[GRASS-SVN] r69937 - grass-addons/grass7/raster/r.seasons
Sun Nov 27 23:56:17 PST 2016
Author: mmetz
Date: 2016-11-27 23:56:17 -0800 (Sun, 27 Nov 2016)
New Revision: 69937
Added:
   grass-addons/grass7/raster/r.seasons/r.seasons.html
Removed:
   grass-addons/grass7/raster/r.seasons/r.hants.html
   grass-addons/grass7/raster/r.seasons/Makefile
   grass-addons/grass7/raster/r.seasons/main.c
new addon r.seasons: detect seasons in a time series
Modified: grass-addons/grass7/raster/r.seasons/Makefile
--- grass-addons/grass7/raster/r.seasons/Makefile	2016-11-28 07:53:41 UTC (rev 69936)
+++ grass-addons/grass7/raster/r.seasons/Makefile	2016-11-28 07:56:17 UTC (rev 69937)
@@ -1,9 +1,9 @@
 MODULE_TOPDIR = ../..
-PGM = r.hants
+PGM = r.seasons
-LIBES = $(GMATHLIB) $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(GMATHDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/raster/r.seasons/main.c
--- grass-addons/grass7/raster/r.seasons/main.c	2016-11-28 07:53:41 UTC (rev 69936)
+++ grass-addons/grass7/raster/r.seasons/main.c	2016-11-28 07:56:17 UTC (rev 69937)
@@ -1,33 +1,22 @@
- * MODULE:       r.hants
- * AUTHOR(S):    Wout Verhoef, NLR, Remote Sensing Dept., June 1998
- *               Mohammad Abouali, converted to MATLAB, 2011
- *               Markus Metz, converted to C, 2013
- *               based on r.series
- * PURPOSE:      time series correction
- * COPYRIGHT:    (C) 2013 by the GRASS Development Team
+ * MODULE:       r.seasons
+ * AUTHOR(S):    Markus Metz
+ * PURPOSE:      season extraction from a time series
+ * COPYRIGHT:    (C) 2016 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
  *               for details.
-#include <string.h>
-#include <stdlib.h>
-#include <unistd.h>
-#include <limits.h>
-#include <float.h>
-#include <math.h>
+#include <stdlib.h>
 #include <grass/gis.h>
 #include <grass/raster.h>
 #include <grass/glocale.h>
-#include <grass/gmath.h>
-/* TODO: add option for amplitude and phase output */
 struct input
     const char *name;
@@ -42,120 +31,178 @@
     DCELL *buf;
-static int solvemat(double **m, double a[], double B[], int n)
+static int (*cmp_dbl)(double a, double b);
+static int cmp_dbl_lo(double a, double b)
-    int i, j, i2, j2, imark;
-    double factor, temp, *tempp;
-    double pivot;		/* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
+    if (a > b)
+	return -1;
-    for (i = 0; i < n; i++) {
-	j = i;
+    return (a < b);
-	/* find row with largest magnitude value for pivot value */
+static int cmp_dbl_hi(double a, double b)
+    if (a < b)
+	return -1;
-	pivot = m[i][j];
-	imark = i;
-	for (i2 = i + 1; i2 < n; i2++) {
-	    temp = fabs(m[i2][j]);
-	    if (temp > fabs(pivot)) {
-		pivot = m[i2][j];
-		imark = i2;
+    return (a > b);
-	/* if the pivot is very small then the points are nearly co-linear */
-	/* co-linear points result in an undefined matrix, and nearly */
-	/* co-linear points results in a solution with rounding error */
+static int get_season(double *val, char *isnull, double *ts, int i0,
+                      int n, double threshold, double minlen,
+		      int *start1, int *start2,
+		      int *end1, int *end2)
+    int i, startin, startout, endout;
+    double blenin, blenout;
-	if (pivot == 0.0) {
-	    G_warning(_("Matrix is unsolvable"));
-	    return 0;
+    if (i0 >= n)
+	return 0;
-	/* if row with highest pivot is not the current row, switch them */
-	if (imark != i) {
-	    for (j2 = 0; j2 < n; j2++) {
-		temp = m[imark][j2];
-		m[imark][j2] = m[i][j2];
-		m[i][j2] = temp;
+    /* get first in-season block of at least minlen */
+    blenin = blenout = 0;
+    *start1 = *end1 = i0;
+    *start2 = *end2 = i0;
+    for (i = i0; i < n; i++) {
+	if (isnull[i] == 0 && cmp_dbl(val[i], threshold) >= 0) {
+	    if (blenin == 0) {
+		*start1 = i;
+	    *end1 = i;
+	    if (i < n - 1)
+		blenin = (ts[i] + ts[i + 1]) / 2.0;
+	    else
+		blenin = ts[i] + (ts[i] - ts[i - 1]) / 2.0;
-	    tempp = m[imark];
-	    m[imark] = m[i];
-	    m[i] = tempp;
+	    if (*start1 > 0)
+		blenin -= (ts[*start1 - 1] + ts[*start1]) / 2.0;
+	    else
+		blenin -= ts[*start1] - (ts[*start1 + 1] - ts[*start1]) / 2.0;
+	    if (blenin >= minlen)
+		break;
+	else {
