[GRASS-SVN] r69921 - in grass-addons/grass7/raster/r.green/r.green.hydro: r.green.hydro.delplants r.green.hydro.discharge r.green.hydro.financial r.green.hydro.optimal r.green.hydro.recommended r.green.hydro.structure r.green.hydro.technical r.green.hydro.theoretical
Fri Nov 25 14:57:40 PST 2016
Author: Giulia
Date: 2016-11-25 14:57:40 -0800 (Fri, 25 Nov 2016)
New Revision: 69921
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
r.green:fix path library
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.delplants/r.green.hydro.delplants.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -117,8 +117,8 @@
     from libhydro.plant import read_plants, write_plants
 except ImportError:
     try:
-        set_path('r.green', 'libhydro', '../etc')
-        set_path('r.green', 'libgreen', '../etc')
+        set_path('r.green', 'libhydro', os.path.join('..', 'etc', 'r.green'))
+        set_path('r.green', 'libgreen', os.path.join('..', 'etc', 'r.green'))
         from libgreen.utils import cleanup
         from libgreen.checkparameter import (check_required_columns,
                                              exception2error)
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -180,8 +180,8 @@
     from libhydro.basin import dtm_corr
 except ImportError:
     try:
     except ImportError:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -526,8 +526,8 @@
 except ImportError:
     try:
     except ImportError:
         warning('libgreen and libhydro not in the python path!')
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -118,8 +118,8 @@
     from libhydro.optimal import write_points
 except ImportError:
     try:
         from libgreen.utils import dissolve_lines
         from libhydro.optimal import find_segments
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -213,8 +213,8 @@
     from libhydro.plant import power2energy
 except ImportError:
     try:
     except ImportError:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.structure/r.green.hydro.structure.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -145,8 +145,8 @@
 except ImportError:
     try:
     except ImportError:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -250,8 +250,8 @@
     from libhydro.optimal import conv_segpoints
 except ImportError:
     try:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2016-11-25 22:42:38 UTC (rev 69920)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2016-11-25 22:57:40 UTC (rev 69921)
@@ -114,8 +114,8 @@
     from libgreen.utils import remove_pixel_from_raster
 except ImportError:
     try:
