[GRASS-SVN] r69935 - grass/trunk/lib/vector/dglib
svn_grass at osgeo.org
Sun Nov 27 23:51:51 PST 2016
Author: mmetz
Date: 2016-11-27 23:51:51 -0800 (Sun, 27 Nov 2016)
New Revision: 69935
grass/trunk/lib/vector/dglib/avl.c
grass/trunk/lib/vector/dglib/avl.h
grass/trunk/lib/vector/dglib/tavl.c
grass/trunk/lib/vector/dglib/tavl.h
grass/trunk/lib/vector/dglib/tree.h
dglib: update to libavl-2.0.3
Modified: grass/trunk/lib/vector/dglib/avl.c
--- grass/trunk/lib/vector/dglib/avl.c 2016-11-28 07:30:35 UTC (rev 69934)
+++ grass/trunk/lib/vector/dglib/avl.c 2016-11-28 07:51:51 UTC (rev 69935)
@@ -1,25 +1,28 @@
-/* Produced by texiweb from libavl.w on 2002/02/09 at 01:45. */
+/* Produced by texiweb from libavl.w. */
/* libavl - library for manipulation of binary trees.
- Copyright (C) 1998-2002 Free Software Foundation, Inc.
+ Copyright (C) 1998, 1999, 2000, 2001, 2002, 2004 Free Software
+ Foundation, Inc.
- This program is free software; you can redistribute it and/or
- modify it under the terms of the GNU General Public License as
- published by the Free Software Foundation; either version 2 of the
- License, or (at your option) any later version.
+ This library is free software; you can redistribute it and/or
+ modify it under the terms of the GNU Lesser General Public
+ License as published by the Free Software Foundation; either
+ version 3 of the License, or (at your option) any later version.
- This program is distributed in the hope that it will be useful, but
- WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- See the GNU General Public License for more details.
+ This library is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ Lesser General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program; if not, write to the Free Software
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+ You should have received a copy of the GNU Lesser General Public
+ License along with this library; if not, write to the Free Software
+ Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
+ 02110-1301 USA.
- The author may be contacted at <blp at gnu.org> on the Internet, or
- as Ben Pfaff, 12167 Airport Rd, DeWitt MI 48820, USA through more
- mundane means.
+/* Nov 2016, Markus Metz
+ * from libavl-2.0.3
+ * added safety checks and speed optimizations
#include <assert.h>
@@ -63,15 +66,15 @@
const struct avl_node *p;
assert(tree != NULL && item != NULL);
- for (p = tree->avl_root; p != NULL;) {
+ p = tree->avl_root;
+ while (p != NULL) {
int cmp = tree->avl_compare(item, p->avl_data, tree->avl_param);
- if (cmp < 0)
- p = p->avl_link[0];
- else if (cmp > 0)
- p = p->avl_link[1];
- else /* |cmp == 0| */
+ if (cmp == 0)
return p->avl_data;
+ p = p->avl_link[cmp > 0];
return NULL;
@@ -97,7 +100,8 @@
z = (struct avl_node *)&tree->avl_root;
y = tree->avl_root;
dir = 0;
- for (q = z, p = y; p != NULL; q = p, p = p->avl_link[dir]) {
+ q = z, p = y;
if (cmp == 0)
@@ -106,25 +110,33 @@
if (p->avl_balance != 0)
z = q, y = p, k = 0;
da[k++] = dir = cmp > 0;
+ q = p, p = p->avl_link[dir];
- n = q->avl_link[dir] =
- tree->avl_alloc->libavl_malloc(tree->avl_alloc, sizeof *n);
+ n = tree->avl_alloc->libavl_malloc(tree->avl_alloc, sizeof *n);
if (n == NULL)
return NULL;
tree->avl_count++;
+ tree->avl_generation++;
+ n->avl_link[0] = n->avl_link[1] = NULL;
n->avl_data = item;
- n->avl_link[0] = n->avl_link[1] = NULL;
n->avl_balance = 0;
- if (y == NULL)
+ if (y == NULL) {
+ tree->avl_root = n;
return &n->avl_data;
+ q->avl_link[dir] = n;
- for (p = y, k = 0; p != n; p = p->avl_link[da[k]], k++)
+ p = y, k = 0;
+ while (p != n) {
if (da[k] == 0)
p->avl_balance--;
else
p->avl_balance++;
+ p = p->avl_link[da[k]], k++;
if (y->avl_balance == -2) {
struct avl_node *x = y->avl_link[0];
@@ -180,7 +192,6 @@
z->avl_link[y != z->avl_link[0]] = w;
- tree->avl_generation++;
