[GRASS-SVN] r69628 - grass/branches/releasebranch_7_2/lib/vector/Vlib
svn_grass at osgeo.org
Sun Oct 2 09:30:30 PDT 2016
Author: martinl
Date: 2016-10-02 09:30:30 -0700 (Sun, 02 Oct 2016)
New Revision: 69628
grass/branches/releasebranch_7_2/lib/vector/Vlib/open_pg.c
vlib/pg: disable any settings defined for pg driver (can be problem when running local/remote db clusters) (relbr72: merge r69627 from trunk)
Modified: grass/branches/releasebranch_7_2/lib/vector/Vlib/open_pg.c
--- grass/branches/releasebranch_7_2/lib/vector/Vlib/open_pg.c 2016-10-02 16:26:21 UTC (rev 69627)
+++ grass/branches/releasebranch_7_2/lib/vector/Vlib/open_pg.c 2016-10-02 16:30:30 UTC (rev 69628)
@@ -522,9 +522,11 @@
/* try connection settings for given database first, then try
* any settings defined for pg driver */
db_get_login2("pg", dbname, &user, &passwd, &host, &port);
+ /* any settings defined for pg driver disabled - can cause
+ problems when running multiple local/remote db clusters
if (strlen(dbname) > 0 && !user && !passwd)
db_get_login2("pg", NULL, &user, &passwd, &host, &port);
if (user || passwd || host || port) {
char conninfo[DB_SQL_MAX];
