[GRASS-SVN] r69924 - grass-addons/grass7/raster/r.in.srtm.region
svn_grass at osgeo.org
Sat Nov 26 07:14:16 PST 2016
Author: neteler
Date: 2016-11-26 07:14:16 -0800 (Sat, 26 Nov 2016)
New Revision: 69924
grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
r.in.srtm.region addon: support for new USGS user authentication (contributed by Jonas Strobel)
Modified: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py 2016-11-26 15:14:04 UTC (rev 69923)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py 2016-11-26 15:14:16 UTC (rev 69924)
@@ -5,10 +5,11 @@
# MODULE: r.in.srtm.region
# AUTHOR(S): Markus Metz
+# URL authenticaton added by Jonas Strobel, intern at mundialis and terrestris, Bonn
# PURPOSE: Create a DEM from 3 arcsec SRTM v2.1 or 1 arcsec SRTM v3 tiles
-# COPYRIGHT: (C) 2011 GRASS development team
+# COPYRIGHT: (C) 2011-2016 GRASS development team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -26,14 +27,24 @@
#% required: yes
#%end
#%option
+#% key: username
+#% description: Username for authentication
+#% required: yes
+#%end
+#%option
+#% key: password
+#% description: Password for authentication
+#% required: yes
+#%end
+#%option
#% key: url
-#% description: base url to fetch SRTM tiles
+#% description: Base URL to fetch SRTM tiles
#% required: no
#%end
#%option G_OPT_M_DIR
#% key: local
-#% label: local folder with SRTM tiles
-#% description: use local folder instead of url to retrieve SRTM tiles
+#% label: Local folder with SRTM tiles
+#% description: Use local folder instead of URL to retrieve SRTM tiles
#% required: no
#%end
#%option
@@ -75,14 +86,12 @@
'UNIT["degree",0.0174532925199433]',
-import sys
import os
-import shutil
import atexit
import urllib
import urllib2
import time
+from cookielib import CookieJar
import grass.script as grass
def import_local_tile(tile, local, pid, srtmv3, one):
@@ -118,7 +127,7 @@
return 0
-def download_tile(tile, url, pid, srtmv3, one):
+def download_tile(tile, url, pid, srtmv3, one, username, password):
output = tile + '.r.in.srtm.tmp.' + str(pid)
if srtmv3:
if one:
@@ -133,31 +142,42 @@
if srtmv3:
remote_tile = str(url) + local_tile
goturl = 1
try:
- f = urllib2.urlopen(remote_tile)
+ password_manager = urllib2.HTTPPasswordMgrWithDefaultRealm()
+ password_manager.add_password(None, "https://urs.earthdata.nasa.gov", username, password)
+ cookie_jar = CookieJar()
+ opener = urllib2.build_opener(
+ urllib2.HTTPBasicAuthHandler(password_manager),
+ #urllib2.HTTPHandler(debuglevel=1), # Uncomment these two lines to see
+ #urllib2.HTTPSHandler(debuglevel=1), # details of the requests/responses
+ urllib2.HTTPCookieProcessor(cookie_jar))
+ urllib2.install_opener(opener)
+ request = urllib2.Request(remote_tile)
+ response = urllib2.urlopen(request)
fo = open(local_tile, 'w+b')
- fo.write(f.read())
+ fo.write(response.read())
fo.close
time.sleep(0.5)
- # does not work:
- #urllib.urlretrieve(remote_tile, local_tile, data = None)
except:
goturl = 0
pass
return goturl
# SRTM subdirs: Africa, Australia, Eurasia, Islands, North_America, South_America
for srtmdir in ('Africa', 'Australia', 'Eurasia', 'Islands', 'North_America', 'South_America'):
remote_tile = str(url) + str(srtmdir) + '/' + local_tile
goturl = 1
try:
fo.close
time.sleep(0.5)
# does not work:
@@ -186,6 +206,8 @@
in_temp = False
url = options['url']
+ username = options['username']
+ password = options['password']
local = options['local']
output = options['output']
memory = options['memory']
@@ -310,7 +332,7 @@
if local != tmpdir:
gotit = import_local_tile(tile, local, pid, srtmv3, one)
else:
- gotit = download_tile(tile, url, pid, srtmv3, one)
+ gotit = download_tile(tile, url, pid, srtmv3, one, username, password)
if gotit == 1:
gotit = import_local_tile(tile, tmpdir, pid, srtmv3, one)
if gotit == 1:
@@ -360,7 +382,7 @@
if local != tmpdir:
grass.fatal(_("Please check if local folder <%s> is correct.") % local)
else:
- grass.fatal(_("Please check internet connection and if url <%s> is correct.") % url)
+ grass.fatal(_("Please check internet connection, credentials, and if url <%s> is correct.") % url)
grass.run_command('g.region', raster = str(srtmtiles));