@@ -209,6 +220,7 @@
void *r = *p;
*p = item;
return r;
@@ -223,23 +235,31 @@
int k; /* Stack pointer. */
struct avl_node *p; /* Traverses tree to find node to delete. */
+ int dir; /* Side of |pa[k]| on which |p| is linked. */
int cmp; /* Result of comparison between |item| and |p|. */
- k = 0;
- p = (struct avl_node *)&tree->avl_root;
- for (cmp = -1; cmp != 0;
- cmp = tree->avl_compare(item, p->avl_data, tree->avl_param)) {
- int dir = cmp > 0;
+ pa[0] = (struct avl_node *)&tree->avl_root;
+ da[0] = 0;
+ k = 1;
+ cmp = tree->avl_compare(item, p->avl_data, tree->avl_param);
+ if (cmp == 0)
+ break;
+ dir = cmp > 0;
pa[k] = p;
da[k++] = dir;
- if (p == NULL)
- return NULL;
+ if (p == NULL)
+ return NULL;
item = p->avl_data;
if (p->avl_link[1] == NULL)
@@ -258,7 +278,7 @@
struct avl_node *s;
int j = k++;
- for (;;) {
+ while (r != NULL) {
da[k] = 0;
pa[k++] = r;
s = r->avl_link[0];
@@ -367,6 +387,7 @@
tree->avl_count--;
return (void *)item;
@@ -463,31 +484,30 @@
void *avl_t_find(struct avl_traverser *trav, struct avl_table *tree,
void *item)
- struct avl_node *p, *q;
+ struct avl_node *p;
assert(trav != NULL && tree != NULL && item != NULL);
trav->avl_table = tree;
trav->avl_height = 0;
trav->avl_generation = tree->avl_generation;
- for (p = tree->avl_root; p != NULL; p = q) {
- if (cmp < 0)
- q = p->avl_link[0];
- else if (cmp > 0)
- q = p->avl_link[1];
- else { /* |cmp == 0| */
+ if (cmp == 0) {
+ trav->avl_node = p;
- trav->avl_node = p;
return p->avl_data;
assert(trav->avl_height < AVL_MAX_HEIGHT);
trav->avl_stack[trav->avl_height++] = p;
trav->avl_node = NULL;
return NULL;
@@ -512,10 +532,12 @@
((char *)p - offsetof(struct avl_node, avl_data)));
trav->avl_generation = tree->avl_generation - 1;
return *p;
else {
avl_t_init(trav, tree);
return NULL;
@@ -644,14 +666,18 @@
The new item must not upset the ordering of the tree. */
void *avl_t_replace(struct avl_traverser *trav, void *new)
- struct avl_node *old;
+ void *old;
assert(trav != NULL && trav->avl_node != NULL && new != NULL);
old = trav->avl_node->avl_data;
trav->avl_node->avl_data = new;
return old;
+/* Destroys |new| with |avl_destroy (new, destroy)|,
+ first setting right links of nodes in |stack| within |new|
+ to null pointers to avoid touching uninitialized data. */
static void
copy_error_recovery(struct avl_node **stack, int height,
struct avl_table *new, avl_item_func * destroy)
@@ -688,13 +714,14 @@
allocator != NULL ? allocator : org->avl_alloc);
if (new == NULL)
return NULL;
new->avl_count = org->avl_count;
if (new->avl_count == 0)
return new;
x = (const struct avl_node *)&org->avl_root;
y = (struct avl_node *)&new->avl_root;
- for (;;) {
+ while (x != NULL) {
while (x->avl_link[0] != NULL) {
assert(height < 2 * (AVL_MAX_HEIGHT + 1));
@@ -754,6 +781,8 @@
x = stack[--height];
+ return new;
/* Frees storage allocated for |tree|.
@@ -764,7 +793,8 @@
assert(tree != NULL);
if (p->avl_link[0] == NULL) {
q = p->avl_link[1];
if (destroy != NULL && p->avl_data != NULL)
@@ -776,6 +806,8 @@
p->avl_link[0] = q->avl_link[1];
q->avl_link[1] = p;
+ p = q;
tree->avl_alloc->libavl_free(tree->avl_alloc, tree);
@@ -785,6 +817,7 @@
void *avl_malloc(struct libavl_allocator *allocator, size_t size)
assert(allocator != NULL && size > 0);
return malloc(size);
@@ -801,6 +834,9 @@
avl_free
+#undef NDEBUG
+#include <assert.h>
/* Asserts that |avl_insert()| succeeds at inserting |item| into |table|. */
void (avl_assert_insert) (struct avl_table * table, void *item)
@@ -816,5 +852,6 @@
void *p = avl_delete(table, item);
assert(p != NULL);
return p;
Modified: grass/trunk/lib/vector/dglib/avl.h
--- grass/trunk/lib/vector/dglib/avl.h 2016-11-28 07:30:35 UTC (rev 69934)
+++ grass/trunk/lib/vector/dglib/avl.h 2016-11-28 07:51:51 UTC (rev 69935)
@@ -1,25 +1,23 @@
+ Foundation, Inc.
