[GRASS-SVN] r69955 - grass/trunk/raster/r.category
Wed Nov 30 07:48:35 PST 2016
Author: neteler
Date: 2016-11-30 07:48:35 -0800 (Wed, 30 Nov 2016)
New Revision: 69955
   grass/trunk/raster/r.category/r.category.html
r.category manual: examples beautified
Modified: grass/trunk/raster/r.category/r.category.html
--- grass/trunk/raster/r.category/r.category.html	2016-11-30 15:18:00 UTC (rev 69954)
+++ grass/trunk/raster/r.category/r.category.html	2016-11-30 15:48:35 UTC (rev 69955)
@@ -39,7 +39,8 @@
 The <b>rules</b> option allows the user to assign category labels from values
 found in a file. The label can refer to a single category, range of
 categories, floating point value, or a range of floating point values.
-The format is given as follows (when separator is set to colon).
+The format is given as follows (when separator is set to colon; no white space
+must be used after the separator):
 <div class="code"><pre>
 cat:Label
 val1:val2:Label
@@ -110,52 +111,54 @@
 Spearfish sample dataset:
-<p><dl>
-<dt><span class="code"><tt>
+<h3>Printing categories</h3>
+<div class="code"><pre>
 r.category map=soils
-</tt></span>
-<dd>
+</pre></div>
 prints the values and labels associated with all of the categories in the
-<em>soils</em> raster map layer;
+<em>soils</em> raster map layer.
+<p>
 r.category map=soils cats=10,12,15-20
-</tt></span>
-<dd>
+</pre></div>
 prints only the category values and labels for <em>soils</em> map layer
-categories <tt>10, 12</tt>, and <tt>15</tt> through <tt>20</tt>; and
+categories <tt>10, 12</tt>, and <tt>15</tt> through <tt>20</tt>.
+<p>
 r.category map=soils cats=10,20 separator=':'
-</tt></span>
-<dd>
+</pre></div>
 prints the values and labels for <em>soils</em> map layer categories
 <tt>10</tt> and <tt>20</tt>, but uses "<tt>:</tt>" (instead of a tab)
 as the character separating the category values from the category
-values in the output.
-</dl>
+values in the output:
-<dl>
-<dt>Example output:
-<dd>
-<p><div class="code"><pre>
+Example output:
 10:Dumps, mine, Cc
 20:Kyle clay, KaA
 </pre></div>
-</dl>
-<dl>
-<dt>Example defining category labels:
-<dd><div class="code"><pre>
+<h3>Adding categories</h3>
+Example for defining new category labels:
 r.category diseasemap separator=: rules=- << EOF
 1:potential absence
 2:potential presence
 EOF
 </pre></div>
-<p>sets the categoy values 1 and 2 to respective text labels.
-</dl>
+This sets the categoy values 1 and 2 to respective text labels.
+Alternatively, the rules can be stored in an ASCII text file and loaded
+via the <em>rules</em> parameter.
 <h2>SEE ALSO</h2>
 UNIX Manual entries for <i>awk</i> and <i>sort</i>