+	    blenin = 0;
+    if (blenin < minlen)
+	return 0;
-	    temp = a[imark];
-	    a[imark] = a[i];
-	    a[i] = temp;
+    /* go back from start1, find start2 */
+    blenout = 0;
+    *start2 = *start1;
+    endout = *start1 - 1;
+    for (i = *start1 - 1; i >= i0; i--) {
+	    blenout = 0;
+	    *start2 = i;
+	else {
+	    if (blenout == 0)
+		endout = i;
-	/* compute zeros above and below the pivot, and compute
-	   values for the rest of the row as well */
+	    if (endout < n - 1)
+		blenout = (ts[endout] + ts[endout + 1]) / 2.0;
+	    else
+		blenout = ts[endout] + (ts[endout] - ts[endout - 1]) / 2.0;
-	for (i2 = 0; i2 < n; i2++) {
-	    if (i2 != i) {
-		factor = m[i2][j] / pivot;
-		for (j2 = j; j2 < n; j2++)
-		    m[i2][j2] -= factor * m[i][j2];
-		a[i2] -= factor * a[i];
+	    if (i > 0)
+		blenout -= (ts[i - 1] + ts[i]) / 2.0;
+	    else
+		blenout -= ts[i] - (ts[i + 1] - ts[i]) / 2.0;
+	    if (blenout >= minlen)
+		break;
+    /* go forward from end1, find end2 */
+    /* shift end1 if there is another in-season block of at least minlen */
+    *end2 = *end1;
+    startout = *end1;
+    startin = *end1;
+    for (i = *end1 + 1; i < n; i++) {
+	    blenout = 0;
+	    if (blenin == 0)
+		startin = i;
+	    *end2 = i;
-    /* SINCE ALL OTHER VALUES IN THE MATRIX ARE ZERO NOW, CALCULATE THE
-       COEFFICIENTS BY DIVIDING THE COLUMN VECTORS BY THE DIAGONAL VALUES. */
+	    if (i < n - 1)
+	    else
-	B[i] = a[i] / m[i][i];
+	    if (startin > 0)
+		blenin -= (ts[startin - 1] + ts[startin]) / 2.0;
+	    else
+		blenin -= ts[startin] - (ts[startin + 1] - ts[startin]) / 2.0;
+		*end2 = i;
+	else {
+	    blenin = 0;
+	    if (blenout == 0)
+		startout = i;
+	    if (i < n - 1)
+		blenout = (ts[i] + ts[i + 1]) / 2.0;
+	    else
+		blenout = ts[i] + (ts[i] - ts[i - 1]) / 2.0;
+	    if (startout > 0)
+		blenout -= (ts[startout - 1] + ts[startout]) / 2.0;
+	    else
+		blenout -= ts[startout] - (ts[startout + 1] - ts[startout]) / 2.0;
+		break;
     return 1;
 int main(int argc, char *argv[])
     struct GModule *module;
     struct
-	struct Option *input, *file, *suffix,
-	              *amp,	/* prefix for amplitude output */
-	              *phase,	/* prefix for phase output */
-	              *nf,	/* number of harmonics */
-		      *fet,	/* fit error tolerance */
-		      *dod,	/* degree of over-determination */
-	              *range,	/* low/high threshold */
-		      *ts,	/* time steps*/
-		      *bl,	/* length of base period */
-		      *delta;	/* threshold for high amplitudes */
+	struct Option *input, *file, *prefix,
+		      *ts,		/* time steps*/
+		      *ns,		/* number of seasons */
+		      *nsout,		/* output map for number of seasons */
+		      *threshold,	/* threshold to start/stop a season */
+		      *min;		/* minimum length in time to recognize a start/stop event */
     } parm;
     struct
-	struct Flag *lo, *hi, *lazy, *int_only;
+	struct Flag *lo, *lazy;
     } flag;
-    int i, j, k;
+    int i;
     int num_inputs;
     struct input *inputs = NULL;
     int num_outputs;
     struct output *outputs = NULL;
-    struct output *out_amp = NULL;
-    struct output *out_phase = NULL;
-    char *suffix;
+    int nsout_fd;
+    CELL *nsoutbuf;
+    char *prefix;
     struct History history;
-    DCELL *values = NULL, *rc = NULL;
+    DCELL *values = NULL;
     int nrows, ncols;
     int row, col;
-    double lo, hi, fet, *cs, *sn, *ts, delta;
-    int bl;
-    double **mat, **mat_t, **A, *Av, *Azero, *za, *zr, maxerrlo, maxerrhi;
-    int asize;
-    int first, last, interp_only;
-    int dod, nf, nr, nout, noutmax;
-    int rejlo, rejhi, *useval;
-    int do_amp, do_phase;
+    double minlen;
+    int ns, nsmax, nfound;
+    double threshold;
+    double *ts;
+    char *isnull;
+    int n_nulls;
+    int start1, start2, end1, end2;
+    int i0;
     G_gisinit(argv[0]);
@@ -175,86 +222,51 @@
     parm.file->description = _("Input file with raster map names, one per line");
     parm.file->required = NO;
-    parm.suffix = G_define_option();
-    parm.suffix->key = "suffix";
-    parm.suffix->type = TYPE_STRING;
-    parm.suffix->required = NO;
-    parm.suffix->answer = "_hants";
