve(find_s_z, [0], args=(x0,
+ prog, h, l_max),
+ full_output=True)
+ if ier == 1:
+ #import pdb; pdb.set_trace()
+ len_plant.append(sol[0])
+ else:
+ len_plant.append(0)
+ len_plant = np.array(len_plant)
+ order = np.argsort(len_plant)
+ x_ink = np.linspace(start, end-tol, num=num)[order]
+ x_rest = x_ink + len_plant[order]
+ s = len_plant[order]
+ aaa = x_rest < end
+ bbb = s > 0
+ ccc = aaa * bbb
+ if ccc.any():
+ if len_plant.sum() == 0:
+ return (start, end-start)
+ else:
+ return (x_ink[ccc][0],
+ s[ccc][0])
+ else:
+ else:
def find_s(s, *params):
#msgr = get_msgr()
x0, prog, h, q, p_max = params
@@ -178,7 +223,7 @@
def recursive_plant(args, range_plant, distance,
- start, end, rank, cat, line, plants, count, p_max):
+ start, end, rank, cat, line, plants, count, p_max,):
msgr = get_msgr()
count = count + 1
#import ipdb; ipdb.set_trace()
@@ -199,16 +244,21 @@
prog, h, q = args
fun_q = interpolate.interp1d(prog, q, bounds_error=False, fill_value=0)
- len_plant = range_plant[1]
- len_min = range_plant[0]
+ delta_h = fun_h(end) - fun_h(start)
+ theta = math.atan(delta_h/(end-start))
+ len_p = end-start
+ dis = abs(distance*math.cos(theta))
+ len_plant = range_plant[1]*math.cos(theta)
+ len_min = range_plant[0]*math.cos(theta)
if count < 6:
- if (end-start) > len_plant + 2*distance:
+ if len_p > len_plant + 2*dis:
+ # if (end-start) > len_plant + 2*distance:
if not(p_max):
- x_min = find_optimal(args, range_plant,
- (start+distance, end-distance))
+ x_min = find_optimal(args, (len_min, len_plant),
+ (start+dis, end-dis))
else:
- x_min = min_len_plant(prog, h, q, p_max, range_plant,
+ x_min = min_len_plant(prog, h, q, p_max, (len_min, len_plant),
seg = line.segment(x_min[0], x_min[0]+x_min[1])
if seg:
ink = Intake(id_point=str(1), id_plants=rank, id_stream=cat,
@@ -223,16 +273,18 @@
restitution=res, intakes=(ink,),
line=seg)
return p, x_min
- elif ((end-start-2*distance) > len_min
- and ((end-start) < len_plant + 2*distance)):
- len_plant = end-start-2*distance
- range_plant = (len_min, len_plant)
+ elif ((len_p-2*dis) > len_min
+ and (len_p < len_plant + 2*dis)):
+ len_plant = end-start-2*dis
+ range_plant = (range_plant[0], len_plant/math.cos(theta))
if not(p_max):
+# x_min = min_len_plant_z(prog, h, l_max, range_plant,
+# (start+distance, end-distance))
else:
if seg:
