[GRASS-SVN] r69918 - in grass-addons/grass7/raster: . r.colors.out_sld
Fri Nov 25 14:39:41 PST 2016
Author: sbl
Date: 2016-11-25 14:39:41 -0800 (Fri, 25 Nov 2016)
New Revision: 69918
Added:
   grass-addons/grass7/raster/r.colors.out_sld/
   grass-addons/grass7/raster/r.colors.out_sld/Makefile
   grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.html
   grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.py
r.colors.out_sld ported to G7/Python
Added: grass-addons/grass7/raster/r.colors.out_sld/Makefile
--- grass-addons/grass7/raster/r.colors.out_sld/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.colors.out_sld/Makefile	2016-11-25 22:39:41 UTC (rev 69918)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.colors.out_sld
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.html
--- grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.html	2016-11-25 22:39:41 UTC (rev 69918)
@@ -0,0 +1,36 @@
+<h2>DESCRIPTION:</h2>
+<p>The module <em>r.colors.out_sld</em> exports the colors of a raster map into
+the Styled Layer Description (SLD) format according to OGC standard.</p>
+For raster maps of tyoe CELL also lables are exported. The export if lables
+requires that the input map is read and may thus take a bit longer than the
+export of contious color rules (ramp).</p>
+<p>Currently only SLD v1.0.0 is implemented.</p>
+<div id="examples">
+<h2>EXAMPLES:</h2>
+<div class="code"><pre>
+# Exporting a color ramp
+r.out.colors_sld map=Testmap style_name=Celsius
+</pre></div>
+</div>
+<div id="seealso">
+<h2>SEE ALSO:</h2>
+<a href="r.colors.out.html">r.colors.out</a>
+</div>
+<div id="references">
+<h2>REFERENCES:</h2>
+<a href="http://www.opengeospatial.org/standards/sld">
+http://www.opengeospatial.org/standards/sld</a><br></div>
+<div id="author">
+<h2>AUTHORS:</h2>
+Hamish Bowman<br>
+Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo, Norway<br>
+</div>
Added: grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.py
--- grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.py	2016-11-25 22:39:41 UTC (rev 69918)
@@ -0,0 +1,175 @@
+#!/usr/bin/env python
+MODULE:       r.colors.out_sld
+AUTHOR(S):    Hamish Bowman
+              Stefan Blumentrath, NINA: Port to GRASS GIS 7 / Python,
+              lable and opacity support
+PURPOSE:      Export GRASS raster color table to OGC SLD template v1.0.0
+COPYRIGHT:    (C) 2011 by Hamish Bowman, and the GRASS Development Team
+ This program is free software; you can redistribute it and/or modify
+ it under the terms of the GNU General Public License as published by
+ the Free Software Foundation; either version 2 of the License, or
+ (at your option) any later version.
+ This program is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ GNU General Public License for more details.
+Based on hints from
+http://docs.geoserver.org/stable/en/user/styling/sld/reference/rastersymbolizer.html
+To Dos:
+- add category support
+- add transparency support
+- support for intervalls ColorMap?
+#%Module
+#% description: Exports the color table associated with a raster map layer in SLD format.