-    parm.suffix->label = _("Suffix for output maps");
-    parm.suffix->description = _("The suffix will be appended to input map names");
+    parm.prefix = G_define_option();
+    parm.prefix->key = "prefix";
+    parm.prefix->type = TYPE_STRING;
+    parm.prefix->required = NO;
+    parm.prefix->label = _("Prefix for output maps");
+    parm.prefix->description = _("The prefix will be prepended to input map names");
-    parm.amp = G_define_option();
-    parm.amp->key = "amplitude";
-    parm.amp->type = TYPE_STRING;
-    parm.amp->required = NO;
-    parm.amp->label = _("Prefix for output amplitude maps");
-    parm.phase = G_define_option();
-    parm.phase->key = "phase";
-    parm.phase->type = TYPE_STRING;
-    parm.phase->required = NO;
-    parm.phase->label = _("Prefix for output phase maps");
-    parm.nf = G_define_option();
-    parm.nf->key = "nf";
-    parm.nf->type = TYPE_INTEGER;
-    parm.nf->required = YES;
-    parm.nf->description = _("Number of frequencies");
-    parm.fet = G_define_option();
-    parm.fet->key = "fet";
-    parm.fet->type = TYPE_DOUBLE;
-    parm.fet->required = NO;
-    parm.fet->multiple = NO;
-    parm.fet->description = _("Fit error tolerance");
-    parm.dod = G_define_option();
-    parm.dod->key = "dod";
-    parm.dod->type = TYPE_INTEGER;
-    parm.dod->required = NO;
-    parm.dod->answer = "0";
-    parm.dod->description = _("Degree of over-determination");
-    parm.range = G_define_option();
-    parm.range->key = "range";
-    parm.range->type = TYPE_DOUBLE;
-    parm.range->key_desc = "lo,hi";
-    parm.range->description = _("Ignore values outside this range");
     parm.ts = G_define_option();
     parm.ts->key = "time_steps";
     parm.ts->type = TYPE_DOUBLE;
     parm.ts->multiple = YES;
     parm.ts->description = _("Time steps of the input maps");
-    parm.bl = G_define_option();
-    parm.bl->key = "base_period";
-    parm.bl->type = TYPE_INTEGER;
-    parm.bl->description = _("Length of the base period");
+    parm.ns = G_define_option();
+    parm.ns->key = "n";
+    parm.ns->type = TYPE_INTEGER;
+    parm.ns->required = YES;
+    parm.ns->description = _("Number of seasons to detect");
-    parm.delta = G_define_option();
-    parm.delta->key = "delta";
-    parm.delta->type = TYPE_DOUBLE;
-    parm.delta->answer = "0";
-    parm.delta->label = _("Threshold for high amplitudes");
-    parm.delta->description = _("Delta should be between 0 and 1");
+    parm.nsout = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.nsout->key = "nout";
+    parm.nsout->required = NO;
+    parm.nsout->description = _("Name of output map with detected number of seasons");
+    parm.threshold = G_define_option();
+    parm.threshold->key = "threshold";
+    parm.threshold->type = TYPE_DOUBLE;
+    parm.threshold->required = YES;
+    parm.threshold->description = _("Threshold to start/stop a season");
+    parm.min = G_define_option();
+    parm.min->key = "min";
+    parm.min->type = TYPE_DOUBLE;
+    parm.min->required = YES;
+    parm.min->label = _("Minimum number of time steps");
+    parm.min->description = _("A season must be at least min long, otherwise the data are considered as noise");
     flag.lo = G_define_flag();
     flag.lo->key = 'l';
-    flag.lo->description = _("Reject low outliers");
+    flag.lo->description = _("Stop a season when a value is above threshold (default: below threshold");
-    flag.hi = G_define_flag();
-    flag.hi->key = 'h';
-    flag.hi->description = _("Reject high outliers");
     flag.lazy = G_define_flag();
     flag.lazy->key = 'z';
     flag.lazy->description = _("Don't keep files open");
-    flag.int_only = G_define_flag();
-    flag.int_only->key = 'i';
-    flag.int_only->description = _("Do not extrapolate, only interpolate");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -265,50 +277,25 @@
     if (!parm.input->answer && !parm.file->answer)
         G_fatal_error(_("Please specify input= or file="));
-    if (parm.amp->answer && parm.phase->answer) {
-	if (strcmp(parm.amp->answer, parm.phase->answer) == 0)
-	    G_fatal_error(_("'%s' and '%s' options must be different"),
-			  parm.amp->key, parm.phase->key);