- mundane means.
+ 02110-1301 USA.
#ifndef AVL_H
@@ -48,9 +46,9 @@
void *avl_malloc(struct libavl_allocator *, size_t);
void avl_free(struct libavl_allocator *, void *);
-/* Maximum AVL height. */
+/* Maximum AVL tree height. */
#ifndef AVL_MAX_HEIGHT
-#define AVL_MAX_HEIGHT 32
+#define AVL_MAX_HEIGHT 92
#endif
/* Tree data structure. */
Modified: grass/trunk/lib/vector/dglib/tavl.c
--- grass/trunk/lib/vector/dglib/tavl.c 2016-11-28 07:30:35 UTC (rev 69934)
+++ grass/trunk/lib/vector/dglib/tavl.c 2016-11-28 07:51:51 UTC (rev 69935)
@@ -1,25 +1,28 @@
+ Foundation, Inc.
+ 02110-1301 USA.
- mundane means.
#include <assert.h>
@@ -63,10 +66,7 @@
p = tree->tavl_root;
- if (p == NULL)
- return NULL;
- for (;;) {
int cmp, dir;
cmp = tree->tavl_compare(item, p->tavl_data, tree->tavl_param);
@@ -77,8 +77,10 @@
if (p->tavl_tag[dir] == TAVL_CHILD)
p = p->tavl_link[dir];
else
- return NULL;
+ p = NULL;
+ return NULL;
/* Inserts |item| into |tree| and returns a pointer to |item|'s address.
@@ -100,25 +102,22 @@
z = (struct tavl_node *)&tree->tavl_root;
y = tree->tavl_root;
- if (y != NULL) {
- for (q = z, p = y;; q = p, p = p->tavl_link[dir]) {
- int cmp =
- tree->tavl_compare(item, p->tavl_data, tree->tavl_param);
- if (cmp == 0)
- return &p->tavl_data;
+ dir = 0;
+ q = z, p = y;
+ int cmp =
+ tree->tavl_compare(item, p->tavl_data, tree->tavl_param);
+ if (cmp == 0)
+ return &p->tavl_data;
- if (p->tavl_balance != 0)
- z = q, y = p, k = 0;
- da[k++] = dir = cmp > 0;
+ if (p->tavl_balance != 0)
+ z = q, y = p, k = 0;
+ da[k++] = dir = cmp > 0;
- if (p->tavl_tag[dir] == TAVL_THREAD)
- break;
+ if (p->tavl_tag[dir] == TAVL_THREAD)
+ break;
+ q = p, p = p->tavl_link[dir];
- else {
- p = z;
- dir = 0;
n = tree->tavl_alloc->libavl_malloc(tree->tavl_alloc, sizeof *n);
if (n == NULL)
@@ -127,23 +126,26 @@
tree->tavl_count++;
n->tavl_data = item;
n->tavl_tag[0] = n->tavl_tag[1] = TAVL_THREAD;
+ n->tavl_balance = 0;
+ if (y == NULL) {
+ n->tavl_link[0] = n->tavl_link[1] = NULL;
+ tree->tavl_root = n;
+ return &n->tavl_data;
n->tavl_link[dir] = p->tavl_link[dir];
- if (tree->tavl_root != NULL) {
- p->tavl_tag[dir] = TAVL_CHILD;
- n->tavl_link[!dir] = p;
- else
- n->tavl_link[1] = NULL;
+ n->tavl_link[!dir] = p;
+ p->tavl_tag[dir] = TAVL_CHILD;
p->tavl_link[dir] = n;
- n->tavl_balance = 0;
- if (tree->tavl_root == n)
- return &n->tavl_data;
- for (p = y, k = 0; p != n; p = p->tavl_link[da[k]], k++)
+ p = y, k = 0;
+ while (p != n) {
if (da[k] == 0)
p->tavl_balance--;
else
p->tavl_balance++;
+ p = p->tavl_link[da[k]], k++;
if (y->tavl_balance == -2) {
struct tavl_node *x = y->tavl_link[0];
@@ -259,6 +261,7 @@
void *r = *p;
*p = item;
return r;
@@ -308,19 +311,26 @@
- if (tree->tavl_root == NULL)
- return NULL;
+ q = (struct tavl_node *)&tree->tavl_root;
+ p = tree->tavl_root;
+ dir = 0;
+ cmp = tree->tavl_compare(item, p->tavl_data, tree->tavl_param);
- p = (struct tavl_node *)&tree->tavl_root;
- cmp = tree->tavl_compare(item, p->tavl_data, tree->tavl_param)) {
+ if (cmp == 0)
+ break;
dir = cmp > 0;
q = p;
- return NULL;
- p = p->tavl_link[dir];
+ if (p->tavl_tag[dir] == TAVL_CHILD)
+ p = p->tavl_link[dir];
+ else
+ p = NULL;
+ if (p == NULL)
+ return NULL;
item = p->tavl_data;
if (p->tavl_tag[1] == TAVL_THREAD) {
@@ -359,7 +369,7 @@
else {
struct tavl_node *s;
- for (;;) {
s = r->tavl_link[0];
if (s->tavl_tag[0] == TAVL_THREAD)
break;
@@ -527,6 +537,7 @@
tree->tavl_count--;
@@ -590,15 +601,13 @@
trav->tavl_node = NULL;
- if (p == NULL)
- return NULL;
- for (;;) {
int cmp, dir;
if (cmp == 0) {
trav->tavl_node = p;
return p->tavl_data;
@@ -606,8 +615,12 @@
else
- return NULL;
+ p = NULL;
+ trav->tavl_node = NULL;
+ return NULL;
/* Attempts to insert |item| into |tree|.