+#% keywords: raster, export, color table
+#%End
+#%Option G_OPT_R_MAP
+#% required: yes
+#%End
+#%Option
+#% key: style_name
+#% required: no
+#% label: Name for style
+#% description: A name for the style which might be displayed on the server
+#% answer: GRASS color table
+#%End
+#%Option G_OPT_F_OUTPUT
+#% required: no
+#% label: Name for output SLD rules file
+#% description: "-" to write to stdout
+#% answer: -
+#%End
+import os
+import sys
+import grass.script as grass
+if not os.environ.has_key("GISBASE"):
+    grass.message( "You must be in GRASS GIS to run this program." )
+    sys.exit(1)
+def set_output_encoding(encoding='utf-8'):
+    import codecs
+    current = sys.stdout.encoding
+    if current is None :
+        sys.stdout = codecs.getwriter(encoding)(sys.stdout)
+    current = sys.stderr.encoding
+        sys.stderr = codecs.getwriter(encoding)(sys.stderr)
+def main():
+    # Set output encoding to UTF-8
+    set_output_encoding()
+    # Parse input
+    output = options['output'] # done
+    style_name = options['style_name'] # done
+    map = options['map'] # done
+    # Get map metadata
+    mapinfo = grass.parse_command('r.info', flags='e', map=map)
+    if mapinfo['title']:
+        name = '{} : {}'.format(mapinfo['map'], mapinfo['title'])
+    else:
+        name = mapinfo['map']
+    # Get color rules
+    color_rules = grass.read_command('r.colors.out', map=map).split('\n')
+    # Get maptype (CELL, FCELL, DCELL)
+    maptype = grass.parse_command('r.info', flags='g', map=map)['datatype']
+    # Check if map has categories if type is CELL
+    if maptype == 'CELL':
+        grass.verbose('Reading category lables, may take a while...')
+        categories = grass.parse_command('r.category', map=map, separator='=')
+    if list(set(categories.values()))[0] or len(list(set(categories.values()))) > 1:
+        use_categories = True
+    # Initialize SLD with header
+    sld = u"""<?xml version="1.0" encoding="UTF-8"?>
+<StyledLayerDescriptor version="1.0.0"
+    xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
+    xmlns="http://www.opengis.net/sld"
+    xmlns:ogc="http://www.opengis.net/ogc"
+    xmlns:xlink="http://www.w3.org/1999/xlink"
+    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
+  <NamedLayer>
+    <Name>{}</Name>""".format(style_name)
+    sld+=u"""    <UserStyle>
+      <Title>{}</Title>\n
+      <FeatureTypeStyle>
+        <Rule>
+          <RasterSymbolizer>\n""".format(name)
+    # Define type of ColorMap depending on data type of input map
+    if use_categories:
+        sld+=u'            <ColorMap type={}>\n'.format('"values"')
+        ColorMapEntry = u'              <ColorMapEntry color="#{0:02x}{1:02x}{2:02x}" quantity="{3}" label="{4}" opacity="{5}" />\n'
+    else:
+        sld+=u'            <ColorMap>\n'
+        # sld+='            <ColorMap type={}>\n'.format('"ramp"')
+        ColorMapEntry = u'              <ColorMapEntry color="#{0:02x}{1:02x}{2:02x}" quantity="{3}" opacity="{4}" />\n'
+    for c in color_rules:
+        if len(c.split(' ')) == 2 and not c.split(' ')[0] == 'default':
+            q = c.split(' ')[0]
+            if q == 'nv':
+                q = u'NaN'
+                r = 255
+                g = 255
+                b = 255
+                o = 0
+            else:
+                r = int(c.split(' ')[1].split(':')[0])
+                g = int(c.split(' ')[1].split(':')[1])
+                b = int(c.split(' ')[1].split(':')[2])
+                o = 1
+                if str(q) in categories.keys():
+                    l = categories[str(q)]
+                elif q == u'NaN':
+                    l = u'NoData'
+                else:
+                    continue
+                sld+=ColorMapEntry.format(r,g,b,q,l,o)
+            else:
+                sld+=ColorMapEntry.format(r,g,b,q,o)
+    # write file footer
+    sld+=u"""            </ColorMap>
+          </RasterSymbolizer>
+        </Rule>
+      </FeatureTypeStyle>
+    </UserStyle>
+  </NamedLayer>
+</StyledLayerDescriptor>\n"""
+    if output == '-':
+        # Write SLD to stdout if no output is requested
+        print sld
+    else:
+        # Write SLD to file if requested
+        with open(output, 'w+') as o:
+            o.write(sld.encode('utf8'))
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.colors.out_sld/r.colors.out_sld.py
___________________________________________________________________
Added: svn:executable