-    do_amp = parm.amp->answer != NULL;
-    do_phase = parm.phase->answer != NULL;
+    if (!parm.prefix->answer && !parm.nsout->answer)
+	G_fatal_error(_("Neither <%s> nor <%s> output requested"),
+	              parm.prefix->key, parm.nsout->key);
-    nf = atoi(parm.nf->answer);
-    if (nf < 1)
-	G_fatal_error(_("The number of frequencies must be > 0"));
+    ns = atoi(parm.ns->answer);
+    if (ns < 1)
+	G_fatal_error(_("Number of seasons must be positive integer"));
-    fet = DBL_MAX;
-    if (parm.fet->answer) {
-	fet = atof(parm.fet->answer);
-	if (fet < 0)
-	    G_fatal_error(_("The fit error tolerance must be >= 0"));
-    dod = 0;
-    if (parm.dod->answer) {
-	dod = atoi(parm.dod->answer);
-	if (dod < 0)
-	    G_fatal_error(_("The degree of over-determination must be >= 0"));
-    lo = -DBL_MAX;
-    hi = DBL_MAX;
-    if (parm.range->answer) {
-	lo = atof(parm.range->answers[0]);
-	hi = atof(parm.range->answers[1]);
-    delta = 0;
-    if (parm.delta->answer) {
-	delta = atof(parm.delta->answer);
-	if (delta < 0 || delta > 1)
-	    G_fatal_error(_("The threshold for high amplitudes must be >= 0 and <= 1"));
-    rejlo = flag.lo->answer;
-    rejhi = flag.hi->answer;
-    if ((rejlo || rejhi) && !parm.fet->answer)
-	G_fatal_error(_("Fit error tolerance is required when outliers should be rejected"));
+    minlen = atof(parm.min->answer);
+    if (minlen <= 0)
+	G_fatal_error(_("Minimum season length must be positive"));
+    threshold = atof(parm.threshold->answer);
-    interp_only = flag.int_only->answer;
+    if (flag.lo->answer)
+	cmp_dbl = cmp_dbl_lo;
+    else
+	cmp_dbl = cmp_dbl_hi;
     /* process the input maps from the file */
     if (parm.file->answer) {
 	FILE *in;
@@ -376,81 +363,68 @@
     if (num_inputs < 3)
 	G_fatal_error(_("At least 3 input maps are required"));
-    /* length of base period */
-    if (parm.bl->answer)
-	bl = atoi(parm.bl->answer);
-    else
-	bl = num_inputs;
+    ts = G_malloc(num_inputs * sizeof(double));
-    /* open output maps */
-    num_outputs = num_inputs;
-    outputs = G_calloc(num_outputs, sizeof(struct output));
-    suffix = parm.suffix->answer;
-    if (!suffix)
-	suffix = "_hants";
-    for (i = 0; i < num_outputs; i++) {
-	struct output *out = &outputs[i];
-	char output_name[GNAME_MAX];
-	sprintf(output_name, "%s%s", inputs[i].name, suffix);
-	out->name = G_store(output_name);
-	out->buf = Rast_allocate_d_buf();
-	out->fd = Rast_open_new(output_name, DCELL_TYPE);
+    if (parm.ts->answer) {
+    	for (i = 0; parm.ts->answers[i]; i++);
+	if (i != num_inputs)
+	    G_fatal_error(_("Number of time steps does not match number of input maps"));
+    	for (i = 0; parm.ts->answers[i]; i++) {
+	    ts[i] = atof(parm.ts->answers[i]);
+	    if (i > 0 && ts[i - 1] >= ts[i])
+		G_fatal_error(_("Time steps must increase"));
+    else {
+	for (i = 0; i < num_inputs; i++) {
+	    ts[i] = i;
-    nr = 2 * nf + 1;
+    /* open output maps */
+    num_outputs = 0;
+    prefix = parm.prefix->answer;
+    if (prefix) {
+	num_outputs = ns * 4;
-    if (nr > num_inputs)
-	G_fatal_error(_("The maximum number of frequencies for %d input maps is %d."),
-	                num_inputs, (num_inputs - 1) / 2);
+	outputs = G_calloc(num_outputs, sizeof(struct output));
-    noutmax = num_inputs - nr - dod;
-    if (noutmax < 0)
-	G_fatal_error(_("The degree of overdetermination can not be larger than %d "
-			"for %d input maps and %d frequencies."),
-			dod + noutmax, num_inputs, nf);
-    if (noutmax == 0)
-	G_warning(_("Missing values can not be reconstructed, "
-	            "please reduce either '%s' or '%s'"),
-		    parm.nf->key, parm.dod->key);
-    if (do_amp) {
-	/* open output amplitude */
-	out_amp = G_calloc(nf, sizeof(struct output));
-	for (i = 0; i < nf; i++) {
-	    struct output *out = &out_amp[i];
+	for (i = 0; i < ns; i++) {
+	    struct output *out;
-	    sprintf(output_name, "%s.%d", parm.amp->answer, i);
+	    out = &outputs[i * 4];
+	    sprintf(output_name, "%s%d_%s", prefix, i + 1, "start1");
+	    out->name = G_store(output_name);
+	    out->buf = Rast_allocate_d_buf();
+	    out->fd = Rast_open_new(out->name, DCELL_TYPE);
+	    out = &outputs[i * 4 + 1];
