[GRASS-SVN] r69945 - grass/branches/releasebranch_7_0/imagery/i.atcorr
svn_grass at osgeo.org
Mon Nov 28 10:26:45 PST 2016
Author: neteler
Date: 2016-11-28 10:26:45 -0800 (Mon, 28 Nov 2016)
New Revision: 69945
grass/branches/releasebranch_7_0/imagery/i.atcorr/README
grass/branches/releasebranch_7_0/imagery/i.atcorr/create_iwave.py
i.atcorr: sync create_iwave.py to trunk (includes trunk, r69411)
Modified: grass/branches/releasebranch_7_0/imagery/i.atcorr/README
--- grass/branches/releasebranch_7_0/imagery/i.atcorr/README 2016-11-28 18:25:00 UTC (rev 69944)
+++ grass/branches/releasebranch_7_0/imagery/i.atcorr/README 2016-11-28 18:26:45 UTC (rev 69945)
@@ -13,11 +13,11 @@
one after the other.
Example Lsat TM: (435-250) / 2.5 = 74
- o add filter function to Iwave.cpp, before IWave::equivwl()
+ o run create_iwave.py and add new filter function to Iwave.cpp, before IWave::equivwl()
o add else-if in IWave::parse() in Iwave.cpp
o add print strings in Iwave.cpp
- o add iwave values and signature in Iwave.h
+ o add satellite sensor to Iwave.h
o add to GeomCond.cpp and GeomCond.h
o add to i.atcorr.html
Modified: grass/branches/releasebranch_7_0/imagery/i.atcorr/create_iwave.py
--- grass/branches/releasebranch_7_0/imagery/i.atcorr/create_iwave.py 2016-11-28 18:25:00 UTC (rev 69944)
+++ grass/branches/releasebranch_7_0/imagery/i.atcorr/create_iwave.py 2016-11-28 18:26:45 UTC (rev 69945)
@@ -32,17 +32,20 @@
def usage():
"""How to use this..."""
print "create_iwave.py <csv file>"
- print "Generate filter function IWave.cpp template from csv file"
- print "csv file must have wl response for each band in each column"
- print "first line must be a header with wl followed by band names"
- print "following lines will be the data."
- print "If response is null, leave empty in csv file. Ex.:"
+ print
+ print "Generates filter function template for iwave.cpp from csv file. Note:"
+ print "- csv file must have wl response for each band in each column"
+ print "- first line must be a header with wl followed by band names"
+ print "- all following lines will be the data."
+ print "If spectral response is null, leave field empty in csv file. Example:"
+ print
print "WL(nm),band 1,band 2,band 3,band 4"
print "455,0.93,,,"
print "485,0.94,0.00,,"
print "545,0.00,0.87,0.00,"
- print "Program will interpolate filter function to 2.5 nm steps"
- print "and output a cpp template file in the IWave format"
+ print
+ print "This script will interpolate the filter functions to 2.5 nm steps"
+ print "and output a cpp template file in the IWave format to be added to iwave.cpp"
def read_input(csvfile):
@@ -51,29 +54,30 @@
should be a .csv file with the values
of the filter function for each band in the sensor
one column for band
- first line must have a header with sensor band name
+ first line must have a header with sensor band names
first column is wavelength
+ values are those of the discrete band filter functions
infile = open(csvfile, 'r')
# get number of bands and band names
bands = infile.readline().split(',')
bands.remove(bands[0])
bands[-1] = bands[-1].strip()
+ print " > Number of bands found: %d" % len(bands)
infile.close()
# create converter dictionary for import
# fix nodata or \n
conv = {}
for b in range(len(bands)):
conv[b+1] = lambda s: float(s or -99)
values = np.loadtxt(csvfile, delimiter=',', skiprows=1, converters = conv)
return (bands, values)
-def interpolate_band(values):
+def interpolate_band(values, step = 2.5):
Receive wavelength and response for one band
interpolate at 2.5 nm steps
@@ -84,19 +88,47 @@
# These 2 lines select the subarray
# remove nodata (-99) lines in values array
# where response is nodata?
w = values[:,1] >= 0
response = values[w]
+ wavelengths = response[:,0] # 1st column of input array
+ spectral_response = response[:,1] # 2nd column
+ assert len(wavelengths) == len(spectral_response), "Number of wavelength slots and spectral responses are not equal!"
# interpolating
- f = interpolate.interp1d(response[:,0],response[:,1])
- filter_f = f(np.arange(response[0,0], response[-1,0] + 2.5, 2.5))
+ f = interpolate.interp1d(wavelengths, spectral_response)
+ start = wavelengths[0]
+ # considering last entry for np.arange
+ input_step = wavelengths[-1] - wavelengths[-2]
+ # if wavelength step in input data is 1 nm
+ # print " > Wavelength step in input data is", input_step, "nm"
+ if input_step == 1:
+ addendum = 0
+ # print " i No need to modify the stop value for the np.arrange function."
+ # what if input step != 1 and input step != 2.5?
+ else:
+ addendum = step
+ # print " ! Wavelength step in input data is nor 1 nm, neither 2.5 nm.",
+ # print "Internally setting the \"stop\" value for the np.arrange()",
+ # print "function so as to not exceed the end value", wavelengths[-1],
+ # print "of the open half ended range."
+ stop = wavelengths[-1] + addendum
+ filter_f = f(np.arange(start, stop, step))
+ # how many spectral responses?
+ expected = np.ceil((stop - start) / step)
+ assert len(filter_f) == expected, "Number of interpolated spectral responses not equal to expected number of interpolations"
# convert limits from nanometers to micrometers
- lowerlimit = response[0,0]/1000
- upperlimit = response[-1,0]/1000
+ lowerlimit = wavelengths[0]/1000
+ upperlimit = wavelengths[-1]/1000
return(filter_f, (lowerlimit, upperlimit))
def plot_filter(values):
@@ -228,7 +260,8 @@
# getting sensor name from full csv file name
sensor = os.path.splitext(os.path.basename(inputfile))[0]
- print "Getting sensor name from csv file: %s" % (sensor)
+ print
+ print " > Getting sensor name from csv file: %s" % (sensor)
# getting data from file
bands, values = read_input(inputfile)
@@ -236,9 +269,10 @@
# writing file in same folder of input file
write_cpp(bands, values, sensor, os.path.dirname(inputfile))
- print "Filter function written to %s" % (sensor+"_cpp_template.txt")
- print "Please check file for possible errors before inserting into IWave.cpp"
- print "Don't forget to add necessary data to IWave.h"
+ print " > Filter functions exported to %s" % ("sensors_csv/"+sensor+"_cpp_template.txt")
+ print " > Please check this file for possible errors before inserting the code into file iwave.cpp"
+ print " > Don't forget to add the necessary data to the files iwave.h, geomcond.h, geomcond.cpp, and to i.atcorr.html"
+ print
return