@@ -634,6 +647,7 @@
else {
tavl_t_init(trav, tree);
return NULL;
@@ -705,11 +719,12 @@
void *tavl_t_replace(struct tavl_traverser *trav, void *new)
- struct tavl_node *old;
+ void *old;
assert(trav != NULL && trav->tavl_node != NULL && new != NULL);
old = trav->tavl_node->tavl_data;
trav->tavl_node->tavl_data = new;
return old;
@@ -748,6 +763,9 @@
return 1;
+/* Destroys |new| with |tavl_destroy (new, destroy)|,
+ first initializing the right link in |new| that has
+ not yet been initialized. */
static void
copy_error_recovery(struct tavl_node *p,
struct tavl_table *new, tavl_item_func * destroy)
@@ -798,7 +816,7 @@
rq.tavl_link[0] = NULL;
rq.tavl_tag[0] = TAVL_THREAD;
- for (;;) {
if (p->tavl_tag[0] == TAVL_CHILD) {
if (!copy_node(new, q, 0, p->tavl_link[0], copy)) {
copy_error_recovery(rq.tavl_link[0], new, destroy);
@@ -830,6 +848,8 @@
return NULL;
+ return new;
@@ -840,9 +860,10 @@
struct tavl_node *n; /* Next node. */
- if (p != NULL)
+ if (p != NULL) {
while (p->tavl_tag[0] == TAVL_CHILD)
p = p->tavl_link[0];
while (p != NULL) {
n = p->tavl_link[1];
@@ -881,6 +902,9 @@
tavl_free
+#undef NDEBUG
/* Asserts that |tavl_insert()| succeeds at inserting |item| into |table|. */
void (tavl_assert_insert) (struct tavl_table * table, void *item)
@@ -896,5 +920,6 @@
void *p = tavl_delete(table, item);
assert(p != NULL);
return p;
Modified: grass/trunk/lib/vector/dglib/tavl.h
--- grass/trunk/lib/vector/dglib/tavl.h 2016-11-28 07:30:35 UTC (rev 69934)
+++ grass/trunk/lib/vector/dglib/tavl.h 2016-11-28 07:51:51 UTC (rev 69935)
@@ -1,25 +1,23 @@
+ Foundation, Inc.
- mundane means.
+ 02110-1301 USA.
#ifndef TAVL_H
@@ -50,7 +48,7 @@
/* Maximum TAVL height. */
#ifndef TAVL_MAX_HEIGHT
-#define TAVL_MAX_HEIGHT 32
+#define TAVL_MAX_HEIGHT 92
#endif
Modified: grass/trunk/lib/vector/dglib/tree.h
--- grass/trunk/lib/vector/dglib/tree.h 2016-11-28 07:30:35 UTC (rev 69934)
+++ grass/trunk/lib/vector/dglib/tree.h 2016-11-28 07:51:51 UTC (rev 69935)
@@ -22,13 +22,10 @@
#ifndef _DGL_TREE_H_
#define _DGL_TREE_H_
-#include "avl.h"
-#include "tavl.h"
#define USE_THREADED_AVL
#if defined(USE_THREADED_AVL)
+#include "tavl.h"
#define avl_table tavl_table
#define avl_traverser tavl_traverser
#define avl_create tavl_create
@@ -51,6 +48,8 @@
#define avl_t_prev tavl_t_prev
#define avl_t_cur tavl_t_cur
#define avl_t_replace tavl_t_replace
+#else
+#include "avl.h"
#endif