+	    sprintf(output_name, "%s%d_%s", prefix, i + 1, "start2");
-    if (do_phase) {
-	/* open output phase */
-	out_phase = G_calloc(nf, sizeof(struct output));
+	    out = &outputs[i * 4 + 2];
+	    sprintf(output_name, "%s%d_%s", prefix, i + 1, "end1");
-	    struct output *out = &out_phase[i];
-	    sprintf(output_name, "%s.%d", parm.phase->answer, i);
+	    out = &outputs[i * 4 + 3];
+	    sprintf(output_name, "%s%d_%s", prefix, i + 1, "end2");
+    nsout_fd = -1;
+    nsoutbuf = NULL;
+    if (parm.nsout->answer) {
+	nsout_fd = Rast_open_new(parm.nsout->answer, CELL_TYPE);
+	nsoutbuf = Rast_allocate_c_buf();
     /* initialise variables */
     values = G_malloc(num_inputs * sizeof(DCELL));
@@ -458,73 +432,12 @@
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
-    cs = G_alloc_vector(bl);
-    sn = G_alloc_vector(bl);
-    ts = G_alloc_vector(num_inputs);
-    rc = G_malloc(num_inputs * sizeof(DCELL));
-    useval = G_malloc(num_inputs * sizeof(int));
+    isnull = G_malloc(num_inputs * sizeof(char));
-    if (parm.ts->answer) {
-    	for (i = 0; parm.ts->answers[i]; i++);
-	if (i != num_inputs)
-	    G_fatal_error(_("Number of time steps does not match number of input maps"));
-	    ts[i] = atof(parm.ts->answers[i]);
-    else {
-	for (i = 0; i < num_inputs; i++) {
-	    ts[i] = i;
-    mat = G_alloc_matrix(nr, num_inputs);
-    mat_t = G_alloc_matrix(num_inputs, nr);
-    A = G_alloc_matrix(nr, nr);
-    Av = *A;
-    Azero = G_alloc_vector(nr * nr);
-    asize = nr * nr * sizeof(double);
-    za = G_alloc_vector(nr);
-    zr = G_alloc_vector(nr);
-    rc = G_alloc_vector(num_inputs);
-    for (i = 0; i < nr * nr; i++)
-	Azero[i] = 0;
-    for (i = 0; i < bl; i++) {
-	double ang = 2.0 * M_PI * i / bl;
-	cs[i] = cos(ang);
-	sn[i] = sin(ang);
-    for (j = 0; j < num_inputs; j++) {
-	mat[0][j] = 1.;
-	mat_t[j][0] = 1.;
-    for (i = 0; i < nr / 2; i++) {
-	int i1 = 2 * i + 1;
-	int i2 = 2 * i + 2;
-	    int idx = (int) ((i + 1) * (ts[j])) % bl;
-	    if (idx >= bl)
-		G_fatal_error("cs/sn index out of range: %d, %d", idx, bl);
-	    if (i2 >= nr)
-		G_fatal_error("mat index out of range: %d, %d", 2 * i + 2, nr);
-	    mat[i1][j] = cs[idx];
-	    mat[i2][j] = sn[idx];
-	    mat_t[j][i1] = mat[i1][j];
-	    mat_t[j][i2] = mat[i2][j];
     /* process the data */
-    G_message(_("Harmonic analysis of %d input maps..."), num_inputs);
+    G_message(_("Detecting seasons for %d input maps..."), num_inputs);
+    nsmax = 0;
     for (row = 0; row < nrows; row++) {
 	G_percent(row, nrows, 4);
@@ -542,211 +455,76 @@
 	for (col = 0; col < ncols; col++) {
-	    int null = 0, non_null = 0;
-	    first = last = -1;
+	    n_nulls = 0;
 		DCELL v = inputs[i].buf[col];
-		useval[i] = 0;
+		isnull[i] = 0;
 		if (Rast_is_d_null_value(&v)) {
-		    null++;
+		    isnull[i] = 1;
+		    n_nulls++;
-		else if (parm.range->answer && (v < lo || v > hi)) {
-		    Rast_set_d_null_value(&v, 1);
-		    null++;
-		else {
-		    non_null++;
-		    useval[i] = 1;
-		    if (first == -1)
-			first = i;
-		    last = i;
 		values[i] = v;
-	    nout = null;
-	    if (!interp_only) {
-		first = 0;
-		last = num_inputs - 1;
-	    /* HANTS */
-	    if (nout <= noutmax) {
-		int n = 0, done = 0;
+	    nfound = 0;
+	    i0 = 0;
+	    while (get_season(values, isnull, ts, i0, num_inputs,
+		  threshold, minlen, &start1, &start2, &end1, &end2)) {
-		while (!done) {
-		    /* za = mat * y */
+		i0 = end2 + 1;
-		    /* A = mat * diag(p) * mat' */
-		    /* mat: nr, num_inputs
-		     * diag(p): num_inputs, num_inputs
-		     * mat_t: num_inputs, nr
-		     * A temp: nr, num_inputs
-		     * A: nr, nr */
-		    memcpy(Av, Azero, asize);
-		    for (i = 0; i < nr; i++) {
-			za[i] = 0;
-			    if (useval[j]) {
-				za[i] += mat[i][j] * values[j];
-				for (k = 0; k < nr; k++)
-				    A[i][k] += mat[i][j] * mat_t[j][k];
-			if (i > 0) {
-			    A[i][i] += delta;
-		    /* zr = A \ za
-		     * solve A * zr = za */
-		    if (!solvemat(A, za, zr, nr)) {
-			done = -1;
-			Rast_set_d_null_value(rc, num_outputs);
-			break;
-		    /* G_math_solver_gauss(A, zr, za, nr) is much slower */
-		    /* rc = mat' * zr */
-		    maxerrlo = maxerrhi = 0;
-			rc[i] = 0;
-			for (j = 0; j < nr; j++) {
-			    rc[i] += mat_t[i][j] * zr[j];
-			if (useval[i]) {
-			    if (maxerrlo < rc[i] - values[i])
-				maxerrlo = rc[i] - values[i];
-			    if (maxerrhi < values[i] - rc[i])
-				maxerrhi = values[i] - rc[i];
-		    if (rejlo || rejhi) {
-			done = 1;
-			if (rejlo && maxerrlo > fet)
-			    done = 0;
-			if (rejhi && maxerrhi > fet)
-			    done = 0;
-			if (!done) {
-			    /* filter outliers */
-				if (useval[i]) {
-				    if (rejlo && rc[i] - values[i] > maxerrlo * 0.5) {
-					useval[i] = 0;
-					nout++;
-				    if (rejhi && values[i] - rc[i] > maxerrhi * 0.5) {
-					useval[i] = 0;
-					nout++;
-		    n++;
-		    if (n >= num_inputs)
-			done = 1;
-		    if (nout > noutmax)
-			done = 1;
+		if (prefix && nfound < ns) {
+		    i = nfound * 4;
+		    outputs[i].buf[col] = ts[start1];
+		    outputs[i + 1].buf[col] = ts[start2];
+		    outputs[i + 2].buf[col] = ts[end1];
+		    outputs[i + 3].buf[col] = ts[end2];
+		nfound++;
+	    if (nsmax < nfound)
+		nsmax = nfound;
-		i = 0;
-		while (i < first) {
-		    Rast_set_d_null_value(&out->buf[col], 1);
-		    i++;
+	    if (prefix) {
+		for (i = nfound * 4; i < num_outputs; i++) {
+		    Rast_set_d_null_value(&outputs[i].buf[col], 1);
-		for (i = first; i <= last; i++) {
-		    out->buf[col] = rc[i];
-		    if (rc[i] < lo)
-			out->buf[col] = lo;
-		    else if (rc[i] > hi)
-			out->buf[col] = hi;
-		i = last + 1;
-		while (i < num_outputs) {
-		    i++;
-		if (do_amp || do_phase) {
-		    /* amplitude and phase */
-		    /* skip constant */
-		    for (i = 1; i < nr; i += 2) {
-			int ifr = i >> 1;
-			if (do_amp) {
-			    out_amp[ifr].buf[col] = sqrt(zr[i] * zr[i] +
-						    zr[i + 1] * zr[i + 1]);
-			if (do_phase) {
-			    double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
-			    if (angle < 0)
-				angle += 360;
-			    out_phase[ifr].buf[col] = angle;
-	    else {
-			if (do_amp)
-			    Rast_set_d_null_value(&out_amp[i].buf[col], 1);
-			if (do_phase)
-			    Rast_set_d_null_value(&out_phase[i].buf[col], 1);
+	    if (nsoutbuf) {
+		if (n_nulls == num_inputs)
+		    Rast_set_c_null_value(&nsoutbuf[col], 1);
+		else
+		    nsoutbuf[col] = nfound;
-	    Rast_put_d_row(outputs[i].fd, outputs[i].buf);
-		if (do_amp)
-		    Rast_put_d_row(out_amp[i].fd, out_amp[i].buf);
-		if (do_phase)
-		    Rast_put_d_row(out_phase[i].fd, out_phase[i].buf);
+	if (prefix) {
+	    for (i = 0; i < num_outputs; i++) {
+		Rast_put_d_row(outputs[i].fd, outputs[i].buf);
+	if (nsoutbuf)
+	    Rast_put_c_row(nsout_fd, nsoutbuf);
     G_percent(row, nrows, 2);
-    /* Close input maps */
-    if (!flag.lazy->answer) {
-	    Rast_close(inputs[i].fd);
+    G_message(_("A maximum of %d seasons have been detected"), nsmax);
+    if (nsmax > ns)
+	G_important_message(_("The number of output seasons (%d) is smaller than the maximum number of detected seasons (%d)."),
+	                    ns, nsmax);
+    /* close input maps */
+	struct input *in = &inputs[i];
+	if (!flag.lazy->answer)
+	    Rast_close(in->fd);
     /* close output maps */
@@ -759,32 +537,13 @@
 	Rast_command_history(&history);
 	Rast_write_history(out->name, &history);
+    if (nsout_fd >= 0) {
+	Rast_close(nsout_fd);
-    if (do_amp) {
-	/* close output amplitudes */
-	    Rast_close(out->fd);
-	    Rast_short_history(out->name, "raster", &history);
-	    Rast_command_history(&history);
-	    Rast_write_history(out->name, &history);
+	Rast_short_history(parm.nsout->answer, "raster", &history);
+	Rast_command_history(&history);
+	Rast_write_history(parm.nsout->answer, &history);
-    if (do_phase) {
-	/* close output phases */
     exit(EXIT_SUCCESS);
Deleted: grass-addons/grass7/raster/r.seasons/r.hants.html
--- grass-addons/grass7/raster/r.seasons/r.hants.html	2016-11-28 07:53:41 UTC (rev 69936)
+++ grass-addons/grass7/raster/r.seasons/r.hants.html	2016-11-28 07:56:17 UTC (rev 69937)
@@ -1,204 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.hants</em> performs a harmonic analysis of time series in order to
-estimate missing values and identify outliers. For each input map, an
-output map with the suffix <em>suffix</em> (default: _hants) is created.
-<p>
-The option <b>nf</b>, number of frequencies, should be carefully chosen.
-Different numbers of frequencies should be tested first on a small test
-region before running the module on the full region. As a rule of thumb,
-the number of frequencies should be at least
-<em>estimated periodicity + 3</em>, e.g. for NDVI with an annual cycle
-(one peak per year), the number of frequencies should be at least 4 when
-analysing one year. If two peaks are assumed per year, the number of
-frequencies should be at least 5 when analysing one year.
-<p>The number of frequencies should also not be too large. With a large
-number of frequencies, outliers can no longer be identified because the
-fit is "too good", outliers can be represented by the estimate.
-The number of frequencies should also be smaller than <em>n input maps / 2</em>
-if missing values should be reconstructed.
-<h2>NOTES</h2>
-The optional <em>amplitude</em> and <em>phase</em> output maps contain
-the amplitude and phase for each frequency. The amplitude maps can be
-used to identify the dominant frequency with <em>r.series
-method=max_raster</em>. The baseline frequeny (base period) has the
-suffix <em>.0</em>, its first harmonic has the suffix <em>.1</em>, its
-second harmonic has the suffix <em>.2</em>, etc. The value of the
-output of <em>r.series method=max_raster</em> is identical to the
-number of the suffix. With the <em>amplitude</em> output maps for NDVI
-input, this can be used to determine the number of peaks in vegetation
-growth within the base period, where 0 (zero) means that the dominant
-frequency is the base period, i.e. one peak per base period.
-<p>
-If the <em>range</em> option is given, any values which fall outside
-that range will be treated as if they were NULL.
-The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
-values outside of this range are treated as NULL.
-<p>
-The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
-<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
-negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
-<p>
-The maximum number of raster maps that can be processed is given by the
-per-user limit of the operating system. For example, the soft limits
-for users are typically 1024. The soft limit can be changed with e.g.
-<tt>ulimit -n 4096</tt> (UNIX-based operating systems) but not higher
-than the hard limit. If it is too low, you can as superuser add an
-entry in
-<div class="code"><pre>
-/etc/security/limits.conf
-# <domain>      <type>  <item>         <value>
-your_username  hard    nofile          4096
-</pre></div>
-This would raise the hard limit to 4096 files. Also have a look at the
-overall limit of the operating system
-cat /proc/sys/fs/file-max
-</pre></div>
-which is on modern Linux systems several 100,000 files.
-<p>Use the <em>file</em> option to analyze large amount of raster maps
-without hitting open files limit and the size limit of command line
-arguments. The computation is slower than the <em>input</em> option
-method. For every single row in the output map(s) all input maps are
-opened and closed. The amount of RAM will rise linear with the number of
-specified input maps. The input and file options are mutually exclusive.
-Input is a text file with a new line separated list of raster map names.
-<p>For the usage of the option <b>fet</b> see Roerink et al. (2000). Its
-value is relative to the value range of the variable being considered.
-<h2>EXAMPLES</h2>
-<h3>Precipitation data example</h3>
-This small example is based on a climatic dataset for North Carolina which
-was from publicly available data (monthly temperature averages and monthly
-precipitation sums from 2000 to 2012, downloadable as
-<a href="http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip">GRASS GIS 7 location</a>):
-# set computational region to one of the maps
-g.region raster=2004_03_tempmean -p
-</pre></div>
-Visualize the time series as animation:
-# note: color table is different from standard "celsius"
-g.gui.animation rast=`g.list type=raster pattern="*tempmean" sep=comma`
-</pre></div>
-<p>
-Since HANTS is CPU intensive, we test for now at lower resolution:
-g.region -p res=5000
-# HANTS: Harmonic analysis of the 156 input maps...
-# just wildly guessing the parameters for a test run:
-# generate and check list of input maps (the order matters!)
-g.list type=raster pattern="20??_??_tempmean" output=tempmean.csv
-r.hants file=tempmean.csv \
-  nf=6 fet=0.1 dod=5 delta=0.1 base_period=12
-# assign reasonable color tables for temperature
-for map in `g.list type=raster pattern="*tempmean_hants"` ; do
-    r.colors $map color=celsius
-done
-# assign degree Celsius color table
-r.colors 2000_06_tempmean_hants color=celsius
-# verify with one of the 156 results (still at reduced resolution):
-r.mapcalc "2000_06_tempmean_diff = 2000_06_tempmean - 2000_06_tempmean_hants"
-r.colors 2000_06_tempmean_diff color=differences
-d.mon wx0
-d.rast 2000_06_tempmean_hants
-d.rast 2000_06_tempmean_diff
-r.univar 2000_06_tempmean_diff -g
-n=5066
-null_cells=5040
-cells=10106
-min=-0.0899336115228095
-max=0.359362050140941
-range=0.449295661663751
-mean=0.188579838052468
-# see HANTS time series as animation
-g.gui.animation rast=`g.list type=raster pattern="*tempmean_hants" sep=comma`
-# Check HANTS behaviour in a given point
-east=740830
-north=168832
-for map in `g.list rast pat="20??_??_tempmean"` ; do
-  r.what map=$map coordinates=$east,$north >> time_series_orig.csv
-done
-for map in `g.list rast pat="*tempmean_hants"` ; do
-  r.what map=$map coordinates=$east,$north >> time_series_hants.csv
-done
-# merge files:
-echo "east|north|temp_orig|temp_hants" > time_series_final.csv
-paste -d'|' time_series_orig.csv time_series_hants.csv | \
-      cut -d'|' -f1,2,4,8 >> time_series_final.csv
-# Resulting CSV file: 'time_series_final.csv'
-</pre></div>
-<h3>Using t.* modules to check for basic statistics</h3>
-The temporal framework (t.* modules) can be used to assess basic statistics:
-# create spatio temporal data set with hants output maps
-t.create type=strds temporaltype=absolute  output=tempmean_hants \
-  title="Mean Temperature HANTS" description="Mean Temperature reconstructed with HANTS"
-# register maps in the strds
-t.register -i type=raster input=tempmean_hants \
-  maps=`g.list raster pattern=*tempmean_hants sep=,` start="2000-01-01" \
-  increment="1 months"
-# getting general info of the strds (including max and min of the whole series)
-t.info type=strds input=tempmean_hants
-# getting statistics for each map in the series
-t.rast.univar -h tempmean_hants > stats_hants.txt
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="r.series.html">r.series</a></em>
-<h2>REFERENCES</h2>
-<p>
-Roerink, G. J., Menenti, M. and Verhoef, W., 2000. Reconstructing
-cloudfree NDVI composites using Fourier analysis of time series.
-International Journal of Remote Sensing, 21 (9), 1911-1917.
-DOI: <a href=http://dx.doi.org/10.1080/014311600209814>10.1080/014311600209814</a>
-<h2>AUTHOR</h2>
-Markus Metz
-<p><i>Last changed: $Date$</i>
Copied: grass-addons/grass7/raster/r.seasons/r.seasons.html (from rev 69936, grass-addons/grass7/raster/r.seasons/r.hants.html)
--- grass-addons/grass7/raster/r.seasons/r.seasons.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.seasons/r.seasons.html	2016-11-28 07:56:17 UTC (rev 69937)
@@ -0,0 +1,61 @@
+<h2>DESCRIPTION</h2>
+<em>r.seasons</em> counts the number of seasons in a time series. A
+season is defined as a time period of at least <em>min</em> length
+where no value is below <em>threshold</em> (with the <em>-l</em> flag,
+no value above <em>threshold</em>).
+<p>
+The <em>nout</em> output holds the number of detected seasons. Output
+raster maps with the start and end dates of each season are produced
+for at most <em>n</em> number of seasons. For each season, two start
+dates and two end dates are determined. The start date start1 and the
+end date end1 indicate the start and end of the core season, while the
+start date start2 and the end date end2 indicate the start and end of
+the full season including some gaps at the beginning and end of the
+season. Gaps are shorter than <em>min</em>, that is, a season will not
+include gaps equal or longer than <em>min</em>.
+<h2>NOTES</h2>
+The maximum number of raster maps that can be processed is given by the
+per-user limit of the operating system. For example, the soft limits
+for users are typically 1024. The soft limit can be changed with e.g.
+<tt>ulimit -n 4096</tt> (UNIX-based operating systems) but not higher
+than the hard limit. If it is too low, you can as superuser add an
+entry in
+<div class="code"><pre>
+/etc/security/limits.conf
+# <domain>      <type>  <item>         <value>
+your_username  hard    nofile          4096
+</pre></div>
+This would raise the hard limit to 4096 files. Also have a look at the
+overall limit of the operating system
+cat /proc/sys/fs/file-max
+</pre></div>
+which is on modern Linux systems several 100,000 files.
+<p>Use the <em>-z</em> flag to analyze large amount of raster maps
+without hitting open files limit and the size limit of command line
+arguments. This will however increase the processing time. For every
+single row in the output map(s) all input maps are opened and closed.
+The amount of RAM will rise linear with the number of specified input
+maps.
+<p>
+The input and file options are mutually exclusive. Input is a
+text file with a new line separated list of raster map names.
+<h2>SEE ALSO</h2>
+<em><a href="r.series.html">r.series</a></em>,
+<em><a href="r.hants.html">r.hants</a></em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
